Dragan Radosevic Posted September 24, 2017 Report Share Posted September 24, 2017 dobro vece. kako naslov kaze zelim da napravim zvucu kutiju,zapravo 2. imam resiver hk 3770 imam dva niskotonska zvucnika b&w signature 8 nt - 8ohm 90db 33-500hz imam dva auto zvucnika infinity 5032 -2ohm 92db 67-21khz plan je da niski radi do 500hz a preko da pruzme ovaj drugi zvucnik . kutije bi sam pravio tu mi je manje vise sve jasno, pomoc mi treba oko skretnice kako da dobijem rez na 500hz citao sam literaturu i saznao da mi minimum treba kalem da bas ne dobija cijeli spektar i kondenzator da visoki ne dobija sve. koliki kalem i koji kondenzator? unapred hvala ps. moderatoru sorry ako sam promasio lokaciju teme -premjesti po sopstvenom nahodjenju? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 24, 2017 Report Share Posted September 24, 2017 То би била скретница 12dB/Oct, значи калем 3,9mH i кондезатор 27µF. Предпостављам да знаш како да повежеш? Quote Link to comment Share on other sites More sharing options...
Dragan Radosevic Posted September 24, 2017 Author Report Share Posted September 24, 2017 pa.... nisam siguran citao sam da ide na plus sa pojacala se zaletuje kalem 1 kraj a drugi na + zvucnika za bas a prije kalema se zaletuje kond na + za visoki imam skretnicu od ovog bowersa mogu li tu nesto iskoristit? https://ibb.co/c3bGdk Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 24, 2017 Report Share Posted September 24, 2017 Ево како изгледа шема скретнице. Quote Link to comment Share on other sites More sharing options...
Dragan Radosevic Posted September 24, 2017 Author Report Share Posted September 24, 2017 https://ibb.co/koaL4Q Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 24, 2017 Report Share Posted September 24, 2017 41 minuta ranije, Dragan Radosevic said: imam skretnicu od ovog bowersa mogu li tu nesto iskoristit? Јел знаш вредности пригушница? Quote Link to comment Share on other sites More sharing options...
Dragan Radosevic Posted September 24, 2017 Author Report Share Posted September 24, 2017 ne. okacio sam sliku mozes li ti pogledat Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 24, 2017 Report Share Posted September 24, 2017 Поглед'о сам и не знам. Quote Link to comment Share on other sites More sharing options...
Dragan Radosevic Posted September 24, 2017 Author Report Share Posted September 24, 2017 dobro . aj da se koncentrisemo na ovo sto znamo. znas li dje mogu da kupim 2 kondenzatora u cg od 27 mf i koja marka je solidna Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted September 24, 2017 Report Share Posted September 24, 2017 Kakvu kutiju misliš da praviš za bas drajver? Pogledao sam malo PDF za Signature, ta kutija ima dve bas jedinice i na taj način proizvodi 90dB. Ako imaš samo jedan takav drajver (za jednu kutiju) računaj -3dB, što je 87dB. Takođe, verujem da je izmerenih 33Hz (-3dB) iz male kompresione kutije moguće samo ako je kutija pri merenju bila prislonjena uz zid, što je i razumljivo, jer je kutija in-wall. Nemoj da se iznenadiš ako ovo tvoje bude zvučalo tanko, pogotovo ako praviš običnu kutiju, s namerom da je slušaš na uobičajeni način - udaljenu od zida. Quote Link to comment Share on other sites More sharing options...
Dragan Radosevic Posted September 24, 2017 Author Report Share Posted September 24, 2017 sto je tu je . imam vec zvucnike ne kupujem ih pa da biram. nisam zahtevan. za 1 projekt je sasvim cool. kompresionu kutiju bi pravio s odvojenom komorom za infiniti ref 5032 unutar . zvucnici bi bili 1 iznad drugog Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted September 24, 2017 Report Share Posted September 24, 2017 Moraćeš na skretnici da značajno utišaš Infinity. Na 500Hz uopšte ga ne bih utišavao - on će značajno pojačati bas, a od dole ništa nije "kraći" nego B&W. Samo bih utišao B&W iznad 500Hz. Ako napraviš uzanu kutiju (oko 20cm), taman će odziv početi da pada, zbog baffle step-a, negde oko 500Hz. Tako da bi, uz malo sreće, sve moglo prilično dobro da se dopuni. Quote Link to comment Share on other sites More sharing options...
