petarjovic Posted November 26, 2020 Report Share Posted November 26, 2020 Imam jedno pitanje, ovaj album sam imao na Tidalu proletos dok sam ga probao free i namestio VPN America. Nedavno sam se priključio jednoj familiji koja je registrovala u Nemačkoj i nema na Tidalu tog albuma! Zasto? Quote Link to comment Share on other sites More sharing options...
Aibo Posted November 26, 2020 Report Share Posted November 26, 2020 Sam si sebi odgovorio. Zato što je nalog iz druge države a katalog se razlikuje po državama jer prava na distribuciju često nisu globalna. US ima najbogatiji katalog. Quote Link to comment Share on other sites More sharing options...
Preddrag Posted November 26, 2020 Report Share Posted November 26, 2020 @Aibopitanje za qobuz sa ebaya, jel to 5,99$ za 6 meseci i da li postoji neki problem, ako je Srbija u pitanju (jel treba onaj VPN i sl.)? Quote Link to comment Share on other sites More sharing options...
Aibo Posted November 26, 2020 Report Share Posted November 26, 2020 Ja sam platio 7€ za 6 meseci, to je najjeftinije što sam našao... Možda jer sam sa eBay.uk naloga uzeo. Ali to je to otprilike.Nema problema i potrebe za VPN. Iz mconnect se spaja bez problema. Qobuz app ne mogu da nađem na PlayStore zbog lokacije ali sam skinuo APK i kad se instalira radi bez problema. Quote Link to comment Share on other sites More sharing options...
Preddrag Posted November 26, 2020 Report Share Posted November 26, 2020 Ok. Hvala puno. Quote Link to comment Share on other sites More sharing options...
Spachek Posted November 26, 2020 Report Share Posted November 26, 2020 Preko Aptoide moze da se instalira Tidal, bez obzira na lokaciju. Ima u temi, ne mogu da se setim koji je od kolega to predlozio kao resenje za zemlje treceg sveta. Sent from my LG-G6 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Aibo Posted November 26, 2020 Report Share Posted November 26, 2020 Usput, vrlo korisna lokacija: https://www.tunemymusic.com/ Automatski prebaci sve playliste, omiljene pesme, albume i izvođače sa bilo kog servisa na bilo koji drugi. Meni je uspešno prebacio sve sa TIdal na Qobuz. Plaćena verzia čak ima autosync i neke perverzije... ali i u besplatnoj varijanti je vrlo korisna stvar. Quote Link to comment Share on other sites More sharing options...
CoyoteKG Posted November 26, 2020 Report Share Posted November 26, 2020 Ja eksportovao u txt fajl, ali kad videh kako izgleda, ncini mi se da su samo nazivi pesama. sutra mi istice free, pa planiram da uzmem nesto sa ebay Quote Link to comment Share on other sites More sharing options...
ivanp Posted November 26, 2020 Report Share Posted November 26, 2020 Uzeo sam od Italijana sa Ebaya šest meseci HiFi ja za 6 dolara. Radi super! Uz 2 sati ranije, Aibo said: Usput, vrlo korisna lokacija: https://www.tunemymusic.com/ Automatski prebaci sve playliste, omiljene pesme, albume i izvođače sa bilo kog servisa na bilo koji drugi. Meni je uspešno prebacio sve sa TIdal na Qobuz. Plaćena verzia čak ima autosync i neke perverzije... ali i u besplatnoj varijanti je vrlo korisna stvar. .........ovo može vrlo lepo da se koristi sve kupujući na raznim popustima i akcijama kad ti odgovara. Quote Link to comment Share on other sites More sharing options...
CoyoteKG Posted November 26, 2020 Report Share Posted November 26, 2020 48 minutes ago, CoyoteKG said: Ja eksportovao u txt fajl, ali kad videh kako izgleda, ncini mi se da su samo nazivi pesama. sutra mi istice free, pa planiram da uzmem nesto sa ebay Da odgovorim sam sebi :). Export u CSV eksportuje sve kako treba Quote Link to comment Share on other sites More sharing options...
