Bato - hi - fi Posted February 2, 2018 Report Share Posted February 2, 2018 Microfarad dje si ti, tj. odakle? Quote Link to comment Share on other sites More sharing options...
microfarad Posted February 2, 2018 Report Share Posted February 2, 2018 Beograd Quote Link to comment Share on other sites More sharing options...
Bato - hi - fi Posted February 2, 2018 Report Share Posted February 2, 2018 nijesam provjeravao, pise Mediterraneo pa se ponadah...da si u CG da ti po nekom busu posaljem. Quote Link to comment Share on other sites More sharing options...
Father Posted February 2, 2018 Report Share Posted February 2, 2018 Mislim da se dovoljno kolega saglasilo da se Aiwa CD pokloni @Bato - hi - fi i ja ne vidim ništa sporno u tome, a i niko se drugi nije prijavio pored njega. Pošaljite mi PP sa potrebnim podatcima i adresom za slanje u Srbiji i to je to. Quote Link to comment Share on other sites More sharing options...
Bato - hi - fi Posted February 2, 2018 Report Share Posted February 2, 2018 OK.Zahvaljujem i saljem ubrzo BG adresu za prijem uredjaja.Hvala jos jednom! Quote Link to comment Share on other sites More sharing options...
Father Posted February 2, 2018 Report Share Posted February 2, 2018 Može i taj tvoj kontakt direktno da dođe i preuzme uređaj od mene, ja sam isto iz Beograda. Možemo dalje na PP... Quote Link to comment Share on other sites More sharing options...
Bato - hi - fi Posted February 2, 2018 Report Share Posted February 2, 2018 Posalji mi pp, nesto me zeza ova skalamerija. Quote Link to comment Share on other sites More sharing options...
Spachek Posted February 2, 2018 Report Share Posted February 2, 2018 Moze to iz C.Gore bez problema da se protne nekim autobusom do Srbije/Beograda, salju ljudi sve i svasta a i vozaci su prilicno vesti kad su takve stvari u pitanju.Sent from my SM-A500FU using Tapatalk Quote Link to comment Share on other sites More sharing options...
borchee Posted February 2, 2018 Report Share Posted February 2, 2018 10 sati ranije, Father said: ... moram da ga prebijem Ih, dok istestiraš i odlučiš, čime bi da ga mlatiš, klinac će biti oženjen. Quote Link to comment Share on other sites More sharing options...
Father Posted February 2, 2018 Report Share Posted February 2, 2018 Eno ga, digao zvučnike na stalke (stolice IKEA Mamuth) i gruva Idole - Čikoladu Quote Link to comment Share on other sites More sharing options...
vladat1 Posted February 2, 2018 Report Share Posted February 2, 2018 Pratim ovu temu od početka, i žao mi je što nisam mogao pre da učestvujem. Početnik sam u ovim vodama i nemam baš mnogo stvari, a "hteo bih sve i odma" Ja poklanjam starijem - iskusnijem članu, kvalitetnije napajanje Nemic-Lambda za samougradnju. Manufacturer: Nemic-Lambda Model: ZD75-0524 Specifications: Manufacturer: Nemic-Lambda (TDK) Model: ZD75-0524 Description: Power Supply (Board Type) A.K.A: PWB-335F Output Power 63W (75W Max) Input Voltage: 100-120VAC 1.4A 50/60Hz 200-240VAC 0.7A 50/60Hz Output: V1: +5VDC 0.5 - 3.0A (6A Peak) V2: +24VDC 0.8 - 2.0A (3A Peak) Ovo napajanje sam nabavio sa konektorima. Napajanje je ispravno. Pošto sam nov ovde na forumu, i ne poznajem mnogo ljudi, predlažem da Kuršum i za mene napravi izbor. Ovo što sam napisao, da je za starijeg i iskusnijeg člana, je zbog toga što početnik ovo neće moći da ugradi. Originalne slike sutra. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted February 2, 2018 Report Share Posted February 2, 2018 Dobro vece ! Posto je ovo rubrika za poklanjanje hi fi aparata i uredjaja danas sam od kolege Solderer-a dobio na poklon Benz Micro MC Gold glavu. Ovde se zahvaljujem ! Dodatno imam jedno pitanje. Stoji mi neki aparati koji rade ali ne mogu se nazvati potpuno ispravnim. Da li dolazi u obzir poklanjanje takvih aparata ukoliko postoji zanimanje za njih ? Sto se tice stanja ja cu reci koliko znam sta nije u redu i sta bi serviser trebao da pogleda. Pozdrav, Krca Quote Link to comment Share on other sites More sharing options...
