dusanbe Posted September 3, 2018 Report Share Posted September 3, 2018 Pozdrav svim ljubiteljima Hi-Fia. Moj prijatelj zeli da kupi nov gramofon. Kako ja nisam neki poznavalac a i korisnik ovog uredjaja predlozio sam mu da postavimo pitanje ovde. Zeli da kupi nov gramofon sa budzetom od 300 do 500EUR. Ostatak sistema cini Naim 5 i Naim CD5 sa zvucnicima Neat Motive 3. Koliko smo pogledali po netu, isticu se Rega Planar 1, ProJect Essential III ili model Debut III, AT LP5. Ostale modele nije video. Koji su vasi predlozi i sugestije? Unapred hvala. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 3, 2018 Report Share Posted September 3, 2018 Ok, ako mora baš da bude novo, evo pa pročitaj: http://www.gramofoni.com/novigram.html Ja bih se ipak nategao još malo i uzeo Rega RP3, ali tu je još dodatan trošak za glavu neminovan. Quote Link to comment Share on other sites More sharing options...
microfarad Posted September 3, 2018 Report Share Posted September 3, 2018 Definitivno od tih jeftinijih gramofona Rega RP3 je najbolji izbor! Quote Link to comment Share on other sites More sharing options...
dusanbe Posted September 4, 2018 Author Report Share Posted September 4, 2018 Hvala na odgovorima. Ipak, cena predlozenog modela (cca 800EUR) je daleko iznad budzeta. Da li neko ima iskustava sa nekim od predlozenih uredjaja? Pozdrav Quote Link to comment Share on other sites More sharing options...
Engine Posted September 4, 2018 Report Share Posted September 4, 2018 Ima li Naim5 phono sekciju? Quote Link to comment Share on other sites More sharing options...
microfarad Posted September 4, 2018 Report Share Posted September 4, 2018 Nema Quote Link to comment Share on other sites More sharing options...
sondek Posted September 4, 2018 Report Share Posted September 4, 2018 Naim Nait 3 je poslednji integralac koji je ima.Ta ista fono sekcija tj. fono kartice su bile i u najskupljem predpojacalu.Opciono biras hoces li MM ili MC.Btw. to pojacalo dosta bolje zvuci od nait 5. Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted September 4, 2018 Report Share Posted September 4, 2018 Svi gramofoni na linku dole su novi sa garancijom a prikazane cene su nize za cca 20% od zvanicnih maloprodajnih. https://www.kupujemprodajem.com/Audio/Gramofoni/Pro-Ject-gramofoni-Essential-III-46230824-oglas.htm?filter_id= Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted September 4, 2018 Report Share Posted September 4, 2018 On 3.9.2018. at 11:11, RingeRaja said: Ok, ako mora baš da bude novo, evo pa pročitaj: http://www.gramofoni.com/novigram.html Ja bih se ipak nategao još malo i uzeo Rega RP3, ali tu je još dodatan trošak za glavu neminovan. Spisak pobrojanih gramofona odavno nije aktuelan. Gotovo sve su modeli koji se vise ne proizvode. Rega 3 je dobar izbor ali daleko premasuje gornju granicu od 500€. Quote Link to comment Share on other sites More sharing options...
sondek Posted September 4, 2018 Report Share Posted September 4, 2018 Videh danas projekt gramofon sa ugrađenim integrisanim pojacalom ,gomilom ulaza,konektorima za zvucnike i wifi antenom odmah pored rucke...kakav diridžabl za hipstere pomislih.Mislim da su ga nazvali juke box. Zajebavaju se vec s ljudima.Ja sam mislio da je drveni tj.medijapan tanjir vr ali bice tu izgleda jos iznenadjenja za mlade.U mk2 modelu ugrađeni zvučnici u poklopcu. Doduse i renomirani švedski gramofonski brend IKEA ima sad svoj gramofon.Ne znam hoče li ih biti i u drugim prodavnicama namestaja ili samo u ikeJi.Postoji priča iz neproverenih izvora da je i preCednik Vučić prilikom otvaranja kupio jedan za kuhinju u nežno bež boji sa plavim matom i zutim zvezdicama.E sad ako su slagali mene i ja sam vas. Eto moja dva predloga moderno,urbano i veselo i uklapaju se brlo lepo u enterijer, ako vas televizor ima fono sekciju tim bolje,ne morate naruziti zivotni prostor sa zvučnicima. Quote Link to comment Share on other sites More sharing options...
