somilenko Posted February 15, 2022 Report Share Posted February 15, 2022 Kako od jedne kontinualne trake namotane napraviti kondenzator kada ima kontinuitet za DC? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 15, 2022 Report Share Posted February 15, 2022 34 minuta ranije, somilenko said: To je folijska zavojnica a ne kond. И Ја бих рек'о, или је извађен из Ал кутије. Quote Link to comment Share on other sites More sharing options...
Delija Posted February 15, 2022 Report Share Posted February 15, 2022 Potejto, potato... Quote Link to comment Share on other sites More sharing options...
somilenko Posted February 15, 2022 Report Share Posted February 15, 2022 I ja imam istog takvog samo Fiću i bele je boje... Rekao je i @Dražo par strana u nazad da je u pitanju folijska zavojnica koju je motao VS audio, ali se nešto izjalovilo... Quote Link to comment Share on other sites More sharing options...
somilenko Posted February 15, 2022 Report Share Posted February 15, 2022 On 28.1.2022. at 19:43, Dražo said: Konacno doslo na red i unapredjenje skretnice na Margaritama. Postojece spulne (VS motao) ostaju, jedino mozda probam na basu folijsku (diy by VS). A usput cu uraditi i unapredjenje volume pota na preampu, uz podrazumevano VBS monokristalno ozicenje na toj poziciji. Cisto da ne zardjam u ove zimske dane... Našao sam ga, prethodna strana... Quote Link to comment Share on other sites More sharing options...
Nixie Posted February 15, 2022 Report Share Posted February 15, 2022 1 sat ranije, somilenko said: Kako od jedne kontinualne trake namotane napraviti kondenzator kada ima kontinuitet za DC? Pa moraš motati dve trake isto tako. Moraju biti smaknute malo levo-desno, i onda se spoje sve trake sa jedne strane i sve sa druge. Mislim... Quote Link to comment Share on other sites More sharing options...
Father Posted February 15, 2022 Report Share Posted February 15, 2022 2 sati ranije, Nixie said: Pa moraš motati dve trake isto tako. Moraju biti smaknute malo levo-desno, i onda se spoje sve trake sa jedne strane i sve sa druge. Mislim... Baš tako! Quote Link to comment Share on other sites More sharing options...
Father Posted February 15, 2022 Report Share Posted February 15, 2022 Quote Link to comment Share on other sites More sharing options...
Nixie Posted February 15, 2022 Report Share Posted February 15, 2022 E sad neki vrhunski kondenzatori imaju druge šeme, recimo dva kondenzatora u jednom kućištu ali vezana na red. Ne mislim na bipolarne elektolite koji su uvek takvi nego na blok kondenzatore. Wima recimo za isti tip kondenzatora zavisno od radnog napona ima različite unutrašnje konstrukcije. Recimo MKP10 se razlikuju konstruktivno do 250V i preko 250V. Verovatno otuda tvrdnja da uglavnom bolje zvuče ovi sa većim probojnim naponom. Quote Link to comment Share on other sites More sharing options...
Dražo Posted February 15, 2022 Author Report Share Posted February 15, 2022 Mardzike uslisile molbu majstora. Prosvirale... Quote Link to comment Share on other sites More sharing options...
Nixie Posted February 15, 2022 Report Share Posted February 15, 2022 Rekoh ja biće nešto. Quote Link to comment Share on other sites More sharing options...
somilenko Posted February 15, 2022 Report Share Posted February 15, 2022 7 sati ranije, Nixie said: Pa moraš motati dve trake isto tako. Moraju biti smaknute malo levo-desno, i onda se spoje sve trake sa jedne strane i sve sa druge. Mislim... Ihhh, pa tako znam i ja... Quote Link to comment Share on other sites More sharing options...
Nixie Posted February 16, 2022 Report Share Posted February 16, 2022 Saće pravimo uvoštene kondenzatore. Kad može Delund možemo i mi. Quote Link to comment Share on other sites More sharing options...
Dražo Posted March 9, 2022 Author Report Share Posted March 9, 2022 Za sada samo dascurina, a sutra ko zna sta... Quote Link to comment Share on other sites More sharing options...
Vlajo Posted March 9, 2022 Report Share Posted March 9, 2022 Je li to pladanj Quote Link to comment Share on other sites More sharing options...
