Vlajo Posted October 6, 2018 Report Share Posted October 6, 2018 Tačno, sa tim što se moj se post odnosio na tvikovanje audio računara slabe snage Quote Link to comment Share on other sites More sharing options...
vladat1 Posted October 6, 2018 Report Share Posted October 6, 2018 Može 1920 x 1080 sasvim fino. Na tome i koristim. Quote Link to comment Share on other sites More sharing options...
Iron man Posted October 6, 2018 Report Share Posted October 6, 2018 Kako (hardverski i softwerski) povezati (touch recimo) mali display ( i koji ) na PC koji glumi audio server? Da se dobije look i funkcionalnost npr ovakvog servera Ne mora da to bude jedini UI. Moze i sa tableta da se upravlje serverom ali da na ovome prikazuje omot, naziv, progres bar ,.... Moze da bude i poseban displejcic, ne mora ugradni. Cisto teorijsko pitanje, sta i kako. Secondary display ili ....? Quote Link to comment Share on other sites More sharing options...
dj.nik Posted October 6, 2018 Report Share Posted October 6, 2018 Ako su oba racunara pod Windows-om onda koristis LAN vezu i RDC - Remote Desktop Connection. Drugi racunar - 'kontrolni' moze biti standardni PC ili tablet, sve jedno je, po zelji. Na kontrolnom PC-u vidis intefejs aplikacije koja je zaduzena da pusta muziku. Na Linux-u imas takodje vise resenja, pominje se npr. Remmina, zatim VNC (TigerVNC, RealVNC, Team Viewer itd,) Za ovu srebrnu lutkicu (OS je specijalizovani Linux) imas dve mogucnosti: android aplikaciju (Novatron MusicX) ili web-interfejs (koji moram da priznam nije bas najlepsi - radili ga nemci al'se nisu nesto iskazali) Edit: android aplikacija na pametnom telefonu ili na tablet racunaru pod android OS-om naravno. Quote Link to comment Share on other sites More sharing options...
dj.nik Posted October 6, 2018 Report Share Posted October 6, 2018 Ko voli serverska resenja, izasao je Windows Server 2019 a prvi korisnici kazu da 'zvuci' odlicno. https://cloudblogs.microsoft.com/windowsserver/2018/10/02/windows-server-2019-now-generally-available/ https://www.microsoft.com/en-us/evalcenter/evaluate-windows-server-2019 i za 'Core' instalaciju: https://docs.microsoft.com/en-us/windows-server/get-started-19/install-fod-19 Quote Link to comment Share on other sites More sharing options...
Iron man Posted October 6, 2018 Report Share Posted October 6, 2018 Nismo se razumeli. PC ima dva grafi;ka porta. DP i VGA. DP ide na TV a VGA je prazan. Na TVu se izabere plejlista ili folder ( vise njih) i startuje PLAY. TV se ugasi.User Interfejs radi preko tableta Sve preko tableta ide dalje. Ali hocu da imam ono ekrance (kao na srebrnoj lutkici sto rece). Kakvo je to, gde se nabavlja i kako se povezuje na PC(hardverski)? kako mu se aplikacija obraca? Ocu tamo VU metri da mi igrav ili ono klasicno, omot, naziv, progres bar,... Quote Link to comment Share on other sites More sharing options...
dj.nik Posted October 6, 2018 Report Share Posted October 6, 2018 Osnova svih takvih masina je neka maticna ploca sa centralnim i video procesorom. Kod srebrenka mozes da izaberes prikazivanje omota, spisak numera pa i tekstove pesama ako se album nalazi u onlajn bazi CD-ova - freedb.org. Imas i HDMI izlaz pa se slika i kompletan meni (opcije) moze prikazivati na TV-u. Kako se radi o embeded OS-u, nije dozvoljeno korisniku da ubacuje svoje aplikacije. A fin VU-metar sa horizontalnim trakama postoji, imas ga npr kada S/PDIF signal saljes na neki eksterni uredjaj ili kada presnimavas ploce na interni HDD. Quote Link to comment Share on other sites More sharing options...