Ružić Slavoljub Posted September 4, 2018 Report Share Posted September 4, 2018 1 sat ranije, sondek said: Videh danas projekt gramofon sa ugrađenim integrisanim pojacalom ,gomilom ulaza,konektorima za zvucnike i wifi antenom odmah pored rucke...kakav diridžabl za hipstere pomislih.Mislim da su ga nazvali juke box. Zajebavaju se vec s ljudima.Ja sam mislio da je drveni tj.medijapan tanjir vr ali bice tu izgleda jos iznenadjenja za mlade.U mk2 modelu ugrađeni zvučnici u poklopcu. Doduse i renomirani švedski gramofonski brend IKEA ima sad svoj gramofon.Ne znam hoče li ih biti i u drugim prodavnicama namestaja ili samo u ikeJi.Postoji priča iz neproverenih izvora da je i preCednik Vučić prilikom otvaranja kupio jedan za kuhinju u nežno bež boji sa plavim matom i zutim zvezdicama.E sad ako su slagali mene i ja sam vas. Eto moja dva predloga moderno,urbano i veselo i uklapaju se brlo lepo u enterijer, ako vas televizor ima fono sekciju tim bolje,ne morate naruziti zivotni prostor sa zvučnicima. Živeo naš preDSednik ALEKSANDAR VUČIĆ !!! Živela SRBIJA !!! Quote Link to comment Share on other sites More sharing options...
dusanbe Posted September 5, 2018 Author Report Share Posted September 5, 2018 AT LP5 ima, za razliku od ostalih, i phono pre amp, pa sa njim nema potrebe kupovati posebno jos jedan uredjaj. A ukoliko resi da buducnosti kupi phono pre amp, moze se izabrati i opcija direktnog prenosa signala bez koriscenja njegovog predpojacala. Predpostavljam da je i ProJect Essential III Phono takodje slican kao i ova Audio Tehnica? Mozda svesti izbor na ova dva gramofona? Pa izabrati sta se vise svidi, vizuelno? Posto su to ipak Plug and Play entry level gramofoni. Quote Link to comment Share on other sites More sharing options...
sondek Posted September 5, 2018 Report Share Posted September 5, 2018 Konačno pozitivno razmisljanje Gramofone vizuelno birati,prema enterijeru.Sa IKEA ne mozete da pogresite,a moze njihov stolar to i da sklopi sa ostatkom nameštaja. Quote Link to comment Share on other sites More sharing options...
sondek Posted September 5, 2018 Report Share Posted September 5, 2018 8 sati ranije, Peter said: Živeo naš preDSednik ALEKSANDAR VUČIĆ !!! Živela SRBIJA !!! Konačno malo patriotizma na forumu! Ana je odabrala šareni dizajn za mat. Quote Link to comment Share on other sites More sharing options...
Engine Posted September 5, 2018 Report Share Posted September 5, 2018 11 minutes ago, sondek said: Konačno pozitivno razmisljanje Gramofone vizuelno birati,prema enterijeru.Sa IKEA ne mozete da pogresite,a moze njihov stolar to i da sklopi sa ostatkom nameštaja. Koliko god misliš da si u pravu- vizuelno je vrlo bitno radi mira u kući Quote Link to comment Share on other sites More sharing options...
sondek Posted September 5, 2018 Report Share Posted September 5, 2018 Ma vizuelno je jedino bitno.To su proizvođači odlično shvatili,časopisi si tu da isprate nove trendove u dizajnu,samo jos da audiofooli shvate.Mirnu ženu u kući imati...zadovoljna zena je čudo.Nikako da shvatim,vidim ja supa ladna ,ručak neslan,kolači ukinuti... Evo gle ovog sta je zeni u kući nevolju navuk'o Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 5, 2018 Report Share Posted September 5, 2018 Ko želi malo ozbiljnije da se posveti ovom hobiju, a nije samac, najpre treba da reši sa ostatkom ukućana neke stvari, a onda da se baci na HiFi. Truli kompromisi su uvek truli, pitanje je samo za koga. Quote Link to comment Share on other sites More sharing options...
