hardwareGQ Posted May 7, 2017 Report Share Posted May 7, 2017 Interesuje me kakav je MV358I op amp. Trenutno imam onaj Fiio D03K i na njemu se nalazi taj op amp. Kako se rangira taj op amp? ( pretpostavljam lose ) Hteo bih da ga zamenim nekim boljim. Koja je vasa preporuka u malo boljem rangu od njega? Hvala Quote Link to comment Share on other sites More sharing options...
vladat1 Posted June 25, 2017 Report Share Posted June 25, 2017 Ovo i mene zanima. Možda je najbolje da ugradiš kućište DIP8 https://www.aliexpress.com/item/20Pcs-Lot-8pin-DIP-IC-sockets-Adaptor-Solder-Type-8-pin-Round-Hole/32764773696.html?ws_ab_test=searchweb0_0,searchweb201602_3_10152_10065_10151_10068_10136_10137_10060_10155_10062_437_10154_10056_10055_10054_10059_303_100031_10099_10103_5320013_10102_10096_10052_10053_10142_10107_10050_10051_10084_10083_10080_10082_10081_10110_519_10111_10112_10113_10114_10179_10182_10078_10079_10073_5260013_10123_10189_142,searchweb201603_1,ppcSwitch_7&btsid=8a61c977-ca80-43a5-8863-fd4983b06732&algo_expid=1fb80ba7-e141-4d79-945b-3ae8e8480f3b-42&algo_pvid=1fb80ba7-e141-4d79-945b-3ae8e8480f3b a onda odeš do Malog Princa, ili neke slične radnje, i na licu mesta poslušaš Amp koji ti odgovora. Quote Link to comment Share on other sites More sharing options...
Zexx Posted June 25, 2017 Report Share Posted June 25, 2017 32 minuta ranije, vladat1 said: Ovo i mene zanima. Možda je najbolje da ugradiš kućište DIP8 https://www.aliexpress.com/item/20Pcs-Lot-8pin-DIP-IC-sockets-Adaptor-Solder-Type-8-pin-Round-Hole/32764773696.html?ws_ab_test=searchweb0_0,searchweb201602_3_10152_10065_10151_10068_10136_10137_10060_10155_10062_437_10154_10056_10055_10054_10059_303_100031_10099_10103_5320013_10102_10096_10052_10053_10142_10107_10050_10051_10084_10083_10080_10082_10081_10110_519_10111_10112_10113_10114_10179_10182_10078_10079_10073_5260013_10123_10189_142,searchweb201603_1,ppcSwitch_7&btsid=8a61c977-ca80-43a5-8863-fd4983b06732&algo_expid=1fb80ba7-e141-4d79-945b-3ae8e8480f3b-42&algo_pvid=1fb80ba7-e141-4d79-945b-3ae8e8480f3b a onda odeš do Malog Princa, ili neke slične radnje, i na licu mesta poslušaš Amp koji ti odgovora. U "Malom princu" preporučujem bele krempite, a u "Mikro princu" možda i nađete to o čemu pišete, jedino ne znam kako je zamišljeno to slušanje na licu mesta... Inače, ne može tek tako da se ubaci DIP podnožje u ovaj Fiio i proba neki sa liste "popularnih" operacionih pojačavača, jer moraju da se koriste kompatibilni, kao što su AD8656 ili OPA2209, pri čemu za ovaj AD kažu da je značajan upgrade: https://hifiduino.wordpress.com/2011/06/23/inside-fiio-d3/ Quote Link to comment Share on other sites More sharing options...
zek Posted June 25, 2017 Report Share Posted June 25, 2017 Za DIP podnožje koje je preporučeno moralao bi da se buši pločica, što verovatno nije dobro obzirom na gustinu vodova. Quote Link to comment Share on other sites More sharing options...
vladat1 Posted June 25, 2017 Report Share Posted June 25, 2017 Ljudi, ja sam totalni amater u ovim vodama. Zato sam i napisao "možda". Ovde sam se javio i da bi malo pokrenuo temu Quote Link to comment Share on other sites More sharing options...
