Father Posted November 21, 2018 Report Share Posted November 21, 2018 10 minuta ranije, dadoo said: Mogu samo da zamislim sta bi se desilo da sednem i podignem jedan mint Messerschmitt Samo mojne preko Voždovca, leti ka Gardošu uz reku, ima tamo livada sa desne strane reke, koliko voliš zaaaa…. znaš već šta. Quote Link to comment Share on other sites More sharing options...
perodeformero Posted November 21, 2018 Report Share Posted November 21, 2018 Pa kako da dođe do Jajinaca nego preko Voždovca? Quote Link to comment Share on other sites More sharing options...
Father Posted November 21, 2018 Report Share Posted November 21, 2018 Šta treba da bombarduje u Jajincima? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 21, 2018 Report Share Posted November 21, 2018 4 minuta ranije, perodeformero said: Pa kako da dođe do Jajinaca nego preko Voždovca? Може и од стране Ресника. Quote Link to comment Share on other sites More sharing options...
perodeformero Posted November 21, 2018 Report Share Posted November 21, 2018 4 minuta ranije, Father said: Šta treba da bombarduje u Jajincima? Ma ništa, samo da proveri bezbednosnu situaciju. Ne bezbedonosnu. Quote Link to comment Share on other sites More sharing options...
dadoo Posted November 21, 2018 Author Report Share Posted November 21, 2018 Quote Link to comment Share on other sites More sharing options...
Father Posted November 21, 2018 Report Share Posted November 21, 2018 Hahahaha Kengur! Vrh, …. imao sam par ortaka, ovakvih blejača, vrlo autentično za moj kraj, pa i vanemaljci Neki od ovih likova, iz mog komšiluka, sada kreiraju nove sorte jabuka po visoko tehnološki projektovanim voćnacima … Bilo je i vanzemaljaca i otmica, siguran sam u to. Quote Link to comment Share on other sites More sharing options...
Delija Posted November 21, 2018 Report Share Posted November 21, 2018 1 sat ranije, alI_Zée said: Скидам капу докторе, крени да правиш имаш моју подршку и немој да се појављујеш док не направиш. Nice try Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 22, 2018 Report Share Posted November 22, 2018 14 sati ranije, Father said: Šta treba da bombarduje u Jajincima? Блу Лајн. Quote Link to comment Share on other sites More sharing options...
Father Posted November 22, 2018 Report Share Posted November 22, 2018 56 minuta ranije, alI_Zée said: Блу Лајн. Nemoj tu da biješ, tamo su raspoređeni "Блу" šlemovi. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 22, 2018 Report Share Posted November 22, 2018 6 minuta ranije, Father said: Nemoj tu da biješ, tamo su raspoređeni "Блу" šlemovi. Ок, Јајинцифор. Quote Link to comment Share on other sites More sharing options...
nemcha83 Posted December 2, 2018 Report Share Posted December 2, 2018 Pozdrav svima! Novi sam član, i izvinjavam se ako upadam u temu ali obzirom da je naziv recap, da ne pravim novu temu bez veze jer mi treba savet upravo iz ove oblasti pa ću postaviti pitanje ovde, ako može:). Naime, juče su mi stigli zvučnici Magnat Art 144408b i risiver Yamaha RX v465. Nakon povezivanja i puštanja u pogon, primetio sam da visokotonci ne rade. Nakon guglanja utvrdio sam da može biti ili da su riknuli zvučnici ili na skretnicama kondenzatori ili otpornici...Da bih testirao zvučnike, odšrafio sam ih i odvojio od žica i uz pomoć 2 parčeta žice i baterije koju sam nakratko povezao na terminale od zvučnika, utvrdio sam da prilikom kontakta sa baterijom šušte što bi trebalo da znači da rade i da je problem u skretnicama. Kada sam izvadio skretnice, na njima mi deluje da su otpornici na koijma piše 5watt 3.3 ohm nagoreli...Da li to znači da moram njih da odlemim i zalemim iste takve ili sam negde pogrešio u dijagnostici? Inače sve zajedno me je koštalo 100eur, tako da nije nešto strašno pa ću se usuditi da sam sve odradim jedino mi treba savet šta da koristim od delova za zamenu. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted December 2, 2018 Report Share Posted December 2, 2018 Н83, мало је све то конфузно дај бар неку слику. Quote Link to comment Share on other sites More sharing options...
