Kulin Ban Posted October 22, 2019 Report Share Posted October 22, 2019 nikad mi nije bio najjasniji taj odnos oko otpora zvučnika i pojačala, šta s čime može, da li manji otpor zvučnika na veći od pojačala ili obrnuto elem, da li je problem spojiti zvučnike od 6 Ohma na pojačalo koje ima izlaz 4 Ohma Quote Link to comment Share on other sites More sharing options...
black coffe Posted October 22, 2019 Report Share Posted October 22, 2019 Kratki spoj - kuršlus je 0 ohma pa računaj Quote Link to comment Share on other sites More sharing options...
Kulin Ban Posted October 22, 2019 Author Report Share Posted October 22, 2019 kratki spoj očigledno nije jer evo radi tako, zvučnici 6 Ohma, a pojačalo 4 Ohma ali me interesuje da li će vremenom doći do problema i naročito prilikom snažnijeg pojačavanja Quote Link to comment Share on other sites More sharing options...
black coffe Posted October 22, 2019 Report Share Posted October 22, 2019 Pojednostavljeno - svirat će u bilo kojoj kombinaciji , ali čim više pojačavaš otpor pada prema 0 znači kad dođe do 0 nešto će se zdimit Quote Link to comment Share on other sites More sharing options...
black coffe Posted October 22, 2019 Report Share Posted October 22, 2019 6 minuta ranije, Kulin Ban said: kratki spoj očigledno nije jer evo radi tako, zvučnici 6 Ohma, a pojačalo 4 Ohma ali me interesuje da li će vremenom doći do problema i naročito prilikom snažnijeg pojačavanja Bolje tako nego obratno čim zvučnici imaju veči otpor lakše je pojačalu , al za glasnije ga treba više "šarafit" pa ..... Quote Link to comment Share on other sites More sharing options...
Kulin Ban Posted October 22, 2019 Author Report Share Posted October 22, 2019 27 minutes ago, black coffe said: znači kad dođe do 0 nešto će se zdimit a kad može doći do nule? kad se maximalno pojača ? Quote Link to comment Share on other sites More sharing options...
Father Posted October 22, 2019 Report Share Posted October 22, 2019 Onog momenta kada struja koja se indukuje u motoru magneta i kalema na strani zvučnika preraste ili probije zaštitu pojačala onda crkavaju tranzistori ili već šta crkava, ako tranzistori prežive. Ume i trafo da rikne, meni se baš to desilo sa Yamahom A-520 na samom kraju žurke ranih devedesetih. A kad nema muzike tu je i kraj ili blagi fade žurke. Kada je pojačalo "strujno" slabije od zvučnika onda zvučnici sa moćnim magnetima mogu da spale pojačalo, čak i ako je sve na 8 ohm-a. Kada je pojačalo "strujno" jače od zvučnika, onda je moguće mehanički oštetiti zvučnik, njegov centrator, vešanje, membranu ili sam motor drivera tj. namotaje. Ima i ova opcija, koja mi se dogodila zajedno sa crkavanjem trafoa u Yamahi na istoj žurci. Pretopostavio sam da Imam "adekvatnu" snagu pojačala za tadašnje zvučike koji su bili oko 6 ohm-a i pravljeni su po uzoru na B&W 801. Znači veliki Bradač-ev modifikovani Redford bass 15", Teledyne AR 48B papirni srednjak i visokotonac. U jednom momentu (oko 3:00 AM) su prestali basovi da sviraju i samo se čuo zvuk sa srednjaka i visokotonca. Sutradan sam odneo basove na servis kod Siniše Rankov. Nakon pregleda je ustanovio da se spulna sa namotajima fizički odlepila od membrane usled visoke temperature kalema. Zalepio nazad, ništa nije naplatio i nasmejao se. Veliki pozdrav za mog druga ovom prilikom. Nisam ni sumnjao na pojačalo. Kada