Father Posted July 29, 2021 Report Share Posted July 29, 2021 Da svakako može tako, samo zbog prljanja možda treba osmisliti neku zaštitu, eventualno. Milje ubaciš u mašinu ili na ruke ovde teško da može nešto od toga kada se zasivi i potamni od prašine. Quote Link to comment Share on other sites More sharing options...
Dražo Posted July 29, 2021 Author Report Share Posted July 29, 2021 U pravu si, mozda samo navucem siroku pamucnu pertlu preko, koju mogu da promenim kada se isprlja, kao jastucnicu na jastuku Quote Link to comment Share on other sites More sharing options...
Father Posted July 29, 2021 Report Share Posted July 29, 2021 Quote Link to comment Share on other sites More sharing options...
Scorpio(DDMF)! Posted August 1, 2021 Report Share Posted August 1, 2021 Ostatak diskusije je prebacen u temu "Monokristalni bakar". Quote Link to comment Share on other sites More sharing options...
Dražo Posted August 1, 2021 Author Report Share Posted August 1, 2021 Zahvaljujem! Quote Link to comment Share on other sites More sharing options...
Dražo Posted August 4, 2021 Author Report Share Posted August 4, 2021 Dobih danas lajk na Instagram, na prastaru fotku (ispod) i prateci post. Te se slatko nasmejah kada zakljucih gde je zavrsila bambusova daska sa slike (gramofonski armboard) Quote Link to comment Share on other sites More sharing options...
somilenko Posted August 4, 2021 Report Share Posted August 4, 2021 Jesi li probao klot, nemašćeni bambus kako svira ili eventualno sa, ne daj Bože, samo povrćem seckanim na njoj? Quote Link to comment Share on other sites More sharing options...
Dražo Posted August 4, 2021 Author Report Share Posted August 4, 2021 Inace, u nemogucnosti ovih dana za vecom fizickom "hifi&manual" aktivnoscu, pozabavih se malo softverskim delom svog digitalnog dela sistema. * Izvor komp, M2Tech Evo kockice (usb-to-spdif konverter, externi master clock, odvojeno napajanje), DAC Lampizator Amber. Ima skoro godina kako koristim JPlayFemto kao audio softver, za pustanje fajlova sa lokala i striming servisa (Tidal, od skoro i Qobuz), uz UPnP kontrolu (Android, Bubble UPnP). OS je Win10 v.14393.0, max "umrtvljen". Za dodatnu optimizaciju koristio sam free verziju Fidelizera, i dodatno Minority Clean (prestao da koristim, kako su odnedavno stali sa radom). Masina (lap-top) je prakticno audio dedicated, sasvim solidnih karakteristika za namenu, sa linearnim napajanjem (monokristalnim - prezicenje, iec, kablic do lap-topa), vrhunskim (monok.) strujnim kablom... Elem, iz "odredjenih" razloga naslo se vise vremena za softverske igrarije, te sam prvo pregledao sve opcije za podesavanje JPlay-a (do sada je bilo podeseno po default-u, fabricki). Pregledao, malo iscitao, uputio se malo vise u materiju, i probao, sve kombinacije. Mogu samo reci da svako od ovih podesavanja donosi razliku u zvuku, i to prilicno cujnu. Kombinacija postavke Xtream / DAC link 1 Hz / XtreamSize 5000 / Hibernate ON / Clock 15,6 ms (3) je ono sto je meni najvise leglo. Uz zaista ogromnu pozitivnu promenu u zvuku, u odnosu na default podesavanje. Medjutim, funkcionalno koriscenje ovakve postavke nije bilo moguce. Od zakucavanja JPlay/Bubble-a, preko seckanja pesama, sporog ucitavanja, do nemogucnosti pustanja hi-res fajlova (Qobuz), itd. Citajuci malo vise po netu (i JPlay forumu) iskustva korisnika, shvatio sam da prilikom instalacije JPlay-a postoji opcija postavke rada JPlay-a koji je prijemcivija mom Intel procesoru (alternative version Intel core CPU Only). Pronasao