Preddrag Posted November 28, 2020 Report Share Posted November 28, 2020 Kupio sam i ja Qobuz preko ebay ita. Hvala @Aibo. Slažem se da je zvučno za nijansu, i za moje uši bolji Qobuz od Tidala. Medjutim, po pitanju biblioteke, Tidal je za moj ukus mnogo bogatiji. Sa Tune my music nije mi pronašao 210 izvodjača i albuma. Ali, ja baš i ne smatram sebe merodavnim za to uporedjenje, jer sam previše u kraut rocku i RPI muzici. Na kraju krajeva, na Tidalu ima tih band-ova. Sve u svemu moja preporuka za Qobuz. Quote Link to comment Share on other sites More sharing options...
CoyoteKG Posted November 28, 2020 Report Share Posted November 28, 2020 i ja uzeh Tidal na 6 meseci preko ebay. Bas da vidim koliko ce da potraje :). Nek potraje i mesec dana, opet se isplatilo. Quote Link to comment Share on other sites More sharing options...
Spachek Posted November 28, 2020 Report Share Posted November 28, 2020 Ne brini, potrajace sigurno 6Sent from my LG-G6 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Delija Posted November 28, 2020 Report Share Posted November 28, 2020 Qobuz jeste za nijansu kvalitetniji od Tidal-a, ali je razlika u koristi streaming-a sa lokalnog server-a (bilo da je u pitanju Roon ili DLNA/UPnP) u odnosu na tu razliku izmedju Qobuz-a i Tidal-a mnogo veca. Poredjenje vrseno na Devialet-u preko BubbleUPnP-a i Roon-a (RAAT). Numera pogodna za poredjenje (samo jedna od mnogih): Josephine Gronholm - In Your Wild Garden. Recimo deo sa cinelama od 2:30 do 3:xx. Internet konekcija perfektna + sasvim solidan router. Konekcija ethernet i Wi-Fi - probao sam obe. https://www.speedtest.net/result/10499332515 Quote Link to comment Share on other sites More sharing options...
NL. Posted November 28, 2020 Report Share Posted November 28, 2020 1 sat ranije, Delija said: Qobuz je mozda za nijansu kvalitetniji od Tidal-a, ali je razlika u koristi streaming-a sa lokalnog server-a (bilo da je u pitanju Roon ili DLNA/UPnP) u odnosu na tu razliku izmedju Qobuz-a i Tidal-a mnogo veca. Poredjenje vrseno na Devialet-u preko BubbleUPnP-a i Roon-a (RAAT i Devialet AIR). Možeš li molim te ovo dodatno da pojasniš? Šta znači streaming sa lokalnog servera, tj.kako ide sa lokalnog servera? Da li Roon na neki način posreduje da streaming ide najpre na lokalni server, pa sa njega u uređaj koji ga "čita"? Quote Link to comment Share on other sites More sharing options...
Delija Posted November 29, 2020 Report Share Posted November 29, 2020 Izgleda da nisam bio dovoljno jasan. Mislim na lokalnu kolekciju muzike (lossless CD ripovi + hi-res/DSD), bilo da je koristi Roon ili se "serviraju" putem DLNA/UPnP servera. Quote Link to comment Share on other sites More sharing options...
NL. Posted November 29, 2020 Report Share Posted November 29, 2020 da, da, jasno mi je sada. Što se tiče poređenja lokalni server vs. tidal/qobuz, ja mislim da to najviše zavisi od kvaliteta samih lokalnih ripova i ostalih hi-res fajlova koji se "serviraju". Sa druge stranem, kod servisa tidal/qobuz mi realno ne znamo kakav je tačno na njihovoj strani izvor sa kojeg "teče" stream. To što za neku numeru koju strimujemo kod nas piše da je 96/24, može da znači i da je izvorno ona bila 44.1/16 , ali su je upseample-ovali... mi to, osim ušima, ne možemo nikako da utvrdimo, zar nije tako? Tu su zatim razlike kod različitih izdanja jedne iste numere... hoću da kažem da mi se čini da to pravi najveću razliku u odnosu na muziku koju imamo u svojim kolekcijama. Quote Link to comment Share on other sites More sharing options...
garson Posted November 29, 2020 Report Share Posted November 29, 2020 Tu bi validno poredjenje bilo kupiti album na Qobuz-u pa porediti lokalni streaming kupljenog albuma sa direktnim streamingom istog sa Qobuza. Ovako je poredjenje apples vs oranges jer kao sto @NL. rece ne znamo koje izdanje Qobuz/Tidal imaju. Quote Link to comment Share on other sites More sharing options...
