Majda Posted December 18, 2018 Author Report Share Posted December 18, 2018 Doktore primi me na terapiju ... Sta da ti kazem, toliko su dobro ocuvani da nisma moga oda odolim. Sasvim impulsivna reakcija. 4 omski su pa zbog toga 4 x. (Da mogu da se povezu recimo serijski pa da to bude neka normalna impedansa...). Ako stignem izmericu transfer i TS parametre ovih dana. (Mada mi je, iskreno, pun Q merenja)... Quote Link to comment Share on other sites More sharing options...
prophet Posted December 18, 2018 Report Share Posted December 18, 2018 U dobrim su rukama zavrsili. Sada imas sve x4. Boles. Sto se snage tice mislim da su 6W a ne 8W. To je dovoljno izdrzljivo. Nece to da zakrklja u tom opsegu. Deklarisani na 65Hz-9kHz. Quote Link to comment Share on other sites More sharing options...
Majda Posted December 18, 2018 Author Report Share Posted December 18, 2018 Pa daj te podatke koje imas? Ja imam samo ove: Technical specifications Exact description: P1834 / 25 Construction year: 1964 Sine-duration power: 8 Watt Max. load-bearing capacity: 15 Watt Impedance Z: 4 Ohm (RDC=2.9 ohm + 3.0 ohm measured) frequency range: 50Hz to 20.000Hz Woofer : 180 x 340 mm Mid-range speaker: 130 x 180 mm High: 130mm Depth: 118mm Front plate (BxH) : 615 x 185mm Quote Link to comment Share on other sites More sharing options...
neskor Posted December 18, 2018 Report Share Posted December 18, 2018 Quote Link to comment Share on other sites More sharing options...
prophet Posted December 18, 2018 Report Share Posted December 18, 2018 Evo@neskor postavio. Quote Link to comment Share on other sites More sharing options...
Majda Posted December 18, 2018 Author Report Share Posted December 18, 2018 @neskor hvala. Ja gledao po katalozima ali po fotografijama. I nisam nasao da bilo koji lici a ne odgovara ni po dimenzijama? ALI nisam gledao oznake, Quote Link to comment Share on other sites More sharing options...
zflazar Posted December 18, 2018 Report Share Posted December 18, 2018 evo ideje za implementaciju Quote Link to comment Share on other sites More sharing options...
zflazar Posted December 18, 2018 Report Share Posted December 18, 2018 ...ili ovo... ? Quote Link to comment Share on other sites More sharing options...
prophet Posted December 18, 2018 Report Share Posted December 18, 2018 Lepo to izgleda, samo je neozbiljno Quote Link to comment Share on other sites More sharing options...
zflazar Posted December 18, 2018 Report Share Posted December 18, 2018 On 16.12.2018. at 10:33, Majda said: interesantni phase plugovi. Mi smo svojevremeno eksperimentisali sa njima na Lowteru EX2 sa raznim oblicima i udaljenošću plug-a od zvučnika. Plugovi su bili od drveta, distanceri plug-a od teflona, centralni brezon od mesinga. čak i najgora geometrija nepodešene distance takvog plug-a je dala bolje rezultate od fabričkog door-knob plug-a. Priznajem, nismo se setili da ubacujemo neki materijal sličan ovom tvom za kuhinjske vragolije ni u varijanti oblaganja ni u varijanti "međuprstenova" ko zna šta bi još iscedili iz mučenog Lowtera? Quote Link to comment Share on other sites More sharing options...
Majda Posted December 18, 2018 Author Report Share Posted December 18, 2018 Pa ovo bi trebalo da bude nesto sto daje suprotan efekat phase plug-u. Kao neki Mesh potato damping za direktivnost iz centra. i "secenje" onog visokog dela spektra koji driver ionako ne moze da odsvira a trudi se iz petinih zila. Jednostavno prevelika je masa pokretnog mehanizma za to... To se cuje kao neko neatikulisano sistanje? Slucajno sam to primetio posto sam postavio ovi polupropusnu krpu na mrezicu. Onda rekoh hajde da probam to direktno na driveru? Za lowther ide onaj kruskasti veliki plug koji "pojacava" visoki deo spektra od 10K pa nadalje. Najbolje od stiropora koji je impregniran pa izgitovan i osmirglan. Ili 3d printer. Da bude lagan. Mada on izlazi van linije drivera u prostor, pa je malo nezgodan. Nezgodno napraviti masku za takav driver... Quote Link to comment Share on other sites More sharing options...