sam sve povezao nazad osetio sam da pojačalo sada nema snage kao ranije, da bi nakon 1-2 dana potpuno stalo. Moj drugi drug i blizak prijatelj je utvrdio da je trafo uginuo. Zamnenio ga za 150W jači i nešto veći, koji je uspeo da uglavi na mesto prethodnog i rekao da sada ne brinem. Takođe je naglasio da na Japanska pojačala nikada, ali nikada ne kačim nominalno manju impedansu zvučnika, a apsolutno nikada zajedno dva para zvučnika na A i B zvučničke izlaze. Naravno ja sam sve ovo što ne sme uradio za tu žurku. Osim što su i glavni zvučnici bili oko 6 ohma i u uobičajnom slušanju nema problema, na žurci sam povezao još jedan par, koji su nadam se bili 8 ohm-a koje je drugar doneo. Mlados ludos, ali i škola za navjek! Normalna glasnoća uglavnom neće ništa pokvariti, ali dugotrajna intenzivna glasnoća isposti trafo pa "bljucka flerove struje" ka zvučnicima što ih može uništiti. Ne znam tačno šta se dešava, ali je to nekakv trenutak kada trafo ne stiže da napuni elektrolite, a oni su prazni dok tranzistori traže ampere da održe dinamiku i izbore se sa indukovanom strujom iz zvučnika u isto vreme, pa onda trafo panično - impulsno šalje struju u njih i probija filtraciju ... Ne znam stručno da objasnim, ali nešto po tom scenariju. Quote Link to comment Share on other sites More sharing options...
Kulin Ban Posted October 22, 2019 Author Report Share Posted October 22, 2019 u mom slučaju je pojačalo "jače" od linije Gorenje za koju nigdje ne mogu naći podatak kolika joj snaga ali ima original zvučnike na kojima stoji 60 W muzička snaga 4 oma zvučnike koje sam natakario su LG max. 40 W 6 oma Quote Link to comment Share on other sites More sharing options...
Nixie Posted October 22, 2019 Report Share Posted October 22, 2019 3 sati ranije, Kulin Ban said: nikad mi nije bio najjasniji taj odnos oko otpora zvučnika i pojačala, šta s čime može, da li manji otpor zvučnika na veći od pojačala ili obrnuto elem, da li je problem spojiti zvučnike od 6 Ohma na pojačalo koje ima izlaz 4 Ohma Ako pričamo o tranzitorskim pojačalima, ona imaju izlaznu impedansu višestruko manju od zvučnika, recimo 0,1om. Ono što piše na pojačalu nije izlazna impedansa pojačala nego preporučena minimalna vrednost impedanse priključenih zvučnika. Znači ako piše na pojačalu ili njegovom uputstvu 4oma, mogu se priključiti zvučnici impedanse jednake ili veće od 4 oma. Ako piše 8 oma, onda zvučnici moraju biti 8 ili više oma. To govori o mogućnostima pojačala da zvučnicima isporuči dovoljno struje, a da na precrkne tek tako kad se pojača do maksimuma. Tipičan dinamički zvučnik nominalne impedanse 4 oma ima promenljivu impedansu recimo u opsegu od 2,5 do 16 oma, kako koji naravno. Zvučnik od nominalnih 8oma obično ima impedansu 5-30oma. Naravno postoje uzuzeci gde impedanse zvučnika na nekim nižim delovima opsega padaju ispod 2oma, ti zvučnici su jako teški za pogon ako pojačalo ne može to da prati. U konkretnom slučaju zvučnike nominalne imedanse 6oma možeš priključiti na pojačalo kome je preporučeni minimum 4oma. To ne znači da ništa neće da crkne ako preteruješ. Ako se tiho i umereno sluša, moguće je na pojačalo deklarisano za 8oma priključiti i zvučnike od 4 oma, samo je veći rizik od pregrevanja i oštećenja pojačala ako se preteruje sa jačinom. Quote Link to comment Share on other sites More sharing options...
