TekManijak Posted January 24, 2020 Report Share Posted January 24, 2020 Treba mi pomoc u vezi pravljenja kabla din konektor na rca. Imam stari (grundig) Din interkonekt 5pin - 5pin dobijen uz grundig pojacalo i tjuner. Hteo bih od tog kabla da jedan din konektor zamenim sa rca konektorima ali mi nije jasno kako to uraditi. Na din konktoru imam tri zice: srednji pin je (pretpostavljam) masa: 4. pin je crvena zica i 5 pin je zuta zica. Moze li to nekako da se prespoji na rca konektore? Quote Link to comment Share on other sites More sharing options...
zek Posted January 24, 2020 Report Share Posted January 24, 2020 Može, evo šeme Quote Link to comment Share on other sites More sharing options...
mdragoslavm Posted January 24, 2020 Report Share Posted January 24, 2020 Koji pojacavac i koji tjuner? Quote Link to comment Share on other sites More sharing options...
TekManijak Posted January 24, 2020 Author Report Share Posted January 24, 2020 Crvena i zuta zica su mi jasne, ali i ne shvatam sta da radim sa masom. Kako masu da zalemim na oba rca konektora kad imam samo jednu zicu za masu? @mrdragoslavm I pojacalo i tjuner su 7200 s tim sto sam pojacalo poklonio jos pre godinu dana tako da mi tjuner stoji neiskoriscen zbog nemogucnosti da ga spojim na rca ulaze. Quote Link to comment Share on other sites More sharing options...
Mos Posted January 24, 2020 Report Share Posted January 24, 2020 Masa ide sa jednog i drugog cinca na 2 na petopolcu. Quote Link to comment Share on other sites More sharing options...
TekManijak Posted January 25, 2020 Author Report Share Posted January 25, 2020 7 hours ago, Mos said: Masa ide sa jednog i drugog cinca na 2 na petopolcu. Da samo sto meni u tom slucaju fali cetvrta zica. Moram li i novi kabl da stavim umesto starog? Quote Link to comment Share on other sites More sharing options...
simass Posted January 25, 2020 Report Share Posted January 25, 2020 Pozdrav.Ne fali ti četvrta žica...mase levog i desnog kanala od rca konektora uvežeš i zalemiš,time si dobio masu ,levi i desni kanal..dakle tri žice...prosto Quote Link to comment Share on other sites More sharing options...
TekManijak Posted January 25, 2020 Author Report Share Posted January 25, 2020 Po cenu da ispadnem glup, ali ja i dalje ne razumem kako spojiti dve mase sa rca konektora na jednu žicu. Treba li da ubacim komad žice koji će prespojiti masu od jednog do drugog rca? Quote Link to comment Share on other sites More sharing options...
sondek Posted January 25, 2020 Report Share Posted January 25, 2020 Nadjes dva Rca kabla po izboru,po mogucstvu bolja.U svakom od njih inas dve zice.Signal na signal,a mase zajedno na pin za masu na petopolcu.Inace petopolac je namenjen da provodi i OUT signal za tape,tj snimanje.Odatle 5 pinova.Ja se ceo zivot bakcem time uz naim pa se moji drugari nalemiše,fala im.Nadji samo nekog ko ima wbt kalaj ili jos bolje kupi lemilicu,da ne smaras ljude kao ja Taj raspored pinova moze biti razlicit na dinovima,kod naima je ovako kao na slici(tjunerski ulaz je ono sto ti treba).Oni samo kanale obelezavaju sa 1 i 2,ali to je ustvari Left i Right.Proveri samo sa nekim da li je taj raspored i kod tebe. Ps.limitirajuci faktor za petopolce je debljina izolacije tj kabla. Quote Link to comment Share on other sites More sharing options...
