giZ_Mo Posted November 13, 2018 Report Share Posted November 13, 2018 9 minuta ranije, Audio Doktor said: Nixi je u pravu А Ја као нисам! Quote Link to comment Share on other sites More sharing options...
Audio Doktor Posted November 13, 2018 Author Report Share Posted November 13, 2018 Just now, alI_Zée said: А Ја као нисам! I ti si u pravu , a sta ja kao nisam ? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 13, 2018 Report Share Posted November 13, 2018 Наравно да сам у праву као и увек. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted November 13, 2018 Report Share Posted November 13, 2018 Poslusaj da li se cuje okretanje tanjira ( tiho rmm rmmm rmmm ) ako se cuje treba podmazati ali treba manual za to. Na onoj slici, sta je phono sekcija ? Quote Link to comment Share on other sites More sharing options...
Audio Doktor Posted November 13, 2018 Author Report Share Posted November 13, 2018 4 minutes ago, Krca44 said: Poslusaj da li se cuje okretanje tanjira ( tiho rmm rmmm rmmm ) ako se cuje treba podmazati ali treba manual za to. Na onoj slici, sta je phono sekcija ? Phono sekcija je nagadjam bez seme , ova druga ploca , do prednje strane , do dugmica ,potova, a ova dola glavni amp . Gde su Vecu kondenzatori . Shaljem sliku ARW jer tj RAW ali trebalo bi da mozes otvoriti Quote Link to comment Share on other sites More sharing options...
Audio Doktor Posted November 13, 2018 Author Report Share Posted November 13, 2018 10 minutes ago, alI_Zée said: Наравно да сам у праву као и увек. Nismo ni sumljali Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 13, 2018 Report Share Posted November 13, 2018 Quote Link to comment Share on other sites More sharing options...
Krca44 Posted November 13, 2018 Report Share Posted November 13, 2018 Hvala ! Quote Link to comment Share on other sites More sharing options...
Audio Doktor Posted November 13, 2018 Author Report Share Posted November 13, 2018 A pored nje su ti potovi , posto su mi trebali malo bolji potovi za nesto ,nebitno ovako, pogledao sam sta ima , mislim da sam platio jedan mono pot , manjeg gabatita od tih , 1000din optrilike . To je gitarski valjda bio Ovi moraju biti bar toliko. Generalno sprava za ucenje i budzenje , restauraciju dusu dala . Pa mi treba ta sema , ali verovatno moze i bez nje , preko nekih univerzalnih, samo kako namestiti , bazdariti potove na ploci bez da znas koje voltaze treba da budu . Quote Link to comment Share on other sites More sharing options...
Nixie Posted November 13, 2018 Report Share Posted November 13, 2018 1 sat ranije, Audio Doktor said: Nixi je u pravu , bar ovi mali nisu, imao sam jedan sa 2 oma ESRa pri ruci sto sam izvadio kad sam ga popravljao i nije , wax paper cap Al i dalje nemam semu , znam otrpilike sta je vidi se , amp radi , ali mislio sam sa shemom da ga doteram u malo bolje stanje , ne mora ako nema od njega bas , ali neki phono preamp koji radi slicno, ili slican 2x20W , 4x Germanijum TO3 mislim da je paket ,trebao bi imati istu semu . Phono ne znam gde udaram , amp tu i tamo znam i bez seme . Zameni sve te elektrolite, očisti kontakte pomoću kontakt spreja, zameni potenciometre ako treba (ili ne diraj ništa ako ne krckaju) i to je to. Ostaje mehanika i eventualno neko friziranje kutije šmirglom i lakom ili čišćenje i voskiranje uz popravku sitnih oštećenja ako je izvodljivo. Glavno je pažljivo čišćenje. Nemoj slučajno da prskaš bilo šta sa WD40 naročito kontakte i pot. Ili gumeni točkić. Quote Link to comment Share on other sites More sharing options...
Nixie Posted November 13, 2018 Report Share Posted November 13, 2018 51 minuta ranije, Audio Doktor said: samo kako namestiti , bazdariti potove na ploci bez da znas koje voltaze treba da budu . Ja vidim samo dva pretpostavljam za mirnu struju. Proveri kolika je mirna struja, meriš napon na žičanim otpornicima pa podeli sa vrednostima otpornika. Quote Link to comment Share on other sites More sharing options...
Nixie Posted November 13, 2018 Report Share Posted November 13, 2018 1 sat ranije, alI_Zée said: Наравно да сам у праву као и увек. Dobro je to, ja nisam uvek Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 13, 2018 Report Share Posted November 13, 2018 1 minut ranije, Nixie said: Dobro je to, ja nisam uvek Труди се. Quote Link to comment Share on other sites More sharing options...
