rankot Posted August 21, 2017 Report Share Posted August 21, 2017 Dvoumim se između ova dva pojačala, AX-930 je starije, ali jače za 20W po kanalu i ima bolji damping faktor. AX-930: Power output: 130 watts per channel into 8Ω (stereo) Frequency response: 10Hz to 50kHz Total harmonic distortion: 0.005% Damping factor: 500 Year: 1990 AX-892: Power output: 115 watts per channel into 8Ω (stereo) Frequency response: 20Hz to 20kHz Total harmonic distortion: 0.008% Damping factor: 320 Channel separation: 50dB (line) Year: 1997 Da li je neko imao iskustva sa njima i kakvi su utisci? Koristio bih pojačalo za Dynaudio BM15P zvučnike u studiju. Quote Link to comment Share on other sites More sharing options...
aco Posted August 21, 2017 Report Share Posted August 21, 2017 Ax 930 Quote Link to comment Share on other sites More sharing options...
Margioni Posted August 21, 2017 Report Share Posted August 21, 2017 Gledano sa tehničke strane, moja preporuka je Yamaha ax-892, jer je tehnički izuzetna. Kod mene u kafiću je svirala danonoćno, u teškim uslovima i to bez ijedne greške, spojena sa 2 para Mission m70 zvučnika, doduše, bilo je to pre 15 godina. Nisam imao prilike da čujem ovo drugo pojačalo, tako da ne mogu da ih uporedim, ali što se tiče izgleda, 12 points goes to ax-892. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted August 21, 2017 Report Share Posted August 21, 2017 AX-892 je odlično pojačalo Iz iskustva ... Quote Link to comment Share on other sites More sharing options...
aco Posted August 21, 2017 Report Share Posted August 21, 2017 A 930 jos bolje. Quote Link to comment Share on other sites More sharing options...
Krnjevac Posted August 22, 2017 Report Share Posted August 22, 2017 Nijedno od pomenutih......i uzmes Yamahu A-1000 Quote Link to comment Share on other sites More sharing options...
Delija Posted August 22, 2017 Report Share Posted August 22, 2017 Ipak AX-1090 Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted August 22, 2017 Report Share Posted August 22, 2017 Не, боље CA-2010. Quote Link to comment Share on other sites More sharing options...
Delija Posted August 22, 2017 Report Share Posted August 22, 2017 Ma jok. To je starije i od mene Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted August 22, 2017 Report Share Posted August 22, 2017 Ал' свира Quote Link to comment Share on other sites More sharing options...
Delija Posted August 22, 2017 Report Share Posted August 22, 2017 Pa realno i izgleda Slab sam na VU metre Quote Link to comment Share on other sites More sharing options...
rankot Posted August 22, 2017 Author Report Share Posted August 22, 2017 Hvala svima na odgovorima, pitao sam koje je bolje od ova dva, jer ta dva mogu da nabavim. Sigurno da ima boljih od njih, ali to nije tema trenutno. Bitna su mi mišljenja ljudi koji su ih imali. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted August 22, 2017 Report Share Posted August 22, 2017 Е ако је тако онда 892, јесте маторији али по мом укусу направљен како треба. Гледајући електричне шеме оба ампа то су 95% исти уређаји само што је код 930 преовладала модернизација(појефтињење производње) те су сви излазни транзистори монтирани на један хладњак док код 892 није случај. О звуку не бих али мислим да то исто свира. Quote Link to comment Share on other sites More sharing options...
Chieftec Posted August 22, 2017 Report Share Posted August 22, 2017 Zar nije 892 noviji Quote Link to comment Share on other sites More sharing options...
Technicssss Posted August 22, 2017 Report Share Posted August 22, 2017 Yamaha AX-892 je novija, a AX-930 ima vise snage sto se i ne primecuje ukoliko se koriste zvucnici normalne ili nesto vece osetljivosti. Da se ja pitam AX-900 je bolja od oba U svakom slucaju nije neka drasticna razlika u zvuku. Od ta dva AX-930 ima kvalitetnije napajanje (bolji trafo i kondove) sto doprinosi nesto boljoj kontroli bass-a (veci damping faktor). AX-892 iznutra podseca na dual mono fazon sa simetricnim stranama, tako su poceli da ih prave od AX-x50 serije. Quote Link to comment Share on other sites More sharing options...
rankot Posted August 22, 2017 Author Report Share Posted August 22, 2017 Hvala! Izgleda da ću ipak uzeti 930. Quote Link to comment Share on other sites More sharing options...
