Dacho Posted March 29, 2020 Report Share Posted March 29, 2020 17 minuta ranije, ab said: A, BBC? Pa Goodmans je radio za BBC Quote Link to comment Share on other sites More sharing options...
ab Posted March 29, 2020 Report Share Posted March 29, 2020 Е, хвала. Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 29, 2020 Report Share Posted March 29, 2020 Klasifikacija BBC MonitoraBBC zvučnici (sve u vezi njih) se može klasifikovati u 4 kategorije:* LS1/--sklopovi zvučnika-kabineti, raznovrsna upotreba.* LS2/--šasije jedinica.* LS3/--sklopovi zvučnika-kabineti, upotreba izvan radijske sfere-(emitovanja).* LS4/--sklopovi zvučnika-kabineti, studijsko korišćenje.Pre nego što je ova klasifikacija zaživela, zvućnici su bili kodirani LSU/--. U budućnosti će se koristiti samo oznake LS1/--, LS2/--, i LS5/--- i za zvučnike koji se koriste izvan radijske sfere kao i za zvucnike za studio, zajedno sa LS5/-kodom. Postoji previše pojedinačnih tipova zvučnika koje treba pokriti pa ćemo se ograničiti na uobičajene tipove zvučnika. Quote Link to comment Share on other sites More sharing options...
Dacho Posted March 29, 2020 Report Share Posted March 29, 2020 Dakle nakon 60-ih gdje je pionir za male zvucnike bio Goodmans, po zahtjevu BBC-a se krenulo u inovacije iz kojih su stvoreni driveri za LS 3/5. Apart from a few examples of metal cones, or composites such as Don Barlow's expanded polystyrene/aluminium-foil cone of 1961, bass/mid-range speaker diaphragms were, until the late 1960s, most often based on various types of pressed wood pulp — paper, in other words. That all changed thanks to research into vacuum-formed thermoplastic cones undertaken by DEL Shorter, Dudley Harwood (who went on to found Harbeth) and Spencer Hughes (who went on to found Spendor) at the BBC Kingswood Warren engineering research department. Along with providing significantly different mass, rigidity and self-damping properties compared with paper, the simplicity of the vacuum forming process meant that experimenting with different cone profiles became rather easier. After appraising numerous different plastics, the BBC engineers plumped for a sheet polystyrene material called Bextrene, and soon began building drivers and systems around it. Commercial speakers with Bextrene‑cone bass/mid drivers soon followed, first from KEF and Rogers, both companies with close commercial links to the BBC, and then subsequently from a number of OEM driver manufacturers. Although Bextrene constituted an advance in speaker engineering, the material was far from perfect. It was relatively heavy and needed a hand-applied coat of PVA glue on its surface to suppress a particularly audible resonance (a characteristic that became known as the, 'Bextrene quack'). Bextrene ruled for between five to 10 years before it began to be replaced by polypropylene (once the significant difficulty of reliably adhering polypropylene to the voice coil and outer surround was overcome). Polypropylene, often reinforced with a variety of fillers, is still today probably the most commonly used thermoplastic cone material. Quote Link to comment Share on other sites More sharing options...
Dacho Posted March 29, 2020 Report Share Posted March 29, 2020 20-tih godina su u studiju bili mono tj samo jedan zvucnik i to uglavnom najpoznatiji proizvođač u to doba Rice & Kellog, ispocetka elektromagnetni a kasnije i obicni alnico. Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 29, 2020 Report Share Posted March 29, 2020 Vintage BBC zvučniciLSU/10Ovaj veliki sklop, u hrastovom kabinetu, napravljen je neposredno posle rata za opštu primenu u studijima. Neki od njih se još uvek koriste.Korišćene su sledeće jedinice:-Parmeko od 18 inča, dual concentric bas/tviter horna.