Parasound Halo A21
Delija
Perfektno stanje bez ikakvih tragova koriscenja, jos uvek u garantnom roku, kompletno originalno pakovanje.
Sposoban da pogoni i najzahtevnije zvucnike. Trenutno - Dynaudio Contour 60.
Na internetu postoji veliki broj maksimalno pozitivnih review-ova.
Prodaje se zbog prelaska na drugaciji koncept stereo dela sistema - integrisano resenje.
Cena: 2000€
Specifications
Continuous power output:
250 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, both channels driven
400 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, both channels driven
750 watts RMS x 1, 20 Hz - 20 kHz, 8 Ω
Current capacity:
60 amperes peak per channel
Power bandwidth:
5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total harmonic distortion:
< 0.2 % at full power
IM distortion: balanced 16 V rms
< 0.04 %
Slew rate:
> 130 V/µsecond
Dynamic headroom:
> 1.5 dB
Interchannel crosstalk:
> 80 dB at 1 kHz;
> 63 dB at 20 kHz
Input sensitivity:
1 V for 28.28 V, THX Reference Level
Input impedance:
33 k Ω unbalanced; 66 k Ω balanced
S/N ratio:
112 dB, input shorted, IHF A-weighted
Damping factor:
> 1100 at 20 Hz
Voltage:
110V - 120V
Dimensions:
Width: 445 mm
Panel height: 178 mm
Height with feet: 194 mm
Depth: 485 mm
Power Requirement:
Standby: 25 Watts
Full Power into 4 Ω: 1500 Watts
Net Weight:
27.3 kg
Shipping Weight:
33.7 kg
  • 6 months later...
  • 4 weeks later...
