pop10 Posted March 3, 2019 Report Share Posted March 3, 2019 Posle malo muke, vraceni u fabricko stanje. Model Electro-Voice Interface D Frequency response: 18Hz - 18kHz +/- 2.5dB Efficiency: 97dB @ 1 Watt/1 Metre 3% Quarter-space Maximum power handling: 500 Watts Impedance: 8 Ohms nominal 5 Ohms minimum Transducer complement: 12 inch Dynamic Woofer - 6.5 inch VMR Vented Midrange (with 16 1/2 pound magnet) - ST350A Neckless Radial Horn Tweeter Bi-amplification capable Tweeter protection Dimensions: 21.75 inches wide (552mm) 32 inches high (813mm) 15.5 inches deep (394mm) Net weight: 114lbs (51kg) je Box Quote Link to comment Share on other sites More sharing options...
pollux Posted March 3, 2019 Report Share Posted March 3, 2019 Prelepo, slusao sam jedan par u NL, jel imas i equalizer koji ide uz njih. Vlasnik mi je rekao da je najveci napredak u basu dobio zamenom elemenata u njemu. Quote Link to comment Share on other sites More sharing options...
pop10 Posted March 3, 2019 Author Report Share Posted March 3, 2019 Nazalost nemam, ostalo mi je da ga nadjem, jedan prijatelj u Americi ce ga potraziti. Mada mi je najcudnije sto na plocici pozadi pise made in Switzerland, nisam imao pojma da su imali deo proizvodnje u Svajcarskoj. Mada radi i bez ekvilajera, kada se okrene zvucnik naopako ima jedan kao selektor u postolju uvucen, gde se odredjuje rezim rada, taj selektor je u stvari na velikoj ploci od skretnice, i odozdo ga mozes prebaciti u rezim bez bi wiring vezivanja i radi u full range onda, bilo kako ga prikacis na konektorima. Quote Link to comment Share on other sites More sharing options...
Ružić Slavoljub Posted March 3, 2019 Report Share Posted March 3, 2019 Deluju vrlo mocno.Daj jos koju sliku. Quote Link to comment Share on other sites More sharing options...
pop10 Posted March 3, 2019 Author Report Share Posted March 3, 2019 Quote Link to comment Share on other sites More sharing options...
pop10 Posted March 3, 2019 Author Report Share Posted March 3, 2019 Ima jos slika ali mi ne dozvoljava vise od dve. Quote Link to comment Share on other sites More sharing options...
