Đile Posted November 11, 2020 Author Report Share Posted November 11, 2020 3 minutes ago, Gile said: Biće i za manje, strpljen spašen. Računaj da ćeš verovatno morati da menjaš elektrolite u napajanju, fabrički su bukvalno najjeftiniji mogući. Ok, hvala, koliko obično košta takav poduhvat, naravno sa elektrolitima normalnog kvaliteta? I kako odmah prepoznati da je zamena neophodna? Quote Link to comment Share on other sites More sharing options...
Gile Posted November 11, 2020 Report Share Posted November 11, 2020 Prepoznaćeš, veruj mi :). Nema simptoma unapred, ali kada crknu, sub vrlo neprijatno zvuči. Servis košta 20 € otprilike. Quote Link to comment Share on other sites More sharing options...
Đile Posted November 11, 2020 Author Report Share Posted November 11, 2020 1 hour ago, Gile said: Prepoznaćeš, veruj mi :). Nema simptoma unapred, ali kada crknu, sub vrlo neprijatno zvuči. Servis košta 20 € otprilike. Hvala, uračunato je onda u total cene, nezgodno je kad nekog svrbe pare... Quote Link to comment Share on other sites More sharing options...
Đile Posted November 18, 2020 Author Report Share Posted November 18, 2020 Ovo mi deluje pristojno, iskreno nemam pojma kakav je generalno Canton. Ispunjava sve što se tiče podešavanja, kontinuirano podešavanje faze, podešavanje skretnice je od 55 do 200 Hz, drajver je 10 inča, prednji bas refleks otvor. High level input i output. Jedino što je pojačalo prilično skromnih 100 W. Ako neko ima mišljenje... Hvala https://www.kupujemprodajem.com/audio/zvucnici-vuferi-kucni/canton-as-105-2sc/oglas/105179591 Quote Link to comment Share on other sites More sharing options...
Nixie Posted November 18, 2020 Report Share Posted November 18, 2020 To ti je u rangu Monitor Audio ASW100 samo dosta jeftinije. Quote Link to comment Share on other sites More sharing options...
Đile Posted November 18, 2020 Author Report Share Posted November 18, 2020 5 minutes ago, Nixie said: To ti je u rangu Monitor Audio ASW100 samo dosta jeftinije. Da slične su karakteristike, kod AW100 je pojačalo 120w, a podešavanje skretnice je od 40 do 180 Hz. E sad, da li to nešto u praksi znači, ne znam... Još jedna od razlika je što je kod Cantona drajver od neke vrste aluminijuma, a kod AW100 je papir u pitanju... Quote Link to comment Share on other sites More sharing options...
Nixie Posted November 18, 2020 Report Share Posted November 18, 2020 52 minuta ranije, Đile said: kod AW100 je pojačalo 120w, Nisam siguran u tačnost tog podatka, otvarao sam ga. Za 150eur praktično i nema ničeg boljeg od tog Canton-a. Quote Link to comment Share on other sites More sharing options...
Đile Posted November 18, 2020 Author Report Share Posted November 18, 2020 40 minutes ago, Nixie said: Nisam siguran u tačnost tog podatka, otvarao sam ga. Za 150eur praktično i nema ničeg boljeg od tog Canton-a. Ja sam podatak našao u skenu uputstva na manualslib-u, pa sam uzeo kao tačno... Cenim i ja laički da je ovaj Canton "the best bang for your buck", na osnovu specifikacija... Nadam se da i zvuči tako. Malo me kopka, da li čekati ASW100 da se pojavi po dobroj ceni... Quote Link to comment Share on other sites More sharing options...
Nixie Posted November 18, 2020 Report Share Posted November 18, 2020 Za 120W prave sinusne snage bi morao imati jači trafo, više izlaznih tranzistora (više od dva plastična) i malo više filterskih kondenzatora. U principu to radi dobro za te pare koja god da je stvarna snaga, obrati pažnju na pozicioniranje tu se najviše greši, moraš imati strpljenja. Kad se pojača zna i da zatrese po nešto u sobi. Ne vidim koje su prednosti ASW100 u odnosu an Canton da bi ga čekao. Možda samo siva metalik boja Canton-a malo odbija ali cena je ok, i godište 2009 valjda. Koji god da kupiš, ima bolje. Quote Link to comment Share on other sites More sharing options...
Đile Posted November 18, 2020 Author Report Share Posted November 18, 2020 40 minutes ago, Nixie said: Ne vidim koje su prednosti ASW100 u odnosu an Canton da bi ga čekao. Možda samo siva metalik boja Canton-a malo odbija ali cena je ok, i godište 2009 valjda. Koji god da kupiš, ima bolje. Istina, malo mi je frka što do sad nikad nisam kupovao na neviđeno, ovaj sub nije u BG-u... Quote Link to comment Share on other sites More sharing options...
Nixie Posted November 18, 2020 Report Share Posted November 18, 2020 Ne znam šta da kažem. Prodavac ima uglavnom dobre ocene i samo jednu negativnu. Ja sam po SUB malo putovao do @nesone, samo zato da to ne bi išlo poštom, greota da se ošteti. Quote Link to comment Share on other sites More sharing options...
Đile Posted November 18, 2020 Author Report Share Posted November 18, 2020 7 minutes ago, Nixie said: Ne znam šta da kažem. Prodavac ima uglavnom dobre ocene i samo jednu negativnu. Ja sam po SUB malo putovao do @nesone, samo zato da to ne bi išlo poštom, greota da se ošteti. Sad pogledah na karti gde je to, i nije toliko daleko kao što zvuči... zvaću sutra, pa ću videti koje su opcije, i kako stoje stvari... PS. Boja jeste gadna, ali kapiram da sub može dobro da se sakrije, a i bitinije je kako zvuči nego kako izgleda... Quote Link to comment Share on other sites More sharing options...
