monitor Posted August 29, 2019 Report Share Posted August 29, 2019 Nabavio sam kutije ali mi nedostaju visokotonci i srednjotonci, zna li neko đe bih mogao nabaviti originalne ili odgovarajuće drajvere? Quote Link to comment Share on other sites More sharing options...
mutayu Posted August 29, 2019 Report Share Posted August 29, 2019 Google je tvoj prijatelj! Tweeter: https://www.ebay.com/itm/152676491382?ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F1%2F711-53200-19255-0%2F1%3Ficep_ff3%3D2%26pub%3D5575084939%26toolid%3D10001%26campid%3D5338421113%26customid%3D53f67308-ca48-11e9-931a-346661316533%26icep_item%3D152676491382%26ipn%3Dpsmain%26icep_vectorid%3D229466%26kwid%3D902099%26mtid%3D824%26kw%3Dlg%26srcrot%3D711-53200-19255-0%26rvr_id%3D2091974318185%26rvr_ts%3Ddcef392416c0ad329b155787ffe0c222&ul_noapp=true Midrange: https://www.ebay.com/itm/152673606826?ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F1%2F711-53200-19255-0%2F1%3Ficep_ff3%3D2%26pub%3D5575084939%26toolid%3D10001%26campid%3D5338421113%26customid%3D52f67368-ca48-11e9-8739-333337623231%26icep_item%3D152673606826%26ipn%3Dpsmain%26icep_vectorid%3D229466%26kwid%3D902099%26mtid%3D824%26kw%3Dlg%26srcrot%3D711-53200-19255-0%26rvr_id%3D2091920344992%26rvr_ts%3Ddcef34f916c0a4d129373459ffe11968&ul_noapp=true Quote Link to comment Share on other sites More sharing options...
bkrmar Posted August 29, 2019 Report Share Posted August 29, 2019 Evo ti info za visokotonac. Treba ti 4ohm, 86 dB MW Audio MT-4121: .75″ Soft Cloth Dome Tweeter Great overall sounding tweeter for any home audio application, but main design is for many Acoustic Research speakers. Many have stated that the original tweeters have been the weak part of their speaker and now we have a great upgrade to the old paper dome, phenolic dome and the “newer” AB Tech version of the 1200084-1 tweeter. We believe our MT-4121 tweeter surpasses the overall tonal quality of all these older AR tweeters. Note that the terminals are on the backside of the tweeter, so some rewiring inside the cabinet may be needed for the older front wired versions. Most models use a 4 ohm version tweeter, but some also use an 8 ohm. 8 ohm models: – AR-2ax: For the later version with the .75″ hard paper dome. The earlier version has the 1″ phenolic 4 ohm tweeter. – AR5 – 200011-2 used in AR-12 – LST-2 4 ohm models: – 1200084 is the newer replacement. – 200029-1 used in AR9. – 200011-1 used in AR11, AR11B. (You can add a .1mH coil in parallel if wanted for these crossovers). – 1200029-1 used in AR58s, AR90, AR91, AR92. – AR10pi – The hard phenolic 1″ dome tweeters used in AR2, AR2a, AR2ax (early version), AR3, LST and more. – The hard paper .75″ dome tweeters used in AR3a and more. Specs: Freq Range: 1200-20,000 Hz Fs: 1200 Hz Power Rating: 75 Watts / 150 Watts Max Impedance: 4 or 8 ohms Re: 3.9 or 6.3 ohms Sensitivity: 86 dB Voice Coil Diameter: .75″ (19mm) Magnet Weight: 11 oz (310g) Face Plate: Aluminum Dimensions: Outside: 4.75″ (120mm) Cutout: 3.55″ (90mm) Screw Hole Size: .315″ (8mm) Quote Link to comment Share on other sites More sharing options...
Body Posted August 29, 2019 Report Share Posted August 29, 2019 Nisam pročitao smešniji post odavno nabavios 10 hours ago, monitor said: Nabavio sam kutije ali mi nedostaju visokotonci i srednjotonci, zna li neko đe bih mogao nabaviti originalne ili odgovarajuće drajvere? Nisam odavno pročitao smešniji post. A još smešniji su odgovori pa zar neko veruje da su originalni driveri na prodaju a pogotovu kolko će da te košta krpljenje starudije kad sve sabereš.A kako znaš da je ostatak ispravan u kutijama. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted August 30, 2019 Report Share Posted August 30, 2019 10 sati ranije, Body said: Nisam odavno pročitao smešniji post. Боље да је те паре потрошио у продавници Forma Ideale, ако су већ у питању шифоњери. Quote Link to comment Share on other sites More sharing options...
