CiraCira Posted December 10, 2018 Report Share Posted December 10, 2018 Planiram u (nadam se bliskoj) buducnosti da napravim kucni bioskop 7.2 za filmove i muziku. Da li postoji varijanta da se ukljuci gramofon u celu pricu i koliko bi to bilo komplikovano? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted December 10, 2018 Report Share Posted December 10, 2018 Ако АВР има улаз за грамофон тад'' је проболем решен. Quote Link to comment Share on other sites More sharing options...
Nixie Posted December 10, 2018 Report Share Posted December 10, 2018 2 minuta ranije, alI_Zée said: Ако АВР има улаз за грамофон тад је проболем решен. Ako nema neka kupi posebno phono preamp. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted December 10, 2018 Report Share Posted December 10, 2018 У том случају +1. Quote Link to comment Share on other sites More sharing options...
ivcha1976 Posted December 10, 2018 Report Share Posted December 10, 2018 Samo povezi gramofon na preamp. Ono sto ces dobiti je prostu podelu na sve zvucnike ( stereo na 7.2 ili sta god podela). enjoy. Quote Link to comment Share on other sites More sharing options...
CiraCira Posted December 10, 2018 Author Report Share Posted December 10, 2018 Super, hvala. Quote Link to comment Share on other sites More sharing options...
ivanp Posted December 10, 2018 Report Share Posted December 10, 2018 54 minuta ranije, ivcha1976 said: Samo povezi gramofon na preamp. Ono sto ces dobiti je prostu podelu na sve zvucnike ( stereo na 7.2 ili sta god podela). enjoy. Naravno da stvar baš i nije tako prosta. Na bilo šta da priključuješ gramofon mora da ima fono ulaz. Ostali ne odgovaraju. Naravno da AVR ne mora da radi stereo preko svih zvučnika. Ima na njemu svašta da se podesi!! Quote Link to comment Share on other sites More sharing options...
ivcha1976 Posted December 10, 2018 Report Share Posted December 10, 2018 Predpostaka je ako prica o gramofonu je da zna da phono ulaz( na ovaj ili onaj nacin) mora da bude tu. Ako ne, prvo na pocetnicka pitanja sekciju, pa onda ovde Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted December 10, 2018 Report Share Posted December 10, 2018 Ауууу који ехо. Quote Link to comment Share on other sites More sharing options...
nesone Posted December 10, 2018 Report Share Posted December 10, 2018 6 sati ranije, CiraCira said: Planiram u (nadam se bliskoj) buducnosti da napravim kucni bioskop 7.2 za filmove i muziku. Da li postoji varijanta da se ukljuci gramofon u celu pricu i koliko bi to bilo komplikovano? Zaboravi to sve. Ili idi na HT ili na klasican stereo. Quote Link to comment Share on other sites More sharing options...
Ružić Slavoljub Posted December 10, 2018 Report Share Posted December 10, 2018 Ovo će da bude opasan hibrid. Nekako mi zvuči nesvakidašnje ideja da povežeš takve sve sprave. U svakom slučaju voleo bih da budeš zadovoljan zvukom. Quote Link to comment Share on other sites More sharing options...
ivanp Posted December 10, 2018 Report Share Posted December 10, 2018 Zašto? Svi bolji AVR ovi imaju fono ulaz. Jel iz istog razloga zbog kojeg katolički pop ima tuksona? Ne bih se složio. Nek počne sa AVR om, nek sluša malo, nek čita, nek se uči. Znaće posle šta mu se sviđa a šta ne. Quote Link to comment Share on other sites More sharing options...
Delija Posted December 10, 2018 Report Share Posted December 10, 2018 Phono sekcija na AVR-ovima koji ga uopste imaju sluzi maltene za ukras. Moze da posluzi samo za prvu pomoc. Quote Link to comment Share on other sites More sharing options...
ivanp Posted December 10, 2018 Report Share Posted December 10, 2018 Eto iz ovih nekoliko odgovora mogao je mnogo da nauči i da zaključi šta mu treba. A da može, može. A katolički popovi imaju tuksona!! Quote Link to comment Share on other sites More sharing options...
