dragan333 Posted December 24, 2016 Report Share Posted December 24, 2016 Pucketanje tokom rada nekad na svakoj 2-6-15oj u toku pesme zapucketa nekad isto tako kad se prebacuje dal je to normalno ili ne i sta bi moglo biti? Hvala Quote Link to comment Share on other sites More sharing options...
vdzele Posted December 24, 2016 Report Share Posted December 24, 2016 Ako si na svom kompjuteru instalirao 2 ili više drajvera za DAC onda može biti da imaš sukob drajvera. Drajveru od Micromege smeta drajver od nekog drugog DACa. Sve ih obriši i ostavi samo Micromegin Ovo nije nikakav problem, ako je ovo uzrok. Quote Link to comment Share on other sites More sharing options...
dragan333 Posted December 24, 2016 Author Report Share Posted December 24, 2016 Koliko znam nema al ce proverimo! Hvala Quote Link to comment Share on other sites More sharing options...
dragan333 Posted December 24, 2016 Author Report Share Posted December 24, 2016 25 minuta ranije, vdzele said: Ako si na svom kompjuteru instalirao 2 ili više drajvera za DAC onda može biti da imaš sukob drajvera. Drajveru od Micromege smeta drajver od nekog drugog DACa. Sve ih obriši i ostavi samo Micromegin Ovo nije nikakav problem, ako je ovo uzrok. Obrisani svi koje sam Imao! Sta jos moze biti? Quote Link to comment Share on other sites More sharing options...
vdzele Posted December 24, 2016 Report Share Posted December 24, 2016 Jesi posle brisanja reset kompa? Quote Link to comment Share on other sites More sharing options...
dragan333 Posted December 24, 2016 Author Report Share Posted December 24, 2016 1 sat ranije, vdzele said: Jesi posle brisanja reset kompa? Naravno,plasim se da nije neki cip ili sta god? Quote Link to comment Share on other sites More sharing options...
harts Posted December 25, 2016 Report Share Posted December 25, 2016 Ne moze da bude nikakav sukob drajvera, sistem vrlo dobro zna koji drajver je gde potreban. Probaj na drugom kompu, ako se isto desava bojim se da je do uredjaja. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted December 25, 2016 Report Share Posted December 25, 2016 Koja je konfiguracija kompjutera i koje taskove radi? Ovo je klasičan simptom opterećenog računara (iako u datom trenutku ne mora da izvršava nijedan aktivan proces) a to što se čuje su drop-outs. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted December 25, 2016 Report Share Posted December 25, 2016 Ne verujem da je toliko slab pc da mu se dešava preopterećenje ? Quote Link to comment Share on other sites More sharing options...
dragan333 Posted December 25, 2016 Author Report Share Posted December 25, 2016 3 sati ranije, Willi Studer said: Koja je konfiguracija kompjutera i koje taskove radi? Ovo je klasičan simptom opterećenog računara (iako u datom trenutku ne mora da izvršava nijedan aktivan proces) a to što se čuje su drop-outs. 53 minuta ranije, Vlajo said: Ne verujem da je toliko slab pc da mu se dešava preopterećenje ? Samo za muziku u filmove se koristi Quote Link to comment Share on other sites More sharing options...
dragan333 Posted December 25, 2016 Author Report Share Posted December 25, 2016 7 sati ranije, harts said: Ne moze da bude nikakav sukob drajvera, sistem vrlo dobro zna koji drajver je gde potreban. Probaj na drugom kompu, ako se isto desava bojim se da je do uredjaja. Probano i na win 8 isto se desava! Quote Link to comment Share on other sites More sharing options...
dragan333 Posted December 25, 2016 Author Report Share Posted December 25, 2016 Preporuka za dobrog servisera u NS? Quote Link to comment Share on other sites More sharing options...
