RADE Posted January 16, 2022 Report Share Posted January 16, 2022 19 minuta ranije, Nixie said: Nije isto, ima verzija sa kvalitetnim Vishay smd otpornicima. stim da su oni serije 1206 mnogo bolji od korišćenih 805.....u svakom pogledu 😂. Quote Link to comment Share on other sites More sharing options...
neskor Posted January 16, 2022 Report Share Posted January 16, 2022 stavite krsten AVC, to ima da svira bolje od bilo kog pota Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 16, 2022 Author Report Share Posted January 16, 2022 3 minuta ranije, RADE said: Odmah iza ide jedan otpor u seriju i sve drugo u paralelu To se zove Shunt potenciometar. Mana je jedna velika kod toga, nikako beznačajna. Ako pot ne daj bože izgubi kontakt sa masom na klizaču, pojavi se pun signal na izlazu pota, pojačalo ide u grubi klipping i zvučnici su ugroženi. Zato sam prežalio poboljšanje zvuka i vratio se na klasičan pot. A šta je najbolje, pa tako nešto ne postoji, odnosno mogu se dobiti različiti rezultati zavisno od ostatka sistema. Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 16, 2022 Author Report Share Posted January 16, 2022 Just now, neskor said: stavite krsten AVC, to ima da svira bolje od bilo kog pota Mala mi ova kutija. Quote Link to comment Share on other sites More sharing options...
skrstic Posted January 16, 2022 Report Share Posted January 16, 2022 10 minuta ranije, neskor said: stavite krsten AVC, to ima da svira bolje od bilo kog pota Hoće ali kršten AVC je puno $$$. Nisam siguran da ostatak prati. Šant pot je jeftino a dobro poboljšanje. Quote Link to comment Share on other sites More sharing options...
skrstic Posted January 16, 2022 Report Share Posted January 16, 2022 1 minut ranije, Nixie said: Mala mi ova kutija. Imaš i veću. 😜 Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 16, 2022 Author Report Share Posted January 16, 2022 Za 2x4W nema frke, jeste bolji Shunt. Za 2x150W, moram još malo da razmislim. Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 16, 2022 Author Report Share Posted January 16, 2022 Just now, skrstic said: Imaš i veću. 😜 Ta je kod kolege otišla, davno još. Quote Link to comment Share on other sites More sharing options...
Father Posted January 16, 2022 Report Share Posted January 16, 2022 4 minuta ranije, skrstic said: Imaš i veću. 😜 Stiso se, pravi za sebe! 🤣 Quote Link to comment Share on other sites More sharing options...
RADE Posted January 16, 2022 Report Share Posted January 16, 2022 7 minuta ranije, Nixie said: Za 2x4W nema frke, jeste bolji Shunt. Za 2x150W, moram još malo da razmislim. Razmišljajući ovih dana kako da rešim taj problem kod arduina....recimo arduino stane i otkači sve releje.....i onda se setim.....pa jednostavno dodam još jedan rele i sa svakog od 14 rejela vučem napon preko diode koja ne ometa ostale releje ali daje napon za 15. rele. To znači da bi taj relej bio uključen svaki put kada god bi bio uključen još po neki ....i to je to 😂 i shodno tome ako ne radi ni jedan relej ne radi ni taj a on u tom položaju ima zakucan signal na masu . Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 16, 2022 Author Report Share Posted January 16, 2022 Sve ću povadim od delova iz raznih sprava i naguram u manje kutije. Quote Link to comment Share on other sites More sharing options...
Father Posted January 16, 2022 Report Share Posted January 16, 2022 24 minuta ranije, neskor said: stavite krsten AVC, to ima da svira bolje od bilo kog pota Vako nešto? Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 16, 2022 Author Report Share Posted January 16, 2022 Just now, RADE said: Razmišljajući ovih dana kako da rešim taj problem kod arduina....recimo arduino stane i otkači sve releje.....i onda se setim.....pa jednostavno dodam još jedan rele i sa svakog od 14 rejela vučem napon preko diode koja ne ometa ostale releje ali daje napon za 15. rele. To znači da bi taj relej bio uključen svaki put kada god bi bio uključen još po neki ....i to je to 😂 To ne važi zta analogni pot, za digitaliju uvek postoji mogućnost neke zaštite tipa brute force. Quote Link to comment Share on other sites More sharing options...
