vrobec Posted March 29, 2017 Report Share Posted March 29, 2017 Pojavio se pre par nedelja Pi-DAC Pro. Cena je 42 GBP. Raspberry Pi HAT (A+/B+/2/3) compliant accessory Full-HD audio – up to 24-bit/192kHz playback Integrated hardware volume control (via ALSA) Built in High quality audio headphone amplifier (TI TPA6133A) Class leading audio; 114db SNR, and -94db THD Audiophile TI Burr Brown 32-bit/384kHz DAC (TI PCM5242) Advanced ESD protection Uses the digital I2S audio signals to reduce CPU load over USB audio solutions Raspberry Pi powered, no external power requirements Industry standard audio quality Phono/RCA connectors Supplied (but not fitted) JST headers to deliver Balanced output to XLR or similar Build in mini DSP Fully built and tested Raspberry Pi accessory Designed and manufactured in the UK Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 13, 2017 Report Share Posted September 13, 2017 Raspberry Pi3/HiFiBerry DAC+ Pro kombinacija dobila jako dobar upgrade u vidu eksternog napajanja. Malo kasnije ću u sitna crevca, ali ovako dobrom upgrade-u se baš nisam nadao, iskreno. Quote Link to comment Share on other sites More sharing options...
zek Posted September 13, 2017 Report Share Posted September 13, 2017 Ima tu svašta nešto za Raspberry DAC http://www.suptronics.com/miniPCkits/x4000.html DAC sa pojačalom http://www.suptronics.com/miniPCkits/x5000.html https://www.gearbest.com/raspberry-pi/pp_618455.html P.S. Postoji i kineska verzija Pi3B modela https://www.gearbest.com/raspberry-pi/pp_488334.html Quote Link to comment Share on other sites More sharing options...
Green Posted September 13, 2017 Report Share Posted September 13, 2017 2 sati ranije, RingeRaja said: Raspberry Pi3/HiFiBerry DAC+ Pro kombinacija dobila jako dobar upgrade u vidu eksternog napajanja. Malo kasnije ću u sitna crevca, ali ovako dobrom upgrade-u se baš nisam nadao, iskreno. Bilo bi zanimiljivo uporediti ga sa naveliko hvaljenim iFi iPower -om. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 13, 2017 Report Share Posted September 13, 2017 U pitanju je ovo napajanje: http://www.ebay.com/itm/Ultra-Low-Noise-linear-power-supply-LPS-PSU-KIT-5V-9V-12V-15V-18V-24V/322050070781?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 Plus kvalitetan trafo, ožičenje i konektori, pa skutijano u diy alu kutiju. Inače, keč je u tome da se direktno napaja DAC, a preko njega RPi3. Quote Link to comment Share on other sites More sharing options...
dj.nik Posted September 13, 2017 Report Share Posted September 13, 2017 Pisao sam vec vise puta, aj'd opet da ponovim: RaspberryPi kao uredjaj nije dobra osnova za DAC. RPi ima samo jedan klok generator s kojim se generise takt signala za video upotrebu (48K) a do takta CD zapisa (44.1K) se dolazi matematikom. Kako se 48 ne deli bas dobro sa 44.1, nema ni tacnog kloka za audio tj. CD zapis (16 bita / 44.1Khz). Kako je RPi bas popularan, ljudi seli pa napravili i re-kloker plocicu za njega - 'Kali' te s njom resili RPi nedostatak koji stalno isticem. A onda dodali nesto vrlo slicno HiFiBerry DAC-u - 'Piano DAC' Na kraju, kad se i cifrovno, trudno i vremenski sve sabere, vec ima gotovih resenja koja za prvi DAC velikim koracima preskacu RPi,. Pocev od davno poznatog 'Dragonfly'-a (druge generacije) do najnovijih kineskih 'cuda' poput S.M.S.L-ovog modela 'iDEA' - gde se za US dolara $86 (+$2 za transport) dobija ESS Sabre9018 sa neverovatnim mogucnostima: DSD512 jednobitni te 768/32-bitni PCM signal. Detaljnu recenziju mozete procitati na blogu ovde te videti poredjenje sa Oppo BDP105. Ovo nije kraj price jer se nedugo zatim, opet za smesne novce pojavio DAC sa dva ESS Sabre9018 i potpuno balansiranim izlazom, sa malim OLED displejom, sve to za .... $97 (trenutno na akciji, $92.14) dolara. Amerikanskih. Za nas mozda smesnog imena ali samo to i nist vise: 'SABAJ DA3' Da pomenen i staru zvezdu: Kod mene je vec godinama u upotrebi LightHarmonic-ov 'GeekOut' (prva verzija) takodje sa Sabre9018 i 045W pojacalom u 'A' klasi (greje ko lood) a njegov jaci brat, sa citavih 1W snage, rasprodaje se za $150 na 'Amazon'-u. Nove verzije (V2 i dalje) su vec u ozbiljnim cifrovnim rangu za prvi DAC. Lista resenja za prvi DAC postaje sve bogatija. I bolja. Pozz. Quote Link to comment Share on other sites More sharing options...
