zek Posted January 10, 2019 Report Share Posted January 10, 2019 59 minuta ranije, locodreams said: u radnji mi prodavac preporucio ovo behringer monitor 1 nije bas jeftin kosta oko 8k ima jedan ulaz i izlaz i kontroler volumena. To sto, ali za mnogo manje para https://de.aliexpress.com/item/Voll-Ausgewogene-Passive-Preamp-pre-verst-rker-XLR-RCA-Potentiometer-audio-volumen-control-FV2/32870638220.html?spm=a2g0x.search0104.3.23.5f7a6f5cudSJVB&transAbTest=ae803_4&ws_ab_test=searchweb0_0%2Csearchweb201602_4_10065_10068_319_10059_10884_317_10887_10696_100031_321_322_10084_453_10083_454_10103_10618_431_10307_537_536%2Csearchweb201603_6%2CppcSwitch_0&algo_pvid=2553ee01-a346-4047-be0c-1fb76dcc1be5&algo_expid=2553ee01-a346-4047-be0c-1fb76dcc1be5-3 https://de.aliexpress.com/item/2018-neuesten-Kleine-B-r-Mini-2-wege-Stereo-L-R-RCA-Audio-Selector-Passive-Preamp/32881885879.html?spm=a2g0x.search0104.3.44.5f7a6f5cudSJVB&transAbTest=ae803_4&ws_ab_test=searchweb0_0%2Csearchweb201602_4_10065_10068_319_10059_10884_317_10887_10696_100031_321_322_10084_453_10083_454_10103_10618_431_10307_537_536%2Csearchweb201603_6%2CppcSwitch_0&algo_pvid=2553ee01-a346-4047-be0c-1fb76dcc1be5&algo_expid=2553ee01-a346-4047-be0c-1fb76dcc1be5-6 Quote Link to comment Share on other sites More sharing options...
TekManijak Posted January 10, 2019 Report Share Posted January 10, 2019 Odgledao sam ovaj video sto si postavio i meni to lici kao da je problem u tjuneru a ne pojacalu. Meni se slicno desava na starom grundig tjuneru.Tada moram samo da pomerim kazaljku za pola mhz napred ili nazad i onda ponovo svira kako treba, ali kod mene posle pola sata se stabilizuje i onda radi normalno. Probaj da ukljucis tuner u cd ulaz na pojacalu kao sto ti je odmah na pocetku sugerisano ako nista makar da otklonis i tu sumnju. EDIT: Ako je onaj pioneer uredjaj tjuner, onda se vidi da dolazi do gubitka signala, rekao bih da se ukljucuje i iskljucuje indikator stereo signala, ali ne vidi se bas dobro na snimku. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 10, 2019 Report Share Posted January 10, 2019 3 sati ranije, Nixie said: Nekad se držalo na TV, sad su tanki TV-i ne može saksija. И шустикла. Quote Link to comment Share on other sites More sharing options...
locodreams Posted January 10, 2019 Author Report Share Posted January 10, 2019 7 minuta ranije, TekManijak said: Odgledao sam ovaj video sto si postavio i meni to lici kao da je problem u tjuneru a ne pojacalu. Meni se slicno desava na starom grundig tjuneru.Tada moram samo da pomerim kazaljku za pola mhz napred ili nazad i onda ponovo svira kako treba, ali kod mene posle pola sata se stabilizuje i onda radi normalno. Probaj da ukljucis tuner u cd ulaz na pojacalu kao sto ti je odmah na pocetku sugerisano ako nista makar da otklonis i tu sumnju. EDIT: Ako je onaj pioneer uredjaj tjuner, onda se vidi da dolazi do gubitka signala, rekao bih da se ukljucuje i iskljucuje indikator stereo signala, ali ne vidi se bas dobro na snimku. Pioneer je player ista serija je tuner kao pojacalo signal nije sjajan ali isto mi se desava i sa playerom taj jazz ide sa audio diska tuner je bio upaljen ali na drugom kanalu pokusao sam sve rezultat isti.... Radi radi pa smetnje pa odblokira pa radi tipa po sata pa opet smetnje Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 10, 2019 Report Share Posted January 10, 2019 16 sati ranije, locodreams said: Mislis da bi trebalo izmjeniti sve kondenzatore eventualno? Ма јок, бацање пара. Проблем је или у Селектору улаза (прљав) или Директ прекидач (штрокав) или веза између штампане плоче која се налази у предњој и матичне плоче као и Релеј у заштити звучника. Не би било згорег прегледати лемове на СВИ 3205 излазном интегралацу. Quote Link to comment Share on other sites More sharing options...