-Lorenc LPH65 tviter (za produžen HF)-Modifikovani Leak TK/12 cevni pojačavač od 12W.LS3/1Sivo ofarbani potpuno zatvoreni kabinet za korišćenje izvan radijskih potreba. HF jedinice su postavljene na perforirane sub-baffle ispred; kako bi se omogućilo precizno monitorisanje na bliskoj udaljenosti.Korišćene su sledeće jedinice:-Plessey bas od 15 inča sa papirnom koničnom membranom-2 x Rola-Celestion HF1300 kao tviteriLS3/1ASlično kao L53/1, ali sa basom koji je zamenjen sa Goodmans C129/15pr.LS3/4, i BOmogućena ugaona montaža u neposrednoj blizini plafona u prostorima na vrhunskom nivou, npr. vozila za emitovanje izvan radio stanica ili preko VT mašina. Pazite! Neki od njih se još uvek koriste, ali su surround bas jedinice sa godinama zastarele. Stari modeli su imali tkaninu u zlatnoj boji za gril. Kasniji modeli, aktuelnog tipa, sa crnim grilom mogu biti modifikovani u nove modele (videti LS3/4C i LS5/11 na sledećoj stranici, u okviru "Današnji monitori").Korišćene su sledeće jedinice:-Spendor BC2/8, 203mm konični bas sa membranom od Bextrene-Rola-Celestion HF1300 tviterLS3/5Prethodnica L53/5A. Kada je ugrađena bas jedinica postala nepouzdana.Korišćene su sledeće jedinice:-KEF B 11O, 1 l Omm Bas sa koničnom membranom od Bextrene-KEF T27 27mm Mylar dome tviterLS3/7Slične veličine kao LS3/1 i dizajniran da ga zameni. Neki su još uvek u funkciji za govorni program, ali sada ne bi trebalo da se koriste za monitoring. Max SPL at 1.5 m: 104dB (A).Korišćene su sledeće jedinice:-Spendor 8-inčni Bextrene konični bas [zapravo, to je 12" jedinica!]-Son Audax HD 12x9D25, 25mm dome tviterPojačivač (AM8/15) je modifikovani Quad 303 gde jedan kanal vozi IF a dugi HF, uz korišćenje elektronskog deljenja frekvencije i ekvalizacije mreže.LS5/1, i AStudio verzije LS3/1 i A, sa ciljem da zameni LSU/10. Kabineti su bili veći od LS3/1, a tviteri su postavljeni iznad basa, a ne ispred njega.Korišćene su sledeće jedinice:-Plessey (LS5/1) ili Goodmans C129/15pr (LS5/1A), bas 15 inča sa papirnom koničnom membranom-2 x rola-Celestion HF1300 tviteriLS5/2 i ATelevizijske verzije LS5/1 i A. Korišćen je drugi oblik kabineta da bi bilo omoguceno njihovo “zaustavljanje”.LS5/4Verzija sistema LS3/1A za kuće za odmor (u prirodi).LS5/5Veliki kabineti za monitoring u studijima, sivo ofarbani kabineti. Max SPL at 1.5 m: 103dB (A).Korišćene su sledeće jedinice:-12-inčni bas sa Bextrene konicnom membranom (LS2/1)-8-inčni srednji sa Bextrene koničnom membranom (LS2/2)-Celestion HF 1400 tviter-modifikovani pojačivač snage Quad 50D (AM8/11)-pre-amp i ekvalizer (AM1/20)LS5/5BVerzija jedinice LS5/5 sa Spendor BC2/8 MKII srednjetoncem i kabinetom furniranim TEAK furnirom.LS5/6Televizijske verzije LS5/5. Korišćen je drugi oblik kabineta da bi bilo omoguceno njihovo “zaustavljanje”.Današnji monitoriLS3/4CTrouglasti kabinet srednje veličine, za montažu na plafonu ili zidu u Premium prostoru. Koristi se na televiziji u CMCRs/MCRs ili VT vozilima sa kutija stim prikolicama. Zamenjuje L53/4 i LS3/4B ili je možda konvertovan iz nekog od gorenavedenih. Max SPL at 1.5 m: 101dB (A). Oko 40 godina je u BBC službi.Koriste se sledeće jedinice:-8-inčni bas sa Bextrene koničnom membranom (LS2/13)-Son Audax HD 13D34, 34mm tviter sa dome-kupolnom membranom od tkanine (LS2/12)Zahtijeva 50 Watt pojačivač.LS3/5AMali kabinet za smeštaj u policu sa knjigama za korišćenje u ograničenim prostorima kao sto su vozila za emitovanje izvan radio stanica.Često se koristi na lokalnim radijima. Max SPL za par na 1,5 m: 95dB (A). Preko 3500 kabineta je u upotrebi u BBC, a preko 100.000 je prodato komercijalno, širom sveta. Pod licencom Swisstone (Rogers), Spendor i Harbeth.Koriste se sledeće jedinice:-KEF B 110 SP1228, 1 l 0mm bas sa Bextrene konicnom membranom.-Modifikovani KEF T27 SP1032, 27 mm Mylar dome-kupolni tviter.-KEF SP2128 skretnica (FL6/38)Zahteva 25 Watt pojačivač.LS5/8Veliki podni kabineti za visok nivo, visoko kvalitetnog studijskog monitoringa. Zamenjuje LS5/1 i LS5/5. Max SPL at 1.5 m: 116dB (A). BBC koristi ispod ovih kabineta. Pod licencom Swisstone (Rogers).Koriste se sledeće jedinice:-Rogers od 12-inčni bas sa polipropilenskom koničnom membranom.