sam je, probao, i odusevio se. Bukvalno svi iznad navedeni bagovi su nestali. Doduse, ne potpuno, ali je omogucena gotovo nesmetana reprodukcija, sto je meni sasvim dovoljno (ako bas ponekad moram da restartujem telefon, pa Boze moj...). ____________________________________ U medjuvremenu sam odlucio da probam (kupim) i full verziju Fidelizera (Fidelizer Pro 8.7), pre svega zbog komfora - FPro verzija funkcionise kao start-up, i prakticno je dovoljno pritisnuti dugme za paljenje lap-top-a, i za nekih 30 sekundi sve je spremno za pustanje muzike (sa free verzijom, sve se moralo rucno pokretati, par klikova misem, i pri tom ucitavanje sporije, reklame...). Pored komfora, Fidelizer Pro je doneo i dosta dodatnih opcija za podesavanje rada i optimizacije, gde svaka opcija utice na zvuk. Naravno, sve sam isprobao (uz konsultacije sa Keetakawee, cini mi se glavnim programerom, ili vlasnikom), i na kraju izabrao podesavanje: Purist / Audio Render / High transparency / Long / Variable / Clock 15.6 ms Razlike koje se opcijama u FPro postizu ravne su bukvalno promeni komponente (ili cak i vise njih) - od karaktera i boje zvuka, transparentnosti, dinamike, scene prostora, i ambijentalnosti, energije... Moze se reci da je FidelizerPro (uz JPlayFemto) najbolja kupovina do sada u digitalnom delu sistema, mnogo znacajnija od recimo jednog visestotinaevra placenog kabla... ____________________________________ I za kraj bih istakao jednu opciju, od brojnih koje se nude uz ova dva softvera, kao nesto sto je na mene ostavilo najjaci utisak. To je opcija Hibernate u JPlay podesavanju. Pre ukljucenja ove opcije, iz oba softvera treba izvuci maximum (prema licnim referencama), i onda samo "na tu tortu dodati jagodu" - izabrati ON, i shvatiti koliko je do tog trenutka ustvari sve bilo lose (zvucno). Ovu hibernate opciju i ljudi iz JPlay-a (Marcin) isticu kao sustinsku za zvuk, u sto sam se i licno uverio. Inace, u pitanju je neka vrsta osnovne optimizacije JPlay-a (pre FidelizerPro), i prilicno je zahtevna za pre svega po Windows OS. Kod mene recimo pri reprodukciji hi-res fajlova sa Qobuz-a, nekada se desi da nece da prebaci na sledecu pesmu, vec u nedogled ponavlja poslednjih 5-10 sekundi prethodne pesme. No, s obzirom na zvucni napredak koji donosi, to nije nesto sto bi me sprecilo da koristim ovu opciju (u duhu vecitih kompromisa u hifi). ____________________________________ Eto, verujem da ovo moje pisanije ne moze da skodi. A ako ne skodi, onda mozda i koristi. Quote Link to comment Share on other sites More sharing options...
Dražo Posted August 4, 2021 Author Report Share Posted August 4, 2021 47 minutes ago, somilenko said: Jesi li probao klot, nemašćeni bambus kako svira ili eventualno sa, ne daj Bože, samo povrćem seckanim na njoj? Probao umasceni, odmasceni, vegeterijanski, maditeranski, sve moguce kombinacije... I svaka utice na zvuk, majke mi Quote Link to comment Share on other sites More sharing options...
dj.nik Posted August 4, 2021 Report Share Posted August 4, 2021 2 sati ranije, Dražo said: ... Minority Clean (prestao da koristim, kako su odnedavno stali sa radom). NIje se stalo sa razvojem. Stiglo se do verzije 222 a u zavisnosti od računara (generacije CPU i konfiguracije OS) neki preferiraju verziju 208, neki 217, neki 220 te ovu poslednju, 222. Za neke je 222 i previše 'upeglana' ('too smooth') - po meni uvek dobar znak ali svi sistemi pa i ušesa te navike slušanja su različita. Quote Link to comment Share on other sites More sharing options...