Iron man Posted October 6, 2018 Report Share Posted October 6, 2018 Hocu da nasvajsujem neki ovakav PC https://www.team-mediaportal.com/wiki/display/MediaPortalHTPC/Marcus+Venturi's+Custom+HTPC+Case+with+Amp Open arhitekture a ne embeded sistem (zatvoren za izmene). Verovatno ce vrteti JRiver. UI sa tableta. TV za inicijalno pu[tanje. Samo gde nabaviti i kako prikljuciti ovakav mali TFT? Quote Link to comment Share on other sites More sharing options...
nenad Posted October 6, 2018 Report Share Posted October 6, 2018 On 4.10.2018. at 11:42, RingeRaja said: Ima smisla Delija, veruj mi. Prvo, hoću Audio Player, a on radi samo na Win-u. DAC ima drajvere za Linux, radi, ali mora drugi plejer. Drugo, igrajući se sa servisima primetio sam drastičnu razliku u zvuku kad neki servisi koji po defaultu rade isključim. U pitanju je prilično dobra mašina, 4770K/16GB, na kojoj nije instalirano ništa osim drajvera za DAC i dotičnog plejera. Eto...može da se tweakuje i ima boljitaka. http://albumplayer.ru/linux/ Quote Link to comment Share on other sites More sharing options...
garson Posted October 6, 2018 Author Report Share Posted October 6, 2018 17 sati ranije, Delija said: Ne dokazujes nista, vec pomazes meni da vidim koliko je i da li je uopste "svetlije" zelen od mog rezultata na "obicnom" Windows-u, bez ikakvih optimizacija i sa gomilom rezidentnih aplikacija. Naravno, i ostali ljudi koje to zanima mogu isto da urade. Mislim da ne bi bila velika pomoc jer se porede razliciti sistemi, u hardverskom smislu. Naravno, jak hardver ce lako da "tera" real-time audio. Moja poenta za LatencyMon je da on moze da "oseti" promene nakom optimizacije. Quote Link to comment Share on other sites More sharing options...
garson Posted October 6, 2018 Author Report Share Posted October 6, 2018 10 sati ranije, dj.nik said: Da ste se potrudili da procitate (uz google translate) onaj japanski blog - imali bi vecinu stvari resene i bez dodatnih softvera nalik BlackBox itd. Drugi nacin je upotreba besplatne verzije Fidelizer-a i takodje besplatne verzije Process Lasso koji ce postici recimo 90% optimizacije placenih softvera. Ostalih 10% je kao u visokom audio segmentu - necije znanje i ulozeno vreme / resursi mora de se plati. Ja sam procitao, detaljno, uz google translate, jako dobro uputstvo, na jednom mestu. Doduse, on je radio izmene na running OSu, licno preferiram izmene u samom ISO image-u. Takodje, dobro je odradio gasenje servisa, mada vidim da je i on naleteo na par servisa koji zeznu explorer. E sad, da sam imao volje, pa da sam pisao sve sto sam radio, rado bih postovao na forumu. Quote Link to comment Share on other sites More sharing options...
misko1989 Posted October 6, 2018 Report Share Posted October 6, 2018 I za win10 nema potrebe opterecivati komp dodatnim antivirusima. Njegov radi posao sasvim dovoljno. Quote Link to comment Share on other sites More sharing options...
garson Posted October 6, 2018 Author Report Share Posted October 6, 2018 @siroma I ja sam razmisljao (tj i dalje razmisljam) o necumu slicnom, mada nisam svajser. Ideja mi je bila da imam mali monitor, tipa 10 inca, gde bi mi se prikazivao omot i koja pesma ide, i slicno. Nije problem naci takav displej, tipa HDMI ili sta vec, niti je problem povezati, mislim da bi to bio samo drugi displej (bar u mom sistemu, kad slusam muziku). Nesto ovako: https://www.amazon.com/Raspberry-Screen-10-1-IPS-SunFounder/dp/B07FZZ95WN/ref=sr_1_16?ie=UTF8&qid=1538852437&sr=8-16&keywords=10.1+inch+monitor https://www.amazon.com/Portable-Monitor-Resolution-2560x1600-Raspberry/dp/B07GDDG3WJ/ref=sr_1_20?ie=UTF8&qid=1538852505&sr=8-20&keywords=10.1+inch+monitor Jedino ostaje pitanje kako "nabudziti" zeljeni prikaz na tom monitoru al to je kontam vise do softvera. Pogledao sam url, vidim pominje neki USB relay board. A vidim da koristi neki MediaPortal media center softver. Vidim ima i tema na tom forumu https://forum.team-mediaportal.com/threads/my-aluminium-case.117909/ Mozda tu ima detalja kako je nabudzio. EDIT: On je ovde uzeo displej (ostavio je url), nesto ovako. https://www.aliexpress.com/store/product/7-0-inch-TFT-lcd-module-800-480-RGB-interface-with-VIDEO-VGA-input-for-car/600281_32824653768.html?spm=2114.12010612.8148356.28.469f1b9dxhktBq Displej, plus AD board, ekran ima flat kabl, i na plocicu VGA input. Quote Link to comment Share on other sites More sharing options...
