DB. Posted June 6, 2020 Report Share Posted June 6, 2020 Jako me zainteresovalo ovo pojacalo. Cena 150e, fabricko stanje. Spolja po koja tackica. Da li je neko imao ili cuo ovo pojacalo kako zvuci? Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted June 6, 2020 Report Share Posted June 6, 2020 Ganjaj 9009, to je zgoditak. Quote Link to comment Share on other sites More sharing options...
DB. Posted June 6, 2020 Author Report Share Posted June 6, 2020 3 minuta ranije, srdjan_c said: Ganjaj 9009, to je zgoditak. Rado, ali ga trenutno nema. Verujem da cu biti zadovoljan i ovim za pocetak. Quote Link to comment Share on other sites More sharing options...
DB. Posted June 7, 2020 Author Report Share Posted June 7, 2020 Da li moze ovo da tera kutije od 4oma? Po natpisu pozadi izgleda da ne, ali citam po stranim forumima da moze i to bez problema bilo kakvih. To vazi i za a903, Philips 960mk2 itd. Quote Link to comment Share on other sites More sharing options...
DB. Posted June 19, 2020 Author Report Share Posted June 19, 2020 Kupih ovo pojacalo. Fabricko stanje, gledao unutra sve na svom mestu. Zvuk je problem. Visoki tonovi fini, srednji tonovi odlicni, bas ga uopste nema. Detaljno sviraju gore nema sta, mnogo toga sam cuo, a pre nisam. Pipnem mu laudnes bas poludi, ali muljavo nesto, meko, javi se dubina, ali udarac fali...Pisalo se po forumu da philips 960mk2 ima izuzetan bas, a ovo su skoro ista pojacala. Sta tu moze da bude problem? Predpostavljam glavni filterski kondezatori... Nadula su se sva 4, ali na 3 samo plastika gore, dok na jednom se oseca da je naduven. Molim za pomoc... Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted June 19, 2020 Report Share Posted June 19, 2020 Full refresh...ali ima da košta.... Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted June 19, 2020 Report Share Posted June 19, 2020 Pre full refresh-a pojačalo treba očistiti, od loudness preklopnika redom, zatim podesiti, pa onda ići dalje u sređivanje. Quote Link to comment Share on other sites More sharing options...
DB. Posted June 19, 2020 Author Report Share Posted June 19, 2020 6 minuta ranije, Willi Studer said: Pre full refresh-a pojačalo treba očistiti, od loudness preklopnika redom, zatim podesiti, pa onda ići dalje u sređivanje. Ocisceno sve, lemovi pregledani sve je to u redu. Mirnu struju sam podesio prema upustvu.Nista se ne greje previse, jedino STK kolo, ali to je valjda normalno. Ugradicu mu neki veci hladnjak. Zamenio sam neke sitne kondezatore oko njega, koje sam imao nove. Cini mi se da nema snage kao na papiru. 120w sinusa, a rms navodno 100w. Daj Boze da ima 70w rms. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted June 19, 2020 Report Share Posted June 19, 2020 55 minuta ranije, Honda94 said: Pipnem mu laudnes bas poludi U redu. Ja sam iz ovoga zakključio da ima preide na konrolama. Ako guraš kutije od 4 oma mimo specifikacije, prirodno je da se STK više greje. Quote Link to comment Share on other sites More sharing options...
DB. Posted June 19, 2020 Author Report Share Posted June 19, 2020 4 minuta ranije, Willi Studer said: Ako guraš kutije od 4 oma mimo specifikacije, prirodno je da se STK više greje. Kutije su 8 oma. Ne smem prst da zadrzim na hladnjak dok ne prodje minut,dva. Nista, da krenem polako da menjam kondezatore. A sto se tice velikih... Da li da uzmem 6800uf ili da idem na 10000uf? Citam poljaci na forumu stavljaju 10000uf i prezadovoljni su rezultatima. Bas postaje gusci, precizniji, sredina ista, visoki jos lepsi. Quote Link to comment Share on other sites More sharing options...
Margioni Posted June 19, 2020 Report Share Posted June 19, 2020 3 hours ago, Honda94 said: Nadula su se sva 4, ali na 3 samo plastika gore, dok na jednom se oseca da je naduven. Molim za pomoc... Čini mi se da sam imao pojačala koja su imala zaobljene plastične poklopce na kondezatorima, a da su sami kondezatori bili potpuno ispravni, jer bi ispod plastike trebalo da postoji i ravan metalni deo. U tom slučaju plastika daje vizuelni utisak nadutosti kondezatora. Quote Link to comment Share on other sites More sharing options...
DB. Posted June 19, 2020 Author Report Share Posted June 19, 2020 1 sat ranije, AlexBgd said: Čini mi se da sam imao pojačala koja su imala zaobljene plastične poklopce na kondezatorima, a da su sami kondezatori bili potpuno ispravni, jer bi ispod plastike trebalo da postoji i ravan metalni deo. U tom slučaju plastika daje vizuelni utisak nadutosti kondezatora. Pa i ovi su ispravni, ali staro je to vec dosta. A pucaju kao petarde kad sam ih praznio kratkim spojem. Kao da su ogromnog kapaciteta i voltaze. Quote Link to comment Share on other sites More sharing options...