Dražo Posted August 4, 2021 Author Report Share Posted August 4, 2021 Pa sjajno, nisam znao. To se onda mora isprobati. Onaj japanski link gde sam uvek skidao posljednje verzije, nije radio neko vreme (evo vidim sada opet funkcionise). Posle na JPlay forumu procitao da je prestao sa radom, obavestio sve da, prosto receno, nece vise da se cima, i hoce vise muziku da slusa. U svakom slucaju, tnx @dj.nikna infu. Quote Link to comment Share on other sites More sharing options...
somilenko Posted August 4, 2021 Report Share Posted August 4, 2021 2 sati ranije, Dražo said: Probao umasceni, odmasceni, vegeterijanski, maditeranski, sve moguce kombinacije... I svaka utice na zvuk, majke mi Nemoj sa tim vegeterijanskim preterivati, oće da osuši zvučnu sliku... Quote Link to comment Share on other sites More sharing options...
Vlajo Posted August 4, 2021 Report Share Posted August 4, 2021 Preporuke za MinorityClean su 98,186,217 kao neutralni i jako dobro zvučeći, pratim na 2 foruma mišljenja korisnika, lično koristim 186, odličan je Quote Link to comment Share on other sites More sharing options...
Dražo Posted August 4, 2021 Author Report Share Posted August 4, 2021 Ja sam stao na 98, i nisam neko vreme pratio. Kada htedoh malo da pogledam i osvezim verziju, nije sajt radio (ko zna sta je bilo), malo proguglao, i nasao da navodno vise nece da radi... Registrovao to, i jednostavno odustao od koriscenja, a posle nisam proveravao. Ali super, probacu preporucene verzije. Tnx. Quote Link to comment Share on other sites More sharing options...
Dražo Posted August 8, 2021 Author Report Share Posted August 8, 2021 @Majdaprihvatas li jedan mali (ili malo veci) paketic svezih neprskanih jedrih slatkih aronija? Rodile kao nikada, ima za pola foruma Quote Link to comment Share on other sites More sharing options...
Vlajo Posted August 8, 2021 Report Share Posted August 8, 2021 Nisam Majda, ali mogu da se ponudim 😊 Quote Link to comment Share on other sites More sharing options...
Dražo Posted August 8, 2021 Author Report Share Posted August 8, 2021 Moze, posalji mi na PP adresu, pa pakujem ovih dana i saljem Quote Link to comment Share on other sites More sharing options...
Vlajo Posted August 8, 2021 Report Share Posted August 8, 2021 E sad si me našao nespremnog, zezao sam se, ali puno hvala kao da sam uzeo 👍 Ako nekad naidješ prema Zlatiboru javi se, ili da se nadjemo kod Andreja, ima prostora da primi 50 forumaša bez da se guramo 🙂 Quote Link to comment Share on other sites More sharing options...
Dražo Posted August 8, 2021 Author Report Share Posted August 8, 2021 Ja se nisam salio, odluka je na tebi A svakako hvala na pozivu, sigurno se javljam kada me povuce Ruza vetrova ka vama Quote Link to comment Share on other sites More sharing options...
Majda Posted August 8, 2021 Report Share Posted August 8, 2021 2 hours ago, Dražo said: @Majdaprihvatas li jedan mali (ili malo veci) paketic svezih neprskanih jedrih slatkih aronija? Rodile kao nikada, ima za pola foruma Naravno One prosle sto je tvoja Mama spremila su bile odlicne na osnovu velikih osmeha klinaca. Quote Link to comment Share on other sites More sharing options...
Dražo Posted August 8, 2021 Author Report Share Posted August 8, 2021 Preneo sam joj to onomad, mnogo joj je srece to pricinilo... S obzirom na okolnosti, ovogodisnje su mojih ruku delo, stize ti paket uskoro u Trgovacku... Quote Link to comment Share on other sites More sharing options...
Delija Posted August 8, 2021 Report Share Posted August 8, 2021 Pa ti si lud. Jel ti je jasno sta znaci rec "mirovanje"? Quote Link to comment Share on other sites More sharing options...
Dražo Posted August 8, 2021 Author Report Share Posted August 8, 2021 Jasno jasno, u branje ne idem ja, vec Boban, ja ga zovem batlerom Quote Link to comment Share on other sites More sharing options...
somilenko Posted August 8, 2021 Report Share Posted August 8, 2021 Još kada bi naučio Bobana da plete monokristal, možda bi konačno malo i mirovao... Quote Link to comment Share on other sites More sharing options...
Delija Posted August 8, 2021 Report Share Posted August 8, 2021 Za to mu treba BobanA Quote Link to comment Share on other sites More sharing options...
