Nixie Posted October 3, 2019 Report Share Posted October 3, 2019 3 minuta ranije, Punisa Racic said: A trimer za podesavanje ne postoji. Ko zna sta li tu jos ne valja. Uglavnom kada treble pojacam do kraja da probam, levi zvucnik susti nekako, drugi sve je odlicno i cisto. Koji si kanal poravljao? Taj što valja ili onaj drugi? Quote Link to comment Share on other sites More sharing options...
mutayu Posted October 3, 2019 Report Share Posted October 3, 2019 Kanal na kome meris 33mV nije u redu. Quote Link to comment Share on other sites More sharing options...
DB. Posted October 3, 2019 Author Report Share Posted October 3, 2019 1 minut ranije, Nixie said: Koji si kanal poravljao? Taj što valja ili onaj drugi? Ovaj gde je mirna struja 27mA. Desna strana pojacala kada se pogleda odozgo. Sad ne znam da li je on levi ili desni izlaz. Meni levi izlaz susti nekako. Quote Link to comment Share on other sites More sharing options...
DB. Posted October 3, 2019 Author Report Share Posted October 3, 2019 4 minuta ranije, mutayu said: Kanal na kome meris 33mV nije u redu. Da to je leva strana kada se.pogleda odozgo. Ali ja nikako ne znam da li sam ja na tom kanalu menjao izlazne ili na ovom drugom. Menjao sam tranzistore gornje, kada se pogleda hladnjak. Ovi dole su ostali fabricki. Quote Link to comment Share on other sites More sharing options...
mutayu Posted October 3, 2019 Report Share Posted October 3, 2019 Slikaj. Ne vredi ovako. Jesu li na drugom kanalu ostali fabricki tranzistori? Quote Link to comment Share on other sites More sharing options...
mutayu Posted October 3, 2019 Report Share Posted October 3, 2019 "Gornji" su levi kanal a "donji" desni. Quote Link to comment Share on other sites More sharing options...
DB. Posted October 3, 2019 Author Report Share Posted October 3, 2019 47 minuta ranije, mutayu said: Slikaj. Ne vredi ovako. Jesu li na drugom kanalu ostali fabricki tranzistori? Da, na drugom su fabricki ostali. Quote Link to comment Share on other sites More sharing options...
DB. Posted October 3, 2019 Author Report Share Posted October 3, 2019 19 minuta ranije, mutayu said: "Gornji" su levi kanal a "donji" desni. Ja sam menjao "gornje", sto znaci da moze da bude do samih izlaznih tranzistora. Meni je jedan poznanik rekao da se menjaju i ostali, jer te nove sto sam stavim, vuku vise struju od ovih fabrickih. U prevodu nisu izjednaceni kanali, a i mirna struja nikako nije dobra. A stvarno mi je stalo do pojacala, kao novo je spolja. Quote Link to comment Share on other sites More sharing options...
mutayu Posted October 3, 2019 Report Share Posted October 3, 2019 Proveri i R219, R221, R223 i Tr605. Posle toga proveri sve "osencene" elemente na semi i premeri napone na naznacenim tackama. Tako ces locirati problem ako ga ima. Smatram da ce na oba kanala trebati postaviti jednake tranzistore kada se rese ostali problemi. Ako se ne snalazis sa ovim sto se trazi od tebe razmisli da pojacalo poveris majstoru. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted October 3, 2019 Report Share Posted October 3, 2019 29 minuta ranije, mutayu said: Ako se ne snalazis sa ovim sto se trazi od tebe razmisli da pojacalo poveris majstoru. То је још напочетку тебао да уради. Quote Link to comment Share on other sites More sharing options...
DB. Posted October 3, 2019 Author Report Share Posted October 3, 2019 1 sat ranije, giZ_Mo said: То је још напочетку тебао да уради. Ja bih, nego si ti mi odmah preporucio s kojim tranzistorima da zamenim fabricke. Odatle je sve pocelo. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted October 3, 2019 Report Share Posted October 3, 2019 1 sat ranije, Punisa Racic said: Ja bih, nego si ti mi odmah preporucio s kojim tranzistorima da zamenim fabricke. Odatle je sve pocelo. 1 sat ranije, Punisa Racic said: Ja bih, nego si ti mi odmah preporucio s kojim tranzistorima da zamenim fabricke. Odatle je sve pocelo. Од овога је све почело. Quote Link to comment Share on other sites More sharing options...
Nixie Posted October 4, 2019 Report Share Posted October 4, 2019 7 sati ranije, giZ_Mo said: Од овога је све почело. Ako je, taman je to pojačalo dobro za vježbicu, sad treba još malo da se ušteluje da valja. Quote Link to comment Share on other sites More sharing options...