Delija Posted November 29, 2020 Report Share Posted November 29, 2020 Jasno, naravno. Ali... Nije to album Pink Floyd-a pa da postoji 30 razlicitih remastera. Kada je drugi remaster u pitanju - to je uglavnom vrlo ocigledno i nije rec o finesama kao sto je fokus cinele ili trajanje "repa" cinele ili razlike u teksturi bas gitare i slicno. "Kriticki" sam slusao nekih 20-ak numera sa razlicitih albuma koje jako dobro poznajem (i potrosio dobran broj sati za to, naravno) - manje-vise svuda je isti zakljucak. Veceras sam u pricu dodao i Qobuz, a do sada sam poredjenje radio sa Tidal-om. Neke numere sam zeleo da poredim, ali nisam uspeo upravo zato sto je vrlo ocigledno da nemam isto izdanje albuma. To je situacija na mom sistemu. Ne znam kakva je na drugim. Probajte, pa onda pricajte iskustva. To bar nije tesko. Ono sto je cinjenica je da se i za UPnP i za Roon koristi identican protokol za lokalni server i za Tidal/Qobuz streaming, tako da tu sigurno ne lezi "problem". Inace ni Roon i UPnP ne zvuce isto, al' je to neka druga prica U principu, i Tidal i Qobuz su vrlo upotrebljivi, ali ako neki album bas volim - moram ga imati u svojoj kolekciji. Quote Link to comment Share on other sites More sharing options...
garson Posted November 29, 2020 Report Share Posted November 29, 2020 Pa neka postoje i 2 remastera, dovoljno je da se razlikuje. U principu mozes i da "skines" u lokal neku numeru sa Tidala pa da uporedis tako. Da ne bude zabune, nisam korisnik streaming servisa, niti ih branim, samo eto smatram da u tom poredjenu CD rip vs Tidal/Qobuz streaming mozda nije sve identicno. Quote Link to comment Share on other sites More sharing options...
Delija Posted November 29, 2020 Report Share Posted November 29, 2020 Ne tvrdim uopste da identican source iz lokala i sa TIdal-a ili Qobuz-a zvuci razlicito - sumnjam najvise na to da nije 100% identican source, ali da to ne potice od izdanja/remastera u konkretnom slucaju. Da li rade neku normalizaciju (ReplayGain mi u lokalu ne pravi toliku razliku), "pumpaju loudness" ili sta vec - ne znam. Cinjenica je da ne bi trebalo to da rade ako nije eksplicitno ukljucena ta opcija. Trudio sam se da koliko mogu match-ujem level, ali je lokal uglavnom i tisi, pa to nije razlog preferencije. BTW, tehnicki, ako nije hi-res ili MQA zezancija, obican 44.1/16 CD "rip" istog izdanja bi trebalo da zvuci identicno sa Tidal-a i Qobuz-a zar ne? Quote Link to comment Share on other sites More sharing options...
petarjovic Posted November 30, 2020 Report Share Posted November 30, 2020 Black friday Tidal! Quote Link to comment Share on other sites More sharing options...
sivuk Posted December 1, 2020 Report Share Posted December 1, 2020 Ne znam šta ko radi sa zvukom, ali i Tidal i Qobuz bi trebalo da prekopiraju Radio Paradise i da više ne diraju dugmiće Послато са Redmi Note 9S помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
džonibigud Posted December 1, 2020 Report Share Posted December 1, 2020 Ako si im rekao... Quote Link to comment Share on other sites More sharing options...
Iron man Posted December 6, 2020 Report Share Posted December 6, 2020 Opet frka sa Tidalom Počastio sam laptopa SSD diskom i instalirao samo Windows10 i Office. I Total commander Skinuo Tidal Setup i neće da se instalira. Kaže; Instalation failed. Failed to extract instaler Probam da slušam Tidal onlajn.Neće da se loguje. Kaže; Could not connect to the reCAPTCHA service. Please check your internet connection and reload to get a reCAPTCHA challenge. Quote Link to comment Share on other sites More sharing options...
