Delija Posted September 23, 2021 Report Share Posted September 23, 2021 Imam ja IR beskontaktni termometar. Moze da meri i temperaturu objekata do 93 stepena. Izmericemo jednom. Mada mislim da treba da se opustis oko toga. To je vrlo mali potrosac. Quote Link to comment Share on other sites More sharing options...
B.R. Posted September 23, 2021 Report Share Posted September 23, 2021 1 hour ago, Green said: Jednostavnije je instalirati plugin "system information" u samom Volumiu (bez SSH): Hvala za ovo. Bio sam ubedjen da moze samo iiz SSH Quote Link to comment Share on other sites More sharing options...
Majda Posted September 23, 2021 Report Share Posted September 23, 2021 1 hour ago, Green said: Jednostavnije je instalirati plugin "system information" u samom Volumiu (bez SSH): Settings-search plugins-system information-install Kada je plugin instaliran : Settings-plugins - installed plugins-system information(active)-settings-probe the system. Da li je ovih 38deg na CPU bez hladnjaka? Quote Link to comment Share on other sites More sharing options...
Green Posted September 23, 2021 Report Share Posted September 23, 2021 Jeste 38°C nakon 12min rada , sada nakon 2h i 40min je 46°C.Nemam hladnjak na CPU .Ovo koristim za rPi : https://www.aliexpress.com/item/4000001902776.html?spm=a2g0o.detail.1000023.17.3f626ee0bcxgsi Imaš par stranica u nazad u ovoj temi fotografiju moje "skalamerije". Quote Link to comment Share on other sites More sharing options...
Majda Posted September 23, 2021 Report Share Posted September 23, 2021 9 minutes ago, Green said: Jeste 38°C nakon 12min rada , sada nakon 2h i 40min je 46°C.Nemam hladnjak na CPU .Ovo koristim za rPi : https://www.aliexpress.com/item/4000001902776.html?spm=a2g0o.detail.1000023.17.3f626ee0bcxgsi Imaš par stranica u nazad u ovoj temi fotografiju moje "skalamerije". Da bas dobro i kompaktno. Tih 46 je i vise nego dobro. Cini mi se kao vrlo dobro resenja i za odbvodjenje toplote ali kao HF oklapanje pa i u smislu antivibracionih osobina. Quote Link to comment Share on other sites More sharing options...
Green Posted September 23, 2021 Report Share Posted September 23, 2021 Za rPi4 je ključno da se odradi "eprom update" koji značajno rešava problem sa povišenom temp.CPU , a onda ne red dolaze hladnjaci i ostalo.Što se tiče vibracija - fali mi samo još doorstoper iz Lidla da pritisne "Allo malinu" pa da projekat bude kompletan. Quote Link to comment Share on other sites More sharing options...
Majda Posted September 23, 2021 Report Share Posted September 23, 2021 33 minutes ago, Green said: Za rPi4 je ključno da se odradi "eprom update" koji značajno rešava problem sa povišenom temp.CPU , a onda ne red dolaze hladnjaci i ostalo.Što se tiče vibracija - fali mi samo još doorstoper iz Lidla da pritisne "Allo malinu" pa da projekat bude kompletan. Mislim da za tvoj rpi nije potreban lidl ds. To je za uredjaje sa kutijama od tankog lima... Ti nemas kutiju i veoma je to kompaktno. Probaj suprotan pristup - na drvenu plocu tvrdo vesanje, meko drvo. Ili mekano "vesanje" kaucuk (dude za bebe ali od prirodnog kaucuka) na metalnoj debljoj ploci Quote Link to comment Share on other sites More sharing options...
ab Posted September 24, 2021 Report Share Posted September 24, 2021 https://m.kupujemprodajem.com/kompjuteri-desktop/mini-pc/raspberry-pi-4-kuciste-metalno-slim/oglas/97014771#mhs0-1632458856375 Quote Link to comment Share on other sites More sharing options...
sondek Posted September 24, 2021 Report Share Posted September 24, 2021 Ziv nisam ako ne vidim uredjaj na dudama za bebe, pa makar u photoshopu 🤣 ...a mislio sam da sam sve cuo. Sorry Majda, nisam izdrzao. Quote Link to comment Share on other sites More sharing options...
