Zexx Posted March 29, 2018 Report Share Posted March 29, 2018 5 minuta ranije, pompi said: SRC? Sample Rate Converter, odnosno alat (u slučaju foobar odgovarajući plugin), koji ume da uradi downrate sa 192, 176.4, 96, 88.2 i 48 kHz na CD standard od 44.1 kHz. Quote Link to comment Share on other sites More sharing options...
pompi Posted March 29, 2018 Author Report Share Posted March 29, 2018 3 minuta ranije, Zexx said: Sample Rate Converter, odnosno alat (u slučaju foobar odgovarajući plugin), koji ume da uradi downrate sa 192, 176.4, 96, 88.2 i 48 kHz na CD standard od 44.1 kHz. upravo u foobaru od flac 24/192 pravim wav 24/44. pa cu da vidim dalje. Hvala. Quote Link to comment Share on other sites More sharing options...
pompi Posted March 29, 2018 Author Report Share Posted March 29, 2018 Odradjeno. Sada taj wav 24/44 pretvaram u flac 16/44 dither always. I kaze mi sledece: 1 out of 1 tracks converted with major problems. Source: "D:\pompi\01. VINYL RIP\Naked Death.wav" An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "D:\pompi\01. VINYL RIP\Atomic Rooster\Naked Death.flac" Additional information: Encoder stream format: 44100Hz / 2ch / 16bps Command line: "C:\Program Files (x86)\foobar2000\flac.exe" -s --ignore-chunk-sizes -5 - -o "Naked Death.flac" Working folder: D:\pompi\01. VINYL RIP\Atomic Rooster\ Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters Quote Link to comment Share on other sites More sharing options...
Krca44 Posted March 29, 2018 Report Share Posted March 29, 2018 11 minutes ago, pompi said: Sada taj wav 24/44 pretvaram u flac 16/44 dither always. Kad si vec u WAVu zasto ga vracas u Flac ? uradi Wav u Wav koji ti na kraju treba Quote Link to comment Share on other sites More sharing options...
pompi Posted March 29, 2018 Author Report Share Posted March 29, 2018 12 minuta ranije, Krca44 said: Kad si vec u WAVu zasto ga vracas u Flac ? uradi Wav u Wav koji ti na kraju treba Do jednostavnosti treba narasti, sto bi rekao jedan moj profesor! Jesam. U foobaru mi je ispao wav 1411 kbps naspram flaca radjenog u ne secam se vise kom konvertoru 818 kbps. A i po megabajtima je skoro duplo veci. To je dobro! E sad, zasto to nisam odmah uradio? Odgovor je sledeci: ja bih to da rezem u neru. Ako nero slucajno nece da nareze wav kao audio cd mrzece me da sad menjam i program za rezanje jer sam na ove konvertore potrosio vec citav dan a sve ovo mi je mnogo mrsko. Hvala. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted March 29, 2018 Report Share Posted March 29, 2018 (edited) Nero reze FLAC bez problema kao normalan audio disk, ja radim to u praistorijskoj 6.02 verziji bez problema, jedino to sto ti je 24 bita... al' da znas za ubuduce flac 16/44 samo ubacis u Nero i snimas Sa Wav fajlom nema problema sa Nerom, to je isto sto i cdaudio file kad otovoris na kompu samo se zove wav da ga racunar lakse ocita Edited March 29, 2018 by Krca44 Quote Link to comment Share on other sites More sharing options...
Krca44 Posted March 29, 2018 Report Share Posted March 29, 2018 Kad ubacis disk za slusanje i pogledas extenziju, pise track01.cda, cd audio, kao takvog ga cita ali nece da ga iskopira na racunar pa ga onda bez kompresije prebacis u WAV, dakle ista stvar samo prilagodjena racunaru koji onda moze sa tim WAVom da radi svasta Quote Link to comment Share on other sites More sharing options...
Father Posted March 29, 2018 Report Share Posted March 29, 2018 Meni je uradio konverziju flac u wav u jednom cugu pomoću onih podešavanja koje sam ilustrovao. Verujem da taj proces automatski radi prvo 88.2khz na 44.1khz pa onda 24bit na 16bit sa ditherom. Ne govorim sa sigurnošću, niti sam uporedjivao oba procesa, tako da moju preporuku uzmete sa rezervom i eventualno proverite njegov kvalitet u poredjenju sa 2 koraka konverzije koje je zexx preporučio. Quote Link to comment Share on other sites More sharing options...