monitor Posted August 30, 2019 Author Report Share Posted August 30, 2019 Nisam pročitao smešniji post odavno nabavios Nisam odavno pročitao smešniji post. A još smešniji su odgovori pa zar neko veruje da su originalni driveri na prodaju a pogotovu kolko će da te košta krpljenje starudije kad sve sabereš.A kako znaš da je ostatak ispravan u kutijama.Ako ti je ovo najsmješniji post onda ti nijesi dobroga u životu vidio. Nastavi da se smiješ, neka ti barem ovaj post dobro učini.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
monitor Posted September 1, 2019 Author Report Share Posted September 1, 2019 On 29.8.2019. at 12:35, bkrmar said: Evo ti info za visokotonac. Treba ti 4ohm, 86 dB MW Audio MT-4121: .75″ Soft Cloth Dome Tweeter Great overall sounding tweeter for any home audio application, but main design is for many Acoustic Research speakers. Many have stated that the original tweeters have been the weak part of their speaker and now we have a great upgrade to the old paper dome, phenolic dome and the “newer” AB Tech version of the 1200084-1 tweeter. We believe our MT-4121 tweeter surpasses the overall tonal quality of all these older AR tweeters. Note that the terminals are on the backside of the tweeter, so some rewiring inside the cabinet may be needed for the older front wired versions. Most models use a 4 ohm version tweeter, but some also use an 8 ohm. 8 ohm models: – AR-2ax: For the later version with the .75″ hard paper dome. The earlier version has the 1″ phenolic 4 ohm tweeter. – AR5 – 200011-2 used in AR-12 – LST-2 4 ohm models: – 1200084 is the newer replacement. – 200029-1 used in AR9. – 200011-1 used in AR11, AR11B. (You can add a .1mH coil in parallel if wanted for these crossovers). – 1200029-1 used in AR58s, AR90, AR91, AR92. – AR10pi – The hard phenolic 1″ dome tweeters used in AR2, AR2a, AR2ax (early version), AR3, LST and more. – The hard paper .75″ dome tweeters used in AR3a and more. Specs: Freq Range: 1200-20,000 Hz Fs: 1200 Hz Power Rating: 75 Watts / 150 Watts Max Impedance: 4 or 8 ohms Re: 3.9 or 6.3 ohms Sensitivity: 86 dB Voice Coil Diameter: .75″ (19mm) Magnet Weight: 11 oz (310g) Face Plate: Aluminum Dimensions: Outside: 4.75″ (120mm) Cutout: 3.55″ (90mm) Screw Hole Size: .315″ (8mm) Hvala! Vidio sam da ih na ebay ima ali sve iz USA, transport bi me koštao više od djelova. Tip iz BG ima potpuno nove srednjotonce, možda naletim i na visokotonce. Quote Link to comment Share on other sites More sharing options...
monitor Posted September 1, 2019 Author Report Share Posted September 1, 2019 On 29.8.2019. at 12:35, mutayu said: Google je tvoj prijatelj! Tweeter: https://www.ebay.com/itm/152676491382?ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F1%2F711-53200-19255-0%2F1%3Ficep_ff3%3D2%26pub%3D5575084939%26toolid%3D10001%26campid%3D5338421113%26customid%3D53f67308-ca48-11e9-931a-346661316533%26icep_item%3D152676491382%26ipn%3Dpsmain%26icep_vectorid%3D229466%26kwid%3D902099%26mtid%3D824%26kw%3Dlg%26srcrot%3D711-53200-19255-0%26rvr_id%3D2091974318185%26rvr_ts%3Ddcef392416c0ad329b155787ffe0c222&ul_noapp=true Midrange: https://www.ebay.com/itm/152673606826?ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F1%2F711-53200-19255-0%2F1%3Ficep_ff3%3D2%26pub%3D5575084939%26toolid%3D10001%26campid%3D5338421113%26customid%3D52f67368-ca48-11e9-8739-333337623231%26icep_item%3D152673606826%26ipn%3Dpsmain%26icep_vectorid%3D229466%26kwid%3D902099%26mtid%3D824%26kw%3Dlg%26srcrot%3D711-53200-19255-0%26rvr_id%3D2091920344992%26rvr_ts%3Ddcef34f916c0a4d129373459ffe11968&ul_noapp=true "Does not ship to Montenegro" ali u svakom slučaju hvala! Quote Link to comment Share on other sites More sharing options...
vdzele Posted September 1, 2019 Report Share Posted September 1, 2019 Ako pogledaš snimke emisije "Ne može to bez kabla", gde su gosti bili Siniša Rankov i Nenad Napijalo, obojica su dali negativne ocene za te kutije. To su dva majstora za zvučnike kod kojih su često bile ovakve kutije. Imaš njihove sajtove na internetu. Ako ih i kompletiraš, treba će ti izuzetno potentno pojačalo da gura bas. Kolega je uspeo da ih pogura sa Karan mono blokovima. To ti je reper kakvo pojačalo ti treba. E sad koliko takvo pojačalo košta naspram kutija od 400-500 eura.... Pogrešna investicija kako rekoše kolege gore. Quote Link to comment Share on other sites More sharing options...