SUROKVL Posted September 24, 2021 Report Share Posted September 24, 2021 Ja bih više voleo sa dudama za odrasle.... Quote Link to comment Share on other sites More sharing options...
sondek Posted September 24, 2021 Report Share Posted September 24, 2021 To samo za perolaku kategoriju strimera, zbog vizuelnog dojma i antirezonantnih vrhova. Quote Link to comment Share on other sites More sharing options...
Dražo Posted September 24, 2021 Author Report Share Posted September 24, 2021 Ajd' da se drzimo moje Maline, i mog kucista, problematike... Ne mogu da pohvatam ni ova pisanja zadnjih 24h, sta je konretan savet meni, sta je ciji problem, o kom uredjaju se govori, ko kome govori, ko samo dangubi... Inace, instalirao sam jutros System Information plugin, pustio high-res (192/24) album sa Qobuza, i evo posle nekih dva ipo sata, temp CPU je 49 stepeni. Sa ovim malim bakarnim RPi4 hladnjacima, doduse sa skinutim gornjim poklopcem sa uredjaja. Posto ce on kod mene raditi i po ceo dan (ili danima), praticu temperaturu u tom rezimu, kao i sa poklopcem. Te na osnovu toga zakljuciti da li cu uopste nesto dodatno raditi po pitanju hladjenja. @GreenAko moze neka instrukcija eprom update. Napominjem da mnogo manje znam o racunarima od onoga kako se cini - sve sto uradim (ne samo na Pi-u, vec i na drugim kucnim racunarima), uglavnom radim tako da nemam pojma sta radim (ali ne marim mnogo, sta softverski lako pokvarim, to softverski moj prijatelj Darko lako popravi ). Quote Link to comment Share on other sites More sharing options...
Green Posted September 24, 2021 Report Share Posted September 24, 2021 Ne diraj ništa ako ti temp.ostaje ispod 50°C . Možda već imaš update-ovanu verziju eproma.Provera verzije i update se rade preko SSH. Ulazak u SSH-Volumio : https://volumio.github.io/docs/User_Manual/SSH.html Ako te baš kopka update eproma evo linka : https://jamesachambers.com/raspberry-pi-4-bootloader-firmware-updating-recovery-guide/ Imaš i na nekoj od prethodnih stranica video koji sam postavio na tu temu. Quote Link to comment Share on other sites More sharing options...
Green Posted September 24, 2021 Report Share Posted September 24, 2021 Još jedna važna napomena : ne može se u Volumio-u preko ssh proveravati verzija eproma i update-ovati.To je moguće jedino kada se ubaci sd kartica i instalira Raspberry Pi OS. Upravo sam probao sa Volumio-om i ne radi. Ako me sećanje dobro služi u piCorePlayeru se može i proveriti i update-ovati eprom preko ssh.Čak se i bez ssh u system information može videti verzija eproma. Quote Link to comment Share on other sites More sharing options...
Dražo Posted September 24, 2021 Author Report Share Posted September 24, 2021 Da, upravo sam probao update. Posle dva puta "sudo apt update" i jednom potvrde "yes", pokrenuo je proces raspakivanja, i kod nekih 70% izbacio "error code 1". Inace, Pi od jutros bez prestanka strimuje high-res fajlove sa Qobuza, i evo gledam 49 stepeni temperaturu. Jos uvek je bez poklopca, sutra cu probatisa njim, sa dodatnim izbusenim rupama. Quote Link to comment Share on other sites More sharing options...
InSides Posted September 24, 2021 Report Share Posted September 24, 2021 Заборавио да раније пишем - можда буде од помоћи. Код мене, стример који сам радио на бази RPi4, користи Ropieee (обични, не XL - зато што је само Roon endpoint). Користи пасивно хлађење, али је плочица скоро потпуно затворена (детаљи овде и овде). Елем, температура је у просеку око 56℃, али никад испод 52℃. Стример је и још смештен унутар затворене полице. Ради без предаха више од десет месеци - тако да не бих превише бринуо о температури (ако се водиш мом искуству). Quote Link to comment Share on other sites More sharing options...