dj.nik Posted October 6, 2018 Report Share Posted October 6, 2018 1 sat ranije, siroma said: Hocu da nasvajsujem neki ovakav PC https://www.team-mediaportal.com/wiki/display/MediaPortalHTPC/Marcus+Venturi's+Custom+HTPC+Case+with+Amp Open arhitekture a ne embeded sistem (zatvoren za izmene). Verovatno ce vrteti JRiver. UI sa tableta. TV za inicijalno pu[tanje. Samo gde nabaviti i kako prikljuciti ovakav mali TFT? Ti se vracas 10-tak godina unazad, kada je HTPC bio vrlo popularan. Bilo je vise cenjenih kucista, npr Zalman HD160XT pa Thermaltake DH202 (ekran na dodir) pa Silverstone CW03 itd. itd. Bese tema na DIYaudio sa svakojakim predlozima. Ali cemu to? Opet zaboravljas cinjenicu da je graficka karta veliko smetalo u namenskoj, audio masini. Ni izbor plejera ti nije bas najsjajniji - JRiver. Ali tebe izgleda ne privlaci toliko dobar zvuk koliko sarenilo raznih svetlecih i skacucih efekata, milion fotografija jednog te istog albuma (naravno skinuto via google, dok svira muzika). Kod srebrenka bar imas dugme da iskljucis ekran. Kod ovih HTPC-a se secam upravo problema da kroz neku tamo njihovu aplikaciju za monitor - ne mozes da iskljucis kojekakve efekte pa ni sam ekran. Ajde da pomenemo i Linux distro, mada je autor treda zamolio bez patkometrije Win-Lin: Euphony Stylus. Odvojen od Audiophile Linux distroa, autori su usli u komercijalni projekat, i to doobro skup u pocetku. Nije tema to vec uputstvo o potrebnoj masini: Nema graficke, nema tastature, nema misa. Bezglava, 'headless' masina za vrhunski zvuk. Isto je vec godinama sa besplatnom 'Vortexbox' distribucijom, ako neces njihove 'sazvakane' i podesene PC-je. Roon je takodje sladunjavi programcic koji ce ti ponuditi slicnu melodiju onome sto upravo slusas (iz tvoje kolekcije) pa ti prikazati sve podatke o autorima pesme/albuma koje moze da iscupa sa interneta. Garnirano lepim fotografijama. Ma super i sjajno. A sto se zvuka tice, ukratko: Roon izoblicava. Makar je tako bilo do izlaska najnovije verzije, nisam se zamarao previse. Kada usvojis koncept jedna 'svirajuca' masina gola golcijata (bezglava i sa minimumom delova ali napredna, sa linearnim napajanjem npr.) daljinski kontrolisana, i druga koja sluzi kao skladiste muzike a moze da bude i kontrolna, ili kontrolu imas via poveci tablet ekrancic / android mobilni, tek tada ces imati pravi digitalni audio sistem. Bolji od gramofona. Quote Link to comment Share on other sites More sharing options...