Dražo Posted March 12, 2022 Author Report Share Posted March 12, 2022 Zahvaljujuci kolegi @Spachek, dodjoh u posed papucice za vakumsko ciscenje vinila. Pa kada je vec tako, odlucih da napravim i ostatak skalamerije, kako bih dobio pravu VVCM (Vacuum Vinyl Cleaning Machine), koje se prodaju za nekoliko stotina evra (tipa Pro-Ject, Okki Nokki, Record Doctor V…). Malo sam promislio kako i sta uraditi, isplanirao, prionuo poslu, i za 2-3 dana dobio masinu, koja, sto se mene tice radi jednako dobro kao fabricka. Treba jos da poradim na samostalnom pogonu (imam iz moje Toyote motor podizaca stakla, imam i neke remene i remenice, medjutim nemam napajanje 12V 20A, koje nije jeftino…). Mada, i da ostane ovako manualno, nista ne smeta. Inace, papucica je uradjena vrhunski. Jaka je i cvrsta, precizne izrade, precnik usisne cevi odgovara cevi usisivaca, deo koji naleze na label zasticen je plisom, kao i usisni prorez… U centralnom delu papucice nalazi se caura, i u njoj osovina koja lepo ulazi u rupu na vinilu (papucica se tako isporucuje). A ko zeli, moze da koristi papucicu i bez osovine (samo caura), sto je opcija koju sam ja izabrao (i prema tome napravio ostatak mehanizma). Koga zanima kupovina papucice (ili bilo koje druge informacije, tehnicke, upotrebne…), moze da se obrati kolegi @Spachek-u. Cena papucice je 3500 din. Sto se tice cele masine, pored ulaganja u papucicu, jedino koje sam jos imao, jeste usisivac za mokro usisavanje. Izabrao sam Villager (Villyvac 10 hu), zbog male velicine, prihvatljive cene, garancije, i pre svega zbog njene upotrebne vrednosti za kucu, automobil… Ostale materijale sam imao po radionici (iverica debljine 5cm, aksijlni i obican lezaj, osovina, guma, akrilna farba, lepak, prihvat za papucicu…). Elem, testirao sam masinu, i sto se mene tice, upotrebno nemam ni jednu jedinu zamerku. To je to. Za prihvatljive novce resio sam dugo sanjano vakumsko ciscenje ploca. Cak sam masini pronasao i odlicno mesto u gajbi, tako da ne moram nista da pripremam i raspremam – jednostavno je uvek spremna za rad. Sto se tice uticaja na zvuk, tek tu nemam zamerke. Ustvari, moze se reci da sam se raspametio ucinkom. Mogu komotno da kazem da je kod mene ovo do sada najveci apgrejd gramofonskog dela sistema, kada pricamo o ulaganjima u pojedinacna unapredjenja vrednosti recimo do 700-800 evra (to je ono sto sam licno isprobao, za skuplja unapredjenja ne mogu da tvrdim). Za test sam izabrao album Kenny Burrell / Guitar Forms, sjano zvucece izdanje (US, stereo, first press iz 1965. godine), koje dobro poznajem. Pri tom je vinyl u gotovo mint stanju. Prvo sam vinyl ocistio dosadasnjim nacinom – AT634a tecnoscu i jastucetom, uz nezno kruzenje po povrsini vinila. Ocistio sam i iglu (glava Benz Micro Ace SL), prvo lagano mehanicki, zatim tecnoscu AT607, i na kraju destilovanom vodom. Pre ciscenja igle sam pustio nekih sat ipo vremena da gramofon radi, da se sve zagreje, kantilever… Da eliminisem te faktore uticaja na zvuk. I potom sam pazljivo poslusao numeru A2 sa Guitar Forms. A zatim prionuo na vakumsko ciscenje. Postavio vinil na masinu. Prvo ga grubo ocistio Analogis valjkom (od eventualne prasine, dlacica). Zatim zastitio label kuhinjskim otpusivacem (za sada ovako, probacu da nadjem isto, samo manjeg precnika, recimo 11cm). Potom sam plocu naprskao rastvorom (100ml 99% izopropil, 400ml demi voda, 3 kapi Triton X100), i rastvor razmazao cetkom uz okretanje tanjira (za sada obicna Analogis cetka, dok mi ne stigne namenska od kozje dlake). Zatim sam spustio papucicu na plocu, upalio usisivac, i uz rucno okretanje tanjira (oblozenog gumom po obodu), a samim tim i ploce, pokupio svu tecnost. Ploca je odmah bila suva, barem na oko, a verovatno i potpuno posle desetak sekundi. Zatim sam ponovo pustio numeru A2, i momentalno cuo napredak. To je jednostavno za klasu bolji zvuk. Sve je jos cistije, bez nekog minimalnog pucketanja (koje se culo pre vakumskog pranja), cuju se tonovi koje nisam do sada cuo, a postojeci su raskosniji, duzi… Rekreacija prostora jos vernija, jos izrazenija slojevitost po dubini… Itd. Jednostavno u svakom smislu bolji zvuk. I tako, resih jos jednu stavku sa mog spiska hifi zelja i obaveza. A kada je sve vec ovako (uspesno) ispalo, evo nudim zainteresovanima usluznu izradu mehanizma, dok je na vama kupovina papucice, hemije, cetke od kozje dlake… A potencijalno i usisivaca za mokro usisavanje, ako vec nemate tako nesto u kuci. Evo i jednog snimka, dok vakumiram vinil. Quote Link to comment Share on other sites More sharing options...