Kulin Ban Posted October 22, 2019 Author Report Share Posted October 22, 2019 elelm, fora je da bolje da je impedanca zvučnika veća od pojačala konkretno kod mene što je 6 oma zvučnici, a 4 pojačalo nego da je obratno, da je impedanca pojačala veća da je kojim slučajem 6 oma zvučnici, a pojačalo 8 Quote Link to comment Share on other sites More sharing options...
shon3i Posted October 22, 2019 Report Share Posted October 22, 2019 1 sat ranije, Father said: Takođe je naglasio da na Japanska pojačala nikada, ali nikada ne kačim nominalno manju impedansu zvučnika, a apsolutno nikada zajedno dva para zvučnika na A i B zvučničke izlaze. Naravno ja sam sve ovo što ne sme uradio za tu žurku. Osim što su i glavni zvučnici bili oko 6 ohma i u uobičajnom slušanju nema problema, na žurci sam povezao još jedan par, koji su nadam se bili 8 ohm-a koje je drugar doneo Ajde i ja da iskoristim da pitam, da li ovo takodje vazi i za surround receivere ? da li se snaga rasporedjuje da kazem isto pralelno izmedju front i back zvucnika ili je tamo drugaciji sistem ? Nisam mogao u upustvu jednog japanca pionirca da nadjem kakve bi kombinacije mogle da se rade. Quote Link to comment Share on other sites More sharing options...
Father Posted October 22, 2019 Report Share Posted October 22, 2019 11 minuta ranije, shon3i said: Ajde i ja da iskoristim da pitam, da li ovo takodje vazi i za surround receivere ? da li se snaga rasporedjuje da kazem isto pralelno izmedju front i back zvucnika ili je tamo drugaciji sistem ? Nisam mogao u upustvu jednog japanca pionirca da nadjem kakve bi kombinacije mogle da se rade. Ja sam Stereo tip , ali mogu da pogledam ... Milsim da svaki zvučnik ima svoje tranzistore i da ne dolazi do pada omaže kod višekanalnih pojačala. Hoću reći da je to kao da si spojio jedno stereo za fornt + jedno stereo pojačalo za back + jedno mono za centar, a sub obično ide preko RCA u aktivni sub. Samo sve u jednoj kutiji. Quote Link to comment Share on other sites More sharing options...
Nixie Posted October 22, 2019 Report Share Posted October 22, 2019 32 minuta ranije, shon3i said: Ajde i ja da iskoristim da pitam, da li ovo takodje vazi i za surround receivere ? da li se snaga rasporedjuje da kazem isto pralelno izmedju front i back zvucnika ili je tamo drugaciji sistem ? Nisam mogao u upustvu jednog japanca pionirca da nadjem kakve bi kombinacije mogle da se rade. Kod tih risivera svaki kanal ima svoje pojačalo i zvučnike, inače ne bi bio surround. Na svakom od tih kanala reprodukuje se drugi sadržaj. Takođe važi ono što sam već napisao, ne treba kačiti zvučnike manje impedanse od one koju preporučuje proizvođač risivera, ako nema na risiveru ima u uputstvu. Ako se ipak povežu zvučnici niže impedanse nego što je deklarisano na risiveru ili bilo kom pojačalu, sve će raditi pod uslovom da se koristi vrlo umereno. Na nekim uređajima postoji pozadi prekidač za 4 ili 8 oma, pa i na to treba obratiti pažnju kod priključivanja zvučnika da se postavi prema nominalnoj impedansi zvučnika. Quote Link to comment Share on other sites More sharing options...
shon3i Posted October 22, 2019 Report Share Posted October 22, 2019 Hvala vam obojci na odgovorima to me je zanimalo Quote Link to comment Share on other sites More sharing options...
