Majda Posted December 4, 2018 Report Share Posted December 4, 2018 Originalna i finalna verzja napajanja za 20W legendarnog konstruktora kaze (1 + 2) x 60000uF po grani. znaci 60000uF- R- 120000uF. I to za oba kanala. Nema nikakvih miliona uF http://www.kaschei.com/classa/hiraga3.htm JH licno u casopisu Laudiophile #15 Quote Link to comment Share on other sites More sharing options...
aaa zmaju! Posted December 4, 2018 Report Share Posted December 4, 2018 Quote Link to comment Share on other sites More sharing options...
anubisgrau Posted December 4, 2018 Author Report Share Posted December 4, 2018 OK pogledacu kad stignem, toliko se pominjalo kada sam poslednji put razmišljao o osvežavanju i odustao od toga. Quote Link to comment Share on other sites More sharing options...
hifista Posted December 4, 2018 Report Share Posted December 4, 2018 2 minutes ago, prophet said: Pa tu ima ceo istorijat da se napiše.Pokojni Hiroyasu Kondo, Peter Qvortrup, Audionote Japan, Audionote UK, Kondo... ovi iz videa mislim da su englezi, Qvortrupovi. Kondo je legendarni dizajner. Bez obzira na razmirice i raskol oko Audinote marke, mora se priznati da Audionote UK sledi slican holisticki pristup dizajnu od najsitnijih delova (trafoa, kondenzatora, otpornika...) do finalnog proizvoda, sto je danas retkost u audiju. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted December 4, 2018 Report Share Posted December 4, 2018 Andy Groove radi dizajn trafoa za AN UK, AN kitove i radio je po narudzbini za ekipu iz magazina Hi Fi World ( World Audio Design ili nesto skraceno sada, World Design ). Covek o kome se ne zna mnogo Quote Link to comment Share on other sites More sharing options...
dj.nik Posted December 4, 2018 Report Share Posted December 4, 2018 11 minuta ranije, anubisgrau said: Hvala na predavanju na poznatu temu ali ajde ovako, da jednom za svagda objasnim kad si se kao drveni advokat namestio. Moja Hiraga ima 1 farad po kanalu i to su originalni (po secanju) Sprague ili Phillips kondovi, mogu da dignem haubu da pogledam. Ne govorim o upotrebi fabričkih kondova. Govori se o krajcovanju kao modus operandiju. Zarđala podloška da da vintage šmek i "prosvira". Ono o cemu sam pisao, a i pomenuo kod Sćepe u emisiji (pa se u tome oni će znati zašto prepoznala cela jedna ekipica iako uopšte nije bilo reči o njihovim uratcima) je bio vrlo konkretan proizvod koji je bio na probi za kupovinu, uzeli smo ga na slušanje, okrenuli đir po parohiji da se utvrdi o čemu se radi, našli bukvalno gomilu smeća izvađenog iz ko zna čega, iz veša mašina, iz televizora, naduvele motor ranove, mrežni trafo sumnjivog stanja. Inžinjeri elektronike se krstili levom i desno, ajde to se ovde smatra negativnom odrednicom ali pominjem kao referncu. Inače forumski kolega ima raniju verziju tog uređaja urađenog u istoj garaži koji svira odlično pa smo bili zagrejani. Uvidom u iznutrice uz zaključak da je u pitanju bezbedonosni hazard mi odustajemo od kupovine, umesto nas uskače drugi iskusni forumski kolega kome se isto dopadao taj prethodni rad, koji na uočene stvari kao i ti odgovara lakonski sa smeškom. Radiće. U narednih par nedelja na spravi odlazi sve od toga dođavola, uz dim, smrad paljevine i slično iako je load bio sve samo zaguljen, i na kraju se operacija završava kompletnom zamenom svega u napajanju, preradom izlaznih trafoa (premotavanjem) i promenom tipa izlazne cevi. Ima slučaj opisan i od strane vlasnika na nekom od foruma, ne znam više gde. Znači preporuka, čitaj šta piše u tvom kvotu koji je zapravo moj: Ja mislim da je to elemetnarno poštovanje prema uređaju, bezbednost ukućana da ne pominjem. Eto toliko, pozdrav. Po ovom opisu poznajem i ja jednog servisera (khm) sa old-tajmer komponentama na kanalu tj. policama i fiJokama . Nije me bas previse kostala neophodna naknadna intervencija ali je iskustvo duboko urezano. Bice da je i kod tebe to slucaj. Hiraga kao Hiraga nije cilj price vec samo kao opis potrebe da se veliki kapaciteti ubrzaju malim bajps kondenzatorcicima. A kao sto vidis, ipak je tvoja Hiraga uradjena pogresno jer ti ne treba tih 1F kapaciteta, a sve po originalnoj schemi Jeste da imam dobru zalihu Sprague tegli ali doci cu i po taj tvoj visak, ako nemas nista protiv ... Quote Link to comment Share on other sites More sharing options...