Zexx Posted March 29, 2018 Report Share Posted March 29, 2018 35 minuta ranije, Father said: Meni je uradio konverziju flac u wav u jednom cugu pomoću onih podešavanja koje sam ilustrovao. Verujem da taj proces automatski radi prvo 88.2khz na 44.1khz pa onda 24bit na 16bit sa ditherom. Ne govorim sa sigurnošću, niti sam uporedjivao oba procesa, tako da moju preporuku uzmete sa rezervom i eventualno proverite njegov kvalitet u poredjenju sa 2 koraka konverzije koje je zexx preporučio. Ko čuje razliku, dobije zvanje počasnog slepog miša foruma. Quote Link to comment Share on other sites More sharing options...
Bujodrag Posted March 31, 2018 Report Share Posted March 31, 2018 Bio mi drugar pa smo isprobavali njegov DAC, on hteo da nešto proba. I morali smo da isključimo i sklonimo phono da bismo na polici napravili mesta za DAC. I sad mi phono stoji neuključen. Kad je to bilo? Pre deset dana! Vajni sam ja gramofondžija postao kad se deset dana nisam setio da pustim neku ploču. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 31, 2018 Report Share Posted March 31, 2018 15 minuta ranije, Bujodrag said: Vajni sam ja gramofondžija postao kad se deset dana nisam setio da pustim neku ploču. Некада и плоче желе да се одморе од досадних винилџија. Quote Link to comment Share on other sites More sharing options...
pompi Posted March 31, 2018 Author Report Share Posted March 31, 2018 5 minuta ranije, Bujodrag said: deset dana Auu.. dug je to post! On 3/29/2018 at 19:54, Krca44 said: al' da znas za ubuduce flac 16/44 samo ubacis u Nero i snimas Hehe.. pa upravo zbog toga i radim 24/192 u 16/44. Doduse, nema mnogo toga. Radi se o nekim ripovima ploca koje na kiosku nisam uspeo da nadjem na CD-u ili je na CD-u izasao samo remaster a ja bih neremaster. Muke . Inace, kad u mom neru odem na add pa pokusam da otvorim WAV, nero se slogira i prijavi neki problem. Kad je ceo album u jednom fajlu, koristim neki xrecode da ga raspakujem pa mi je palo na pamet da flac 24/192 pretvorim u wav 16/44 pomocu foobara a onda taj wav u xrecode-u pretvorim u flac koji posle rezem u neru. Probao sam i to funkcionise. Jedinu zamerku nalazim u snizenju kbps, (wav bude 1411 kbps a flac +-800). Tako da bih se zahvalio svima koji su ucestvovali u ovoj temi i na ovo izgubili vreme. Ama bas svaki post je bio koristan, hvala. Quote Link to comment Share on other sites More sharing options...
Bujodrag Posted March 31, 2018 Report Share Posted March 31, 2018 15 minuta ranije, alI_Zée said: Некада и плоче желе да се одморе од досадних винилџија. Moje su i zaslužile odmor. Neplaćeni, naravno. Quote Link to comment Share on other sites More sharing options...
Zexx Posted March 31, 2018 Report Share Posted March 31, 2018 1 sat ranije, pompi said: Jedinu zamerku nalazim u snizenju kbps, (wav bude 1411 kbps a flac +-800). Nema razlike u krajnjem rezultatu bez obzira na različit protok. Quote Link to comment Share on other sites More sharing options...
Bujodrag Posted March 31, 2018 Report Share Posted March 31, 2018 Vesti iz sveta: Pola veka Cambridge Audija Kako bi na najbolji način proslavila jubilarni 50. rođendan, ostrvska kompanija Cambridge Audio rešila je da smanji cene svih svojih proizvoda za jubilarnih 50%. Kompanija navodi da je devetočlani tim inženjera proveo tri godine u podrumu zgrade izložem elktrošokovima i izgladnjivanju uz jasno objašnjenje da neće biti pušteni dok ne naprave bolje i jeftinije uredjaje. Nastavak vesti Quote Link to comment Share on other sites More sharing options...