Majda Posted December 19, 2018 Author Report Share Posted December 19, 2018 19 hours ago, zflazar said: ...ili ovo... ? Mogu ti reci da posle neposrednog iskustva sa Acoustically Damped Enclosure, OB kabinetom, vise uopste ne razmisljam o drugim tipovima OBa. Ravna ploca, Uframe, Hframe itd. Sve to radi osetno losije od ADEa. A i na merenjima se ponasa mnogo bolje. Sve rezonance, pikovi i rupe koje postoje na klasicnim OB se osetno umanje sa ADE otvorenim kabinetom. Quote Link to comment Share on other sites More sharing options...
hifista Posted December 19, 2018 Report Share Posted December 19, 2018 Ja nisam neki ljubitelj OB. Nekako mi je ispravan rezon da pozadinski talas drajvera treba da se uhvati i spreci da izadje napolje kroz kutiju i drajver. Quote Link to comment Share on other sites More sharing options...
prophet Posted December 19, 2018 Report Share Posted December 19, 2018 40 minuta ranije, hifista said: Ja nisam neki ljubitelj OB. Nekako mi je ispravan rezon da pozadinski talas drajvera treba da se uhvati i spreci da izadje napolje kroz kutiju i drajver. Možeš li da pojasniš ovo rezonovanje? Na šta konkretno misliš kada kažeš ovo za pozadinski talas? Na sve drajvere tj. opsege ili neki posebno? Quote Link to comment Share on other sites More sharing options...
hifista Posted December 19, 2018 Report Share Posted December 19, 2018 18 minutes ago, prophet said: Možeš li da pojasniš ovo rezonovanje? Na šta konkretno misliš kada kažeš ovo za pozadinski talas? Na sve drajvere ili neki posebno? Mislim na sve drajvere sa izuzetkom basa (za koji ne mogu da generalizujem zbog omnidirekcione prirode). Svo zracenje koje se generise iza drajvera reakcijom membrane treba uhvatiti. Jedan nacin je damping materijalom, ako uzmes kompresionu jako dampovanu kutiju, damping odradi svoje ali se dosta pozadinskih refleksija vrati na drajver. Ako bi kombinovao adekvatan damping sa oblikom kutije kod koje se nista ne reflekuje nazad (recimo kutije kao kod BW Nautilus) to bi bilo jos efikasnije. Ovaj Acoustically Damped Enclosure sto pomenu Majda mi izgleda kao slican nacin rezonovanja, sa laksom i manje fensi realizacijom. Quote Link to comment Share on other sites More sharing options...
hifista Posted December 19, 2018 Report Share Posted December 19, 2018 On 12/18/2018 at 11:24 PM, zflazar said: evo ideje za implementaciju Allaha mu, al su zeleni... Quote Link to comment Share on other sites More sharing options...
prophet Posted December 19, 2018 Report Share Posted December 19, 2018 Da, slažem se da je to postavljanje drajvera na dasku možda i najgori izbor. Dosta se toga podvodi pod OB. Ipak, postoje razrađene koncepcije koje itekako dobro rade. Pre svega u smislu bas dipola. Acoustically Damped Enclosure možda nije fensi ali je veoma elegantno i kvalitetno rešenje. Naravno uz određenu usaglašenost sa basovima. Imaš već postavljenu sliku na kojoj se jasno vide poređenja istog sa kompresijom itd. On 16.12.2018. at 10:40, Majda said: Quote Link to comment Share on other sites More sharing options...