anubisgrau Posted December 4, 2018 Author Report Share Posted December 4, 2018 53 minuta ranije, Majda said: Originalna i finalna verzja napajanja za 20W legendarnog konstruktora kaze (1 + 2) x 60000uF po grani. znaci 60000uF- R- 120000uF. I to za oba kanala. Nema nikakvih miliona uF http://www.kaschei.com/classa/hiraga3.htm JH licno u casopisu Laudiophile #15 digo sam haubu majda je u pravu kod mene su general electric elektroliti 6 x 60,000, tri po strani verovatno sam bio prezupčio sa tim mitovima o faradima, mada kod JH na semi za 30W verziju mislim da stoji 1.3 farada i setio sam se zašto nisam osvežavao, zato što su osveženi u međuvremenu. a za majdu, ko je u pravu.... Quote Link to comment Share on other sites More sharing options...
Majda Posted December 4, 2018 Report Share Posted December 4, 2018 Uvek je tako bilo i bice... (ovo iz poslednje recenice) Quote Link to comment Share on other sites More sharing options...
miletrosak1959 Posted December 4, 2018 Report Share Posted December 4, 2018 1 sat ranije, anubisgrau said: digo sam haubu majda je u pravu kod mene su general electric elektroliti 6 x 60,000, tri po strani verovatno sam bio prezupčio sa tim mitovima o faradima, mada kod JH na semi za 30W verziju mislim da stoji 1.3 farada i setio sam se zašto nisam osvežavao, zato što su osveženi u međuvremenu. a za majdu, ko je u pravu.... Sure I'm a middle-aged fussy kind of audiophile, yet really it wasn't only something aesthetic-related... the 30W 1,5 Farads caps amp is a beast and sounding very, I mean VERY different from its smaller brother... ahem, frere...ORIGINAL LE CLASSE A. Quote Link to comment Share on other sites More sharing options...
Majda Posted December 4, 2018 Report Share Posted December 4, 2018 @miletrosak1959 Ćiji su uopste to navodi u postu? Ovo je najverovatnije (posto nije dovoljno jasno) potpuno drugi model od onoga o kome je ovde reč.Mi smo pisali o modelu 20W Ovo je mozda model Super 30W class A. Evo i originalne sheme. ALI bez sheme oroginalnog napajanja. Za ovaj model. Nisam uspeo da pronadjem... evo i linka sa kog je skinuta fotka. http://twogoodears.blogspot.com/2010/10/hiraga-frenzy.html Ljudi koji to prave, ne prave po originalnim shemama vec na svoju ruku menjaju vrednosti. Najcesce se povecavaju vrednosti C u napajanju. EVO tacnih Navoda jednog DIYra koji je na svoju ruku povecao, vrednosti napona napajanja sa 24V na 35V! Snagu na preko 50W i C na 6 x 220000uF. Tako da se to ne moze vise smatrati originalnom konstrukcijom. My version of the Jean Hiraga Super Class-A Amplifier is running at a bias of about 1.65A @ 35V resulting in about 58W of continuous dissipation per transistor in the output stage (just over 1/3 their rating of 150W). As you can imagine, the heat sink runs quite hot, approximately 40 Celsius (100F) above room temperature. The enclosure work is all done by hand using aluminum. Channel sides, 3 mm top plate, 3 mm base plate. The heat sink is comprised of two pieces cut to size and is approx 420 x 180 x 35 mm. The fasteners are mainly countersunk stainless M5 or M3 stainless. Heat sinking was increased. The capacitor bank was also increased to six 220000 uF capacitors (yes that is 1.2 Farads). A 500VA potted toroid transformer was used for the supply. Jasno pise da je povecao na svoju ruku vrednosti C, to znaci da su originalne wrednosti bile manje. Ovde primetiti da navodi temperaturu 40 iznad sobne to znaci 60 - 65 stepeni. Tako je na ovaj nacin pokusao da ucini da stvarna temp deluje manja... Verovatno je to i vise od 65 stepeni... Naravno i jako mali trafo po kanalu je to 250W. A za tu snagu od preko 50W ide mnogo veci trafo i to PO kanalu. http://diyaudioprojects.com/Solid/Jean-Hiraga-Class-A-Amplifier/ Quote Link to comment Share on other sites More sharing options...
anubisgrau Posted December 4, 2018 Author Report Share Posted December 4, 2018 1 sat ranije, miletrosak1959 said: the 30W 1,5 Farads caps amp majda, piše ti gore, stavi naočare Quote Link to comment Share on other sites More sharing options...