Body Posted June 20, 2020 Report Share Posted June 20, 2020 Druze to pojačalo je Marantz filosofija i tu nema popravke uvek će biti bez udarca i sa manjkom basa ili muljavim basom tako da nećeš ništa uraditi sa promenom delova a ima da te košta i onako si preplatio pojačalo staro više od 30 godina Quote Link to comment Share on other sites More sharing options...
DB. Posted June 20, 2020 Author Report Share Posted June 20, 2020 25 minuta ranije, Body said: Druze to pojačalo je Marantz filosofija i tu nema popravke uvek će biti bez udarca i sa manjkom basa ili muljavim basom tako da nećeš ništa uraditi sa promenom delova a ima da te košta i onako si preplatio pojačalo staro više od 30 godina Jedni kazu Marantz ima mastan bas i odlican je. Evo sad cujem ovo od tebe. Imam 3 pojacala, integru 8650, technics su 7700 i ovo. Integra je ostra previse u srednjem opsegu, bas ima udarac, ali preovladaju previse srednji tonovi i deru se. Technics ima dobar bas, jak udarac, srednji losi i fali snage. Grundig srednji odlicni, visoki isto, bas ima dubinu i cuje se trzaj bas gitare. Da kazem da je pun, ali bez udaraca... Bacam pare, ne znam sta da kupim. Na kraju kupicu technics su vx800 ne moze da ne valja. Briga me za ime. A iskreno i ja sam tog misljenja da cim radi i ispravan je, a ovako svira, da tu nema pomoci. Mozda nesto malo se poboljsa ili dobijem placebo efekat. Quote Link to comment Share on other sites More sharing options...
Spachek Posted June 20, 2020 Report Share Posted June 20, 2020 Sve to na gomilu i prodaj, uzmi ovo i ne bacaj pare visehttps://www.kupujemprodajem.com/audio/pojacala/kenwood-ka-7020/oglas/95786056Sent from my SM-A520F using Tapatalk Quote Link to comment Share on other sites More sharing options...
DB. Posted June 20, 2020 Author Report Share Posted June 20, 2020 1 sat ranije, Spachek said: Sve to na gomilu i prodaj, uzmi ovo i ne bacaj pare visehttps://www.kupujemprodajem.com/audio/pojacala/kenwood-ka-7020/oglas/95786056 Sent from my SM-A520F using Tapatalk Ili da menjam zvucnike? Imam Magnate All Ribbon 6p II i All Ribbon 10p II. Da kupim nesto za klasu bolje od 10p II? Quote Link to comment Share on other sites More sharing options...
Body Posted June 20, 2020 Report Share Posted June 20, 2020 26 minutes ago, Honda94 said: Ili da menjam zvucnike? Imam Magnate All Ribbon 6p II i All Ribbon 10p II. Da kupim nesto za klasu bolje od 10p II? E tu sam te čeko da ti kažem pravu stvar, zvuk daje zvučnik prvenstveno i to je to, znači pokušaj da prodaš te kutije i uzmi nešto iz srednje klase Canton, Heko, Elac, Magnat, MB Quart, Qudral, Dali, i da te bog vidi da progledaš što se tiče zvuka. Tako sam ja imao top model Mission 783 kataloška cena 2000 evra 2002 god. brate namenjao sam se pojačala jedno od njih je bio i taj tvoj Onkyo ali ne vredi nema visokih bas mutan jedino sam imao srednje kako tako, ništa nisam uradio ni sa kablovima i na kraju kad sam ih prodao kupim Elac i oduševim se sa zvukom tako da to je to. Quote Link to comment Share on other sites More sharing options...
DB. Posted June 20, 2020 Author Report Share Posted June 20, 2020 1 sat ranije, Body said: E tu sam te čeko da ti kažem pravu stvar, zvuk daje zvučnik prvenstveno i to je to, znači pokušaj da prodaš te kutije i uzmi nešto iz srednje klase Canton, Heko, Elac, Magnat, MB Quart, Qudral, Dali, i da te bog vidi da progledaš što se tiče zvuka. Tako sam ja imao top model Mission 783 kataloška cena 2000 evra 2002 god. brate namenjao sam se pojačala jedno od njih je bio i taj tvoj Onkyo ali ne vredi nema visokih bas mutan jedino sam imao srednje kako tako, ništa nisam uradio ni sa kablovima i na kraju kad sam ih prodao kupim Elac i oduševim se sa zvukom tako da to je to. Znam i sam da su zvucnici bitniji svakako za krajnji zvuk. Planirao sam da zamenim zvucnike, ali ajde prvo da kupim dobro pojacalo. Kablove ne gledam uopste, interkonetk klotz, zvucnicki su strujni 2,5mm italijanska neka firma, dobra izolacija, samo sam ih uvio u buzir. Razmisljam nesto, a to je vrlo moguce, da ovo pojacalo daje odlican signal i mnostvo detalja i informacija, pa ovi zvucnici nemaju taj kvalitet da se snadju kako treba, pa bas mulja. Sto moze da znaci da je pojacalo odlicno, a da zvucnici ne valjaju. Mozda bi trebali neki novije proizvodnje, sa alu membranama ili karbon, brzi, precizniji itd. Quote Link to comment Share on other sites More sharing options...