RADE Posted January 16, 2022 Report Share Posted January 16, 2022 1 minut ranije, Father said: Vako nešto? Uf, šta je to Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 16, 2022 Author Report Share Posted January 16, 2022 Just now, Father said: Vako nešto? Ne, Neskor je mislio na auto trafo sa velikim brojem izvoda. Tu se još postavlja pitanje nekog buffer-a ispred trafoa. Quote Link to comment Share on other sites More sharing options...
skrstic Posted January 16, 2022 Report Share Posted January 16, 2022 9 minuta ranije, Nixie said: Za 2x4W nema frke, jeste bolji Shunt. Za 2x150W, moram još malo da razmislim. Ko ti kriv što si watadžija. Quote Link to comment Share on other sites More sharing options...
RADE Posted January 16, 2022 Report Share Posted January 16, 2022 Just now, Nixie said: To ne važi zta analogni pot, za digitaliju uvek postoji mogućnost neke zaštite tipa brute force. Šta ne važi...ja ti govorim o arduinu koji upravlja sa 14 releja preko linearnog potenciometra.......okrećeš potenciometra a releji samo zvrckaju 😂 Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 16, 2022 Author Report Share Posted January 16, 2022 Ma mi pričamo o analognom potu, vezanom kao šant. Taj je opasan ako se desi nepožejna stvar. Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 16, 2022 Author Report Share Posted January 16, 2022 Just now, skrstic said: Ko ti kriv što si watadžija. Spakovaću sve u malecke kutije. Japanske. Quote Link to comment Share on other sites More sharing options...
RADE Posted January 16, 2022 Report Share Posted January 16, 2022 6 minuta ranije, Father said: Vako nešto? Inače moram uskoro da idem gore kod ajendista da ih pitam jel menjaju redovno ulje u kondezatorima 🤣....mislim na koliko ih sati rada menjaju ...ne kondezatore nego ulje u njima. Quote Link to comment Share on other sites More sharing options...
Father Posted January 16, 2022 Report Share Posted January 16, 2022 9 minuta ranije, RADE said: Uf, šta je to Atenuator sa allen bradley carbon composition otpornicima. Imam sliku od septembra, nekog preampa kod Ace Andonova. On voli pošteno da se pomuči oko tog pitanja. Quote Link to comment Share on other sites More sharing options...
RADE Posted January 16, 2022 Report Share Posted January 16, 2022 2 minuta ranije, Nixie said: Ma mi pričamo o analognom potu, vezanom kao šant. Taj je opasan ako se desi nepožejna stvar. svaki je opasan ako mu se nešto otkači.... Ja sam imao problema sa preklopnikom jer su kupci to okretali kao običan potenciometar pa su posle određenog vremena počeli da krckaju.....a na tržištu nema ništa što može da se okreće kao potenciometar...mislim na brzinu okreta 😀.....ja mislim da bi shebali i one preklopnike od 300 evra. I onda sam stavio Alps prema masi pa neka ga okreću do nove godine. 😀. Quote Link to comment Share on other sites More sharing options...
RADE Posted January 16, 2022 Report Share Posted January 16, 2022 8 minuta ranije, Father said: Atenuator sa allen bradley carbon composition otpornicima. Imam sliku od septembra, nekog preampa kod Ace Andonova. On voli pošteno da se pomuči oko tog pitanja. lepo urađeno 💪 Quote Link to comment Share on other sites More sharing options...
RADE Posted January 16, 2022 Report Share Posted January 16, 2022 Ideja sa arduinom je u stvari pokušaj da imam preciznost i pokreta i okreta a da ne mogu baš tako lahko da ga " iskrckaju" jer nema mehaničkih delova. Quote Link to comment Share on other sites More sharing options...
Nixie Posted January 16, 2022 Author Report Share Posted January 16, 2022 To je u redu, običan pot upravlja tim sokoćalom i relejima. Tako imaš mnogo bolji pot za mnogo manje para od onih preskupih varijanti. Samo kvalitet releja treba da bude dobar, ako nije, opet smo na početku. I da se reši make before brake da ne pucketa pri promneni jačine, ali to pretpostavljam nije problem, rešava se programom. Barem sae nadam da je tako. Quote Link to comment Share on other sites More sharing options...
