trem2452 Posted April 19, 2019 Report Share Posted April 19, 2019 Pozdrav svima! Interesuje me kako povezati 5 pina din kabli na rca sa 2 izlaza (beli i crveni)? Din kabl ima 5 zicica (crna, bela, plava, zelena, crvena), dok rca ima 3 zicice (bela, crvena, uzemljenje). Unapred zahvalan. Quote Link to comment Share on other sites More sharing options...
Iron man Posted April 19, 2019 Report Share Posted April 19, 2019 za gramofon? Quote Link to comment Share on other sites More sharing options...
zek Posted April 19, 2019 Report Share Posted April 19, 2019 Ovako https://en.wikipedia.org/wiki/DIN_connector#Analog_audio Quote Link to comment Share on other sites More sharing options...
sondek Posted April 19, 2019 Report Share Posted April 19, 2019 Ili ako je izvor sa rca izlazima ovakav din to rca kabl ti zavrsava posao https://www.flashbacksales.co.uk/acatalog/2-x-Phono-RCA-Plugs---5-Pin-DIN-Plug-Premiere-Cable-380.html ,ako se ne odlucis na DIY.Kod mene su na svim pozicijama njihovi kablovi.Pokazali boljima i par puta jeftinijim od ''velikih'' brendova.Dave je super lik,brzo odgovara na mailove i vec sledeci dan ti napravi i posalje kabl po tvojim zahtevima.Do 50E nema carine,shipping nije preskup ,7-8 funti... malo EPP-a zadovoljnog korisnika. Quote Link to comment Share on other sites More sharing options...
zek Posted April 19, 2019 Report Share Posted April 19, 2019 57 minuta ranije, trem2452 said: dok rca ima 3 zicice (bela, crvena, uzemljenje). RCA za jedan kanal ima samo jedan živi vod u sredini i širm za uzemljenje. Inače DIN 5-to polni služi za snimanje i reprodukciju preko jednog kabla i jednog konektora. Konektori broj 1 i 4 su za snimanje. Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 13 sati ranije, siroma said: za gramofon? Da, za gramofon. Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 12 sati ranije, zek said: Ovako https://en.wikipedia.org/wiki/DIN_connector#Analog_audio Hvala! Probacu i ovaj nacin, pa javljam. :) Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 12 sati ranije, sondek said: Ili ako je izvor sa rca izlazima ovakav din to rca kabl ti zavrsava posao https://www.flashbacksales.co.uk/acatalog/2-x-Phono-RCA-Plugs---5-Pin-DIN-Plug-Premiere-Cable-380.html ,ako se ne odlucis na DIY.Kod mene su na svim pozicijama njihovi kablovi.Pokazali boljima i par puta jeftinijim od ''velikih'' brendova.Dave je super lik,brzo odgovara na mailove i vec sledeci dan ti napravi i posalje kabl po tvojim zahtevima.Do 50E nema carine,shipping nije preskup ,7-8 funti... malo EPP-a zadovoljnog korisnika. Uzeo vec takav kabli na aliexpress-u.Gramofon, fabricki dolazi sa 5 pin din kablom. Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 12 sati ranije, zek said: RCA za jedan kanal ima samo jedan živi vod u sredini i širm za uzemljenje. Inače DIN 5-to polni služi za snimanje i reprodukciju preko jednog kabla i jednog konektora. Konektori broj 1 i 4 su za snimanje. Da, tako je. Kod mene su na ovom din kablu povezani samo 3, 5, 2 konektori, 1 i 4 nisu. Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 Kao što napisah, gramofon fabrički dolazi sa 5-to pinskim din kablom. Moja zamisao je da izbacim taj kabli i da gramofon prebacim na rca kabli. Problem je u tome što ne mogu da nađem idealnu šemu na netu da prespojim rca kabli na gramofon, jer prethodni kabli ima 5 žičica, pa mi to sve otežava stvar. Cilj mi je da povežem gramofon na pojačalo, zato i celi ovaj posao. Evo slike, kako je din kabli bio povezan u gramofonu(ove deblje žičice), njega sam skinuo, a rca sam povezao samo na belo, crveno i crno, međutim kad pustim na pojačalo, zvuk se jako slabo čuje, a pojačalo je maksimalno pojačano. Hvala unapred! Quote Link to comment Share on other sites More sharing options...
zek Posted April 20, 2019 Report Share Posted April 20, 2019 Ne vidi se sa slike najbolje, ali mi se čini da ima oznake L. LG, RG i R. Ako je tako onda na levi činč idu bela (+) i plava (-) a za desni činč crvena (+) i zelena(-). 1 sat ranije, trem2452 said: međutim kad pustim na pojačalo, zvuk se jako slabo čuje, a pojačalo je maksimalno pojačano. Gde si na pojačalu priključio gramofon (da li pojačalo uopšte ima ulaze za gramofon)? Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 12 minuta ranije, zek said: Ne vidi se sa slike najbolje, ali mi se čini da ima oznake L. LG, RG i R. Ako je tako onda na levi činč idu bela (+) i plava (-) a za desni činč crvena (+) i zelena(-). Gde si na pojačalu priključio gramofon (da li pojačalo uopšte ima ulaze za gramofon)? Tako je, te oznake pišu. To sam skontao, ali je problem što na rca kablu, ima samo bela, crvena i uzemljenje. Mene interesuje gde to da spojim na ovoj pločici? Na pojačalu nemam ulaz za din, već imam samo rca ulaze, te obično povezujem na cd. Hvala unapred! Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 Šta je zanimljivo, probao sam sa još jednim gramofonom koji ima din izlaz i kad njega povežem na pojačalom preko rca kabla, zvuk radi bez problema, dok kod ovog neće. Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 2 sati ranije, trem2452 said: Hvala! Probacu i ovaj nacin, pa javljam. :) Probao sam i ovu varijantu, neće, zvuk se jako slabo čuje, a pojačalo mi je na max. Quote Link to comment Share on other sites More sharing options...