DB. Posted June 22, 2020 Author Report Share Posted June 22, 2020 Zamenio velike kondezatore. Samwha na 80V. Bas ne mulja vise, vratio se udarac. Moze da se slusa i bez tonskih kontrola, pojavio se odnekud. Dva kondezatora se prazne normalno, mala varnica i to je to, druga 2 pucaju jako cak i vise puta mogu da ih praznim bez punjenja i dalje pucaju, to mi nije jasno. Nego nebitno, vazan je zvuk. Uskoro menjam i sve male, samo da prodje junski rok. Quote Link to comment Share on other sites More sharing options...
Nixie Posted June 22, 2020 Report Share Posted June 22, 2020 Na pravom si putu. Kad sve zameniš biće i zvuk drugačiji, bliže originalnom. Quote Link to comment Share on other sites More sharing options...
DB. Posted June 27, 2020 Author Report Share Posted June 27, 2020 On 22.6.2020. at 23:14, Nixie said: Na pravom si putu. Kad sve zameniš biće i zvuk drugačiji, bliže originalnom. E sad imam mali problem. Slusao sam muziku i odjednom se cuo udar jak na basovima. Ugasim pojacalo, trazim kvar i nadjem ga u predpojacalu. Naduo se jedan kondezator i izgoreo otpornik. Zamenim to sve, zvuk ima, ali nesto suska na oba kanala kad je potenciometar na nuli, kada pojacam se izgubi ili ga ja ne cujem. Zamenio sam sve kondezatore u predpojacalu i opet ista stvar. Ne znam sta li je tu jos moglo da crkne osim konda i otpornika... Quote Link to comment Share on other sites More sharing options...
Nixie Posted June 27, 2020 Report Share Posted June 27, 2020 Šuškanje hoće da se javi kad propadnu elektroliti i lemna mesta. Da li ima još nešto, teško je reći, tipa loš lem ili slično pošto si zamenio elektrolite. Može biti i do prekidača, konektora, potenciometra, dotrajalog spoja izvoda na otpornicima itd. Proveri da nisi neki elektrolit okrenuo naopako, ti će brzo otići u večna lovišta. Ako ništa ne šuška kad otkačiš pretpojačalo, onda postoji još uvek neki problem u pretpojačalu. Ako samo izlazno šuška, menjaj sve elektrolite i prelemi spojeve pod hitno. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted June 27, 2020 Report Share Posted June 27, 2020 On 19.6.2020. at 19:47, srdjan_c said: Full refresh...ali ima da košta.... Kao što rekoh... Quote Link to comment Share on other sites More sharing options...
DB. Posted June 27, 2020 Author Report Share Posted June 27, 2020 47 minuta ranije, Nixie said: Šuškanje hoće da se javi kad propadnu elektroliti i lemna mesta. Da li ima još nešto, teško je reći, tipa loš lem ili slično pošto si zamenio elektrolite. Može biti i do prekidača, konektora, potenciometra, dotrajalog spoja izvoda na otpornicima itd. Proveri da nisi neki elektrolit okrenuo naopako, ti će brzo otići u večna lovišta. Ako ništa ne šuška kad otkačiš pretpojačalo, onda postoji još uvek neki problem u pretpojačalu. Ako samo izlazno šuška, menjaj sve elektrolite i prelemi spojeve pod hitno. Malo me sramota da pricam, nasao sam kuci neki kineski tinol, kupljen bas kod kineza u radnji. On je strokav, pa sam pastom cistio, lemio, ma katastrofa. Pa sam kupio dobar tinol i preko ovog kineskog preletovao ovaj cist. Malo su mesta i propala, imam neku jacu lemilicu, pa sam strugao da dodjem do voda, pa zujalicom proverio provod samih lemova i bilo je u redu. Mozda ovaj prljav tinol utice na suskanje, mada ne bi trebalo. A zamenio sam sve male elektrolite u izlaznom stepenu i pojacalo je pocelo mnogo, ali mnogo dobro da svira... Merio sam im kapacitet i pogubili dosta. Nego, da se bacim opet na letovanje jos jednom ovim cistim tinolom, pa javljam. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted June 27, 2020 Report Share Posted June 27, 2020 Ma samo letuj, i ja ću da letujem, ali u Grčkoj Quote Link to comment Share on other sites More sharing options...