monitor Posted September 1, 2019 Author Report Share Posted September 1, 2019 Ako pogledaš snimke emisije "Ne može to bez kabla", gde su gosti bili Siniša Rankov i Nenad Napijalo, obojica su dali negativne ocene za te kutije. To su dva majstora za zvučnike kod kojih su često bile ovakve kutije. Imaš njihove sajtove na internetu. Ako ih i kompletiraš, treba će ti izuzetno potentno pojačalo da gura bas. Kolega je uspeo da ih pogura sa Karan mono blokovima. To ti je reper kakvo pojačalo ti treba. E sad koliko takvo pojačalo košta naspram kutija od 400-500 eura.... Pogrešna investicija kako rekoše kolege gore.Nikad nijesam čuo ni jedne AR iz grupe 9 a čitao sve najbolje o njima.Pogledaću svakako tu emisiju.Hvala na info!Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
vdzele Posted September 1, 2019 Report Share Posted September 1, 2019 Imaj zavodljiv gornji spektar, kad se stavi jako pojačalo. Bez takvog se dernjaju, uglavnom je tako, jer se teško nalazi sposobno da ih pogura. Ali bez obzira i da se nadje, bas je veoma lenj. Nazovi ih sutra direktno i pitaj. Quote Link to comment Share on other sites More sharing options...
monitor Posted September 2, 2019 Author Report Share Posted September 2, 2019 On 1.9.2019. at 18:16, vdzele said: Imaj zavodljiv gornji spektar, kad se stavi jako pojačalo. Bez takvog se dernjaju, uglavnom je tako, jer se teško nalazi sposobno da ih pogura. Ali bez obzira i da se nadje, bas je veoma lenj. Nazovi ih sutra direktno i pitaj. Kod nas nijesu bile rasprostranjene ali ameri su kunu u tu seriju. S obzirom da su mi "lagano" pale mislio sam i da uradim nešto sa njima. Komplikovano jeste ali bih barem pokušao da ih osposobim, najlakše ih se otarasiti. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 2, 2019 Report Share Posted September 2, 2019 Овај продавац нема ограничења што се тиче слања али приказана је комадна цена $69.95 + $54.55 шипинг. https://www.ebay.com/itm/AR-Acoustic-Research-Replacement-Tweeter-for-AR90-AR91-AR92-Speaker-MT-4121-4/152720219407?hash=item238ed59d0f:g:k~kAAOSwc8lZzEo4 Quote Link to comment Share on other sites More sharing options...
monitor Posted September 2, 2019 Author Report Share Posted September 2, 2019 Овај продавац нема ограничења што се тиче слања али приказана је комадна цена $69.95 + $54.55 шипинг.https://www.ebay.com/itm/AR-Acoustic-Research-Replacement-Tweeter-for-AR90-AR91-AR92-Speaker-MT-4121-4/152720219407?hash=item238ed59d0f:g:k~kAAOSwc8lZzEo4To je upravo to što sam naveo u ranijem postu, transport uzima dosta novca. Ne žuri mi se, ako ne “naletim” na komponente kod nas barem imam alternativu.Hvala giZ_Mo!Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
bkrmar Posted September 6, 2019 Report Share Posted September 6, 2019 On 2.9.2019. at 21:34, monitor said: To je upravo to što sam naveo u ranijem postu, transport uzima dosta novca. Ne žuri mi se, ako ne “naletim” na komponente kod nas barem imam alternativu. Hvala giZ_Mo! Sent from my iPhone using Tapatalk Pazi, tesko da ces kod nas da naletis na takve. Možeš da nađeš slične ali onda to više nije to, džaba si krečio. Kad si se već odlučio za taj "projekat" onda bolje uštedi i kupi oridjidji drajvere, pa bili oni i iz uvoza. Ja sam imao sličnu situaciju sa nekim Bower što sam uzeo, falio mi tviter, našao sam kao neke Monacor okoji su dobri viskotonci ali nije ista bila osetljivost i to se jasno čuje. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 6, 2019 Report Share Posted September 6, 2019 On 2.9.2019. at 21:34, monitor said: Ne žuri mi se, ako ne “naletim” na komponente kod nas barem imam alternativu. А зашто се не направиш паметан па пошаљеш мејл фабрици са упитом о набавци звучника? Ништа не губиш, можда они имају неку идеју. Quote Link to comment Share on other sites More sharing options...
