Krca44 Posted October 18, 2018 Report Share Posted October 18, 2018 Pa sacekaj par meseci i poslusaj sta ima do tad. S vecim budzetom imas i nesto siri izbor. Tebi je pored snage zapravo bitno kako se ta snaga prevodi u kontrolu zvucnika, slusanje bi bilo preporucljivo. Naim pojacala na papiru nisu snazna ( ona osnovna ) al' prica se da rade dobro u smislu kontrole, mozda vredi raspitati se ovde kod "republikanaca". .......... Sa 4 Omskim bi trebalo da pakuje vise struje ako je dobro izradjeno napajanje ( teorijski ), u praksi probas sta bolje ide 8 ili 4 oma. Quote Link to comment Share on other sites More sharing options...
vladat1 Posted October 18, 2018 Report Share Posted October 18, 2018 1 sat ranije, Aoxomoxoa said: Yamaha a s-501 je u 4Audio 440e, a Rega Brio(2017) 780e.Novo. i ovo je novo. Šverc od Mađara Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted October 18, 2018 Author Report Share Posted October 18, 2018 @vladat1O kom pojacalu pricas? Quote Link to comment Share on other sites More sharing options...
goran_p Posted October 18, 2018 Report Share Posted October 18, 2018 Probaj Naim Nait 5 ili 5i Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted October 18, 2018 Author Report Share Posted October 18, 2018 Ima 4 ulaza,nema phono.A ja imam 5 uredjaja za slusanje:gramofon,cd,kasetofon,magnetofon i laptop.Koliko vidim,nema mogucnost povezivanja gole zice zvucnickih kablova,ili viljuske. Quote Link to comment Share on other sites More sharing options...
VU metar Posted October 18, 2018 Report Share Posted October 18, 2018 Juri neki snagaš, a sadašnji amp koristi kao preamp, ako ima tu opciju. Quote Link to comment Share on other sites More sharing options...
zek Posted October 18, 2018 Report Share Posted October 18, 2018 1 sat ranije, Aoxomoxoa said: phono ulaz je manje osetljivosti od line ulaza(sto mi je i prodavac potvrdio) Phono ulaz po svojoj strukturi mora biti mnogo osetljiviji od line ulaza (za MM je 3 mV a line je 200 mV). Moraš videti podatke za tvoju glavu na gramofonu koliki napon daje, pa uporediti sa ovim podacima za Yamahu. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted October 18, 2018 Report Share Posted October 18, 2018 Snagas je Pass 40 (?) diy ako se osvezi i stavi hladnjak na onaj jedan tranzistor sto greje ( vidi se na slici sa teme ) mozda bi mogao da radi dobro.... & full preamp ? Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted October 18, 2018 Author Report Share Posted October 18, 2018 Imam predpojacalo,lampasko,ali sam hteo sve u jednom. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted October 18, 2018 Author Report Share Posted October 18, 2018 2 minuta ranije, Krca44 said: Snagas je Pass 40 (?) diy ako se osvezi i stavi hladnjak na onaj jedan tranzistor sto greje ( vidi se na slici sa teme ) mozda bi mogao da radi dobro.... & full preamp ? Moze i tako.Mislio sam da iskoristim ovu verovatno poslednju mogucnost da potrosim ovoliko para,jer ne verujem da cu uskoro imati jos jednu priliku. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted October 18, 2018 Report Share Posted October 18, 2018 Kad bi mogao da utvrdis za pocetak nekako ( makar nosio zvucnike u salon ) da li Yamaha radi bolje od onog sto imas, pa da znas bar otprilike Quote Link to comment Share on other sites More sharing options...
VU metar Posted October 18, 2018 Report Share Posted October 18, 2018 Onda pažljivo, ne mislim da je 501 bog zna šta. Bolje vrebaj 1100 na ponudi ili uvoz, možda uskoro bude novi model pa padnu cene. I računaj da nijedna Yamaha nema tape monitor. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted October 18, 2018 Report Share Posted October 18, 2018 Ima li još koje pojačalo koje bi mogao da probaš ? Ja sam imao nekad Yamaha pojačalo, ima snagu ali pršti ... Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted October 18, 2018 Author Report Share Posted October 18, 2018 25 minuta ranije, zek said: Phono ulaz po svojoj strukturi mora biti mnogo osetljiviji od line ulaza (za MM je 3 mV a line je 200 mV). Moraš videti podatke za tvoju glavu na gramofonu koliki napon daje, pa uporediti sa ovim podacima za Yamahu. Ortofon 2M Blue - 5.5mV Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted October 18, 2018 Author Report Share Posted October 18, 2018 19 minuta ranije, VU metar said: Onda pažljivo, ne mislim da je 501 bog zna šta. Bolje vrebaj 1100 na ponudi ili uvoz, možda uskoro bude novi model pa padnu cene. I računaj da nijedna Yamaha nema tape monitor. Ja bih mogao da pazarim i a s-801,ali nisam siguran da je zvucno bolja.Ima ugradjen DAC,ali ga ja vec imam(M2Tech). A S-1100 je vec ozbiljna zver(501=10kg, 1100=23kg.).Cena je 1.700e,tesko da ce skoro ispod 1.000e. Ne mora da ima tejp monitor,ali Dayens Menueto nema ni tape out. Quote Link to comment Share on other sites More sharing options...
