srdjan_cvetkovic Posted September 2, 2018 Report Share Posted September 2, 2018 10 sati ranije, alI_Zée said: Бад решава проблем. A što se zezaš i rizikuješ da zezneš stvar, kada za par limenki piva može da ti sredi stoN. Quote Link to comment Share on other sites More sharing options...
Paki Posted September 2, 2018 Author Report Share Posted September 2, 2018 Nisam iz prve skontao za bada. Mislio sam da je to vrsta bušilice Probao sam onako kako su mi ljudi sa prethodne stranice objasnili (hvala im na predlozima) i ne ispada to baš kako treba, sa ovom debljinom žice. Bad je definitivno bolje rešenje Quote Link to comment Share on other sites More sharing options...
Paki Posted September 11, 2018 Author Report Share Posted September 11, 2018 Može mala pomoć ovde? Počeo sam da skidam ožičenje i, trafo kao da je zapečaćen nekom vrstom voska. Ceo trafo je napunjen. Kojom metodom da povadim kablove? Quote Link to comment Share on other sites More sharing options...
zoranzu Posted September 12, 2018 Report Share Posted September 12, 2018 Ostavi te zice,ako neces da menjas i trafo Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 12, 2018 Report Share Posted September 12, 2018 5 sati ranije, Paki said: Može mala pomoć ovde? Počeo sam da skidam ožičenje i, trafo kao da je zapečaćen nekom vrstom voska. Ceo trafo je napunjen. Kojom metodom da povadim kablove? Bad je bolje rešenje???? Izgleda da se nećeš smiriti dok ovo ne razjebeš do kraja. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 12, 2018 Report Share Posted September 12, 2018 6 sati ranije, Paki said: Kojom metodom da povadim kablove? Мани ћорава посла. Quote Link to comment Share on other sites More sharing options...
Paki Posted September 12, 2018 Author Report Share Posted September 12, 2018 Ja reko' da ostane što manje posla za bada...al' bolje je da ne idem dalje od ovoga. Quote Link to comment Share on other sites More sharing options...
safet Posted September 12, 2018 Report Share Posted September 12, 2018 ja da sam umesto tebe istopio bih tu leguru ili šta li je već i završio bih sa mukama Quote Link to comment Share on other sites More sharing options...
Paki Posted September 12, 2018 Author Report Share Posted September 12, 2018 Ma polako ja to radim, kad imam vremena. Nisu neke muke. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted September 12, 2018 Report Share Posted September 12, 2018 16 sati ranije, Paki said: Može mala pomoć ovde? Počeo sam da skidam ožičenje i, trafo kao da je zapečaćen nekom vrstom voska. Ceo trafo je napunjen. Kojom metodom da povadim kablove? Nema potrebe da to skidaš. Quote Link to comment Share on other sites More sharing options...
Audio Doktor Posted October 14, 2018 Report Share Posted October 14, 2018 Ne diraj to doktor TITA napravio , to se ne dira , radi shljaka ako ti treba dokaz , poshalji ga kod mene dacu ti dokaz nesto kao ovo Quote Link to comment Share on other sites More sharing options...
Audio Doktor Posted October 14, 2018 Report Share Posted October 14, 2018 Al to je kinesko smece , Imas vremensku zonu ulaz izlaz Nugen , a imas i Spektrogram sta ti je draze , Ovo je drugi merac , al ispravno merenje , vidi se da nema niskakvih smetnji , samo 1khz signal . Moguca merenja na svim frekvencijama , al nema potrebe . Quote Link to comment Share on other sites More sharing options...
Audio Doktor Posted October 14, 2018 Report Share Posted October 14, 2018 Ovo ISpravno ti je TEchniks Titin , tvoje je jos bolje , 90db noise flor , harmonik na -80db, inace ljudi cuju do -30db , znaci 2-3x nize nego sto mozemo cuti je sum ovde , sto dirati te stvari , ja tako inace popravljam , ako valja ne diram, ako ne valja , onda druge nema diraj . Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted October 14, 2018 Report Share Posted October 14, 2018 8 minuta ranije, Audio Doktor said: Ne diraj to doktor TITA napravio , to se ne dira , radi shljaka ako ti treba dokaz , poshalji ga kod mene dacu ti dokaz nesto kao ovo 4 minuta ranije, Audio Doktor said: Al to je kinesko smece , Imas vremensku zonu ulaz izlaz Nugen , a imas i Spektrogram sta ti je draze , Ovo je drugi merac , al ispravno merenje , vidi se da nema niskakvih smetnji , samo 1khz signal . Moguca merenja na svim frekvencijama , al nema potrebe . 2 minuta ranije, Audio Doktor said: Ovo ISpravno ti je TEchniks Titin , tvoje je jos bolje , 90db noise flor , harmonik na -80db, inace ljudi cuju do -30db , znaci 2-3x nize nego sto mozemo cuti je sum ovde , sto dirati te stvari , ja tako inace popravljam , ako valja ne diram, ako ne valja , onda druge nema diraj . Џабе се трудиш, покретача теме то не интересује 100% сам сигуран. Quote Link to comment Share on other sites More sharing options...
Audio Doktor Posted October 14, 2018 Report Share Posted October 14, 2018 Verujem , mene niko ne bi zaustavio da diram , tako sam i naucio sve , sve sam sam radio , puklo je vise od par puta , pokidalo se jos vise puta . I danas kad vidim te konekcije na kondezatorima pa to je isto bilo u Apollo Raketi (svemirskom brodu) identicno , to da secem kljestima , to ne bi ni gledao popreko Al eto , samo da se ne povredi mozda bolje da mu pomenem mere opreza koje i iskusni koriste , pravilo jedne ruke , izolacioni trafo , ogranicavac struje , Variak , itd a jos do alata nismo stigli, meni deluje da ce nesto pokidati , al eto , nek mu pukne puklo je i meni , bice pametniji PS: Jos se nisam naucio pameti, danas mi se zadimi Trafo, umesto da iskljucim ja uhvatim rukom da vidim jel to samo skida prasnu sa sebe jer dugo nije radilo ili je kratki spoj . To nije pametno , traziti nevolju , al uhvatio sam tu zverku bas kako ne treba unutrasnjim delom ruke , da me klepilo stego bi ga rukom i cao . Al eto nije kratki spoj , skida prasinu sa sebe Trafo Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted October 14, 2018 Report Share Posted October 14, 2018 Ма ок, схватили смо. Quote Link to comment Share on other sites More sharing options...
