Sign in to follow this
rain dogs
Cyrus 8vs (Perfektan Primerak)
Ajde da probam jos jednom ovde sa Cyrus-om.Mada je nejasno iz kog razloga niikog ne interesuje ovaj zaista perfektno ocuvan primerak,sa originalnim daljincem,strujnim kablom,kutijom.....etc....etc
-Kada se pojavio 2006/2007god Cyrus 8vs je u Nemackoj kostao 1500eu, a u Americi 1800$, sto je pokazatelj da je rec o izuzetnom uredjaju visoke srednje klase, koji sa ponosom nosi kao zemlju porekla "Made in UK" a ne Kinu, Maleziju. . . etc. . . etc odakle dolaze razne skalamerije.
-Cyrus 8vs je jako potentno pojacalo, tako da bez problema puni i zahtevnije kutije, veoma je detaljan, za nijansu otvoreniji, s toga mu prijaju kutije koje su zvucno na meksoj strani.
-Slike su od pojacala koji je predmet prodaje (nisu sa interneta).
-Cena pojacala je 450eu.
-Na dole 3 postavljena "Youtube" video zapisa se moze videti/cuti da pojacalo odlicno zvuci/radi,sto je ujedno i jedina uloga ovih videa.
https://www.youtube.com/watch?v=YuQRWOJOmPA
https://www.youtube.com/watch?v=cYzQLhi9ZZA
https://www.youtube.com/watch?v=ifn38RYDdQg
Specifications:
Solid-state Remote-controlled Integrated Amplifier
Construction
Enclosure Cyrus Inverted die-cast chassis
Material Lightweight alloy and non-magnetic material throughout
Electrical
Line inputs 6 Line + 1 Tape
Outputs Bi-wire Loudspeakers, Tape-out, Preamp-out, Headphone
Power Supply 330VA Toroidal transformer with 5 regulated rails
External Highly regulated PSX-R upgradeable
Communications MC-BUS™ System BUS
Remote Control Supplied with Cyrus Amp/CD/tuner system remote control
Specifications
Continuous Power 70W/CH (both driven into 8 Ohms)
110W/CH (both driven into 4 Ohms)
Burst Power 340W (IHF, one channel driven into 1 Ohm)
Distortion 0.003%, 1kHz (into 8 Ohms)
0.005%, 1kHz (into 4 Ohms)
Frequency Response -3 dB, 0.2Hz and 85kHz
Damping Factor (1kHz) 150
Sensitivity (50W) Line: 200mV
Input impedance 50kOhm (RCA).
Output voltage 200mV (Tape out), 380mV (Pre out)
S/N Ratio 101dBA (ref. 50W)
Channel Balance ±0.2dB (0dB to -63dB)
Volume control accuracy ±0.1dB (0dB to -63dB)
Dimensions (H x W x D) 73 x 215 x 360 (mm), 2.8 x 8.4 x14.1 (inches)
Weight 5.5kg
Finish Silver or Satin Black
      25,196
      305,969