dusanbe Posted September 5, 2018 Author Report Share Posted September 5, 2018 U principu @sondek @RingeRaja su u pravu, ali u ovom slucaju, kad neko ne zeli da se bavi sa sredjivanjem polovnih uredjaja, popravljanjem, vec jednostavno da iskoristi maksimum iz onog sto ima, nije ni to daleko od istine. Ali da ne pisem u tudje ime. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 5, 2018 Report Share Posted September 5, 2018 Moje pisanije je bilo generalno apropo WAF vs. HiFi. Da li važnije da svira ili da se uklapa ukućanima u ambijent? Prvo sa ovim mora da se bude načisto. Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted September 5, 2018 Report Share Posted September 5, 2018 Zasto ne i jedno i drugo? Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 5, 2018 Report Share Posted September 5, 2018 9 sati ranije, dusanbe said: Mozda svesti izbor na ova dva gramofona? Pa izabrati sta se vise svidi, vizuelno? Posto su to ipak Plug and Play entry level gramofoni. @Sonichammer Moj post je bio komentar na ovaj zaključak. RP3 je bio predlog, a on i relativno dobro svira, a i ne izgleda loše. Uostalom, preporuči mu ti neki iz tvog arsenala. Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted September 5, 2018 Report Share Posted September 5, 2018 Slozio sam se da je Rega 3 odlicna opcija ali prevazilszi cenu od 500€. Prvi Project koji je bolji od Rege 3 je RPM 5 Carbon ali on kosta 1200€ bez picki ip-a ali za tu cenu otprl ina i Rega 6. Ja na stanju nemam trenutno nista sto moze da parira R3 ali u okviru trazene cene imam i Essential 3 i Debut III i to sa 20ak % popusta. Eno ga link “gore”. Quote Link to comment Share on other sites More sharing options...
dusanbe Posted September 5, 2018 Author Report Share Posted September 5, 2018 @RingeRaja napisao sam u prvom postu da moj prijatelj (malo stariji pa ne koristi mnogo racunre, pozdrav Zoki) zeli da kupi nov gramofon, da mu je budzet toliki i da se nadamo vasim predlozima, pa ne zelim u njegovo ime pisati o WAFu vs HiFi, ali Vam se zahvaljujem na predlogu, iako je on van budzeta, i savetu za web stranu na kojoj ima informacija o kupovini novog gramofona. @Sonichammer hvala na predlogu za ProJect gramofone, uzeti su u razmatranje @sondek jednom smo razmenili neki post o gramofonima, znam za Vas stav o Linn i uopste o gramofonima pa razumem Vase ironicne odgovore Ukoliko ipak ima nekog ko poseduje ili je posedovao neki od ova dva gramofona, molim da napise neki utisak pa makar bio da ih treba zaobici u sirokom luku. Hvala unapred. Pozdrav svima Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 5, 2018 Report Share Posted September 5, 2018 Ok, ako mora novo i u okviru budžeta, onda su možda jedini izbor ova dva koje nudi SonicHammer. Pitaj ga da li ima Debut Carbon sa cenom u okviru 500€, to bi bila po meni bolja opcija nego Debut 3, koji je po meni opet nešto bolja opcija od Essential 3. Ili uraditi zaokret pa ići na Regu, RP1. Moje mišljenje je da su Rega gramofoni muzikalniji, ali to čisto subjektivno. Quote Link to comment Share on other sites More sharing options...
VU metar Posted September 6, 2018 Report Share Posted September 6, 2018 DUAL CS 455-1 Isti, sa predpojacalom, ali bolje kupiti posebno: DUAL 455-1 EV Isti, samo pod drugim imenom: Thorens TD 190-2 AT LP5 slobodno zaobiđi(te). Quote Link to comment Share on other sites More sharing options...