Nixie Posted November 13, 2018 Report Share Posted November 13, 2018 1 minut ranije, alI_Zée said: Труди се. Hoću, a ako ipak pogrešim praviću se kao da ništa nije bilo. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted November 13, 2018 Report Share Posted November 13, 2018 Mat gumenjak na tanjiru ima sa donje strane blize osovini kao neki jezicak kojim se kaci za metalni tanjir. Malo nezgodno kad se skine radi podmazivanja osovine ali nije frka vratiti ga. Sem tog podmazivanja i podesavanja rucke najbolje je ne dirati nista ispod sasije ( mehanika automatike ). U levom gornjem cosku gramofona je sraf koji sluzi da se zategne ( osovina / shasija ? zaboravio.. ) pri transportu a pri normalnoj upotrebi treba ga otsrafiti. Kad se otsrafi aktiviraju se federi subsasije i to pravilan mod za rad. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 13, 2018 Report Share Posted November 13, 2018 Ма дај подешавање ручке на том кршу. Оно може али ту иде најпримитивниоји Шур. Иначе фор д рекорд напајање излазног степена је једноструко. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted November 13, 2018 Report Share Posted November 13, 2018 21 minutes ago, alI_Zée said: Ма дај подешавање ручке на том кршу. Pa one osnovne stvari gazna sila / AS, pogledajte kako stoji teg na kraju rucke, ne treba tako. Te osnove kad se podese taj Shure roka, gruva bas , ritam za djuskanje Quote Link to comment Share on other sites More sharing options...
Audio Doktor Posted November 13, 2018 Author Report Share Posted November 13, 2018 2 hours ago, Nixie said: Zameni sve te elektrolite, Jako lepo izgledaju , mozda se preko slike ne vidi ,ali cak i prljavo kad sam otvorio , bilo je WOW, gre'ota je ditari , mislim nikad od ovoga nece biti HI END , a moze biti Origigi vintage . To mi je cilj , i da se stogod nauci . Fali mi 2 dugmeta ne znam bez da kupim identican za delove kako da ih nadjem, mozda da ih napravim I fali mu poklopac . Kolega sa foruma shalje glavu pa ce izgleda i pustati plocu , kako bude islo kacicu ja pa cemo videti sta se desava, bacicemo ga i na merenje , da vidimo kakav je shum i distorzija, znam da ce distorzije biti, al kakva je germanijumska nisam do sad video. Quote Link to comment Share on other sites More sharing options...
Audio Doktor Posted November 13, 2018 Author Report Share Posted November 13, 2018 1 hour ago, alI_Zée said: Иначе фор д рекорд напајање излазног степена је једноструко. A sta je for D rokord napajanje izlaznog stepena , mozda je glupo pitati ali zvuci mi kao neko napajanje/kontola motora , jel moze to da se budzi? Quote Link to comment Share on other sites More sharing options...
Audio Doktor Posted November 13, 2018 Author Report Share Posted November 13, 2018 2 hours ago, Nixie said: Ja vidim samo dva pretpostavljam za mirnu struju. Proveri kolika je mirna struja, meriš napon na žičanim otpornicima pa podeli sa vrednostima otpornika. Mislim da i ima 2 , mozda jos 2 na Phono sekcji, za ove na ampu se secam da su krcali za medalju , ali to sam radio dosta ranije , bio je cist skroz , sad je opet u prasini toliko davno , pa cemo videti , Ako bude pevao iole lepo , kao sto se secam da je pevao , pa ulozicu da ga doteram jer nemam drugi Gramofon . KAd to propeva onda Lampaski preamp umesto ovog sto je unutra , pa nece biti potrebe za nekim lampasem na izlazu kad je vec lepo obojen germanijumom i lampom. Videcemo . Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 13, 2018 Report Share Posted November 13, 2018 20 minuta ranije, Audio Doktor said: A sta je for D rokord napajanje izlaznog stepena , mozda je glupo pitati ali zvuci mi kao neko napajanje/kontola motora , jel moze to da se budzi? Quote Link to comment Share on other sites More sharing options...
Delija Posted November 13, 2018 Report Share Posted November 13, 2018 Quote Link to comment Share on other sites More sharing options...
Krca44 Posted November 13, 2018 Report Share Posted November 13, 2018 Nemo' se zaj.....te bice broadcast makina kad se sredi Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 13, 2018 Report Share Posted November 13, 2018 Aha. Quote Link to comment Share on other sites More sharing options...
Audio Doktor Posted November 14, 2018 Author Report Share Posted November 14, 2018 mislim da sam nasao semu, moram jos da proverim ali izgleda tako , izgleda da je ovo samo push oba izlaza su NPN ,tako sam i mislio jer u to vreme , PnP je bio skup Znaci nema crossover distorzije bar ne na izlazu , ali zato ima ogromne kondenzatore da ne bi DC probio zvucnike , ili trafo Izgleda da ce ovakav dizajn da profitira od kvalitetnih izlaznih kondenzatora , moracu dati 100e za Bakarne il nesto Znao sam po zvuku odma da je to nesto drugacije nego uobicajeno , e sad samo jos d askontam sta svaki deo radi , vecinom mi je to tu jasno , feeback u sredini sa 2n3053, tu mi se zamuti ne mogu da ispratim sve , mada kasno je , mozda bolje skontam kasnije . ako znate pojasnjavajte , pomagajte . Quote Link to comment Share on other sites More sharing options...
