NAD M33 - fono sekcija
boskos
Pročitah razne testove ali nigde nisam primetio da je neko obratio pažnju na fono sekciju. Ne znam kod koga je završio testirani primerak ali bih bio jako zahvalan kada bi neko uporedio fono sekciju m33 sa bilo kojom drugom, ili prosto napisao svoja zapažanja.
Čekam na par foruma da ga ljudi uporede sa Devialetom. To će da bude baš zanimljivo.
Nisam nikada u sistemima imao D klasu, možda je došlo vreme...
Da, ali mooozda znaju ono sto mi ne znamo. Treba cuti i uporediti. Zato sam i ponenuo ta dva.
ako ne dobijemo odgovor pre nego stigne m33 kod nas, ja se Delija najavljujem kod tebe da testiramo fono sekcije. Ili ti kod mene. Svejedno.
svakako je zanimljivo da poredi fono sekciju sa Chord Huei koji sam kosta 1000+ evra, pri cemu je Darko veliki ljubitelj lp zvuka. I zna kako to treba da zvuci.
One thing that the M33 does do in the analog domain is RIAA equalization for its MM/MC phono stage. According to Greg Stidsen, using DSP to provide the great amount of headroom (40dB) required for this wouldn’t have allowed them to meet their signal/noise target with the digital technology currently available. He added that they were still able to achieve a precision of ±0.2dB by using high-quality resistors and capacitors in the analog circuits. Whatever NAD has done in the analog and digital domains, Dire Straits’ Dire Straits (LP, Vertigo) sounded fantastic. In “Six Blade Knife” there was plenty of separation and imaging of Mark Knopfler’s unique finger-picking style on electric guitar, and of John’s Illsey’s bass guitar. And even though my turntable’s analog signal had been digitized by the M33 and then further DSP applied to that signal, everything in “Sultans of Swing” sounded exactly right. The M33 situated Knopfler’s guitar more centrally and not as far forward as it appears in “Six Blade Knife” and “Down to the Waterline,” slightly differentiating the presentation of the guitar on these three tracks.
from https://www.soundstagehifi.com/index.php/equipment-reviews/1480-nad-masters-m33-integrated-amplifier-dac
  • 4 weeks later...
Samo da se javim, stigao je m33, ali...
izgleda da na mom primerku ne radi desni kanal. :(
levi pucketa konstantno, ne znam o cemu se radi. Prikazuje da je desni kanal -128 stepeni dok se muzika uopste ne cuje na drugom kanalu.
vidim u prospektu da je optimalna temp levog i desnog kanala 45/46.
ima li neko ideju sta da se radi?
Tek mi je sada indekairao hdd, pomislio sam da i to ne radi o.O
striming na aktivne zvucnike radi bez problema i bas je simpa displej.
da li neko zna, moze li m33 da tera dva pasivna i u isto vreme jedan aktivni? Ista muzika na 2+1.
Koristio sam dosta jamahin musiccast i B&O aplikacije. Kada ih uporedim sa Bluos aplikacijom - jamaha najbolja!
Био , слушао и остао равнодушан ...
НАД М33 јако лепо изгледа , дисплеј је одличан и може да се угаси што је јако важно...
Звучници са којима сам га слушао су неки Проац мали подностојећи модел са рибоном и мид-басом , све у свему одличан бас , веома дубок за тако малу кутију и пречник мид бас јединице од свега 6 до 7 инча.
Простор у коме сам слушао је око 4 пута 5 метера , са два огромна бас трапа у ћошковима висине до плафона и 4 апсорбера на зиду између звучника.
Звучнички каблови су били Транспарент аудио , ценим да су добри.
Звук је детаљан , помало напоран  у ЕСС стилу. Бас одличан , детаљан и затегнут.
Све у свему среднји и високи су помало напорни и превише истакнути напред тако да нема говора о неком врхунском доживљају. Укупно гледајући за те паре овде је тешко склопити комплетан систем тако да уређај није промашио тему али свакако није хајенд , него пре само хифи :D
Само да напоменем да је урађај усвиран прописно и да звучници нису кривци за бритак тон , јер смо их касније повезали на Сим Аудио Моон 340и интегралац са ДАЦ-ом и свирали су поптуно другачије , такорећи одлично !
Поздрав из Тексаса!
ѕаборавих да додам , НАИМ Нова нисам слушао јер га немају на лагеру. По речима продавца има мало заокруженији звук од НАД М33 и диста компликованији мени.Такође има дисплеј који је немогуће искључити па се људи жале на то.
Моон Аце је према речима продавца одлична алтернатива НАИМ-у.Сличан звук а јефтинији уређај.
Поздрав из Тексаса!
Ovo je zvuk preko DAC-a?