NShappy Posted December 10, 2018 Report Share Posted December 10, 2018 CiroCiro, valjda si pohvatao da li šta i kako može. Poenta jeste sledeća. Ako tvoj AVR ima ulaz označen sa PHONO, onda u sebi ima i gramofonsko predpojačalo ili po engleski, phono preamp. Samo u taj ulaz možeš uključiti klasičan gramofon. Na kojem češ od 5-6-7 zvučnika čuti zvuk zavisi od podešenja u AVR. Ako tvoj AVR nema PHONO ulaz, trebaće ti i posebno gramofonsko predpojačalo, phono preamp (na primer) koji kačiš između gramofona i AVR-a. U ovom slučaju, gramofon preko tog phono preamp-a kačiš na bilo koji analogni ulaz AVR-a. I dalje od podešenja AVR-a zavisi na kojim ćeš sve zvučnicima čuti ta dva kanala iz analognog ulaza. Postoji retka mogućnost i da gramofon u sebi ima phono preamp, ali to je malo verovatno. Koji gramofon imaš? Quote Link to comment Share on other sites More sharing options...
CiraCira Posted December 11, 2018 Author Report Share Posted December 11, 2018 Nista od opreme nemam jos uvek. Citao sam dosta o kucnom bioskopu i ozvucenju, samo nikad prakticno nisam povezao nista osim obicnog "decijeg" 5.1 sistema na komp. Hvala na odgovorima. Dakle da zakljucim: Kako god da prikljucim gramofon, zvuk ce da izlazi samo iz pojedinih zvucnika, ali i to je dovoljno jer mi ne treba surround za muziku sa vinila, jel? Mislim to ce opet lepo da zvuci? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted December 11, 2018 Report Share Posted December 11, 2018 Нормално када са винила можеш да добијеш само два канала. Quote Link to comment Share on other sites More sharing options...
Nixie Posted December 11, 2018 Report Share Posted December 11, 2018 54 minuta ranije, alI_Zée said: Нормално када са винила можеш да добијеш само два канала. A jel ima na tim spravama da od dva kanala napraviš virtualnih 7+1? Quote Link to comment Share on other sites More sharing options...
Delija Posted December 11, 2018 Report Share Posted December 11, 2018 7+1 je demode. Sada je 7+1+4 "in" Quote Link to comment Share on other sites More sharing options...
NShappy Posted December 11, 2018 Report Share Posted December 11, 2018 1 sat ranije, CiraCira said: Nista od opreme nemam jos uvek. Citao sam dosta o kucnom bioskopu i ozvucenju, samo nikad prakticno nisam povezao nista osim obicnog "decijeg" 5.1 sistema na komp. Hvala na odgovorima. Dakle da zakljucim: Kako god da prikljucim gramofon, zvuk ce da izlazi samo iz pojedinih zvucnika, ali i to je dovoljno jer mi ne treba surround za muziku sa vinila, jel? Mislim to ce opet lepo da zvuci? Pa AVR-ovi mogu da preusmere jedan kanal sterea na 3 zvučnika, drugi kanal sterea na druga tri, centralni da ćuti, ili da pušta mix levog i desnog, a sub da svira niske tonove koje će procesor u AVR-u da izdvoji iz analognog ulaza gde je prikačen gramofon. A može i da se podesi da jedan kanal AVR-a svira levi stereo sa gramofona, drugi kanal AVR-a svira ono desno sa gramofona, a ostali zvučnici da ćute. A u nekim AVR-ovima, procesori mogu da pametuju pa da prave neki kvazi surround iz dva stereo kanala (što uglavnom kvari zvuk). Ali to su sve podešavanje unutar AVR. Ono bitno, da slušaš gramofon preko AVR-a, treba ti phono preamp, bilo da je ugrađen u AVR (danas su ti jako loši), bilo da je eksterni (najbolje rešenje), bilo da je ugrađen u gramofon (retka opcija). Quote Link to comment Share on other sites More sharing options...
Ružić Slavoljub Posted December 11, 2018 Report Share Posted December 11, 2018 10 sati ranije, Nixie said: A jel ima na tim spravama da od dva kanala napraviš virtualnih 7+1? Ima. Quote Link to comment Share on other sites More sharing options...