Zexx Posted December 25, 2016 Report Share Posted December 25, 2016 Taj DAC, barem prema izvorima sa interneta, ume da bude problematičan sa USB Class 2 drajverom za Windows, i Micromega je zbog ovakvih i sličnih problema povukla s tržišta određenu seriju uređaja. Ja bih prvo proverio sa proizvođačem po serijskom broju da li je ovaj uređaj među problematičnim i da li eventualni upgrade firmvera rešava problem. Ako ne slušaš fajlove preko 96k, nema potrebe da instaliraš bilo kakav drajver, radiće i bez njega, uz već pomenuto ograničenje, a velika je verovatnoća i bez ikakvih problema. Takođe, probaj ga sa nekim od Linux baziranih plejera (Daphile, Volumio), to nije puno posla niti puno komplikovano čak i za nekoga ko ništa sem Windows operativnih sistema nije nikad video u životu, da ne pominjem da sam siguran da ćeš se zvukom prijatno iznenaditi... Quote Link to comment Share on other sites More sharing options...
dragan333 Posted December 25, 2016 Author Report Share Posted December 25, 2016 Instalirano je sve kako je Micromega objasnila na Windows 10 da se pri instalaciji u setup.exe podesi da ga prepoznaje kao Windows 7, i da se time izbegnu slicne stvari i da radi kako treba, tako da mislim da je do samog uredjaja problem. Te bi mi bilo drago ako neko moze da mi preporuci nekog majstora u N.S.? Quote Link to comment Share on other sites More sharing options...
vdzele Posted December 25, 2016 Report Share Posted December 25, 2016 Stav po kome "Ne moze da bude nikakav sukob drajvera, sistem vrlo dobro zna koji drajver je gde potreban." je netačan. Ovo pričam iz ličnog iskustva, iskustva prijatelja i onog što su mnogi pisali po internetu. Ukucajte recimo u google "audio driver conflict" i naći ćete mnogo primera. Ako svi znamo da se preporučuje da uvek u sistemu postoji samo jedan driver za grafičku kartu, zašto to ne bi važilo i za audio uređaje? Naravno, sve ovo su ređi slučajevi ali ne treba ih isključiti. Problem oko drivera je siguran. Ja sam imao jednom problem sa mojim laptopom da nisam mogao da podesim moju NI Traktor Audio 2 i DAC koji je radio preko XMOS-a. Traktor kartica je pucketala preko njihovog ASIO drivera, dok DAC nije. Čim sam izbacio XMOS driver Traktor Audio 2 je proradio normalno. Drugi primer je moj postojeći DAC koji radi sa Amanero je bio u konfliktu sa XMOS-om od DAC koji je bio na probi kod mene. Itd... Drop-outs o kojima Willi piše je više problem koji je vezan za laptopove nego desktop konfiguracije. Kod laptopa je problem što je sav hardver veoma stešnjen i tu nastaju problemi. Pogotovo nastaju problemi kad se na laptop nakači spoljni audio uređaj. USB 2 linija zna da pravi problem kod ovih uređaja. Microsoft je izbacivao zakrpe za USB driver koji su nekima rešavali problem pucketanja laptop + audio uređaj. Ovaj problem je opet i vezan sa dropout-ima koje češće daje laptop. Postoje programi koji detektuju oprterećenost konfiguracije, vi zaustavite te procese i onda Win USB driver patch može da proradi. Treba probati i sa driverima tipa Wasapi i Asio, dali i preko njih ima pucketanja. Pa onda probati i sa drugim ulazima tipa optički. Siguran sam da preko optike neće biti problema. Po svemu sudeći problem nije vezan za operativni sistem već za driver i mislim da ovo što je Zexx napisao će najverovatnije da uradi posao. Ja bi pre napisao jedan email proizvođaču šta raditi nego davao nekom majstoru. Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted December 25, 2016 Report Share Posted December 25, 2016 Ja sam isti ili slican problem imao sa svim Arcam DAC-ovima kada je u pitanju USB veza, Bili su prilicno selektivni po pitanju razlicitih USB kablova. Npr, neki modeli kablova proizvodjaca Locus Design i Cryo parts im nisu odgovarali...Neki cak do te mere da DAC uopste nije video kompijuter (i obrnuto) a kod nekuh se javljalo pucketanje. Sa nekim drugim USB kablovima su radili dobro Pokusaj da promenis USB kablo prvo. Ja sam problem resio koriscenjem eksternog USB/SPDF konnertora M2Tech HiFace Two, Nove ja prodajem i kostaju 160e ali trenutno na KP ima mislim dva komada po ceni od 100e. Na stranu sto je zvuk preko ovog uredjajcica najcesce bolji nego direktno preko USB veze DAC-komp. Quote Link to comment Share on other sites More sharing options...