locodreams Posted January 10, 2019 Author Report Share Posted January 10, 2019 38 minuta ranije, zek said: To sto, ali za mnogo manje para https://de.aliexpress.com/item/Voll-Ausgewogene-Passive-Preamp-pre-verst-rker-XLR-RCA-Potentiometer-audio-volumen-control-FV2/32870638220.html?spm=a2g0x.search0104.3.23.5f7a6f5cudSJVB&transAbTest=ae803_4&ws_ab_test=searchweb0_0%2Csearchweb201602_4_10065_10068_319_10059_10884_317_10887_10696_100031_321_322_10084_453_10083_454_10103_10618_431_10307_537_536%2Csearchweb201603_6%2CppcSwitch_0&algo_pvid=2553ee01-a346-4047-be0c-1fb76dcc1be5&algo_expid=2553ee01-a346-4047-be0c-1fb76dcc1be5-3 https://de.aliexpress.com/item/2018-neuesten-Kleine-B-r-Mini-2-wege-Stereo-L-R-RCA-Audio-Selector-Passive-Preamp/32881885879.html?spm=a2g0x.search0104.3.44.5f7a6f5cudSJVB&transAbTest=ae803_4&ws_ab_test=searchweb0_0%2Csearchweb201602_4_10065_10068_319_10059_10884_317_10887_10696_100031_321_322_10084_453_10083_454_10103_10618_431_10307_537_536%2Csearchweb201603_6%2CppcSwitch_0&algo_pvid=2553ee01-a346-4047-be0c-1fb76dcc1be5&algo_expid=2553ee01-a346-4047-be0c-1fb76dcc1be5-6 Hvala ti puno na postu sestra mi je u kini i salje sad paket neki trazicu i to ovaj prvi je cak i bolji od njemca koji kosta 8000 Quote Link to comment Share on other sites More sharing options...
locodreams Posted January 10, 2019 Author Report Share Posted January 10, 2019 6 minuta ranije, darT_Vader said: Ма јок, бацање пара. Проблем је или у Селектору улаза (прљав) или Директ прекидач (штрокав) или веза између штампане плоче која се налази у предњој и матичне плоче као и Релеј у заштити звучника. Не би било згорег прегледати лемове на СВИ 3205 излазном интегралацу. Moguce da je prljav nisam ga otvarao ni cistio volio bi ga srediti posto je meni sasvim dovoljan i dobro je radio Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 10, 2019 Report Share Posted January 10, 2019 Прљавштина + година производње '90. Quote Link to comment Share on other sites More sharing options...
locodreams Posted January 10, 2019 Author Report Share Posted January 10, 2019 12 minuta ranije, darT_Vader said: Прљавштина + година производње '90. Da samo vidicu da nadjem neki servis da mi to pregledaju slabo ko hoce da radi vise to. Quote Link to comment Share on other sites More sharing options...
locodreams Posted January 11, 2019 Author Report Share Posted January 11, 2019 19 sati ranije, darT_Vader said: Ма јок, бацање пара. Проблем је или у Селектору улаза (прљав) или Директ прекидач (штрокав) или веза између штампане плоче која се налази у предњој и матичне плоче као и Релеј у заштити звучника. Не би било згорег прегледати лемове на СВИ 3205 излазном интегралацу. lik mi u nekim servisu dok trepnes u ns trazi za dijagnostiku 2400 Quote Link to comment Share on other sites More sharing options...
