JTGTS Posted January 7, 2019 Report Share Posted January 7, 2019 2 minutes ago, darT_Vader said: У шеми су 12AT7/ECC81 и 12AU7/ECC82 као и 6Z4. Оно што сам приметио је да су уградили руске папир у зејтину кондезаторе. https://imgur.com/a/JMlqEps moj izgleda za nijansu drugacije unutra i nosi druge lampe tj.verovatno postoje 2 razlicita modela sa istom oznakom stim da je moj mnogo redji.Nema te 4 crne budze verovatno te ruske kondenzatore nego crvene blok Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 7, 2019 Report Share Posted January 7, 2019 Вероватно постоји више модела. Један је са а други без тонских контрола. https://www.ebay.com/itm/Latest-High-End-XiangSheng-728A-Vacuum-12AT7-12AU7-Stereo-HiF-Tube-Preamplifier/292612060753?_trkparms=aid%3D888007%26algo%3DDISC.MBE%26ao%3D1%26asc%3D20131227121020%26meid%3D9eacf66a189a45139ce2d25ef168905b%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D121989326017%26itm%3D292612060753&_trksid=p2047675.c100009.m1982 Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 7, 2019 Report Share Posted January 7, 2019 Мада постоји и са тон контролама али са руским кондезаторима. Базна шема је иста. https://www.ebay.com/itm/XiangSheng-728A-Vacuum-Tube-Preamplifier-12AT7-12AU7-6Z4-tube-amp-pre-amplifier/121989326017?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20131231084308%26meid%3D3b132dc10f8947a2846565fce70d4355%26pid%3D100010%26rk%3D6%26rkt%3D12%26sd%3D292612060753%26itm%3D121989326017&_trksid=p2047675.c100010.m2109 Quote Link to comment Share on other sites More sharing options...
Krca44 Posted January 7, 2019 Report Share Posted January 7, 2019 Sta ima je uopste bazna shema ? Marantz 7 za koji se ne zna kako je promenjena ? Quote Link to comment Share on other sites More sharing options...
JTGTS Posted January 7, 2019 Report Share Posted January 7, 2019 Verovatno je i moj slican unutra tj skoro isto ali nema te ruske kondenzatore i nosi druge lampe.Na netu jako malo podataka ima o njima. https://imgur.com/a/JMlqEps Quote Link to comment Share on other sites More sharing options...
JTGTS Posted January 7, 2019 Report Share Posted January 7, 2019 Jos jedna stvar nazad ima izlaze za 2 snagasa, na 1 pise high koliko se secam na 1 low output. High ima malo jaci izlaz i izrazenije visoke ali gubi mikro detalje dok na low se cuje malo tise (sto mi i odgovara) ali je zvuk linearniji ima cistije visoke iako su tisi, pun je micro detalja i zvuk dobija mnogo siru scenu. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 7, 2019 Report Share Posted January 7, 2019 9 sati ranije, Krca44 said: Sta ima je uopste bazna shema ? На ово сам мислио. Quote Link to comment Share on other sites More sharing options...
Mingus,Mingus Posted January 7, 2019 Author Report Share Posted January 7, 2019 Ja i moj prijatelj smo nekada pravili cevna predpojacala,izlaze, VTL je bio jedan od tih.Pravljenje ,ko nije pravio ne zna koliko je tesko u nasim uslovima i koliko kosta.Kada sam pravio trudio sam se da to osim da dobro radi da lepo izgleda. Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 7, 2019 Report Share Posted January 7, 2019 Evo ga noviji model, neko je skidao šemu, meni se ovo ama baš ni malo ne dopada, ima puno loših rešenja. Ispravljačice su u opasnosti, tonske kontrole uza aktivnog dela, potenciometar na izlazu, aktivni deo nepotrebno komplikovano urađen. Nije čudno što je mekan zvuk. Te starije šeme sa 6N3 i ECC88 nigde nema, tako da možemo samo da nagađamo da li je slično izvedeno sa drugim lampama, ili skroz različito. http://audiokarma.org/forums/index.php?threads/xiang-sheng-728a-preamp-drawing-attempt-for-a-schematic.832242/ Quote Link to comment Share on other sites More sharing options...