dragan333 Posted December 25, 2016 Author Report Share Posted December 25, 2016 52 minuta ranije, Sonichammer said: Ja sam isti ili slican problem imao sa svim Arcam DAC-ovima kada je u pitanju USB veza, Bili su prilicno selektivni po pitanju razlicitih USB kablova. Npr, neki modeli kablova proizvodjaca Locus Design i Cryo parts im nisu odgovarali...Neki cak do te mere da DAC uopste nije video kompijuter (i obrnuto) a kod nekuh se javljalo pucketanje. Sa nekim drugim USB kablovima su radili dobro Pokusaj da promenis USB kablo prvo. Ja sam problem resio koriscenjem eksternog USB/SPDF konnertora M2Tech HiFace Two, Nove ja prodajem i kostaju 160e ali trenutno na KP ima mislim dva komada po ceni od 100e. Na stranu sto je zvuk preko ovog uredjajcica najcesce bolji nego direktno preko USB veze DAC-komp. Probao i optiku i koax. isto se desava. Ja bi rekao da je problem vise do nekog dela u uredjaju nego da je do veze i drivra kao i operativnog sistema. Ima li neko mozda neku predstavu sta bi moglo biti da ne ispadne da sam bacio novce bezveze, uredjaj je nov i zao bi mi bilo da zavrsi u smecu? Quote Link to comment Share on other sites More sharing options...
prophet Posted December 25, 2016 Report Share Posted December 25, 2016 Direct, wasapi, kernel, asio? Quote Link to comment Share on other sites More sharing options...
dragan333 Posted December 25, 2016 Author Report Share Posted December 25, 2016 1 minut ranije, prophet said: Direct, wasapi, kernel, asio? Nisam raziumeo? Quote Link to comment Share on other sites More sharing options...
prophet Posted December 25, 2016 Report Share Posted December 25, 2016 Napravi printscreen ponudjenih output-a. Quote Link to comment Share on other sites More sharing options...
dragan333 Posted December 25, 2016 Author Report Share Posted December 25, 2016 4 minuta ranije, prophet said: Napravi printscreen ponudjenih output-a. Ako na ovo mislis? Quote Link to comment Share on other sites More sharing options...
prophet Posted December 25, 2016 Report Share Posted December 25, 2016 Ne to. Na softverskom plejeru na Windows-u. Quote Link to comment Share on other sites More sharing options...
dragan333 Posted December 25, 2016 Author Report Share Posted December 25, 2016 21 minuta ranije, prophet said: Ne to. Na softverskom plejeru na Windows-u. ? Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted December 25, 2016 Report Share Posted December 25, 2016 Probaj drugi USB port na računaru. Ne mora da računar bude opterećen, možda je port na nekom opterećenom IRQ. Quote Link to comment Share on other sites More sharing options...
Kuršum Posted December 25, 2016 Report Share Posted December 25, 2016 23 minuta ranije, dragan333 said: ? Ne output operativnog sistema, nego plejera koji koristiš. Al' ako ti je to Windows 10, onda će biti da je do njega. p.s. No ako si kao što kažeš probao i optiku i coax i isti problem se javlja, a pretpostavljam da ta dva nisu probana sa kompa, onda džaba tražimo softverske probleme. Onda je nešto do dac-a. Quote Link to comment Share on other sites More sharing options...