Spachek Posted February 2, 2018 Report Share Posted February 2, 2018 Bogami Krco bas te hoce, 2 ove godine u zdravlju da te sluze, samo "ori" Sent from my SM-A500FU using Tapatalk Quote Link to comment Share on other sites More sharing options...
gvlada Posted February 2, 2018 Report Share Posted February 2, 2018 Да ли се може напајање искористити за пи 3 дак? Пријавио бих се за њега, ако је то у реду са заједницом. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted February 2, 2018 Report Share Posted February 2, 2018 1 hour ago, Spachek said: Bogami Krco bas te hoce, 2 ove godine u zdravlju da te sluze, samo "ori" Hvala ! Neka i tebe sluzi u zdravlje Quote Link to comment Share on other sites More sharing options...
Bato - hi - fi Posted February 3, 2018 Report Share Posted February 3, 2018 Da se zahvalim clanu Father , cd plejer je stigao danas na adresu u BG.Cim prije cu se postarati da posaljem svoj dek RSB 705.Dogovorite se ko bi bio primalac.Moje misljemnje je da bi Microfarad trebao da dobije, ali vi odlucite.Nadam se da cu nekog sofera nagovoriti, a primalac bi morao da ga prihvati u BG.O tom, potom. Quote Link to comment Share on other sites More sharing options...
Father Posted February 3, 2018 Report Share Posted February 3, 2018 Neka je sa srećom i dugovečno uživanje u muzici. Quote Link to comment Share on other sites More sharing options...
fule99 Posted February 3, 2018 Report Share Posted February 3, 2018 Pozdrav momci, u potrazi sam za vintage tunerom i gramofonom, e sad ako nekome smeta i spreman ga je pustiti za neku simbolicnu cijenu ili poloniti, vrlo rado cu udomiti i pridružiti mom rotelu i BW sviraljkama. Živili!Sent from my Mi 4i using Tapatalk Quote Link to comment Share on other sites More sharing options...
vladat1 Posted February 3, 2018 Report Share Posted February 3, 2018 Evo i slika. Javio se za sada @gvlada, a ako nekog još zanima neka je javi Kuršumu Quote Link to comment Share on other sites More sharing options...
Тодор НС Posted February 3, 2018 Report Share Posted February 3, 2018 Kako su stvari počele da se odvijaju uskoro ćemo osim Šćepanove emisije dobiti i novu "S Kuršumom u akciji". Quote Link to comment Share on other sites More sharing options...
Kuršum Posted February 3, 2018 Report Share Posted February 3, 2018 Ja rekoh da ne želim ulogu forumskog sudije. Poklanjajte svoje uređeje kome vi želite. Tako će biti svi mirni. I nemojte da brinete o tome da li ste učinili pravi izbor, neka vas usreći sam čin poklanjanja. Bojim se da će ova tema neminovno jednog dana izazvati polemiku, kad se sličan ili baš poklonjen uređaj nađu na KP-u. To mislim ne treba da brine onog ko poklanja. To i jeste suština poklona. O onom ko poklon primi, pa eventualno izazove polemiku, neću ni da pričam. Zato ne mogu ja da budem taj koji sudi. Dajte onom ko se prvi javi ili ko vas ubedi da mu je potrebno ili onom ko vam je simpatičan, svejedno. Prihvatio sam predlog koji je dao @zarko1803 i to je to (mada još nisam načinio izbor, nije mi se ukazao pravi put). Dodatno sam pogurao stvar da @Father-ovog sinčića obraduje BD plejer i evo za treću sreću mogu reći i da ne vidim zašto napajanje ne bi dobio @gvlada ako već zna šta će sa njim i treba mu. I da nadalje završimo sa mojim učešćem u ovoj temi na ovakav način. Oglasiću se kad budem imao šta da poklonim. A i tu sam omanuo, obećao sam članu @DobriDiv kablove zvučničke i interkonekt još pre dva meseca i još mu nisam poslao. Malo zbog obaveza ne stižem, a malo što počinjem da lapim polako, pa zaboravim. Svejedno sramota. Quote Link to comment Share on other sites More sharing options...
Father Posted February 3, 2018 Report Share Posted February 3, 2018 Hvala @Kuršum , ja sam se baš iz tog razloga i obratio članstvu da predloži ili podrži nekoga za koga misle da će uređaj koji se pokalnja otići u prave ruke. Slažem se sa tobom i tvojom ulogom u ovoj temi i ne nalazim za potrebno da arbitriraš dalje od poklona koje je pokretač teme uslovio tvojom odlukom. Meni je bilo dovoljno da se dva člana založe za trećeg i dan pauze za amandmane, kojih nije bilo i poklon ode u prave ruke, što se mene tiče. Quote Link to comment Share on other sites More sharing options...
gvlada Posted February 3, 2018 Report Share Posted February 3, 2018 Идеја за напајање је да се тестира какав звук може да се извуче из пи 3 дака. Рингераја је дао пар савета из искуства, те мислим да вреди пробати. Quote Link to comment Share on other sites More sharing options...
vladat1 Posted February 3, 2018 Report Share Posted February 3, 2018 Ja mogu samo da dam još predlog za kutiju , kako bi izgleda, gde bi se spakovalo sve to. Ovo sam nešto hteo za sebe Quote Link to comment Share on other sites More sharing options...