TekManijak Posted January 25, 2020 Author Report Share Posted January 25, 2020 Hvala sondek, Izgleda da ću morati tako da uradim. Ideja je bila da iskoristim originalni din interkonekt i da samo na jednom kraju odcvikam din i zalemim cinceve. Quote Link to comment Share on other sites More sharing options...
sondek Posted January 25, 2020 Report Share Posted January 25, 2020 Saljem preporuku za odlicne din to rca kablove koji se prave po zahtevima.Neobicno su jeftine vece duzine,pa je cak zahvalno za diyerisanje.Drugar je kupio sebi 5m i nareckao za sve izvore po metar.Tih preh locking dinova koje koristi naim ima po ebay jeftino kao i rca bananica u razlicitom kvalitetu. Firma flashback cable,progooglaj ih.Jeftini ,a dobri.Bolji od recimo dosta skupih brendiranih. Edit.evo recimo 5m din to rca za 38funti.Moze da se narecka 5 kablova od toga. https://www.flashbacksales.co.uk/acatalog/2-x-phono-rca-plugs-naim-style-5-pin-ring-locking-din-plug-performance-cable-176.html#SID=14 Quote Link to comment Share on other sites More sharing options...
zflazar Posted January 25, 2020 Report Share Posted January 25, 2020 Nije ni ovo skupo za početak: https://www.avmarket.rs/kabl-din5-2xrcam-1-2m-a29w.html Quote Link to comment Share on other sites More sharing options...
TekManijak Posted January 25, 2020 Author Report Share Posted January 25, 2020 Hero sam baš da iskoristim taj stari kabl i konektore iz razloga što smatram da su dosta kvalitetniji od ovih jeftinih koje je preporučio zflazar. Sondek-ov predlog mi je preskup s knickerbocker's da mi treba samo jedan kabl i to za tjuner. Pošto imam i stari phono interkonekt (takodje Grundig) napraviću od njega, samo ću morati da žrtvujem dva kabla da bih napravio jedan. Quote Link to comment Share on other sites More sharing options...
zek Posted January 25, 2020 Report Share Posted January 25, 2020 A možda da nabaviš ovakav adapter ili ako si iz Beograda, može Kanibal da ti napravi kabl kakav želiš, ili kod njih da kupiš odgovarajući kabl i DIN i cinch utikače pa sam napraviš, mada ako je za tjuner i onaj što je zflazar preporučio je dovoljan. Quote Link to comment Share on other sites More sharing options...
sondek Posted January 25, 2020 Report Share Posted January 25, 2020 1 sat ranije, TekManijak said: Sondek-ov predlog mi je preskup Ja sam ti tamo oznacio za 5m kabla,najkraca duzina je 25eura sto je ok cena za dobar interconekt.Ta duzina od 5m je za nekog ko voli da se igra lemilicom pa napravi od toga vise komada i malo pristedi. Quote Link to comment Share on other sites More sharing options...
TekManijak Posted February 1, 2020 Author Report Share Posted February 1, 2020 hehe, napravio sam uzbunu ovde bez veze. Tek kad sam presekao stari din kabl video sam da ipam ima 4 zice (a ne tri kako sam tvrdio). Tako da sada nije nikakav problem da se stave cincevi. Kabl sam osposobio da radi ali je jako lose zalemljeno jer su stari cincevi bili zaliveni plastikom, mez mogucnosti demontaze. Ako neko ima preporuku za jeftine cinceve koji mogu da se kupe u NS-u neka javi. Za sada sam video da ima rean po ceni od 210 i 330 din. Rean vec imam na jednom cordial interkonektu pa bih rado probao sa nekim drugim. Da naglasim da je kabl namenjen za tjuner tako da mi se ne isplati da bacam pare na skuplje varijante. Quote Link to comment Share on other sites More sharing options...
sondek Posted February 1, 2020 Report Share Posted February 1, 2020 Imas u Doza Djerdja psp elektronik.Mozes kupiti Klotz audio kabl za oko 1100-1200 din,mozda plus koji dinar za Din konektor,a drze i neutrik,ili na pocetku Brace Ribnikar sa leve strane imas isto radnju,pa se nesto nadje,konektora ima raznoraznih.Bolje da.kupis ceo kabl nov,matoro je to sto imas..pa nek je i za tjuner Quote Link to comment Share on other sites More sharing options...