Nixie Posted October 4, 2019 Report Share Posted October 4, 2019 11 sati ranije, Punisa Racic said: Ja sam menjao "gornje", sto znaci da moze da bude do samih izlaznih tranzistora. Meni je jedan poznanik rekao da se menjaju i ostali, jer te nove sto sam stavim, vuku vise struju od ovih fabrickih. U prevodu nisu izjednaceni kanali, a i mirna struja nikako nije dobra. A stvarno mi je stalo do pojacala, kao novo je spolja. Oko mirne struje, sve to je do podešavanja, samo što ovde nema trimera za mirnu struju, ali sam siguran da može da se namesti nekako. U principu treba zameniti izlazne i na drugom kanalu, da ne zvuče različito i ništa više. Moram skinuti šemu da pogledam kako to izvesti. Mirna strija 27mA je na donjoj granici, treba je malo podići recimo na 50mA. Mirna struja 100mA je OK mada je za taj par tranzistora dovoljno i 50mA. Ja sam za te iste tranzistore MJ15003/04 podešavao oko 100mA u svom pojačalu, a konstruktor je definisao minimum 50mA da nema prelaznih izobličenja. U onom uputstvu piše da ako je prevelika struja (preko 75mA) treba preseći neki jumper na PCB, možda je to rešenje, moraš probati presecanjem te žice da smanjiš struju na kanalu gde je prevelika, drugi ne diraj. Za podizanje mirne struje na drugom kanalu treba verovatno zameniti neki otpornik na PCB. Inače pojačalo jeste dreš unutra, ali veoma lepo izgleda spolja tako da ga valja osposobiti. Ako je to ovo, imalo je iste probleme kao to tvoje. http://audio-room.net/technics-su-7700-beauty-is-only-skin-deep/ PS Pojačalo je sa simetričnim napajanjem, nema kondenzator na izlazu, pa kada odradi relej zvučnika izmeri DC offset na izlaznim konektorima za zvučnike, mora ga biti i ne treba da prelazi plus minus 100mV. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted October 4, 2019 Report Share Posted October 4, 2019 Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted October 4, 2019 Report Share Posted October 4, 2019 Ево шема да се не патите.. Quote Link to comment Share on other sites More sharing options...
Nixie Posted October 4, 2019 Report Share Posted October 4, 2019 Sad mi je sve jasno. Quote Link to comment Share on other sites More sharing options...
DB. Posted October 4, 2019 Author Report Share Posted October 4, 2019 3 sati ranije, Nixie said: Oko mirne struje, sve to je do podešavanja, samo što ovde nema trimera za mirnu struju, ali sam siguran da može da se namesti nekako. U principu treba zameniti izlazne i na drugom kanalu, da ne zvuče različito i ništa više. Moram skinuti šemu da pogledam kako to izvesti. Mirna strija 27mA je na donjoj granici, treba je malo podići recimo na 50mA. Mirna struja 100mA je OK mada je za taj par tranzistora dovoljno i 50mA. Ja sam za te iste tranzistore MJ15003/04 podešavao oko 100mA u svom pojačalu, a konstruktor je definisao minimum 50mA da nema prelaznih izobličenja. U onom uputstvu piše da ako je prevelika struja (preko 75mA) treba preseći neki jumper na PCB, možda je to rešenje, moraš probati presecanjem te žice da smanjiš struju na kanalu gde je prevelika, drugi ne diraj. Za podizanje mirne struje na drugom kanalu treba verovatno zameniti neki otpornik na PCB. Inače pojačalo jeste dreš unutra, ali veoma lepo izgleda spolja tako da ga valja osposobiti. Ako je to ovo, imalo je iste probleme kao to tvoje. http://audio-room.net/technics-su-7700-beauty-is-only-skin-deep/ PS Pojačalo je sa simetričnim napajanjem, nema kondenzator na izlazu, pa kada odradi relej zvučnika izmeri DC offset na izlaznim konektorima za zvučnike, mora ga biti i ne treba da prelazi plus minus 100mV. Opet ne pali relej. A samo sam ocistio malo kontakte i prelemio na ploci malo bolje, jer prekidao. Naterace me da ga bacim kroz prozor koliko vidim. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted October 4, 2019 Report Share Posted October 4, 2019 Potrebno ti je malo strpljenja i metodičnosti da bi to uradio ljudski. Ako već imaš problematične lemove, onda je svakako korisno da pod dobrim svetlom i sa lupom pregledaš celu ploču i preletuješ svaki lem koji izgleda sumnjivo. Tako ćeš preduprediti i potencijalne buduće probleme. Quote Link to comment Share on other sites More sharing options...