hifista Posted December 19, 2018 Report Share Posted December 19, 2018 56 minutes ago, prophet said: Dosta se toga podvodi pod OB. Ipak, postoje razrađene koncepcije koje itekako dobro rade. Pre svega u smislu bas dipola. To bi voleo da cujem, morala bi da bude bas velika povrsina drajvera. 56 minutes ago, prophet said: Acoustically Damped Enclosure možda nije fensi ali je veoma elegantno i kvalitetno rešenje. Naravno uz određenu usaglašenost sa basovima. Imaš već postavljenu sliku na kojoj se jasno vide poređenja istog sa kompresijom itd. Koncept mi je logican i dopadljiv, to cu jednom da probam. Quote Link to comment Share on other sites More sharing options...
damic Posted December 20, 2018 Report Share Posted December 20, 2018 Majda, ima li sanse da vidimo spl odziv u sobi mereno mikrofonom sa mesta slusanja, jos bolje waterfall, do 200Hz bez smoothinga? Quote Link to comment Share on other sites More sharing options...
Majda Posted December 20, 2018 Author Report Share Posted December 20, 2018 16 hours ago, damic said: Majda, ima li sanse da vidimo spl odziv u sobi mereno mikrofonom sa mesta slusanja, jos bolje waterfall, do 200Hz bez smoothinga? Za SPL ima sanse. Ali ona kompjuterska amaterska merenja... A Waterfall mislim da ovi programi koje koristim nemaju (free verzije) i onako nema smisla, sem ako se ne zeli gledati haos od refleksija u sobi bez zavese i sa 4kvm stakla. Quote Link to comment Share on other sites More sharing options...
Majda Posted December 20, 2018 Author Report Share Posted December 20, 2018 On 12/19/2018 at 11:34 PM, prophet said: Da, slažem se da je to postavljanje drajvera na dasku možda i najgori izbor. Dosta se toga podvodi pod OB. Ipak, postoje razrađene koncepcije koje itekako dobro rade. Pre svega u smislu bas dipola. Acoustically Damped Enclosure možda nije fensi ali je veoma elegantno i kvalitetno rešenje. Naravno uz određenu usaglašenost sa basovima. Imaš već postavljenu sliku na kojoj se jasno vide poređenja istog sa kompresijom itd. Na ovoj fotografiji je ustvari Acoustical Resistance unit. (Na slici nije Acoustically damped enclosure, to su oni krugovi unutar U-frame kabineta.) Ono sto je problematicno na fotografije je to da je ARU veoma blizu drivera. Jordan u clnku za ARU kaze jasno da mora biti najmanje oko 35cm udaljen od drivera. Ne se cam se tacno treba prekontrolisati sta pise. Quote Link to comment Share on other sites More sharing options...
prophet Posted December 21, 2018 Report Share Posted December 21, 2018 Da, ja sam uneo zabunu. Da li si proveravao uticaj samo ARU, bez Acoustically damped enclosure? Quote Link to comment Share on other sites More sharing options...
Majda Posted December 21, 2018 Author Report Share Posted December 21, 2018 Nazalost to nisam mogao da uradim, posto sam vec postavio one koncentricne krugove unutar kabineta, A posto nisu na ramovima, nego zaheftani, nisam mogao da ih vadim i ponovo posle postavljam... Tako da sam prvo poslusao i izmerio Uframe, zatim ADE, i doao na kraju ARU. Quote Link to comment Share on other sites More sharing options...
damic Posted December 21, 2018 Report Share Posted December 21, 2018 7 sati ranije, Majda said: Za SPL ima sanse. Ali ona kompjuterska amaterska merenja... A Waterfall mislim da ovi programi koje koristim nemaju (free verzije) i onako nema smisla, sem ako se ne zeli gledati haos od refleksija u sobi bez zavese i sa 4kvm stakla. Mogu da preporucim izvanredan REW free program, ima sve: https://www.avnirvana.com/resources/ Quote Link to comment Share on other sites More sharing options...
Majda Posted December 21, 2018 Author Report Share Posted December 21, 2018 Koristim i taj REW za impedansu i TS parametre solidan je ali ima malo losiji interfejs i postoji verzija za OSX. Za transfer korisim Fuzzmeazure koji je jednostavan, pregledan i dobar. I Acoustictoolbox. Imam i neki Smaart ali je previse komplikovan. To je za ove PRO korisnike... Quote Link to comment Share on other sites More sharing options...
