Father Posted January 27, 2021 Report Share Posted January 27, 2021 Povremeno imam problem kada pilotiram iz mconnect lite app na telefonu, da mu zaledi otvaranje foldera na kompu gde je muzika. Ili da mi oppo koji je na switch-u ne reaguje na play ili stop. Odglavi on posle 10sec, ali nekada nastavi da kočaka, a nekada proradi normalno. Pa me to malo nervira. Možda je i do telefona i wifi veze, ne mogu sa sigurnošću da znam. Ovako računar na rooteru i računar, oppo i TV na switchu u dnevnoj rade sasvim ok. Možda je do Redmi 8 ili wifi-a na troantenskom TP-LINK TL-WR1043ND rooteru...? Quote Link to comment Share on other sites More sharing options...
garson Posted January 27, 2021 Report Share Posted January 27, 2021 Da, ne deluje kao da je problem sa switch-om. Uvek prvo posumnjam na wi-fi nego na switch. Quote Link to comment Share on other sites More sharing options...
Father Posted January 27, 2021 Report Share Posted January 27, 2021 Onda je u rooteru neko podešavanje. Umeju ukućani da se požale da im nestane net na telefonima iznenada i rekao bih često. Bar jednim u nedelji. Samo nestane sa spiska wifi mreža. Quote Link to comment Share on other sites More sharing options...
somilenko Posted January 27, 2021 Report Share Posted January 27, 2021 2.4 ili 5 GHz?Sent from my ONEPLUS A6003 using Tapatalk Quote Link to comment Share on other sites More sharing options...
garson Posted January 27, 2021 Report Share Posted January 27, 2021 Eto onda glavnog osumnjicenog. Quote Link to comment Share on other sites More sharing options...
Green Posted January 27, 2021 Report Share Posted January 27, 2021 1 sat ranije, nkrgovic said: Aruba InstantON, recimo. Bivsi HP bivsi itd... Ma bre 1930 switch. To radi, provereno i dobro. Mislim da je oko 16,000 dinara za po kuci to radi sasvim OK, proveren uredjejaj, radi. Hvala za predlog , ipak malo premašuje planirani budžet . Ne sumnjam da je u pitanju odličan switch. Neki max.koji bih bio spreman da izdvojim je recimo 8.000 din. Quote Link to comment Share on other sites More sharing options...
Father Posted January 27, 2021 Report Share Posted January 27, 2021 1 sat ranije, somilenko said: 2.4 ili 5 GHz? 2.4 Ghz Quote Link to comment Share on other sites More sharing options...
somilenko Posted January 27, 2021 Report Share Posted January 27, 2021 Po mom iskustvu, pogotovo u zgradama, 2.4 GHz je debelo zagušen i preopterećen, pored kućnih bežičnih uređaja i mobilnih telefona, koriste ga i bežični fiksni.Pređi na 5 GHz, tj ac standard, meni je to rešilo sve probleme, manjeg je dometa ali ima i manje neprijatelja i mnooogo veću brzinu.2.4 GHz ostavi kao paralelnu za starije uređaje ako moraš a na 5 GHz prebaci sve što možeš...Meni se ovaj ruter pokazao odlično a ne košta puno...https://www.tehnomanija.rs/it-shop/ruteri/tp-link-ruteri-archer-c6.html Sent from my ONEPLUS A6003 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Delija Posted January 27, 2021 Report Share Posted January 27, 2021 Radi i 2.4 GHz ok sa dobrim router-om. Quote Link to comment Share on other sites More sharing options...
nkrgovic Posted January 27, 2021 Author Report Share Posted January 27, 2021 27 minuta ranije, Green said: Hvala za predlog , ipak malo premašuje planirani budžet . Ne sumnjam da je u pitanju odličan switch. Neki max.koji bih bio spreman da izdvojim je recimo 8.000 din. TP-Link TL-SG1008D, ispod 3000 dinara. Kolege ih koriste u par firmi po kancelarijama, kao "razvod". Radi, ne pravi probleme... Nije cudo u boji, ali za pristojan switch za po kuci, za te pare - radi. Quote Link to comment Share on other sites More sharing options...
Father Posted January 27, 2021 Report Share Posted January 27, 2021 Hvala momci! Iščačkaću nešto. Možda da mi predložite neko rešenje rootera na 5GHz. Da malo promenim. Imam ovat TP-Link već baš dugo, pa od kad je sada sve i svašta na njega nakačeno hoće da uđe u tilt. Inače taj TP je Wan spojen na SBB rooter kome sam ugasio njegov wifi. Od TP rootera imam razvod do soba, a samo u dnevnoj imam 5‑Port Gigabit Easy Desktop Switch GO‑SW‑5G koji dalje prosleđuje na 4 uređaja (Oppo, MultMedia kompjuter, TV LG i Sbb D3 box) Quote Link to comment Share on other sites More sharing options...