Dražo Posted September 25, 2021 Author Report Share Posted September 25, 2021 @InSides Zahvaljujem na informaciji. Znam da sam citao o ovim tvojim radovima, u naznakama mi je ostalo u secanju finalno kuciste, bakarne ploce, folije, aluminijumska kucista za module... No, kada sam ovo moje cereslo planirao, nisam mogao da se setim gde sam tacno citao, nisam nalazio preko search-a i kljucnih reci... Tada sam nasao ono sto ste Igor i ti radili na Wlith-u, i fotografiju oklapanja phono dela, i to mi je izmedju ostalog dalo ideju o bakarnom oklapanju (doduse uz obradu rucnom brusilicom, bonsekom i turpijama ). Elem, Wraidd je po konceptu skutijavanja slican ovoj mojoj Malini, tako da mi je dragoceno tvoje iskustvo po pitanju temperature, i neprestanog rada. Evo radi od juce ujutro bez prestanka, i temperatura je 48C (bez poklopca). Nisam jos uvek siguran da li moja verzija Volumia ima vec ugradjen Eprom apdejt Bios-a, ali ako nema, i ako se to uradi, bice samo bolje. Plus vise rupa na poklopcima (i vecih), to bi moglo biti sasvim dovoljno okruzenje za normalan i dugotrajan rad Maline, bez dodatnih pasivnih hladnjaka, ventilatora... Testiracu ovih dana. Quote Link to comment Share on other sites More sharing options...
InSides Posted September 25, 2021 Report Share Posted September 25, 2021 За будуће радове, бакарна самолепљива трака (фолија) је сасвим довољна а веома погоднија за коришћење. Продаје се на КПу (тамо сам је и ја узео једном) од неколико продавца (обично се користи код електричних гитара за shielding празнина за пикапе). Quote Link to comment Share on other sites More sharing options...
Dražo Posted September 25, 2021 Author Report Share Posted September 25, 2021 Kod "Maline" sam koristio bakarnu samolepljivu foliju. Ona je nalepljena direktno na drvo, oblozeno celo kuciste izunutra. Pa sam preko folije stavio bakarni lim debljine 0,8mm. I tek onda bakarne i aluminijumske ploce debljine 5mm. Foliju i lim sam uzeo na KP, od prodavca iz Nisa. Quote Link to comment Share on other sites More sharing options...
Zexx Posted September 25, 2021 Report Share Posted September 25, 2021 Na koliku nuklearku, od koliko kilotona je sad otporna malina? Quote Link to comment Share on other sites More sharing options...
Dražo Posted September 25, 2021 Author Report Share Posted September 25, 2021 Otporna, nego sta! Mora tako, kada je vec radjena 60-tih, za nasega Titu... Quote Link to comment Share on other sites More sharing options...
Toza Posted September 25, 2021 Report Share Posted September 25, 2021 Bio danas na kafi kod Draže... Slušali main sistem. Fino. Vrlo fino. Sad postoji još jedan sistem uz čiji zvuk na vrlo pristojnoj glasnoći mogu da dremnem, što će reći, ništa više ne smeta i ne pravi stres. I onda još samo ovo i još samo ono, pa još malo tu i tamo... Uf. Igranci nema kraja... I ja sam mislio da sam završio, pa onda dođe malo ovoga, pa malo onoga... Sve u svemu, vrlo iritantan i zahtjevan audio kontrolor, zadovoljan! Quote Link to comment Share on other sites More sharing options...
Toza Posted September 25, 2021 Report Share Posted September 25, 2021 A i Draža se ćunuo. Mora da se nagutao monokristala. Sad je tolerantniji, po malo i sluša, a i čuje... Bez šale, izgleda da mu prija odmor, pa makar i prinudni. Quote Link to comment Share on other sites More sharing options...
Majda Posted September 27, 2021 Report Share Posted September 27, 2021 On 9/24/2021 at 9:37 AM, sondek said: Ziv nisam ako ne vidim uredjaj na dudama za bebe, pa makar u photoshopu 🤣 ...a mislio sam da sam sve cuo. Sorry Majda, nisam izdrzao. Ma sve je OK zasto? Samo dajem informaciju koja ce mozda biti korisna. Prirodni kaucuk. to su one braonkaste. visestruko su skuplje od onih prozirnih. Koristi se ustvari podloga a ne "duda". Duda se odsece i dobije se jedna ravna podloga oko 5-6mm debline i od nje se mogu naparaviti mozda i vise od 4 za manje ploce. Materijala je trajan i ne menja osobine. Odlican za te mehanicke izolacije koje "plivaju" Quote Link to comment Share on other sites More sharing options...
Majda Posted September 27, 2021 Report Share Posted September 27, 2021 On 9/24/2021 at 9:43 AM, SUROKVL said: Ja bih više voleo sa dudama za odrasle.... ha ha.. Kakvo vreme dolazi mozda ce i biti Quote Link to comment Share on other sites More sharing options...