ab Posted September 14, 2017 Report Share Posted September 14, 2017 7 sati ranije, RingeRaja said: U pitanju je ovo napajanje: http://www.ebay.com/itm/Ultra-Low-Noise-linear-power-supply-LPS-PSU-KIT-5V-9V-12V-15V-18V-24V/322050070781?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 Plus kvalitetan trafo, ožičenje i konektori, pa skutijano u diy alu kutiju. Inače, keč je u tome da se direktno napaja DAC, a preko njega RPi3. Tu je bio neophodan dual rail PSU? Imao si i single rail σ11 PSU takodje. Sa kojim dac-om i setup-om si poredio tvoj Raspberry Pi3/HiFiBerry DAC+ Pro? Sada kada imas napajanje voleo bih cuti. To oko reclocka o cemu govori @DJ.NIKmoze biti presudno. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 14, 2017 Report Share Posted September 14, 2017 Pa ovo je single? Poređenjeno je sa onim što sam do juče imao, HiFace EVO DAC, single i u kombinaciji sa HiFace EVO usb/spdif i RPi combo se uopšte nije obrukao, daleko od toga. Što se tiče slušanja, nema problema, možemo da se dogovorimo. A ovo što piše DJ.NIK...Baš zato na DAC-u postoje dva nezavisna kristala za clock + napajanje ide direkt u DAC. Ovde je RPi3 samo i isključivo transport, vuče fajlove sa hard diska i isporučuje ih DAC-u putem SB Server aplikacije. Quote Link to comment Share on other sites More sharing options...
ab Posted September 14, 2017 Report Share Posted September 14, 2017 Ok, sada pogledao - single rail. Zbunilo me zato sto je navedeno kao σ22 koji je dual. Mislio sam da si poredio sa jos nekim dacom jer se Skrtic javio. Quote Link to comment Share on other sites More sharing options...
Zexx Posted September 14, 2017 Report Share Posted September 14, 2017 Za još malo para, eto SB Touch klona. http://www.audiophonics.fr/en/cases-for-raspberry-pi-and-other-sbc/smartipi-touch-for-raspberry-pi-3-pi2-a-b-and-official-pi-display-lcd-7-p-11870.html Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 14, 2017 Report Share Posted September 14, 2017 Ovo je samo plastično kućište, plus displej nije baš za toliko malo. Quote Link to comment Share on other sites More sharing options...
Zexx Posted September 14, 2017 Report Share Posted September 14, 2017 2 sati ranije, RingeRaja said: Ovo je samo plastično kućište, plus displej nije baš za toliko malo. Nemo' da si cepidlaka... Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 14, 2017 Report Share Posted September 14, 2017 Ma jok, ima i za više para. npr. Ovakav combo: https://shop.max2play.com/en/audiophonics-sabre-raspberry-bundle.html plus dedicated napajanje: http://www.audiophonics.fr/en/linear-regulated-psu/module-alimentation-lineaire-regulee-mje15034g-faible-bruit-5v-a-24v-2a-p-11131.html pa da se skutija kako treba, da bude pravi parnjak prvom kompletu... Izađe na 350+€ đuture kad se sračunaju svi mogući troškovi. Mene moj komplet izašao džumle manje od 150€. I za te pare svira opasno dobro. Quote Link to comment Share on other sites More sharing options...
zek Posted September 14, 2017 Report Share Posted September 14, 2017 Da li je tačno da I2S veza iz Pi3B podržava samo 24/192 fajlove i ne može da se pušta nativni DSD? Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 14, 2017 Report Share Posted September 14, 2017 Koliko vidim, ovde može i preko: http://www.audiophonics.fr/en/diy-dac/audiophonics-i-sabre-dac-es9018k2m-raspberry-pi-3-pi-2-a-b-i2s-p-11500.html Quote Link to comment Share on other sites More sharing options...
ab Posted September 14, 2017 Report Share Posted September 14, 2017 51 minuta ranije, RingeRaja said: Koliko vidim, ovde može i preko: http://www.audiophonics.fr/en/diy-dac/audiophonics-i-sabre-dac-es9018k2m-raspberry-pi-3-pi-2-a-b-i2s-p-11500.html Nista onda, javi se kada nabavis Kali Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted September 14, 2017 Report Share Posted September 14, 2017 Nećeš da poslušaš ovog "jadnička" što ne "baca" preko? Quote Link to comment Share on other sites More sharing options...
ab Posted September 14, 2017 Report Share Posted September 14, 2017 Tarabe? Quote Link to comment Share on other sites More sharing options...
ab Posted September 15, 2017 Report Share Posted September 15, 2017 Imal ovde ekrance za ove nofce http://www.audiophonics.fr/en/dac-without-volume/topping-d30-usb-dac-24bit-192khz-dsd-128-xmos-p-12278.html Quote Link to comment Share on other sites More sharing options...
