brale Posted December 9, 2019 Report Share Posted December 9, 2019 Moji licni zvucnici, kupljeni od prethodnog vlasnika pre dve godine. Menjam ih jer su drugi dosli da ih zamene. Stanje i tehnicki i vizuelno perfektno, bez ikakve falinke. Prethodni vlasnik ih je osvezio i zamenio foliju kod Soltanusa, sto se vidi na jednoj od slika. Elektrostatici, rade izvrsno, veliki 3d prostor, definicija, biwire . . . . Specifications: Frequency Response: 40–20,000 Hz ±3dB Sensitivity: 89dB/2.83 volts/meter Impedance: 4 Ohms, 1.7 at 20kHz Compatible with 4, 6, or 8 Ohm rated amplifiers. Crossover Frequency: 450 Hz High Frequency Transducer: 42" (106.7cm) CLS™ electrostatic transducer Low Frequency Transducer: 8" (20.3cm) high excursion, high rigidity cone with extended throw driver assembly, non-resonant asymmetrical chamber format; Weight: 25 kg Dimensions: 141cm x 26.7cm x 31.75cm Cena (forumaska): 800E Tel: 061 642 7244 Link sa sajta prozivodjaca: https://www.martinlogan.com/en/product/aeriusi Srecna kupovina! Srdjan Link to comment Share on other sites More sharing options...
brale Posted December 19, 2019 Author Report Share Posted December 19, 2019 Cena ide na 750E, dok je u prodaji pojačalo koje me zanima. Link to comment Share on other sites More sharing options...
brale Posted December 29, 2019 Author Report Share Posted December 29, 2019 Moguca kupovina na rate karticom Bance Intesa. Link to comment Share on other sites More sharing options...
brale Posted January 9, 2020 Author Report Share Posted January 9, 2020 Pojačalo koje sam jurio sam kupio tako da kupovina karticom otpada kao opcija. U obzir dolaze zamene i to samo iz naim programa dodatnog napajanja, najbolje flatcap 2 ili naim kablova Link to comment Share on other sites More sharing options...
brale Posted January 26, 2020 Author Report Share Posted January 26, 2020 i naravno teddy pardo napajanja Link to comment Share on other sites More sharing options...
brale Posted February 25, 2020 Author Report Share Posted February 25, 2020 Up Sent from my SM-G960F using Tapatalk Link to comment Share on other sites More sharing options...
brale Posted March 27, 2020 Author Report Share Posted March 27, 2020 Moze lock, prodato.Sent from my SM-G960F using Tapatalk Link to comment Share on other sites More sharing options...