Delija Posted March 12, 2022 Report Share Posted March 12, 2022 Bicikl i dinamo i mali aku, pa biciklas malo ti - malo gosti Quote Link to comment Share on other sites More sharing options...
Dražo Posted March 12, 2022 Author Report Share Posted March 12, 2022 Ajd' onda na rekreaciju, da otvorimo sezonu biciklanja Quote Link to comment Share on other sites More sharing options...
Delija Posted March 12, 2022 Report Share Posted March 12, 2022 Uz odgovarajuce "gorivo" - biciklacemo, nego sta Quote Link to comment Share on other sites More sharing options...
InSides Posted March 12, 2022 Report Share Posted March 12, 2022 Одлично Дражо, да те у здрављу служи. Око четке, не мораш се мучити са четком од козје длаке. Писали смо раније о томе - иди у било који ДМ, узми четку за бријање од природних длака. Код нас је око 5 евра, а траје мени ето више од пар година. А узео сам неколико комада, да се нађе. И још, покушај (ако више ниси) да укључиш и испирање плоче само дестилираном водом, након прања са смесом коју си раније навео. Дуплира време чишћења, али резултати (бар код мене) су вредни труда. Quote Link to comment Share on other sites More sharing options...
Majda Posted March 13, 2022 Report Share Posted March 13, 2022 On 2/15/2022 at 10:11 AM, Nixie said: Malo manje basa. 😂 Ali preciznijeg, smanjio si ukupan Q faktor bas sekcije i povećao damping faktor pojačala na niskim frekvencijama gde je i bitno. Ne. naprotiv vise bas regiona, dublji i po nivou veci. velika razlika je ako zavojnica ima otpor blizu 1om i ako ima otot 0.25oma. posmatra se u odnosu na otpor zvicnika. i pravi DC L_pad slicno kao potenciometar.., Pa korisna energija koja dolazi na zvucnik manja a deo se nepotrebno trosi i pretvara u termicku energiju na otporu zavojnice. Drugo ako komponente nisu "ciste" ako u L komponeneti ima "previse" R ili C komponente. Onda se koriste drugacije formule za filtere i sve ostalo. Zavojnica je L komponenta i ove ostale komponenete moraju biti sto manje. Isto vazi i za druge komponenete ako je C onda mora imati sto manju L i R komponenetu. I za R komponenete isto... Tu jednostavno nema kompromisa i relativizacije. Zato je @Dražo u pravu sto je postavio L sa debelom zicom. Zvucno to ce se reflektovati u cistijem, dubljem i za nijansu jacem bas regionu. A cela slika ce biti manje komprimovana. A ako je taj princip primenio i na ostale zavojnice - jos je i bolje. Zavojnica sa malim R mnogo znaci i za srednje i za visoke. Jednostavno celo kolo skretnice je po komponenetam "cistije" i priblizava se teoretskom koje uziuma apstraktne i ciste vrednosti elemenata... Ostaje problem sa zavojnicama sto postoje optimalne dimenzije i oblik zavojnice. A to je takozvani Brooks coil (google za formule). To znaci da nema univerzalnog kalemskog tela vec se mora optimizovati kalemsko telo u odnosu na broj namotaja, debljinu zice. To je onda jos bolje. Optimizuje broj navojaka i dodatno "prociscava" L komponenetu. Ali to se retko primenjuje uprkos tome sto je naucnik to dokazao pre vise desetina godina (mozda vise od 50... On 2/15/2022 at 1:56 PM, somilenko said: Kako od jedne kontinualne trake namotane napraviti kondenzator kada ima kontinuitet za DC? Ne mora da znaci da je kontinuirana i da je motan kao zavojnica. Ne vidi se donji deo. KOndenzator se najprostije pravi tako sto se izmedju dve foljie, kao izolator, postavi neka papirna ili druga izolatorska folija. Onda se to namota a krajevi foljia izvedu kao konektori kondenzatora. Tada folije nisu spojene i ne postoji medju njima nikakav fizicki kontakat. Ukupna povrsina folija i dielektricna konstanta izolacionog materijala su cicnioci za pocetno odredjivanje kapaciteta takvog kondenzatora. @Dražo ostalo je jos da napravis grafitne otpornike I da (ako postoji) L-Pad zamenis Bridge T padom isto sa Grafitnim otporima i iste vrednosti atenuacije. Quote Link to comment Share on other sites More sharing options...