Zexx Posted September 15, 2017 Report Share Posted September 15, 2017 15 minuta ranije, ab said: Imal ovde ekrance za ove nofce http://www.audiophonics.fr/en/dac-without-volume/topping-d30-usb-dac-24bit-192khz-dsd-128-xmos-p-12278.html Taj sa ekranom je x5, model M9... Quote Link to comment Share on other sites More sharing options...
bkrmar Posted August 14, 2018 Report Share Posted August 14, 2018 Ako je još aktelno http://en.tpdz.net/products_detail/productId=31.html Quote Link to comment Share on other sites More sharing options...
vladat1 Posted August 14, 2018 Report Share Posted August 14, 2018 On 14.9.2017. at 0:10, dj.nik said: Pisao sam vec vise puta, aj'd opet da ponovim: RaspberryPi kao uredjaj nije dobra osnova za DAC. RPi ima samo jedan klok generator s kojim se generise takt signala za video upotrebu (48K) a do takta CD zapisa (44.1K) se dolazi matematikom. Kako se 48 ne deli bas dobro sa 44.1, nema ni tacnog kloka za audio tj. CD zapis (16 bita / 44.1Khz). Kako je RPi bas popularan, ljudi seli pa napravili i re-kloker plocicu za njega - 'Kali' te s njom resili RPi nedostatak koji stalno isticem. A onda dodali nesto vrlo slicno HiFiBerry DAC-u - 'Piano DAC' Na kraju, kad se i cifrovno, trudno i vremenski sve sabere, vec ima gotovih resenja koja za prvi DAC velikim koracima preskacu RPi,. Pocev od davno poznatog 'Dragonfly'-a (druge generacije) do najnovijih kineskih 'cuda' poput S.M.S.L-ovog modela 'iDEA' - gde se za US dolara $86 (+$2 za transport) dobija ESS Sabre9018 sa neverovatnim mogucnostima: DSD512 jednobitni te 768/32-bitni PCM signal. Detaljnu recenziju mozete procitati na blogu ovde te videti poredjenje sa Oppo BDP105. Ovo nije kraj price jer se nedugo zatim, opet za smesne novce pojavio DAC sa dva ESS Sabre9018 i potpuno balansiranim izlazom, sa malim OLED displejom, sve to za .... $97 (trenutno na akciji, $92.14) dolara. Amerikanskih. Za nas mozda smesnog imena ali samo to i nist vise: 'SABAJ DA3' Da pomenen i staru zvezdu: Kod mene je vec godinama u upotrebi LightHarmonic-ov 'GeekOut' (prva verzija) takodje sa Sabre9018 i 045W pojacalom u 'A' klasi (greje ko lood) a njegov jaci brat, sa citavih 1W snage, rasprodaje se za $150 na 'Amazon'-u. Nove verzije (V2 i dalje) su vec u ozbiljnim cifrovnim rangu za prvi DAC. Lista resenja za prvi DAC postaje sve bogatija. I bolja. Pozz. Bravo za post. Zanima me samo da li ovi DAC ovi, što si nabrojao, za slušalice mogu da se priključe na pojačalo (Y kabal) Quote Link to comment Share on other sites More sharing options...
dj.nik Posted August 14, 2018 Report Share Posted August 14, 2018 Mogu svakako. Neki od modela imaju i zaseban konektor za 'line out' nivo signala. Primer - 'GeekOut'. U medjuvremenu su isplivala jos dva odlicna uredjaja - 'Topping D50' i 'S.M.S.L. SU-8' sa D/A chip-ovima poslednje generacije (Sabre 9038), balansiranim izlazima itd. Pozz Quote Link to comment Share on other sites More sharing options...
Aibo Posted August 14, 2018 Report Share Posted August 14, 2018 Ako je još aktelno http://en.tpdz.net/products_detail/productId=31.html+1 za Topping D30. Koristim ga od skoro, očekivano bolji DAC od ovih malih poput SMSL Idea i sl. Baš detaljan i utegnut zvuk. Quote Link to comment Share on other sites More sharing options...
vladat1 Posted August 15, 2018 Report Share Posted August 15, 2018 Čitao sam na stranom forumu gde kažu da je SMSL Sanskrit 6th 32bit/192kHz USB/Optical/Coaxial bolji od Toppinga D30 u toj jeftijijoj klasi 100 - 120€. Isto tako piše , da je SMSL SU-8 2ES9038Q2M USB overkill u kategoriji do 250€ Quote Link to comment Share on other sites More sharing options...
