steva Posted February 11, 2018 Author Report Share Posted February 11, 2018 Ko je u ovom topiku novi hifista? Prica se o servisu navedenog deka. Quote Link to comment Share on other sites More sharing options...
aco Posted February 11, 2018 Report Share Posted February 11, 2018 Niko nije rekao da si novi hifista.Za tu cenu sigurno vredi popraviti ga,ako može,ali dobre muzike se nećeš naslušati. Quote Link to comment Share on other sites More sharing options...
steva Posted February 11, 2018 Author Report Share Posted February 11, 2018 Aco, ovo je deo foruma gde se prica o servisu, a ne o zvuku i hifistima. Ako imas neku ideju, savet, kako da sredim dek, napisi, ako ne, preskoci. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 11, 2018 Report Share Posted February 11, 2018 Ма пусти хифисте шта си урадио до сада, има ли помака? Quote Link to comment Share on other sites More sharing options...
steva Posted February 12, 2018 Author Report Share Posted February 12, 2018 Za vikend nisam ništa radio. Danas ću, samo da nahvatam vreme. Quote Link to comment Share on other sites More sharing options...
steva Posted February 12, 2018 Author Report Share Posted February 12, 2018 Do sad sam zevao u njega. Definitivno ga ni jedan graničnik ne koči da dođe bliže kapstanu. Očistio sam i podmazao dd motor kao i reel motor, jel se čuje puckanje u zvuku kako reel motor radi. Sad je mnogo tiši. Razvukao msa i one oprugice što služe kao kočnice na reel točkićima, jer nema filca za kočenje. Kad malko primaknem roler kapstanu, ne jede traku, ovako traku privuče uz unutrašnju stranu kasete. Nemam više ideje, šta da gledam. Quote Link to comment Share on other sites More sharing options...
steva Posted February 12, 2018 Author Report Share Posted February 12, 2018 Snimak problema. Definitivno roler nema "grip" iz nekog razloga. Quote Link to comment Share on other sites More sharing options...
steva Posted February 12, 2018 Author Report Share Posted February 12, 2018 Fina šmirgla po roleru... Za sad radi, a sigurno nije trajno rešenje. Niko ne zna tačne dimenzije org. pinč rolera? Quote Link to comment Share on other sites More sharing options...
steva Posted February 12, 2018 Author Report Share Posted February 12, 2018 Dimenzije su 13.5mm, a ne 13 Oznaka je RXP0004. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 12, 2018 Report Share Posted February 12, 2018 2 sati ranije, steva said: Dimenzije su 13.5mm, a ne 13 Oznaka je RXP0004. Да потражим већи? Quote Link to comment Share on other sites More sharing options...
steva Posted February 13, 2018 Author Report Share Posted February 13, 2018 Ako imaš. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 13, 2018 Report Share Posted February 13, 2018 Онај твој мученик има да нас замрзи. Quote Link to comment Share on other sites More sharing options...
steva Posted February 13, 2018 Author Report Share Posted February 13, 2018 Samo da ponovo ide za BG. Pazi ovo, na pločici DD motora, ni jedan kond ne valja! SMD elektrolite ću da zamenim, al koji su ovi C209-211? Liče na ElKo, al u šemi nisu! Po šemi bi tu trebali da legnu neki blok kondenzatori. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 13, 2018 Report Share Posted February 13, 2018 Ух, тај 4,7µF/25V по шеми је униполаран а блок за тај називни напон мислим да не постоји. Mожда тантал http://www.kelco.rs/katalog/detalji.php?ID=3325 Или два на ред - ++- http://www.mikroprinc.com/proizvodi/pasivne-elektronske-komponente/kondenzatori/elektrolitski-kondenzatori/elektrolitski-radijalni-kondenzatori-25v/10/25-105c/index.php http://www.kelco.rs/katalog/detalji.php?ID=12517 Предходно проверити димензије ради уградње. Quote Link to comment Share on other sites More sharing options...
steva Posted February 13, 2018 Author Report Share Posted February 13, 2018 Ovo sam mislio da stavim. http://www.mgelectronic.rs/kondenzator-smd-višeslojni-1206-47µf Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 13, 2018 Report Share Posted February 13, 2018 Извињавам се превидео сам зарез. Ја бих ипак ту ставио електролит али може и тај мада ми јадно изгледа. Quote Link to comment Share on other sites More sharing options...
steva Posted February 13, 2018 Author Report Share Posted February 13, 2018 Još to ću da izmenjam i ako ne radi, ode u oglase. Možda će nekom da treba za delove. Quote Link to comment Share on other sites More sharing options...
steva Posted February 21, 2018 Author Report Share Posted February 21, 2018 Napredak? Zamenio kondenzatore na pločici DD motora, sad se ništa ne čuje i ne pucka, ali nikako da sredim brzinu. Kad pritisnem malo roler na gore, sve je ok, ovako zavija u pm! Interesantno je da kad sam zamenio roler, drugim, malo manjim od onog koju mi je vaN_Helsing poklonio, prestao je da žvaće traku. Zbunj! Na žalost, nemam osciloskop, EPS mu odavno presudio, da bih mogao da proverim kako radi stabilizacija brzine Quote Link to comment Share on other sites More sharing options...
steva Posted February 21, 2018 Author Report Share Posted February 21, 2018 Da li je moguće da dek ne podiže glave, i roler dovoljno? Siguran sam da nisam ništa pomerio, ali ko zna kako je sklopljen pre nego je stigo do mene. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 21, 2018 Report Share Posted February 21, 2018 1 sat ranije, steva said: Da li je moguće da dek ne podiže glave, i roler dovoljno? Siguran sam da nisam ništa pomerio, ali ko zna kako je sklopljen pre nego je stigo do mene. Могуће је. Quote Link to comment Share on other sites More sharing options...
steva Posted February 21, 2018 Author Report Share Posted February 21, 2018 Kad je dek reprodukuje, mehanizmu sa glavama fali oko 0.5mm da udaji u metalne graničnike. Mislim da je ok, al ko bi ga znao :(. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 21, 2018 Report Share Posted February 21, 2018 Извади механику па наново. Quote Link to comment Share on other sites More sharing options...
steva Posted February 22, 2018 Author Report Share Posted February 22, 2018 Uradio, sad ide tačno do graničnika. Sklapam kantu i odustajem! Oni trakasti kablovi i pripadajući konektori su muka živa!!! Quote Link to comment Share on other sites More sharing options...
safet Posted February 22, 2018 Report Share Posted February 22, 2018 i sad dali mu se diže ?? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 22, 2018 Report Share Posted February 22, 2018 4 minuta ranije, safet said: i sad dali mu se diže ?? Неки пут да а неки пут не. Quote Link to comment Share on other sites More sharing options...