dj.nik Posted December 4, 2018 Report Share Posted December 4, 2018 " Sunday, November 15, 2015 Thanking HiFiShark (great site!), I found - it was on last Friday, actually - a pristine, 100% original, unmodified, a truly sought-after piece of gear... years and years of search... also recently begging with a friend owning one, offering big money and... voilà, by chance, I found it. " http://twogoodears.blogspot.com/2015/11/hiraga-le-classe-30w-amp-i-today-found.html Malo li je 180.000uF (x2 = 360.000uF) za 8W ojacaloP? Quote Link to comment Share on other sites More sharing options...
anubisgrau Posted December 4, 2018 Author Report Share Posted December 4, 2018 Moje je 20W. Zvanicno L'Audiophile Amplificateur Hiraga Classe A. 8W se zove Le Monstre, 30W se zove Le Classe A. Jednom u 5 godina se pojavi ovakav komplet na prodaju (ovo veliko je moj amp), uvek odustanem sa obrazlozenjem koji ce mi to u zivotu, posle se kajem kao sada kada vidim ovu sliku. Cista istorija: Quote Link to comment Share on other sites More sharing options...
ab Posted December 4, 2018 Report Share Posted December 4, 2018 Le ovo, le ono Quote Link to comment Share on other sites More sharing options...
dj.nik Posted December 4, 2018 Report Share Posted December 4, 2018 Hiraga LeMonstre (8W), 2x5x52.000uF Quote Link to comment Share on other sites More sharing options...
zflazar Posted December 4, 2018 Report Share Posted December 4, 2018 auf, imaš sliku možda komobarice koja se greje? šalim se. ajd da manemo patkometriju i da se vratimo na topic, važi? Quote Link to comment Share on other sites More sharing options...
dj.nik Posted December 4, 2018 Report Share Posted December 4, 2018 Obrisano, sem lepog primera 'LeMonstre' 8W. Quote Link to comment Share on other sites More sharing options...
Majda Posted December 6, 2018 Report Share Posted December 6, 2018 Da uskocimo u sedlo. 1936. Western Electric TA-7331 sistem izvodljivo i danas kao koncept, sa replikama horni i horn drivera, malo teze sa originalnim jedinicama. Quote Link to comment Share on other sites More sharing options...
Majda Posted December 6, 2018 Report Share Posted December 6, 2018 pogledajte kako im izgleda skretnica. i koje su razlike u odnosu na ove danas. i zbog cega. Quote Link to comment Share on other sites More sharing options...
Majda Posted December 6, 2018 Report Share Posted December 6, 2018 Quote Link to comment Share on other sites More sharing options...
Majda Posted December 6, 2018 Report Share Posted December 6, 2018 Zanimljivo resenje WE ing ekipe za OB LF jedinicu. Ova krilca su dobra i to im je neki H frame. Ide 18in Field Coil. Ali ljudi su tu stavljali i 15in? Quote Link to comment Share on other sites More sharing options...
neskor Posted December 6, 2018 Report Share Posted December 6, 2018 Line Magnetic je radio nesto slicno https://www.line-magnetic.eu/en/products-line-magnetic-en/speakers-line-magnetic-en Quote Link to comment Share on other sites More sharing options...
Majda Posted December 6, 2018 Report Share Posted December 6, 2018 Sta im je to dole Onken? Jebote nisu u stanju da napisu na sajtu osnovne stvari. Ne samo Line Mag vesc skoro svi... Meni se cini da su kabinetu 2 zvucnika? Nadjoh an 18-inch speaker, the TA-7376 founded in a low-reflex load u specifikaciji model Bass driver: BA-18 Woofer diameter: 46 cm Quote Link to comment Share on other sites More sharing options...
neskor Posted December 6, 2018 Report Share Posted December 6, 2018 13 minuta ranije, Majda said: Sta im je to dole Onken? nesto tako The pavillon and its medium driver are replicas of the famous Western Electric 22A and the Western Electric 555W. The bandwith extends from 150 à 13kHz. In the bass, an 18-inch speaker, the TA-7376 founded in a low-reflex load. Finally the treble is entrusted to the LM-302, replica of inspiration Jensen. An input sensitivity of 105 dB for an impedance of 8 Ohms. Quote Link to comment Share on other sites More sharing options...
Majda Posted December 6, 2018 Report Share Posted December 6, 2018 Ili je to onaj Supravox-ov dizajn pre onkena? Dobra im ta 18ica Iz drugog njihovog modela from the back Sudeci po fotografiji membrane, to je izgleda recone iili samo membrana od 18in Jensen Field Coil Drivera? On ima taj karakteristicni dust cap i takvo vesanje? Dok korpa i naravno permanentni magnet nisu. Najverovatnije pravljeni... Quote Link to comment Share on other sites More sharing options...
