Oknarb Posted July 17, 2019 Report Share Posted July 17, 2019 Pozdrav, da li vam je poznat majstor za gramofon na potezu SU - NS? Quote Link to comment Share on other sites More sharing options...
Oknarb Posted July 17, 2019 Author Report Share Posted July 17, 2019 Pored ovih gramofona slušam CD! Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 17, 2019 Report Share Posted July 17, 2019 3 sati ranije, Oknarb said: Pozdrav, da li vam je poznat majstor za gramofon na potezu SU - NS? Мени не али за БГ да. Quote Link to comment Share on other sites More sharing options...
Oknarb Posted July 18, 2019 Author Report Share Posted July 18, 2019 Neću skorije prema BG, a problem se juče javio. Hteo da ga rešim narednih dana. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 18, 2019 Report Share Posted July 18, 2019 10 sati ranije, Oknarb said: a problem se juče javio. А то је? 10 sati ranije, Oknarb said: Neću skorije prema BG Ма слободно, отиш'о француз. Quote Link to comment Share on other sites More sharing options...
VU metar Posted July 18, 2019 Report Share Posted July 18, 2019 22 sati ranije, Oknarb said: Pored ovih gramofona slušam CD! Nijedan ne radi? Koji ti je najbolji inače? Quote Link to comment Share on other sites More sharing options...
Oknarb Posted July 18, 2019 Author Report Share Posted July 18, 2019 Technics i Lenco su ispravni nego imaju mm glave a PP je samo za mc. Rega je u pitanju, jednostavno je prestala da svira. Prvo prestao jedan kanal a kasnije su oba kaput. Quote Link to comment Share on other sites More sharing options...
VU metar Posted July 18, 2019 Report Share Posted July 18, 2019 Možda su žičice na glavi. Razmrdaj ih, pritisni kontakte malim fazomerom, recimo. Inače koji ti svira najlepše? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 18, 2019 Report Share Posted July 18, 2019 26 minuta ranije, Oknarb said: Rega je u pitanju, jednostavno je prestala da svira. Prvo prestao jedan kanal a kasnije su oba kaput. Скини ручку и пошаљи ми је и не секирај се. Quote Link to comment Share on other sites More sharing options...
Ružić Slavoljub Posted October 24, 2019 Report Share Posted October 24, 2019 Da ne otvaram posebnu temu,pitaću u ovoj. Imam Lenco L 75. Od skoro je počeo da zeza kada pustim prvu ploču.Teško mu je da zavrti tanjir pa mu ja malo pomognem i pokrenem ga rukom. Posle toga radi normalno i savršeno drži brzinu. Takođe,kod slušanja druge,treće ploče, nema problem da normalno zavrti tanjir. Šta je problem ? Kako da ga rešim ? Quote Link to comment Share on other sites More sharing options...
Aurelijano Buendija Posted October 24, 2019 Report Share Posted October 24, 2019 za početak skini tanjir i pogledaj u kakvom je stanju idler, očisti, podmaži ležaj Quote Link to comment Share on other sites More sharing options...
Ružić Slavoljub Posted October 24, 2019 Report Share Posted October 24, 2019 Idler mi deluje ok. I gumeni točak a i osovina koja ga pogoni. Nigde lufta ,ništa ne pravi neki otpor.Sve se lako pokreće. Podmazaću "spoljni" ležaj a dali da prsnem malo ulja ( onako,na slepo ) i u stator ? Trebalo bi da i tamo ima ležaj. Quote Link to comment Share on other sites More sharing options...
aaa zmaju! Posted October 24, 2019 Report Share Posted October 24, 2019 Mora mas https://www.lencoheaven.net/forum/index.php?topic=2087.0 Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted October 24, 2019 Report Share Posted October 24, 2019 48 minuta ranije, Ružić Slavoljub said: Podmazaću "spoljni" ležaj a dali da prsnem malo ulja ( onako,na slepo ) i u stator ? Neee! Ne ide isto ulje u ležaj tanjira i u motor. Ništa ne prskaj na slepo, samo ćeš bespotrebno umastiti delove. I obavezno ispiranje benzinom pre novog ulja. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted October 24, 2019 Report Share Posted October 24, 2019 51 minuta ranije, Ružić Slavoljub said: Idler mi deluje ok. I gumeni točak То је једна те иста ствар. ------------------------------------------------------ Провери стање гуме на повшини која належе на осовину мотора. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted October 24, 2019 Report Share Posted October 24, 2019 Jesmo li sigurni da u bronzani ležaj ide mas a ne ulje? Sećam se da je u biksne stojadina išla mast ali mislim da je ovo drugačiji slučaj. Quote Link to comment Share on other sites More sharing options...
Ružić Slavoljub Posted October 24, 2019 Report Share Posted October 24, 2019 7 sati ranije, Willi Studer said: Neee! Ne ide isto ulje u ležaj tanjira i u motor. Ništa ne prskaj na slepo, samo ćeš bespotrebno umastiti delove. I obavezno ispiranje benzinom pre novog ulja. Zato i pitam. Nisam prskao ništa u motor. Quote Link to comment Share on other sites More sharing options...
Ružić Slavoljub Posted October 24, 2019 Report Share Posted October 24, 2019 7 sati ranije, giZ_Mo said: То је једна те иста ствар. ------------------------------------------------------ Провери стање гуме на повшини која належе на осовину мотора. Deluje mi ok ali ja baš i nisam mnogo stručan. Ovo mi je prvi Idler. Quote Link to comment Share on other sites More sharing options...
Ružić Slavoljub Posted October 24, 2019 Report Share Posted October 24, 2019 6 sati ranije, Willi Studer said: Jesmo li sigurni da u bronzani ležaj ide mas a ne ulje? Sećam se da je u biksne stojadina išla mast ali mislim da je ovo drugačiji slučaj. Sumnjiva mi je ta osovina tanjira. Može li se skinuti a da ne razvalim ceo gramofon ? Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted October 24, 2019 Report Share Posted October 24, 2019 Šta je sumnjivo na osovini? Da li ima riseve? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted October 24, 2019 Report Share Posted October 24, 2019 1 sat ranije, Ružić Slavoljub said: Sumnjiva mi je ta osovina tanjira. Može li se skinuti a da ne razvalim ceo gramofon ? Може, три означена завртња М4 и осовина иде на доле. Мораћеш ипак да дигнеш шасију. Quote Link to comment Share on other sites More sharing options...
Ružić Slavoljub Posted October 24, 2019 Report Share Posted October 24, 2019 1 sat ranije, Willi Studer said: Šta je sumnjivo na osovini? Da li ima riseve? Nema ali mislim da ona pravi problem. Quote Link to comment Share on other sites More sharing options...
Ružić Slavoljub Posted October 24, 2019 Report Share Posted October 24, 2019 53 minuta ranije, giZ_Mo said: Може, три означена завртња М4 и осовина иде на доле. Мораћеш ипак да дигнеш шасију. Ok Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted October 24, 2019 Report Share Posted October 24, 2019 Zašto hoćeš da skineš osovinu? Šta ćeš tačno da radiš na njoj? Osovina je čelična, pre može da pravi problem mesingana čaura ležaja na tanjiru. Ali ako se okreće bez šuma ili zapinjanja, onda je u tom sklopu sve u redu. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted October 25, 2019 Report Share Posted October 25, 2019 Ja kad nešto ne znam dam nekome ko zna, a iskoristim priliku da naučim (ako se to da izvesti). Ovako, može samo da bude veća šteta nego korist, gramofon je osetljiva sprava, lako može da se zezne. Quote Link to comment Share on other sites More sharing options...
