surferlola Posted January 5, 2018 Report Share Posted January 5, 2018 Prva serija, iz 1971. , sa T27 i B110, preteca cuvenih LS3/5A. Bili su odlicno ocuvani, ali mi je jedan ispao i ostecena mu je prednja desna ivica. Ostecenje je kozmeticko, ne utice na reprodukciju. Sto se tice zvuka, visoki i srednji odlicni, basa nedostaje, pa ko voli. . Bez zamena, 120 eur! System type: Two-way, bookshelf Enclosure type: Closed box Input Impedance: 8 ohms Rated Maximum Power: 20 W programme Amplifier Requirements: 15 - 20 watts per channel into 8 ohms System Resonance: 60Hz Nominal Frequency Range: 50 - 40,000 Hz Specific Frequency Response: 85 Hz - 30,000 Hz ±4 dB Crossover Frequency: 3500Hz Sensitivity: 96 dB (19 W into 8 Ω at 1m in anechoic conditions) Finishes: Walnut, Teak, White Grille: Brown Grey, Beige System: SP1034 Drive units: B110 bass unit (SP1003), T27 tweeter (SP6535) Crossover: SP1035 Internal Volume: 7,26 litres Dimensions (W x H x D): 230 x 330 x 146 mm (9 x 13 x 5.75 inches) Weight: 5 kg (10.4 lb) net each Link to comment Share on other sites More sharing options...
surferlola Posted February 15, 2018 Author Report Share Posted February 15, 2018 aktuelno Link to comment Share on other sites More sharing options...
surferlola Posted March 16, 2018 Author Report Share Posted March 16, 2018 aktuelno, i dalje Link to comment Share on other sites More sharing options...
surferlola Posted April 23, 2018 Author Report Share Posted April 23, 2018 lock Link to comment Share on other sites More sharing options...