miletrosak1959 Posted January 7, 2019 Report Share Posted January 7, 2019 11 sati ranije, JTGTS said: Prve su ispravljacice i koliko sam razumeo one rade kao grec i to bi trebalo da ima neke razlike u zvuku e sad kako rade ostale to mi nije jasno.Koristim uvek ukljucen direct i kada sam zamenio ecc88 neznam koje su nema oznake sa telefunken e88cc razlika u zvuku je bila ogromna ali ne bas na bolje zvuk postao premekan pa se razmisljam da vratim stare ali da bi stare prosvirale kako treba treba mu 1h rada. Mislis da su one 6n3p za tonske kontrole ? ako jesu necu ni da ih menjam Mogu samo da se nadovezem da ces tesko naci bolje lampe od Telefunken e88cc.Mozda treba nesto da se podesi prema njima a ne da se samo ubodu. Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 7, 2019 Report Share Posted January 7, 2019 5 minuta ranije, miletrosak1959 said: Mogu samo da se nadovezem da ces tesko naci bolje lampe od Telefunken e88cc.Mozda treba nesto da se podesi prema njima a ne da se samo ubodu. Šta da se podešava kad su i originalne bile na tom mestu ECC88, mislim to je onda prepravka uređaja, možda je kupio dotrajale Telefunkenove? Quote Link to comment Share on other sites More sharing options...
JTGTS Posted January 7, 2019 Report Share Posted January 7, 2019 3 minutes ago, Nixie said: Šta da se podešava kad su i originalne bile na tom mestu ECC88, mislim to je onda prepravka uređaja, možda je kupio dotrajale Telefunkenove? Lampe ECC88 bez drugih oznaka su bile unutra i sa njima je svirao bolje.Sad meni nije jasno zasto moj preamp nosi druge lampe i zasto nema ona 4 crna kondenzatora nego sve crvene blok. Samim tim verujem da je i karakter zvuka skroz drugaciji.Sve ostalo je identicno. Dal je to neka revizija ili je covek od kog sam uzeo vec menjao nesto mada slika koju sam upload vec pokazuje da postoji tako nesto (da nisam jedini). U svakom slucaju preamp meni zvuci odlicno (na tisem izlazu) sa pravim lampama, mozda to moze dosta bolje ali nisam imao prilike da uporedim. Quote Link to comment Share on other sites More sharing options...
JTGTS Posted January 7, 2019 Report Share Posted January 7, 2019 Inace druge lampe su 6n3p a ne ecc81 Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 7, 2019 Report Share Posted January 7, 2019 1 minut ranije, JTGTS said: Dal je to neka revizija ili je covek od kog sam uzeo vec menjao nesto mada slika koju sam upload vec pokazuje da postoji tako nesto (da nisam jedini). Вероватно је замењено али ипак су то Кинези, ко ће их знати. Quote Link to comment Share on other sites More sharing options...
JTGTS Posted January 7, 2019 Report Share Posted January 7, 2019 https://imgur.com/a/xD3iB7h Quote Link to comment Share on other sites More sharing options...
JTGTS Posted January 7, 2019 Report Share Posted January 7, 2019 Ove su bile u njemu i bolje sviraju od novih tesli e88cc Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 7, 2019 Report Share Posted January 7, 2019 2 minuta ranije, JTGTS said: Ove su bile u njemu Verovatno Kineske 6N11 pa rebrandirane malo nevešto. Ajde uslikaj 6N3P. Quote Link to comment Share on other sites More sharing options...
JTGTS Posted January 7, 2019 Report Share Posted January 7, 2019 Sad cu da otvorim preamp za par minuta kacim slike Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 7, 2019 Report Share Posted January 7, 2019 10 minuta ranije, darT_Vader said: Вероватно је замењено али ипак су то Кинези, ко ће их знати. Verovatno ranija varijanta preampa, ova novija je iz 2018. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted January 7, 2019 Report Share Posted January 7, 2019 2 minuta ranije, JTGTS said: Sad cu da otvorim preamp za par minuta kacim slike На крају ћеш ти то да средиш к'о за врбицу. Quote Link to comment Share on other sites More sharing options...
JTGTS Posted January 7, 2019 Report Share Posted January 7, 2019 https://imgur.com/a/dZYyE2B 6n3p https://imgur.com/a/zvLx9cB Quote Link to comment Share on other sites More sharing options...
JTGTS Posted January 7, 2019 Report Share Posted January 7, 2019 https://imgur.com/a/VTBrXWj Tesla https://imgur.com/a/D3PDgK2 https://imgur.com/a/Hb4CAuO https://imgur.com/a/Ehb9Aj5 Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 7, 2019 Report Share Posted January 7, 2019 4 minuta ranije, JTGTS said: https://imgur.com/a/dZYyE2B 6n3p https://imgur.com/a/zvLx9cB Te su Ruske definitivno. Quote Link to comment Share on other sites More sharing options...
JTGTS Posted January 7, 2019 Report Share Posted January 7, 2019 Vratio sam stare lampe bolje je svirao. Pustio sam sporet malo da se zagreje XD Quote Link to comment Share on other sites More sharing options...
JTGTS Posted January 7, 2019 Report Share Posted January 7, 2019 Just now, Nixie said: Te su Ruske definitivno. Menjati to ili ne ? Mada tesko cu i naci nesto za zamenu Quote Link to comment Share on other sites More sharing options...
