Golum Posted March 19, 2018 Report Share Posted March 19, 2018 Naleteh danas na ovog proizvodjaca r2r DACova pa rekoh da podelim sa vama - moz bidne nekome zanimljivo. Koliko videh, lepe stvari se pisu o njima (I na nekim ozbiljnim forumima), a ni cene nisu stratosferske... https://www.denafrips.com/ Pozz., G Quote Link to comment Share on other sites More sharing options...
robespierre Posted December 5, 2018 Report Share Posted December 5, 2018 Da li je neko imao priliku da poslusa nesto iz njihovog asortimana? Quote Link to comment Share on other sites More sharing options...
Body Posted December 5, 2018 Report Share Posted December 5, 2018 On 3/19/2018 at 10:54 AM, golum said: a ni cene nisu stratosferske... Pa naravno ko ima dobru platu sta je da da 1000 dolara za DAC koji budi rečeno ne znam čemu sluzi al aj nema veze, kao da poboljsa kompresovan file pa da zvuči kao CD ili Ploča sto moze da odradi bilo koja bolja zvučna karta od 100 inak evra Quote Link to comment Share on other sites More sharing options...
Golum Posted December 5, 2018 Author Report Share Posted December 5, 2018 Ako ne znate cemu sluzi onda neka malo radi google ili pak ostanite na vasoj “boljoj” zvucnoj kartici i svi srecni a vi pogotovo...nema sikiracije Quote Link to comment Share on other sites More sharing options...
Majda Posted December 5, 2018 Report Share Posted December 5, 2018 "odradi" Quote Link to comment Share on other sites More sharing options...
Filipescu Posted December 5, 2018 Report Share Posted December 5, 2018 5 minuta ranije, Majda said: "odradi" Ključna reč . Izjava je suštinski tačna, jer nema kartice koja to "neodrađuje" (loše). Quote Link to comment Share on other sites More sharing options...
Majda Posted December 5, 2018 Report Share Posted December 5, 2018 Hvala na linku Golum. Pogledao. Izgleda vrlo dobro sto se tice izrade? Medjutima ima nekoliko stvari koje se daju opaziti na pvi pogled. Svi modeli imaju OPampove u izlazu. I jako malo prostora je posveceno analognom delu. Posle konverzije. To su balansirani dac moduli stp znaci da pstoje i +DAC i denticni -DAC za svaki kanal. Tako da je upotreba line transformatora tu neophodna. Jednostavno se ne dobijaju dobri rezultati kada se to vestacki uradi OPampvima. I bufferi za izlaze su OPamp. Oni doduse mogu da "mere" jako dobro, odlicno, ali zvucno su losi. Sa druge strane, nepotrebno mnogo prostora je potroseno na bezbrojne nizove kondenzatora. Digitalna kola ne trose no priblizno toliko energije koja im je "obezbedjena" na taj nacin. Ako kazem da su samo 2 ta velika C imaju preteranu vrednost da li bi mi verovali? Ovde je ocigledni cilj bio da se na fotografijama vidi da je uredjaj "pun" a ne prazan ili poluprazan kao vecina na trzistu... Master klokovi su dobri i cak natprosecno kvalitetni u odnpsu sta se sve postavlja na tu poziciju. Medjutim vide se procesori koji imaju ulogu nekog DSP-a i/ili korektora u digitalnom domenu... To nije dobro. Na taj nacin se Analogni deo pokusati uciniti jednostavnijim. Ali to ipak nije ni uputno a ni potrebno. Jednostavno vidim veliku nesrazmeru i velike nelogicnosti u smislu iskoriscenja standardnog prostora kutije. Recimo AKO su ti kondovi originalni, onda je polovina njihove cene recimo jedan superkvalitetan BAL to SE trafo od jedno 300usd. Quote Link to comment Share on other sites More sharing options...
Majda Posted December 5, 2018 Report Share Posted December 5, 2018 14 minutes ago, Filipescu said: Ključna reč . Izjava je suštinski tačna, jer nema kartice koja to "neodrađuje" (loše). Ja mislim da si u pravu, i da ustvari to neko originalno znacenje te reci, koja je se veoma mnogo upotrebljava u svakodnevnoje komunikaciji... Quote Link to comment Share on other sites More sharing options...
Golum Posted December 5, 2018 Author Report Share Posted December 5, 2018 @Majda kao i obicno hvala na iscrpnom tehnickom “seciranju” DACa! Nisam nesto vican sa te strane pa mi komentari ovog tipa odlicno dodju za edukaciju. Konkretan DAC nisam slusao osim sto sam eto procitao po netu prilican broj pozitivnih komentara pa mi je zato zapao za oci. Puno pozdrava! G Quote Link to comment Share on other sites More sharing options...
Majda Posted December 6, 2018 Report Share Posted December 6, 2018 Ja sam sastavio jedan 32bit PCM (I2S) i DSD diskretni dac. Dual mono, balansirani i PCM i DSD. (na fotografiji je bez interstage trafoa, izlzanog buffera, i USB/I2S/DSD interfejsa. Nije me mrzelo da uradim point to point. Namerno sam radio sa 5V napajanjem i "velikim" integralnim logickim kolima. Ide do 384KHz SR dalje nisam isprobao... Ovih dana ga pakujem u kutiju. Quote Link to comment Share on other sites More sharing options...
prophet Posted December 6, 2018 Report Share Posted December 6, 2018 Ja sam sastavio jedan 32bit PCM (I2S) i DSD diskretni dac. Dual mono, balansirani i PCM i DSD. (na fotografiji je bez interstage trafoa, izlzanog buffera, i USB/I2S/DSD interfejsa. Nije me mrzelo da uradim point to point. Namerno sam radio sa 5V napajanjem i "velikim" integralnim logickim kolima. Ide do 384KHz SR dalje nisam isprobao... Ovih dana ga pakujem u kutiju.Hej pa ovo smo slusali. Kako ce svirati kod tebe kuci mogu samo da zamislim. Kazi mi to je DSD 1-bit? Quote Link to comment Share on other sites More sharing options...
Majda Posted December 6, 2018 Report Share Posted December 6, 2018 Nije. Za DSD cekciju ovde je 32bit DSD. Onaj new concept 1-bit mi je bio samo za probu da se vidi kako radi. I da se moze upotrebiti kao 1bit za bilo sta ili DSD ili I2S/PCM. (Njega nismo slusali.) sorry na off-u bice vise reci o tome u temi u sistemima... Quote Link to comment Share on other sites More sharing options...