TekManijak Posted February 1, 2020 Author Report Share Posted February 1, 2020 Ne uzeh nista danas. psp ne radi subotom. Ja nekako imam poverenja u te stare kablove, mislim da su stavljali cistij bakar nego u danasnje vreme. Za tjuner ce u svakom slucaju biti sasvim korektan. Quote Link to comment Share on other sites More sharing options...
NShappy Posted February 1, 2020 Report Share Posted February 1, 2020 Ako si iz NS, imaš Technotronik u Braće Ribnikara ulici. 50-ak m od bulevara. Oni imaju i gotove DIN to RCA kombinacije, kao i posebne konektore. Quote Link to comment Share on other sites More sharing options...
patason Posted February 1, 2020 Report Share Posted February 1, 2020 On 25.1.2020. at 10:24, sondek said: Saljem preporuku za odlicne din to rca kablove koji se prave po zahtevima.Neobicno su jeftine vece duzine,pa je cak zahvalno za diyerisanje.Drugar je kupio sebi 5m i nareckao za sve izvore po metar.Tih preh locking dinova koje koristi naim ima po ebay jeftino kao i rca bananica u razlicitom kvalitetu. Firma flashback cable,progooglaj ih.Jeftini ,a dobri.Bolji od recimo dosta skupih brendiranih. Edit.evo recimo 5m din to rca za 38funti.Moze da se narecka 5 kablova od toga. https://www.flashbacksales.co.uk/acatalog/2-x-phono-rca-plugs-naim-style-5-pin-ring-locking-din-plug-performance-cable-176.html#SID=14 On 25.1.2020. at 15:10, sondek said: Ja sam ti tamo oznacio za 5m kabla,najkraca duzina je 25eura sto je ok cena za dobar interconekt.Ta duzina od 5m je za nekog ko voli da se igra lemilicom pa napravi od toga vise komada i malo pristedi. lepo te sondek stedi, za tuner od 1000 din kupis ovaj kabal od 5 metara + 4 seta konektora + lemilicu i milina......mozes da kupis jos 4 slicna tunera pa radis A,B,C,D,E test......ako nemas dovoljno ulaza kupis ili napravis jedan dodatni selektor ulaza, mada tu ce ti trebati jos jedan kabal.....ipak ih seci na 80cm da dobijes 6 komada, asve od zice koja kosta euro/metar. vazno da nije skupo to da pise "naim style" vredi tih para. Quote Link to comment Share on other sites More sharing options...
sondek Posted February 1, 2020 Report Share Posted February 1, 2020 Razumeo sam,mozda pogresno,da ima i pojacalo sa dinovima pa da kompletira za sve izvore solidne interkonekte 4-5kom za 70-80eur.Kad sam shvatio da je samo jedna sprava tj tjuner u pitanju preporucio sam mu Klotz za 10evra. Ne vidim nista u tome lose. Btw.tjuner za 1000 din ne mora uopste da bude losa sprava,samo nepopularna kao i din standard. Quote Link to comment Share on other sites More sharing options...
laky Posted February 1, 2020 Report Share Posted February 1, 2020 2 sati ranije, TekManijak said: Ne uzeh nista danas. psp ne radi subotom. Ja nekako imam poverenja u te stare kablove, mislim da su stavljali cistij bakar nego u danasnje vreme. Za tjuner ce u svakom slucaju biti sasvim korektan. Ovo je misljenja i moj drugar koji se godinama bakce /testira pravi kablove Quote Link to comment Share on other sites More sharing options...
TekManijak Posted February 5, 2020 Author Report Share Posted February 5, 2020 Posto vec treba da idem u psp, uzecu odmah i klotz video kabl da napravim spdif koaksijalac za pc. Jel moze ovaj klasicni rca konektor (u psp-u ima neutrik) da korektno odradi posao i kao spdif ili mora neki 75-omski konektor? Quote Link to comment Share on other sites More sharing options...
