s2m008 Posted July 10, 2019 Report Share Posted July 10, 2019 Zdravo, Zeleo bih da sastavim polovan stereo proverenih komponenti, a voleo bih da to ukljucuje i Dayens Ampino (ili preporuka za neki slican proizvod) za sobu od 20m2 pa bi mi dobrodosla neka preporuka. Pozdrav, Quote Link to comment Share on other sites More sharing options...
Nixie Posted July 10, 2019 Report Share Posted July 10, 2019 17 minuta ranije, s2m008 said: Zdravo, Zeleo bih da sastavim polovan stereo proverenih komponenti, a voleo bih da to ukljucuje i Dayens Ampino (ili preporuka za neki slican proizvod) za sobu od 20m2 pa bi mi dobrodosla neka preporuka. Pozdrav, Koliko para za sve to, šta će biti izvor zvuka (gramofon, PC+DAC, CD .... nešto treće)? Quote Link to comment Share on other sites More sharing options...
džonibigud Posted July 10, 2019 Report Share Posted July 10, 2019 Uz Ampino, Omega 3 XRS, jedan par starije generacije se pojavljivao na KP u veoma lepom finišu Quote Link to comment Share on other sites More sharing options...
s2m008 Posted July 10, 2019 Author Report Share Posted July 10, 2019 Pokusavam da nadjem oglas al mi ne ide Da se oglasim da bih kupio i polovan ampino do 150e. Quote Link to comment Share on other sites More sharing options...
s2m008 Posted July 10, 2019 Author Report Share Posted July 10, 2019 1 hour ago, Nixie said: Koliko para za sve to, šta će biti izvor zvuka (gramofon, PC+DAC, CD .... nešto treće)? Budzet mi je do 400e. Izvor ce biti uglavnom PC+DAC. Quote Link to comment Share on other sites More sharing options...
Nixie Posted July 10, 2019 Report Share Posted July 10, 2019 Za DAC znam otprilike odgovor, Topping D10, a za ostalo, mislim da gledaš prvo zvučnike pa onda na kraju pojačalo. Pretpostavljam da PC ne ulazi u budžet od 400 eur? Nešto treba odvojiti i za kablove. https://www.aliexpress.com/item/32852868314.html Quote Link to comment Share on other sites More sharing options...
s2m008 Posted July 10, 2019 Author Report Share Posted July 10, 2019 4 minutes ago, Nixie said: Za DAC znam otprilike odgovor, Topping D10, a za ostalo, mislim da gledaš prvo zvučnike pa onda na kraju pojačalo. Pretpostavljam da PC ne ulazi u budžet od 400 eur? Nešto treba odvojiti i za kablove. https://www.aliexpress.com/item/32852868314.html Ne, PC ne ulazi. Quote Link to comment Share on other sites More sharing options...
Nixie Posted July 10, 2019 Report Share Posted July 10, 2019 https://www.kupujemprodajem.com/Audio/Zvucnici/Monitor-Audio-Bronze-B2-80531259-oglas.htm?filter_id=434489528 Quote Link to comment Share on other sites More sharing options...
zek Posted July 10, 2019 Report Share Posted July 10, 2019 19 minuta ranije, Nixie said: Za DAC znam otprilike odgovor, Topping D10 Može da se nađe i malo jeftinije, https://www.amazon.com/Topping-TP30-MARK2-Headphone-Amplifier/dp/B00J2P9I2A/ref=pd_day0_hl_23_4/182-0100239-5791314?_encoding=UTF8&pd_rd_i=B00J2P9I2A&pd_rd_r=4e14a1f0-a310-11e9-bd3f-4b85b1506dc1&pd_rd_w=rFb4u&pd_rd_wg=KmLku&pf_rd_p=ad07871c-e646-4161-82c7-5ed0d4c85b07&pf_rd_r=XQ4EDJ2XPMKM6XMMEE1C&psc=1&refRID=XQ4EDJ2XPMKM6XMMEE1C Zvučno je na svetlijoj strani spektra, nedostaje mu malo topline u sredini, meni to nije odgovaralo. Možda je bolji izbor Khadas Tone Boarad https://www.khadas.com/product-page/tone-board https://www.aliexpress.com/item/32891480505.html https://www.digikey.com/product-detail/en/khadas/KTONE-G-001/2064-KTONE-G-001-ND/9867223 i kutija za njega https://www.audiophonics.fr/en/aluminium-boxes-cases/aluminum-case-for-khadas-tone-board-p-13626.html Quote Link to comment Share on other sites More sharing options...
Nixie Posted July 10, 2019 Report Share Posted July 10, 2019 35 minuta ranije, zek said: Može da se nađe i malo jeftinije, Kako misliš jeftinije na Amazonu, a poštarina veća od cene uređaja? Kod Kineza je besplatno slanje koliko vidim. Khadas izađe mnogo skuplje sa kutijom, nema ni onaj lep displej. Osim toga ostatak sistema koji će on kupiti verovatno neće biti previše detaljan , to su ipak neke jeftine komponente, tako da mi je Topping u ovom slučaju na prvom mestu baš zato što je svetlijeg karaktera. Khadas ima USB C to mi se ne dopada nikako, bolji je onaj USB B na Topping. Ako bude previše svetlo, to se može rešiti kablovima ili zamenom OP na izlazu Topping-a, u suprotnom slučaju nema pomoći. Quote Link to comment Share on other sites More sharing options...
zek Posted July 10, 2019 Report Share Posted July 10, 2019 19 minuta ranije, Nixie said: Ako bude previše svetlo, to se može rešiti kablovima ili zamenom OP na izlazu Topping-a Može, ali samo jedan OP od ukupno tri da se zameni. Jedan ima ugrađeno podnožje, druga dva su direktno zalemljeni na pločici. Quote Link to comment Share on other sites More sharing options...
zek Posted July 10, 2019 Report Share Posted July 10, 2019 4 sati ranije, s2m008 said: Zeleo bih da sastavim polovan stereo proverenih komponenti, a voleo bih da to ukljucuje i Dayens Ampino Ima li neki poseban razlog zašto baš Ampino - retko se nalazi na oglasima, a iako ih ima cena čini mi se nije baš konkurentna. Quote Link to comment Share on other sites More sharing options...
Nixie Posted July 10, 2019 Report Share Posted July 10, 2019 20 minuta ranije, zek said: Može, ali samo jedan OP od ukupno tri da se zameni. Jedan ima ugrađeno podnožje, druga dva su direktno zalemljeni na pločici. Da znam to, već je bilo igranja na jednom drugom forumu. Ima vajde i od zamene tog jednog na izlazu. Mada, na bih ja tu ništa menjao ako ne mora. Quote Link to comment Share on other sites More sharing options...
s2m008 Posted July 10, 2019 Author Report Share Posted July 10, 2019 7 minutes ago, zek said: Ima li neki poseban razlog zašto baš Ampino - retko se nalazi na oglasima, a iako ih ima cena čini mi se nije baš konkurentna. Iskreno i nema, samo sam citajuci komentare foruma stekao utisak da je odlican izbor cene i kvaliteta. Quote Link to comment Share on other sites More sharing options...