Dragan Radosevic Posted September 25, 2017 Author Report Share Posted September 25, 2017 al infiniti je na 2 oma mora neki kond da ne bi zgorio Quote Link to comment Share on other sites More sharing options...
Dragan Radosevic Posted September 25, 2017 Author Report Share Posted September 25, 2017 probao sam danas infiniti sa 30mf kond ... mnooogo ga visoko kida treba manji neki Quote Link to comment Share on other sites More sharing options...
zek Posted September 25, 2017 Report Share Posted September 25, 2017 Evo malo za zabavu http://web.vip.hr/bicpark.vip/pocetnici/zvucnici/1skretnica_pasivna.htm Quote Link to comment Share on other sites More sharing options...
Dragan Radosevic Posted September 25, 2017 Author Report Share Posted September 25, 2017 hvala. nema u Tivat dje da se kupe kondenzatori al nasao sam jednu radnju u pg pa cu poc uskoro i kupit nekoliko parova pa da probam na uvo taman da osmislim kutije detaljno palo mi je na pamet nesto odprilike sirina25xvisina40xdubina35 cm kompresija. dampiranje azmafonom infiniti isto u kompresiju unutar. mada prihvatam predloge iskusnijih oko kabineta Quote Link to comment Share on other sites More sharing options...
jager Posted September 25, 2017 Report Share Posted September 25, 2017 A da odeš do Zlatka kad si već u Tivtu . Zastupnik je visatona , ima on djelova i iskustva , vjerujem da ćeš dobiti poneki savjet. Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted September 25, 2017 Report Share Posted September 25, 2017 10 sati ranije, Dragan Radosevic said: al infiniti je na 2 oma mora neki kond da ne bi zgorio Zaboravio sam na ovo. Ali, ovaj drajver je, verovatno, neki dual concentric, pa ako je tviter isto na dva Oma, opet će se spaliti? Quote Link to comment Share on other sites More sharing options...
Dragan Radosevic Posted September 26, 2017 Author Report Share Posted September 26, 2017 moze li br tel ili neki kontakt od tog momka sto zastupa visaton. pise u specifikacije da je 2 ohm / Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 26, 2017 Report Share Posted September 26, 2017 On 9/25/2017 at 12:31, Dragan Radosevic said: al infiniti je na 2 oma mora neki kond da ne bi zgorio Какав сад Висатон? Quote Link to comment Share on other sites More sharing options...
Dragan Radosevic Posted September 26, 2017 Author Report Share Posted September 26, 2017 neki momak u Tivtu zastupa visaton, cuo sam i ranije za njega al nisam ga upoznao jos, mozda moze da mi pomogne oko kalema i kondenzatora. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 26, 2017 Report Share Posted September 26, 2017 6 minuta ranije, Dragan Radosevic said: neki momak u Tivtu zastupa visaton, cuo sam i ranije za njega al nisam ga upoznao jos, mozda moze da mi pomogne oko kalema i kondenzatora. А то. па што не кажеш.................http://www.visaton.de/en/service/marketing/europa/Montenegro/index.html Quote Link to comment Share on other sites More sharing options...
Dragan Radosevic Posted September 26, 2017 Author Report Share Posted September 26, 2017 to buraz ... razbijas internet. hvala Quote Link to comment Share on other sites More sharing options...
jager Posted September 26, 2017 Report Share Posted September 26, 2017 8 minuta ranije, Dragan Radosevic said: neki momak u Tivtu zastupa visaton, cuo sam i ranije za njega al nisam ga upoznao jos, mozda moze da mi pomogne oko kalema i kondenzatora. Nije momak al je dobar čovjek i veliki znalac Šaljem ti broj na pp . Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted September 26, 2017 Report Share Posted September 26, 2017 1 minut ranije, Dragan Radosevic said: to buraz ... razbijas internet. hvala Их Quote Link to comment Share on other sites More sharing options...