zek Posted April 20, 2019 Report Share Posted April 20, 2019 Uzemljenje veži za plavu i zelenu, belu na belu i crvenu na crvenu. Ali ti je džaba posao jer na pojačalu očigledno nemaš ulaz za gramofon (phono) i ne možeš da slušaš gramofon bez posebnog pre-pre ampa za phono (RIAA). Znači ne može se spojiti gramofonski izlaz na bilo koji ulz na pojačalu (AUX, TAPE, CD) samo na PHONO ulaz ako postoji. Da bi mogao da slušaš gramofon na tvom pojačalu treba da nabaviš phono-preamp (RIAA) koji ćeš da vežeš između gramofona i bilo kog ulaza u pojačalo. Quote Link to comment Share on other sites More sharing options...
zek Posted April 20, 2019 Report Share Posted April 20, 2019 12 minuta ranije, trem2452 said: Šta je zanimljivo, probao sam sa još jednim gramofonom koji ima din izlaz i kad njega povežem na pojačalom preko rca kabla, zvuk radi bez problema, dok kod ovog neće. Nigde nisi napisao koji je gramofon u pitanju, kakvu glavu (zvučnicu) ima, koje je pojačalo? Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 10 minuta ranije, zek said: Nigde nisi napisao koji je gramofon u pitanju, kakvu glavu (zvučnicu) ima, koje je pojačalo? http://www.grammofoon.com/frameset.htm?http://www.grammofoon.com/Philips/Philips_22GA312.htm&ContentFrame - Ovo mi je gramofon. A pojačalo je: https://www.fein-hifi.de/Surround-Receiver/Sony/Sony-STR-DE595-Digital-Mehrkanal-AV-Receiver-silber::1840.html Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 17 minuta ranije, zek said: Uzemljenje veži za plavu i zelenu, belu na belu i crvenu na crvenu. Ali ti je džaba posao jer na pojačalu očigledno nemaš ulaz za gramofon (phono) i ne možeš da slušaš gramofon bez posebnog pre-pre ampa za phono (RIAA). Znači ne može se spojiti gramofonski izlaz na bilo koji ulz na pojačalu (AUX, TAPE, CD) samo na PHONO ulaz ako postoji. Da bi mogao da slušaš gramofon na tvom pojačalu treba da nabaviš phono-preamp (RIAA) koji ćeš da vežeš između gramofona i bilo kog ulaza u pojačalo. Možda to i jeste problem, ali kako mi onda radi ei nis gramofon na pojačalu bez problema? Quote Link to comment Share on other sites More sharing options...
zek Posted April 20, 2019 Report Share Posted April 20, 2019 3 minuta ranije, trem2452 said: ali kako mi onda radi ei nis gramofon na pojačalu bez problema? Možda ima kristalnu glavu koja daje veći signal nego normalne gramofonske glave (koji je to model, nisam ni znao da je Ei sklapala neki gramofon!!!) Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 7 minuta ranije, zek said: Možda ima kristalnu glavu koja daje veći signal nego normalne gramofonske glave (koji je to model, nisam ni znao da je Ei sklapala neki gramofon!!!) Pardon! Nije Ei, već je ovaj: https://www.njuskalo.hr/gramofoni/gramofon-tosca-20-gp-5660-oglas-16754495 Quote Link to comment Share on other sites More sharing options...
zek Posted April 20, 2019 Report Share Posted April 20, 2019 Ako je baš takva Toska ona ima u sebi ugrađeno pojačalo, a tvoj Philips je čist gramofon bez ičega u sebi od elektronike (sem naravno za rad samog gramofona). Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 5 sati ranije, zek said: Uzemljenje veži za plavu i zelenu, belu na belu i crvenu na crvenu. Probao i ovu opciju, opet isto, jako se slabo čuje. Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 3 sati ranije, zek said: Ako je baš takva Toska ona ima u sebi ugrađeno pojačalo, a tvoj Philips je čist gramofon bez ičega u sebi od elektronike (sem naravno za rad samog gramofona). Znači u prevodu ništa ne može da se uradi? Quote Link to comment Share on other sites More sharing options...
zek Posted April 20, 2019 Report Share Posted April 20, 2019 Možeš da kupiš poseban pre-pre amp za phono sekciju. Quote Link to comment Share on other sites More sharing options...
trem2452 Posted April 20, 2019 Author Report Share Posted April 20, 2019 3 sati ranije, zek said: Možeš da kupiš poseban pre-pre amp za phono sekciju. Ok, videću. Puno hvala i Vama i drugim korisnicima na informacijama. Pozdrav! Quote Link to comment Share on other sites More sharing options...