monitor Posted September 6, 2019 Author Report Share Posted September 6, 2019 Komponente, zapravo, je lakše pronaći nego što sam mislio. Problem jedino leži u tome što bi me sve četiri nove koštale, ne manje, od 400€ (računajući transport). S obzirom da kutije nikada nijesam čuo a pročitao mnogo dobrih komentara za njih (osim kod nas) imao sam namjeru da ih osposobim i probam. Veliko je pitanje koliko će se uopšte isplatiti a možda se i prijatno iznenadim. U svakom slučaju, nijesu moje jedine kutije i ne zavisim od njih (dobra očuvanost me "gurnula" u ovu avanturu), zbog čega imam vremena. Koristila bi mi mišljenja forumaša o kvalitetu te serije jer to može uticati na konačnu odluku, da li će nabavka biti isključivo originalnih drajvera ili sastavljanje te kasnija prodaja. Hvala svima na komentarima! Quote Link to comment Share on other sites More sharing options...
Body Posted September 6, 2019 Report Share Posted September 6, 2019 11 hours ago, monitor said: dobra očuvanost Ha Ha Ha slatko me nasmeja čemu onda nabavka novih drivera ako su dobro očuvani Quote Link to comment Share on other sites More sharing options...
monitor Posted September 6, 2019 Author Report Share Posted September 6, 2019 Ha Ha Ha slatko me nasmeja čemu onda nabavka novih drivera ako su dobro očuvaniMali, neinteresantan si, ne petljaj se dje ti nije mjesto nego odgledaj crtani i u krevet kad već nemaš prijatelja i drugova.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ružić Slavoljub Posted September 6, 2019 Report Share Posted September 6, 2019 1 sat ranije, Body said: Ha Ha Ha slatko me nasmeja čemu onda nabavka novih drivera ako su dobro očuvani Pa,neko ih je silovao i spržio - pretpostavljam ali kabineti izgledaju fino. Quote Link to comment Share on other sites More sharing options...
monitor Posted September 6, 2019 Author Report Share Posted September 6, 2019 Pa,neko ih je silovao i spržio - pretpostavljam ali kabineti izgledaju fino.Moguće, ja sam ih dobio bez tih djelova koje pokušavam da nabavim.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
black coffe Posted September 7, 2019 Report Share Posted September 7, 2019 22 sati ranije, monitor said: Komponente, zapravo, je lakše pronaći nego što sam mislio. Problem jedino leži u tome što bi me sve četiri nove koštale, ne manje, od 400€ (računajući transport). S obzirom da kutije nikada nijesam čuo a pročitao mnogo dobrih komentara za njih (osim kod nas) imao sam namjeru da ih osposobim i probam. Veliko je pitanje koliko će se uopšte isplatiti a možda se i prijatno iznenadim. U svakom slučaju, nijesu moje jedine kutije i ne zavisim od njih (dobra očuvanost me "gurnula" u ovu avanturu), zbog čega imam vremena. Koristila bi mi mišljenja forumaša o kvalitetu te serije jer to može uticati na konačnu odluku, da li će nabavka biti isključivo originalnih drajvera ili sastavljanje te kasnija prodaja. Hvala svima na komentarima! Kupi originalne i ako ti se svide ostavi sebi , ako ne lako ćeš ih kao originalne prodati dok kao "karabuđene" puno teže . + trošak tzv zamjenskih. Ljudi vole kupiti "oriđiđi" stvari pa si sami kemijati ako žele. Quote Link to comment Share on other sites More sharing options...
monitor Posted September 7, 2019 Author Report Share Posted September 7, 2019 Kupi originalne i ako ti se svide ostavi sebi , ako ne lako ćeš ih kao originalne prodati dok kao "karabuđene" puno teže . + trošak tzv zamjenskih. Ljudi vole kupiti "oriđiđi" stvari pa si sami kemijati ako žele.Tako sam i ja razmišljao, teško da mogu izvući sav uloženi novac ali svakako ću bolje proći nego sa krpljenjem.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
black coffe Posted September 7, 2019 Report Share Posted September 7, 2019 4 minuta ranije, monitor said: Tako sam i ja razmišljao, teško da mogu izvući sav uloženi novac ali svakako ću bolje proći nego sa krpljenjem. Sent from my iPhone using Tapatalk Ako ti se svide na dobitku si ? , ako ne znaš i sam da se u ovom hobyu teško vrača uloženo no kolko vidim sačuvani primjerci dobro drže cijenu Quote Link to comment Share on other sites More sharing options...
monitor Posted September 7, 2019 Author Report Share Posted September 7, 2019 Ako ti se svide na dobitku si ? , ako ne znaš i sam da se u ovom hobyu teško vrača uloženo no kolko vidim sačuvani primjerci dobro drže cijenu Čitaš mi misli black coffe Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