Spachek Posted January 11, 2019 Report Share Posted January 11, 2019 Molim lepo, da ošiša na brzinuSent from my SM-A520F using Tapatalk Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 11, 2019 Report Share Posted January 11, 2019 2 sati ranije, locodreams said: lik mi u nekim servisu dok trepnes u ns trazi za dijagnostiku 2400 Много. Quote Link to comment Share on other sites More sharing options...
locodreams Posted January 11, 2019 Author Report Share Posted January 11, 2019 2 sati ranije, darT_Vader said: Много. jeste a znam jedan servis u kom ne traze pare za dijagnostiku ali su im argumenti to je staro ne moze se popraviti vec sam nosio nesto pa nije islo probacu sada opet pa cemo vidjeti...javicu se sta ispadne na kraju Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted January 11, 2019 Report Share Posted January 11, 2019 Zašto mislite da je za dijagnostiku mnogo 20 evra? Quote Link to comment Share on other sites More sharing options...
Delija Posted January 12, 2019 Report Share Posted January 12, 2019 Upravo tako. Koliko kosta zamena i balansiranje 4 gume/tocka kod vulkanizera? A vulkanizer moze da bude (skoro) svako. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 12, 2019 Report Share Posted January 12, 2019 18 minuta ranije, Delija said: Upravo tako. Koliko kosta zamena i balansiranje 4 gume/tocka kod vulkanizera? A vulkanizer moze da bude (skoro) svako. Мени то пријатељ ради џабе. Слажем се да вулканизер може да буде оно свако. Кад сам ја то успео да научим мислим да може свако. Сада јурим да радим као вулканизер у Ферари Ф1 тиму. Quote Link to comment Share on other sites More sharing options...
Delija Posted January 12, 2019 Report Share Posted January 12, 2019 Nije mi nikako bila namera da degradiram zanimanje vulkanizera. Sta vise, mog vulkanizera bezrezervno preporucujem svima, jer perfektno radi svoj posao - bilo da su to vulkanizerski poslovi ili trgovina gumama. Poenta je bila u tome da je savrseno ok da neko naplati svoje znanje i iskustvo, pogotovo kad to ne moze da se nadje bas na svakom koraku. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 12, 2019 Report Share Posted January 12, 2019 Има истине. Quote Link to comment Share on other sites More sharing options...
locodreams Posted January 14, 2019 Author Report Share Posted January 14, 2019 nasao sam servisera u lokalu uradjena je dijagnostika, do sada na pojacalu nije nikada nista radjeno potrebno je promjeniti sve preklopnike i potenciometre i kostace 3900 servis pojacala...mislim da na kraju i nije skupo...dijagnostika je bila besplatna mozda je sada uradcunata ko zna Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 14, 2019 Report Share Posted January 14, 2019 Баш ме интересује где ће наћи делове. Quote Link to comment Share on other sites More sharing options...
locodreams Posted January 14, 2019 Author Report Share Posted January 14, 2019 5 sati ranije, darT_Vader said: Баш ме интересује где ће наћи делове. Mislis da me kupa? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 14, 2019 Report Share Posted January 14, 2019 Не, само сам пит'о. Quote Link to comment Share on other sites More sharing options...
locodreams Posted January 14, 2019 Author Report Share Posted January 14, 2019 6 minuta ranije, darT_Vader said: Не, само сам пит'о. Iskreno ne znam zvao me danas da mi kaze ako sam dobro razumio preklopnike i neke potenciometre oni rade vjerovatno ce ih podmazati i ocistiti samo daje mi i garanciju na rad jebiga Quote Link to comment Share on other sites More sharing options...
locodreams Posted January 17, 2019 Author Report Share Posted January 17, 2019 sredjeno je pojacalo...ocistio je samo sve potenciometre i dao mi garanciju 3 mjeseca kaze da nikada nista nije cackano niti budzeno, mislim da se isplatilo za 3900 zadovoljan sam sa ovim pojacalom...uzecu mu nove zvucnike cim prodam stare Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 17, 2019 Report Share Posted January 17, 2019 40 minuta ranije, locodreams said: sredjeno je pojacalo...ocistio je samo sve potenciometre i dao mi garanciju 3 mjeseca kaze da nikada nista nije cackano niti budzeno, mislim da se isplatilo za 3900 zadovoljan sam sa ovim pojacalom...uzecu mu nove zvucnike cim prodam stare E to je mnogo samo za potenciometre, zar nije te silne prekidače očistio i podmazao? Quote Link to comment Share on other sites More sharing options...