zek Posted October 18, 2018 Report Share Posted October 18, 2018 7 minuta ranije, Aoxomoxoa said: Ortofon 2M Blue - 5.5mV Onda nema problema. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted October 18, 2018 Author Report Share Posted October 18, 2018 Ipak ce raditi tise od cd-a na istoj jacini? Quote Link to comment Share on other sites More sharing options...
Krca44 Posted October 18, 2018 Report Share Posted October 18, 2018 Iskreno snimanje na magnetofon verovatno ima smisla al' trake nisu jeftine. Kazetne vrpce... kako kad, Tanberg dek treba servisirati ( nije jeftino ). Mislim realno treba dobro razmisliti da li ces se zaista baviti snimanjem kaseta ili je to samo zelja koja moze brzo da prodje ( vrlo malo sam snimao realno, imam nesto malo neotpakovanih traka koja postaju suludo skupe, imam odlican dek koji vec godinu dana ceka da ide na servis i drugi koji povremeno utaknem za slusanje, snimanje je jako redak dodgadjaj kod mene ). .......... Da li ce phono ( ploce ) biti isto tako glasne kao CD zavisi kako je proizvodjac uklopio pojacanje signala na ulazu i linijsko predpojacalo... mislim treba da budu bar priblizne glasnoce a ako nije tako onda rade kao da su i dalje u praistoriji ( ako nisu prilagodili izlaz iz phonoa da bude slicne jacine signalu koji dolazi iz CDa, a na ulazu u line ). Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted October 18, 2018 Report Share Posted October 18, 2018 Da ne kazu zli jezici da nudim svoje, evo hvalim tudje https://www.kupujemprodajem.com/Audio/Pojacala/Creek-Evolution-50A-V2--67444461-oglas.htm?filter_id=265742835 Creek Evolution 50A Slusao Creek Evolution 100A na Harbeth 5 nesto.... dobra sinergija. Solidna revija na Stereophile sajtu za Creek Evolution 50A https://www.stereophile.com/content/creek-evolution-50a-integrated-amplifier Quote Link to comment Share on other sites More sharing options...
VU metar Posted October 18, 2018 Report Share Posted October 18, 2018 Koji je class A amp koji koristiš? Nisi li imao i neki Tandberg? Quote Link to comment Share on other sites More sharing options...
violent femmes Posted October 18, 2018 Report Share Posted October 18, 2018 @Aoxomoxoa Ja bih na vasem mestu sa tim kutijama probao Exposure 3010. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted October 18, 2018 Author Report Share Posted October 18, 2018 Snimanje na magnetofon i kasetofon u principu danas nema mnogo smisla(imalo je kada nije postojao cd i hard disk) Ali sam cin snimanja i reprodukcije ne moze se platiti komforom slusanja vise terabajta sa harda. Prodavac u 4Audio mi je rekao da sva pojacala imaju takav odnos phono i line, Quote Link to comment Share on other sites More sharing options...
Krca44 Posted October 18, 2018 Report Share Posted October 18, 2018 Exposure 2010 je dobar, to sam slusao Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted October 18, 2018 Author Report Share Posted October 18, 2018 7 minuta ranije, VU metar said: Koji je class A amp koji koristiš? Nisi li imao i neki Tandberg? Pravljen snagas po semi Pass 40a,osiromasena verzija(sta god znacilo). Davno sam imao Tandberg TR 2055. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted October 18, 2018 Report Share Posted October 18, 2018 Creek Evolution 100A što kaže Sima, ako zvuči kao moj Creek Evo 2 a ima 30% više snage to je odlično ... Quote Link to comment Share on other sites More sharing options...