Krca44 Posted March 31, 2018 Report Share Posted March 31, 2018 1 hour ago, Bujodrag said: Kompanija navodi da je devetočlani tim inženjera Umesto Inzenjera citati direktora marketinga Quote Link to comment Share on other sites More sharing options...
Bujodrag Posted March 31, 2018 Report Share Posted March 31, 2018 Oni su braća sada. Zaboravi na sedamdesete pa čak i na osamdesete. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted March 31, 2018 Report Share Posted March 31, 2018 2 minutes ago, Bujodrag said: Oni su braća sada. Zaboravi na sedamdesete pa čak i na osamdesete. Pronasao sam Ortofon 2M Series User Guide.pdf file i na kraju se bave takozvanom PnP kombinacijom, glava u Ort shellu ( koju imam ) i pazi sad sta kazu : "Distance to connector 52mm" ( znas na kojih 52mm se misli, kad ubacim u Technics Gauge, tih 52mm ). "Headshell with a 2M cartridge pre-mounted provides correct Baerwald aligment with the major part of tonearms with universal mount." Ko je ovo pisao mislim da se malo zeknuo kad je napisao Baerwald, jer to na Techniscu , ubaceno u Gauge, izgleda kao Technics preporuceni original sto je mnogo blize Stevensonu nego Baerwaldu, pa mislim da je neko iz marketinga malo prolupao... ili je pitao brata inzenjera "braco sta da pisem" a onaj mu u prolazu onako brzinski rekao "pisi Baerwald" i otisao svojim poslom.... A mozda , ako sam cinicno raspolozen, neko rece "pisi Baerwald, to je sad popularno kod audiofila" Quote Link to comment Share on other sites More sharing options...
alti Posted March 31, 2018 Report Share Posted March 31, 2018 9 sati ranije, alI_Zée said: Некада и плоче желе да се одморе од досадних винилџија. ali zasto bi ??? Quote Link to comment Share on other sites More sharing options...
pompi Posted April 1, 2018 Author Report Share Posted April 1, 2018 21 sati ranije, Zexx said: Nema razlike u krajnjem rezultatu bez obzira na različit protok. Verujem i krenuo sam sa rezanjem. Quote Link to comment Share on other sites More sharing options...
pompi Posted April 1, 2018 Author Report Share Posted April 1, 2018 Opet ja da pitam. Imam rip mono ploce, prebacio bih je u 16/44, narezao ali voleo bih da narezano ostane mono. Pretpostavljam da se u Processing (foobar) cekira potrebna opcija. Koja bi to opcija bila? Hvala. Quote Link to comment Share on other sites More sharing options...
Father Posted April 1, 2018 Report Share Posted April 1, 2018 Mislim da Audio CD ne možes da snimiš iz mono wav faila, ili možeš ali će samo da se čuje levi kanal npr. Moraš da imaš stereo sa oba identična kanala i tako dobiješ mono na CD-u. Nisu mi poznati procesi, ali ako je fail u originalu deklarisan kao mono a zapravo je stereo samo ga prekonvertuj u 16/44.1 i snimaj na CD. Izbegavaj previše vratolomija sa informacijama jer će doći do veće degradacije kvaliteta nego što je potrebno ili očekivano downsamplingom. Quote Link to comment Share on other sites More sharing options...
pompi Posted April 1, 2018 Author Report Share Posted April 1, 2018 3 sati ranije, Father said: Izbegavaj previše vratolomija Hvala @Father. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted April 1, 2018 Report Share Posted April 1, 2018 (edited) Proveri u nekom programu tipa SoundForge ili Wavelab ili neki Adobe Audition da li imas mono snimak na oba kanala. To mozes i Foobaru preko Peak Meter opcije koja se upali u opciji View/Visualisation. Ako imas onda snimsi disk bez problema, ako nemas, onda izaberes taj jedan kanal i otvoris novi file sa dva kanala za stereo pa kopiras na drugi... mislim da tako ide proces, ali treba proveriti kod jos nekog i za ceo disk ili 45 min. ima da bude zezanja Edited April 1, 2018 by Krca44 Quote Link to comment Share on other sites More sharing options...
pompi Posted April 1, 2018 Author Report Share Posted April 1, 2018 26 minuta ranije, Krca44 said: da li imas mono snimak na oba kanala Ha.. pa ja imam samo jedan kanal?! Quote Link to comment Share on other sites More sharing options...