Iron man Posted October 6, 2018 Report Share Posted October 6, 2018 Vidi vako. Nisam rekao da je ovo ni jedino a ni najbolje resenje. Hoću da eksperimentišem i da isprovam sve i svašta. Pa da vidim šta mi najviše odgovara.Imam dva tri PCa koji mi rede kao izvori zvuka. Jedan je čak sa DC napajanjem , drugi klasični mini komp (I5 G7) bez išta(bez ekrana), upravljanje tabletom (i tu ima više načina. Ili aplikacija omogućuje remote ili Timvjuer ili RDC...) i sve je to OK. Dovoljno mi je da tabletomupravljam ne mora šareniš Igrao sam se čak i sa nekim MSI multimedijalnim PCem koji liči na ovog tvog ljubimca (Srebrnka)i koji ima klasičan displej na kućištu gde alfanumerički ispisuje numeru i vreme. Lepo, liči na muzičku komponentu, pali se na dugme... Ali me interesuje da napravim nešto kao Naim Uniti ili Coctail ( mada ima more sličnih uredjaja sa TFT displejom) Pa ako se pokaže da ne valja, u redu. Da ne bude da nisam probao. Klasičan švajser Više pitam da saznam kako se to pravi nego što mi mnogo treba. Al da je lepo, šareno, ciganjski,...To stoji BTW Naim nudi ISO fajl svog softvera. Nisam još probao da ga bootujem na klot PC. Pitanje je i da li je PC mašina u Naimu Quote Link to comment Share on other sites More sharing options...
garson Posted October 6, 2018 Author Report Share Posted October 6, 2018 @dj.nik Nije problem pominjanje linux-a, samo bih voleo da tema ne ode u raspravu, da ne kazem svadju, kako je win bolji od linux, ili linux od wina za ovu namenu. Quote Link to comment Share on other sites More sharing options...
Delija Posted October 6, 2018 Report Share Posted October 6, 2018 3 sati ranije, garson said: Mislim da ne bi bila velika pomoc jer se porede razliciti sistemi, u hardverskom smislu. Naravno, jak hardver ce lako da "tera" real-time audio. Moja poenta za LatencyMon je da on moze da "oseti" promene nakom optimizacije. Upravo to je i poenta - uz dovoljno jak hardver (a to je danas sasvim prosecan "gaming" PC) nema nikakve potrebe za bilo kakvim optimizacijama. Quote Link to comment Share on other sites More sharing options...
dj.nik Posted October 7, 2018 Report Share Posted October 7, 2018 @siroma Quote Link to comment Share on other sites More sharing options...
dj.nik Posted October 7, 2018 Report Share Posted October 7, 2018 Eno ti onaj kompjuter za Win10 - 'Lattepanda', 4G/64G memorije, plocica pored ostalog ima i displej port. 'Mouser' nudi razne TFT ekrane, ovaj 7" npr, podrzava 1024x600 rezoluciju sto je ihaha dovoljno. Eto osnove za igranje. Quote Link to comment Share on other sites More sharing options...
garson Posted October 8, 2018 Author Report Share Posted October 8, 2018 On 7.10.2018. at 0:15, Delija said: Upravo to je i poenta - uz dovoljno jak hardver (a to je danas sasvim prosecan "gaming" PC) nema nikakve potrebe za bilo kakvim optimizacijama. Ja ne bih izvukao takav zakljucak, bar iz LatencyMon-a. To sto 2 masine dobro hendluju real time audio, ne mora da znaci da podjednako dobro "zvuce". Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted October 10, 2018 Report Share Posted October 10, 2018 Opet će rasprava da li su jedinice i nule uvek samo jedinice i nule ili ne. U audio domenu nisu zato što postoji nešto što se zove korekcija greške i vreme, a što u slučaju zvuka igra bitnu ulogu. Quote Link to comment Share on other sites More sharing options...
garson Posted October 11, 2018 Author Report Share Posted October 11, 2018 Mislim da nisam eksplicitno naveo, ali se moglo videti sa screenshot-a servisa, Windows Audio i Windows Audio Endpoint Builder servisi su disabled, tako da wasapi u mom slucaju ne radi. No, to ne utice na ASIO i Kernel Streaming . Quote Link to comment Share on other sites More sharing options...
dj.nik Posted October 11, 2018 Report Share Posted October 11, 2018 Odlican - tako treba Quote Link to comment Share on other sites More sharing options...
garson Posted October 11, 2018 Author Report Share Posted October 11, 2018 Evo jedan opsirniji (bar sto se broja strana tice ) pdf sa nekim dobrim smernica oko podesava Win7/Win10 pod nazivom "An in-depth guide to tuning Windows for reliable real-time audio performance". https://www.cantabilesoftware.com/glitchfree/ Quote Link to comment Share on other sites More sharing options...
arnage Posted November 11, 2018 Report Share Posted November 11, 2018 Ako imaš USB DAC, ovim si ga osakatio... Quote Link to comment Share on other sites More sharing options...