DB. Posted October 4, 2019 Author Report Share Posted October 4, 2019 4 sati ranije, Nixie said: Oko mirne struje, sve to je do podešavanja, samo što ovde nema trimera za mirnu struju, ali sam siguran da može da se namesti nekako. U principu treba zameniti izlazne i na drugom kanalu, da ne zvuče različito i ništa više. Moram skinuti šemu da pogledam kako to izvesti. Mirna strija 27mA je na donjoj granici, treba je malo podići recimo na 50mA. Mirna struja 100mA je OK mada je za taj par tranzistora dovoljno i 50mA. Ja sam za te iste tranzistore MJ15003/04 podešavao oko 100mA u svom pojačalu, a konstruktor je definisao minimum 50mA da nema prelaznih izobličenja. U onom uputstvu piše da ako je prevelika struja (preko 75mA) treba preseći neki jumper na PCB, možda je to rešenje, moraš probati presecanjem te žice da smanjiš struju na kanalu gde je prevelika, drugi ne diraj. Za podizanje mirne struje na drugom kanalu treba verovatno zameniti neki otpornik na PCB. Inače pojačalo jeste dreš unutra, ali veoma lepo izgleda spolja tako da ga valja osposobiti. Ako je to ovo, imalo je iste probleme kao to tvoje. http://audio-room.net/technics-su-7700-beauty-is-only-skin-deep/ PS Pojačalo je sa simetričnim napajanjem, nema kondenzator na izlazu, pa kada odradi relej zvučnika izmeri DC offset na izlaznim konektorima za zvučnike, mora ga biti i ne treba da prelazi plus minus 100mV. Inace dzampere sam presekao jos kad sam ga kupio. Desni je bio presecen, ja sam njega spojio, a levi sam presekao. Tada je mirna struja bila priblizna. 25mV na levom i 33mV na drugom pad napona na emiterima. Quote Link to comment Share on other sites More sharing options...
Nixie Posted October 4, 2019 Report Share Posted October 4, 2019 42 minuta ranije, Punisa Racic said: Inace dzampere sam presekao jos kad sam ga kupio. Desni je bio presecen, ja sam njega spojio, a levi sam presekao. Tada je mirna struja bila priblizna. 25mV na levom i 33mV na drugom pad napona na emiterima. Kad sam video šemu shvatio sam šta meriš, pad napona na emiterskim otpornicima. Jel sad presečen jumper tamo gde je pad napona 33mV? Odnosno u kakvom je stanju jumper na onom drugom gde je 9mV, spojen ili presečen? Quote Link to comment Share on other sites More sharing options...
DB. Posted October 4, 2019 Author Report Share Posted October 4, 2019 35 minuta ranije, Nixie said: Kad sam video šemu shvatio sam šta meriš, pad napona na emiterskim otpornicima. Jel sad presečen jumper tamo gde je pad napona 33mV? Odnosno u kakvom je stanju jumper na onom drugom gde je 9mV, spojen ili presečen? Sada su oba jumpera spojena. Kada sam kupio pojacalo presecen je bio na ovom od 9mV. Ja sam taj spojio, a drugi sam presekao i tada koliko toliko je mirna struja bila priblizna. Quote Link to comment Share on other sites More sharing options...
Nixie Posted October 4, 2019 Report Share Posted October 4, 2019 58 minuta ranije, Punisa Racic said: Sada su oba jumpera spojena. Kada sam kupio pojacalo presecen je bio na ovom od 9mV. Ja sam taj spojio, a drugi sam presekao i tada koliko toliko je mirna struja bila priblizna. Onda ponovo raskači jumper na tom gde meriš 33mV da se smanji mirna struja koliko toliko. Prava stvar bi bila da se neki od tih otpornika za mirnu struju izvade i na njihovo mesto stave trimeri za podešavanje (jedan je 150 oma a ovaj paralelno jumperu je 82 oma, umesto oba staviš trimer 500oma), tako da kad se lepo ugreje možeš namestiti na oba kanala 20-25mV pada napona na emiterskim otpornicima. Ili da skineš onaj od 150 oma i staviš dva pina, pa stavljaš razne otpornike dok ne namestiš približno. Quote Link to comment Share on other sites More sharing options...
DB. Posted October 4, 2019 Author Report Share Posted October 4, 2019 18 minuta ranije, Nixie said: Onda ponovo raskači jumper na tom gde meriš 33mV da se smanji mirna struja koliko toliko. Prava stvar bi bila da se neki od tih otpornika za mirnu struju izvade i na njihovo mesto stave trimeri za podešavanje (jedan je 150 oma a ovaj paralelno jumperu je 82 oma, umesto oba staviš trimer 500oma), tako da kad se lepo ugreje možeš namestiti na oba kanala 20-25mV pada napona na emiterskim otpornicima. Ili da skineš onaj od 150 oma i staviš dva pina, pa stavljaš razne otpornike dok ne namestiš približno. A sta da radim sa relejom? Merio sam napon na spulni nema ga uopste. A treba da bude 24v dc Quote Link to comment Share on other sites More sharing options...
Nixie Posted October 4, 2019 Report Share Posted October 4, 2019 6 minuta ranije, Punisa Racic said: A sta da radim sa relejom? Merio sam napon na spulni nema ga uopste. A treba da bude 24v dc Ako ima veliki DC offset na izlazu onda neće da se upali relej, to je zaštita zvučnika i tajmer zadrške po uključenju. Ti si rekao da je DC offset na uzlazu 0V a to ne može biti nego neka mala vrednost, par desetina mV. Izmeri na spoju između dva emiterska otpornika prema GND koliko je (ispred kontakta releja). Quote Link to comment Share on other sites More sharing options...