Father Posted January 27, 2021 Report Share Posted January 27, 2021 17 minuta ranije, somilenko said: Meni se ovaj ruter pokazao odlično a ne košta puno... https://www.tehnomanija.rs/it-shop/ruteri/tp-link-ruteri-archer-c6.html Hvala, promaklo mi ovo!? Quote Link to comment Share on other sites More sharing options...
somilenko Posted January 27, 2021 Report Share Posted January 27, 2021 Radi i 2.4 GHz ok sa dobrim router-om.Nznm, imao sam solidne Cisco rutere ranije i jeste to nekada radilo ok, ali nije bio toliko zakrčen wifi saobraćaj. Kada uključim wifi analyzer i vidim 20 mreža u okolini koje pokušavaju da se rasporede na 14 kanala, odlučio sam da pobegnem na 5 GHz. Dobro 2.4 GHz radi dok god sam blizu rutera, ali čim se malo odaljim i pojavi se 2 zida, počne da zeza...U prilogu slika mog wifi okruženja...Sent from my ONEPLUS A6003 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Father Posted January 27, 2021 Report Share Posted January 27, 2021 Komšiji Đorđeviću najveći!! Quote Link to comment Share on other sites More sharing options...
somilenko Posted January 27, 2021 Report Share Posted January 27, 2021 Da, njegov ruter ima samo jedan zid do dnevne a moj na 2 i fizički dalji, pa ispade da je moj manji (stvar percepcije, dobar je on, tešim se...)Ali zato na 5 GHz dominiram... Sent from my ONEPLUS A6003 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Father Posted January 27, 2021 Report Share Posted January 27, 2021 2 minuta ranije, somilenko said: Ali zato na 5 GHz dominiram... E to je to. Aj sad komša Dorđević nešto da doda na skupštini stanara ako sme. Quote Link to comment Share on other sites More sharing options...
Filipescu Posted January 27, 2021 Report Share Posted January 27, 2021 Цена права ситница. 12к Quote Link to comment Share on other sites More sharing options...
garson Posted January 27, 2021 Report Share Posted January 27, 2021 39 minuta ranije, Father said: Hvala momci! Iščačkaću nešto. Možda da mi predložite neko rešenje rootera na 5GHz. Da malo promenim. Imam ovat TP-Link već baš dugo, pa od kad je sada sve i svašta na njega nakačeno hoće da uđe u tilt. Da, secam se po dizajnu tih TP Link rutera, matoro je to. Imam pozitivna iskustva sa Asus ruterima (dobar SW, cesto izbacuju nove verzije tj fixeve), nesto ovako npr. https://www.tehnomanija.rs/it-shop/ruteri/asus-90ig0550-bm3410.html https://www.tehnomanija.rs/it-shop/ruteri/asus-rt-ac1200-v2.html Quote Link to comment Share on other sites More sharing options...
somilenko Posted January 27, 2021 Report Share Posted January 27, 2021 Da malo "osvežimo" temu - može li neki konkretan predlog za ethernet switch (sa napajanjem ili PoE, šta smatrate da je bolje)? Za kućnu upotrebu , 5-6 portova , mada mi realno ne treba više od 3 (audio server , audio steramer i EON).Meni ovaj završava posao, nisam primetio neke probleme sa njim...https://gigatron.rs/switch-uredjaji/dlink-switch-dgs-1008d-68761Sent from my ONEPLUS A6003 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Green Posted January 28, 2021 Report Share Posted January 28, 2021 Hvala , i budžet ste mi sačuvali Def. 1008D , tvoj ili @nkrgovic-ev predlog. Quote Link to comment Share on other sites More sharing options...
misko1989 Posted January 28, 2021 Report Share Posted January 28, 2021 Imam 1005D, radi bez ikakvih problema. Quote Link to comment Share on other sites More sharing options...
bkrmar Posted January 28, 2021 Report Share Posted January 28, 2021 Ja sam od SBB dobio neki francuski, kako ga je SBB nazvao "industrijski" modem/ruter koji je navodno mnogo bolji od nekog običnog što daju za gradjanstvo. Kod mene 2.4Ghz je blago rečeno užas. Živim u centru, okružen sa ko zna koliko telefona koji rade na 2.4 Ghz, rutera, HAARP-a i ko zna čega još... Na 2.4 Ghz je sporo da sporije ne može biti do te mere da često kačim LAN kabl na laptop (moj laptop nema 5Ghz) Kada sam na 5Ghz na telefonu, radi net odlično ali signal ume da se izgubi. Da li je do rutera ili nečeg drugog, ne znam. Problem je što će za par godina da i 5 Ghz biti zagušen i onda eto nas na kablu opet... Quote Link to comment Share on other sites More sharing options...
Spachek Posted January 28, 2021 Report Share Posted January 28, 2021 Kontaktiraj korisnicki servis, mozda ti oni rese problem.Sent from my SM-A530F using Tapatalk Quote Link to comment Share on other sites More sharing options...
garson Posted January 28, 2021 Report Share Posted January 28, 2021 Krenusmo od "audiofilskog" switch-a, preko HPa od 150e i zavrsismo na najjeftinijim varijantama (TP-Link/D-LInk). Al dobro, za kucu to savrseno radi posao. Quote Link to comment Share on other sites More sharing options...
Pedjica Posted January 28, 2021 Report Share Posted January 28, 2021 “Audiophile switch” — u narodu poznatiji kao snake oil. Quote Link to comment Share on other sites More sharing options...