Nixie Posted October 22, 2019 Report Share Posted October 22, 2019 47 minuta ranije, Kulin Ban said: elelm, fora je da bolje da je impedanca zvučnika veća od pojačala konkretno kod mene što je 6 oma zvučnici, a 4 pojačalo nego da je obratno, da je impedanca pojačala veća da je kojim slučajem 6 oma zvučnici, a pojačalo 8 Opet kažem to nije izlazna impedansa pojačala, ona je mnogo puta manja, to je deklaracija proizvođača o minimalnoj nominalnoj impedansi zvučnika koji se smeju priključiti na uređaj, i treba je poštovati. Ako je deklarisano da je minimum 8 oma, u principu ne treba ići niže, ali 6 oma je podnošljivije za pojačalo od 4 oma. Veće izlazne impedanse pojačala reda 1om ili više postoje kod lampaških pojačala koja imaju izlazni trafo. Time je znatno smanjen damping faktor pojačala, tako da se dobija fini i umilni lampaški zvuk. Quote Link to comment Share on other sites More sharing options...
zek Posted October 22, 2019 Report Share Posted October 22, 2019 I još jednom : zvučnici imaju impedansu a pojačala nemaju impedansu već podatak koje zvučnike podržavaju. P.S. Preteče me Nixie dok sam kuckao. Quote Link to comment Share on other sites More sharing options...
Nixie Posted October 22, 2019 Report Share Posted October 22, 2019 5 minuta ranije, zek said: I još jednom : zvučnici imaju impedansu a pojačala nemaju impedansu već podatak koje zvučnike podržavaju. Imaju sva pojačala izlaznu impedansu, samo je kod tranzistorskih jako mala, a kod lampaša puno veća. Tako se računa damping faktor, impedansa zvučnika / impedansa pojačala. Ako je 0,1om pojačalo, onda je damping faktor za 8omski zvučnik 80. Izlazna impedansa pojačala takođe nije konstantna vrednost, već raste na višim a ponekad i na nižim frekvencijama sve zavisno od konstrukcije pojačala. Quote Link to comment Share on other sites More sharing options...
Nixie Posted October 22, 2019 Report Share Posted October 22, 2019 7 minuta ranije, zek said: Preteče me Nixie dok sam kuckao. Brzina x veština Quote Link to comment Share on other sites More sharing options...
zek Posted October 22, 2019 Report Share Posted October 22, 2019 Ma OK, ali ono što piše na pojačalima i na šta narod misli nije to. Opet je bio brži..... Quote Link to comment Share on other sites More sharing options...
Kulin Ban Posted October 22, 2019 Author Report Share Posted October 22, 2019 pa tako ispada da su "kvalitenija" pojačala koja "predlažu" nižu impedancu zvučnika od 4 oma npr. nego ona sa 8 oma ili ne ? Quote Link to comment Share on other sites More sharing options...
Nixie Posted October 22, 2019 Report Share Posted October 22, 2019 6 minuta ranije, Kulin Ban said: pa tako ispada da su "kvalitenija" pojačala koja "predlažu" nižu impedancu zvučnika od 4 oma npr. nego ona sa 8 oma ili ne ? Da, ali nije vezano sa kvalitetom zvuka direktno. Ona jesu kvalitetnije izvedena, manje se štedelo i mogu jače da se opterete, zato što imaju jače napajanje, veće hladnjake i više struje kroz izlazne tranzistore na raspolaganju. To dođe do izražaja naročito leti, kad se skromnije dimenzionisana puno više greju, a to skraćuje vek komponenata, u prvom redu elektrolitskih kondenzatora koji su najosetljiviji. Quote Link to comment Share on other sites More sharing options...
MickoM Posted October 10, 2020 Report Share Posted October 10, 2020 Pozdrav svima, zamolio bih ako neko strucan moze da mi pruzi odgovor obzirom da se slabo razumem u materiju. Naime, nedavno sam kupio kvalitetne Arcus zvucnike od 4 oma na 60w, i nesto kasnije pojacalo Sony F235R. Na pojacalu nazad pise impedansa od 8 do 16 oma na 30w, medjutim u uputstvu na netu sam nasao za ovo pojacalo da pise minimum 4 oma, tako da sam ja kupio ovo pojacalo i povezao na zvucnike. Za sada sve radi odlicno ali me brine da pojacalo mozda trpi opterecenje i da ce pregoreti nesto. Quote Link to comment Share on other sites More sharing options...