Dražo Posted March 13, 2022 Author Report Share Posted March 13, 2022 Hvala @InSidesna zeljama! Porucio sam sa Alija cetku od kozje dlake, ali od viska glava ne boli, tako da cu pogledati i u DM-u te preporucene. Znam da je negde pisano o tome, ali sam vec zaboravio gde. A sto se tice ispiranja destilovanom vodom, hvala na savetu, pokusacu, zasto da ne. Verujem da se i to cuje, kao uostalom sto se cuje i svaka druga sitna promena, barem u mom slucaju (sistemu). A vreme za vakumsko ciscenje kolekcije je relativna stvar - svakako ne mogu sve da obavim naprecac, tako da ce u svakom slucaju potrajati dugo. A kada je "dugo", onda nista ne znaci i "dugo na kvadrat". @Delija Za sada imamo sve vrste goriva, i kod nas nema poskupljenja Quote Link to comment Share on other sites More sharing options...
Dražo Posted March 13, 2022 Author Report Share Posted March 13, 2022 @MajdaHvala ti na javljanju. Proslo je skoro mesec dana kako sam u pogon pustio zvucnike sa novim skretnicama, i imam utisak da se zvuk jos uvek menja, narocito u donjem opsegu. Upravo u pravcu kako si napisao, uz dublje bas podrucje, veci volumen, i bolju definiciju, iliti cistiji bas. Upravo ovo poslednje je ono sto se menja, prociscava, sto pripisujem procesu usviravanja zavojnice. Na srednjim i visokim nisam menjao zavojnice (isto ih je VS radio), jer sam ogranicen sa prostorom unutar kutije, bukvalno za cent duza ili sira daska, ne bi mogla da stane. Doduse, jos nekako bi i stala, ali ne bih mogao da je ubacim u zvucnik kroz otvor za bas drajver (jedina mogucnost). Pomislio sam o opciji skretnice van kutije, ali bi to iziskivalo potpuno novo ozicenje, gde bi postojece postalo neupotrebljivo. U pitanju je okruglo 50 metara VBS monokristalne zice razlicitih preseka, sto je samo po sebi prilicno skupo. A skretnica van kutije bi zahtevala mozda i 150 metara, naravno iskljucivo te zice, sto nemam, i sto bi po novim cenama i meni bilo nemoguce kupiti od Andreja. Za grafitne otpornike, Father mi je pricao jos pre nekih godinu dana, da su on i Aca Andonov to probali, i da je apsolutna preporuka. No, i ta akcija je ostavljena za neki drugi put, nisam imao strpljenja vise od 2 dana, da mi prvi sistem ne svira dok sredjujem kutije. Sto se tice predloga za "L-pad u Bridge-pad", kako Insides rece negde, "its new to me". Moracu malo nad literaturu, za pocetak. U vezi pravljenja folijskih kondova, ostavljam Milenku i Nixiju diskusiji oko toga Quote Link to comment Share on other sites More sharing options...
Majda Posted March 13, 2022 Report Share Posted March 13, 2022 32 minutes ago, Dražo said: jer sam ogranicen sa prostorom unutar kutije, bukvalno za cent duza ili sira daska To i jeste osnovni problem kod skretnica koje su unutra. Ali sta da se radi... Mozda je veci problem to st o danas motaju zavojnice nekom zutom zicom, turska najverovatnije, koja je neuporedivo losija od domace koja je imal mnogo bolji bakar i mnogo bolji lak u 2 sloja. Tamno crvene boje je uglavnom i moze jos uvek ponegde da se nadje ali je znacajno skuplja. Vidi se i po savijanju zice ova svetla se lako savije previse lako za bakar cini mi se, i lak se previse lagano skida... Postavljao sam slike grafitnih otpora pa sigurno pre 5-10 godina. Medjutim nije bilo nekog feedbacka... Mislim da imam jos uvek nekih desetak napravljenih standardnih vrednosti koje se koriste u skretnicama. Nije neka rocket sciens da se to napravi, ali malo je nezgodna terminacija grafita, i mora se imati precizniji R metar. I to da se mora "ugoditi" svaki otpor posebno, jednostavno ne vazi ono ista duzina daje isti otpor. razlke su deo milimetra za te manje vrednosti otpora u sretnicama. Pa onda eksperimentisanje sa tvrdocama mina patent olovke, koje se danas teze nalaze kod nas. Ja pronasao neke moje iz osnovne skole ovako izgledaju kutijice https://www.pencils4artists.co.uk/staedtler-mars-carbon-2mm-leads-pack-12-c2x37154914 https://www.faber-castell.com/products/TK9071lead2BØ2mm/127102 Quote Link to comment Share on other sites More sharing options...
ab Posted March 13, 2022 Report Share Posted March 13, 2022 То чика Дуелунд лансирао, а Ви се сада јурите ко је писао пре годину, пет или десет о графитним отпорницима Quote Link to comment Share on other sites More sharing options...