-Son Audax HD13D34H, 34mm dome-kupolni tviter sa membranom od tkanine (LS2/15)-modifikovani Quad 405 pojačivač (AM8/16)AM8/16 predpojačivač ima ekvalizaciju i skretnicu u sebi. Bas i tviter su drajvovani zasebnim kanalima pojačavača.LS5/8AL, i RSličan kao LS5/8, ali sa bafl-om pod 30 stepeni za montažu u uglovima vozila. Leva i desna verzija čine par. Poseban akustični tretman je obavezan zbog blizine zvučnika zidovima. Osam parova BBC koristi.LS5/9Srednja veličina studijskih monitora za monitoring visokog kvaliteta tamo gde je LS5/8 prevelik. Dizajniran da proizvede subjektivno sličan zvuk kao LS5/8. Max SPL u l. 5m: lO5dB (A). Preko hiljadu njih je u upotrebi u BBC. Pod licencom Swisstone (Rogers) i Spendor.Koriste se sledeće jedinice:-8-inčni bas sa polipropilenskom koničnom membranom (LS2/14)-Son Audax HD13D34H, 34mm dome-kupolni tviter sa membranom od tkanine (LS2/15)-skretnica (FL6/36)Zahtijeva 50 Watt pojačivač.LS5/11Ovo je modifikovani LS3/4 koji ima za cilj da proizvede sličan subjektivno zvuk kao LS5/9. Koristi iste jedinice kao i LS5/9, koja su modifikovane za baffle LS3/4, iako je izmenjena skretnica. Max SPL at 1.5 m: 106dB (A). Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 Bilo bi lepo kada bi neko od znalaca odvojio malo vremena pa ispravio ovaj materijal koji postavljam, jer koliko god da ulažem napora ja sam ipak “dunster”. Quote Link to comment Share on other sites More sharing options...
Majda Posted March 30, 2020 Report Share Posted March 30, 2020 21 hours ago, Dacho said: Dakle nakon 60-ih gdje je pionir za male zvucnike bio Goodmans, po zahtjevu BBC-a se krenulo u inovacije iz kojih su stvoreni driveri za LS 3/5. Tako je Goodmans je vec tada imao dugu tradicju. Medjutim trebalo bi uzeti u obzir i EMI monitore koji su postojali u to vreme i uticali direktno na dalji razvoj BBC modela. EMI monitor loudspeaker Na ovom linku ima vise tih prvobitnih modela na bazi EMI drivera koji su mahom ovalni alnico driveri https://sfmkm.blogspot.com/p/blog-page.html Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 LSU/10 Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 LS3/1 Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 LS3/1A Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 LS3/4C Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 LS3/5Chartwell Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 LS3/7 Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 LS5/1A Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 LS5/5 Quote Link to comment Share on other sites More sharing options...
zflazar Posted March 30, 2020 Report Share Posted March 30, 2020 momci imajte milosti, ovo nije za ljude sa slabijim živcima i hrčakozom u blagoj remisiju. Molio bih administraciju da zbog ravnomernijeg lučenja serotonina ograniči postavljanje slika ovakvih zvučnika na 1x dnevno na prazan buđelar!!! ... svaka čast, samo dalje!!! Quote Link to comment Share on other sites More sharing options...
sondek Posted March 30, 2020 Report Share Posted March 30, 2020 Evo mojih lepotana nakon furniranja kod majstor Save...od svih fensi furnira ja izabrah ovaj duh '70-tih Quote Link to comment Share on other sites More sharing options...
Majda Posted March 30, 2020 Report Share Posted March 30, 2020 @Srecko hvala na rekapitulaciji modela i fotografijama 3 minutes ago, sondek said: Evo mojih lepotana nakon furniranja kod majstor Save...od svih fensi furnira ja izabrah ovaj duh '70-tih Odlicno Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 Bilo bi lepo, ako budete imali vremena Majda, da ispravite-korigujete to sto sam postovao (iz glave, verujem da Vi to bolje znate za klasu nego ovi iz čijih sam članaka prepisivao). Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 LS5/5 i LS5/6 bas drajver Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 LS3/5ARogersHarwoodFalcon AcousticStirlingChartwellGrahamitd. Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 LS5/8Graham Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 LS5/9Graham Quote Link to comment Share on other sites More sharing options...
Srecko Posted March 30, 2020 Report Share Posted March 30, 2020 HARBETHGama Harbeth P3ESRC7ES-3Domestic monitor 30.2Super HL5 PlusDomestic monitor 40.2 Quote Link to comment Share on other sites More sharing options...
