Aoxomoxoa Posted July 30, 2017 Report Share Posted July 30, 2017 Debljine 1.5-2mm,dimenzije 41.2 x 19.2. Kao na slici Ne znam od cega je(zuta je),da li moze aluminijum(da se lako busi) Quote Link to comment Share on other sites More sharing options...
miletrosak Posted July 30, 2017 Report Share Posted July 30, 2017 Moze aluminijum da se eloksira u razne boje ali nisam siguran da moze u zutu.Sigurno moze u sivo crnu i neku nijansu zelene. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 30, 2017 Report Share Posted July 30, 2017 1 sat ranije, Aoxomoxoa said: Ne znam od cega je(zuta je),da li moze aluminijum(da se lako busi) Може. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted July 30, 2017 Author Report Share Posted July 30, 2017 I,kako kaze tema,gde da kupim Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 30, 2017 Report Share Posted July 30, 2017 41.2 x 19.2 ово су димензије у мм или у цм? Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted July 30, 2017 Author Report Share Posted July 30, 2017 cm naravno Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 30, 2017 Report Share Posted July 30, 2017 Имам ново парче Ал. лима али 3мм дебљине. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted July 30, 2017 Author Report Share Posted July 30, 2017 Mnogo, 1.5-2 Quote Link to comment Share on other sites More sharing options...
vladat1 Posted July 30, 2017 Report Share Posted July 30, 2017 Ja bih obložio sve to u Orahovnu. Naravno posle toga samo neko kvalitetnije ulje za drvo. Quote Link to comment Share on other sites More sharing options...
prophet Posted July 30, 2017 Report Share Posted July 30, 2017 To gore lici na bakar ili nesto pobakrenisano. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 31, 2017 Report Share Posted July 31, 2017 13 sati ranije, Aoxomoxoa said: Mnogo, 1.5-2 Ух, 1мм квари дизајн када се оборе ивице 1мм под углом од 45 степени биће далеко лепше парче лима. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted July 31, 2017 Author Report Share Posted July 31, 2017 Nema obaranja ivica,jer je gornja ploca pojacala 2mm ispod stranica i prednje ploce,pa ce ta ploca biti u ravni sa njima. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 31, 2017 Report Share Posted July 31, 2017 Страна која је оборена окрене се према уређају, значи надоле и тако ће плоча изгледати да лебди. Ух, претер'о сам . Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted July 31, 2017 Author Report Share Posted July 31, 2017 Jesi Quote Link to comment Share on other sites More sharing options...
ManicP Posted August 2, 2017 Report Share Posted August 2, 2017 Ako je potreban sirov materijal guglati "rajan" ili "metali online". Ako je potreban gotov proizvod kontaktirati člana foruma Leonardo. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted August 2, 2017 Report Share Posted August 2, 2017 Рајан не продаје комаде малих димензија. Quote Link to comment Share on other sites More sharing options...
ab Posted August 2, 2017 Report Share Posted August 2, 2017 http://jeepcommerce.rs/proizvodnja/proizvodnja-sdc/proizvodnja-sdc-cnc-laser/ Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted August 3, 2017 Author Report Share Posted August 3, 2017 Hvala,svraticu. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted August 4, 2017 Author Report Share Posted August 4, 2017 Hvala svima na sugestijama,ali cu ipak ostaviti pojacalo kako jeste.Nekako su mi se ove stranice od oraha uklopile sa crnom plocom. Gde mogu da se kupe plasticne zastitne kapice za srafove? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted August 4, 2017 Report Share Posted August 4, 2017 15 minuta ranije, Aoxomoxoa said: Nekako su mi se ove stranice od oraha uklopile sa crnom plocom. То ти причам Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted August 4, 2017 Author Report Share Posted August 4, 2017 A kapice? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted August 4, 2017 Report Share Posted August 4, 2017 Какве капице? Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted August 4, 2017 Author Report Share Posted August 4, 2017 Da pokriju glavu srafa. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted August 4, 2017 Report Share Posted August 4, 2017 То си мог'о и сам да нађеш. http://www.axon.rs/subcategory.asp?gpcid=16&cid=162 Quote Link to comment Share on other sites More sharing options...
zek Posted August 4, 2017 Report Share Posted August 4, 2017 Tamo gde prodaju kant trake, postoje okrugli stikeri u raznim bojama, ranije su bile plastične kapice za krstaste glave šrafova - ne znam ima li ih još. Quote Link to comment Share on other sites More sharing options...