Body Posted December 2, 2018 Report Share Posted December 2, 2018 1 hour ago, nemcha83 said: Pozdrav svima! Novi sam član, i izvinjavam se ako upadam u temu ali obzirom da je naziv recap, da ne pravim novu temu bez veze jer mi treba savet upravo iz ove oblasti pa ću postaviti pitanje ovde, ako može:). Naime, juče su mi stigli zvučnici Magnat Art 144408b i risiver Yamaha RX v465. Nakon povezivanja i puštanja u pogon, primetio sam da visokotonci ne rade. Nakon guglanja utvrdio sam da može biti ili da su riknuli zvučnici ili na skretnicama kondenzatori ili otpornici...Da bih testirao zvučnike, odšrafio sam ih i odvojio od žica i uz pomoć 2 parčeta žice i baterije koju sam nakratko povezao na terminale od zvučnika, utvrdio sam da prilikom kontakta sa baterijom šušte što bi trebalo da znači da rade i da je problem u skretnicama. Kada sam izvadio skretnice, na njima mi deluje da su otpornici na koijma piše 5watt 3.3 ohm nagoreli...Da li to znači da moram njih da odlemim i zalemim iste takve ili sam negde pogrešio u dijagnostici? Inače sve zajedno me je koštalo 100eur, tako da nije nešto strašno pa ću se usuditi da sam sve odradim jedino mi treba savet šta da koristim od delova za zamenu. Pre svega kakav si ti majstor amater kad nemas multimetar ili ti unimer pa proveravas sa sijalicom, drugo skines nagorele delove vidis vrednosti na njima i odes u radnju i trazis kvalitetne sa istim vrednostima ili poručis preko neta. Nadam se da imas bar kvalitetniju lemilicu kad se vec igras majstora.Osim toga nisi rekao da li te je preprodavac prevario ili ti je rekao da visokotonci ne rade. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted December 2, 2018 Report Share Posted December 2, 2018 Мислим да је проблем озбиљније природе и у помоћ ипак треба позвати "Доктора". Quote Link to comment Share on other sites More sharing options...
nemcha83 Posted December 2, 2018 Report Share Posted December 2, 2018 Ja sam u Odžacima, i majstora za te stvari ovde nema. E sad koliko se isplati da ove zvučnike nosim ili šaljem na popravku, ne znam.. Mislio sam da prvo probam da skinem te nagorele otpornike i zamenim ih novim kvalitetnim istih vrednosti, pa ako ne dobijem time ništa da onda razmišljam o servisu. Da li mogu da napravim neku veću štetu ako odradim tu zamenu? Zašto vam zvuči kao ozbiljniji problem? Quote Link to comment Share on other sites More sharing options...
nemcha83 Posted December 2, 2018 Report Share Posted December 2, 2018 U obe skretnice je ista situacija, ima po jedan kondenzator i po jedan otpornik i po dva kalema. Sve deluje OK osim otpornika koji su sa jedne strane crni, inače su beli.. Tako da na obe kutije imam isti problem, ne rade tweeteri:(. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted December 2, 2018 Report Share Posted December 2, 2018 За пробу премости отпорнике али не одврћи. Quote Link to comment Share on other sites More sharing options...
nemcha83 Posted December 2, 2018 Report Share Posted December 2, 2018 Mogu da pretpostavim kako zvučim ali kako da premostim? Lemio sam nekoliko puta da sada razne stvari, potenciometre u gitari, led diode... ali nikada ovako nešto. Pretpostavljam da izvadim ove otpornike i na njihovo mesto ubacim komad žice, jel? Quote Link to comment Share on other sites More sharing options...
bokyy Posted December 2, 2018 Report Share Posted December 2, 2018 Jel to ova skretnica Quote Link to comment Share on other sites More sharing options...
nemcha83 Posted December 2, 2018 Report Share Posted December 2, 2018 Evo sad ću slikati.. Quote Link to comment Share on other sites More sharing options...
nemcha83 Posted December 2, 2018 Report Share Posted December 2, 2018 Quote Link to comment Share on other sites More sharing options...
bokyy Posted December 2, 2018 Report Share Posted December 2, 2018 ne vidim dobro,to se izgleda nesto razletelo, pravo je cudo da tebi drajveri budu ispravni moras imati instrument, tu kao da je jedan kond explodirao to se obicno desi kad tranzistor probije na pojacalu i pusti pedesetak volti mislim da moras da proveris drajvere da nisu nagoreli a onda da skretnicu radis Quote Link to comment Share on other sites More sharing options...
bokyy Posted December 2, 2018 Report Share Posted December 2, 2018 slikaj drugu skretnicu Quote Link to comment Share on other sites More sharing options...
