nikola.m Posted November 24, 2016 Report Share Posted November 24, 2016 Pozdrav, ovako imam jedan problem sa auto ozvucenjem, kada na HU (pioneer deh-6400bt) utisam muziku na 0 ili ako bilo sta menjam od podesavanja woofera pojacalo mi se iskljuci i upali se protect crvena lampica na njemu.. dali mozda neko zna u cemu moze biti problem? hvala unapred Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 24, 2016 Report Share Posted November 24, 2016 27 minuta ranije, nikola.m said: dali mozda neko zna u cemu moze biti problem? Гаси се појачавач за вуфер, очигледно да нешто не ваља. Како се понаша ХУ без појачавача? Quote Link to comment Share on other sites More sharing options...
nikola.m Posted November 24, 2016 Author Report Share Posted November 24, 2016 Sa njim je sve uredu, i ovako dok ne utisam na 0 sve radi, ali kad utisam onda se iskljuci pojacalo Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 24, 2016 Report Share Posted November 24, 2016 Када га утишаш измери римот напон ка појачавачу. Quote Link to comment Share on other sites More sharing options...
nikola.m Posted November 24, 2016 Author Report Share Posted November 24, 2016 Evo probao sam, i nista se ne menja napon kada ga utisam ili sta diram. Probao sam i da premostim sa 12+ na remote i isto se desava kada utisam.. da se on upali posle to nebi bio problem nego moram gasiti HU Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 24, 2016 Report Share Posted November 24, 2016 Како 12В, треба да је више. Quote Link to comment Share on other sites More sharing options...
nikola.m Posted November 24, 2016 Author Report Share Posted November 24, 2016 Mislio sam na to da sam premostio ulaz remote na ulaz 12+, ako razumete sta hocu da kazem Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 24, 2016 Report Share Posted November 24, 2016 Онда је нешто са појачавачем, бер мени тако делује. Quote Link to comment Share on other sites More sharing options...
nikola.m Posted November 24, 2016 Author Report Share Posted November 24, 2016 Hvala na odgovoru, probacu da nabavim drugo da probam Quote Link to comment Share on other sites More sharing options...
impuls Posted November 25, 2016 Report Share Posted November 25, 2016 Ne moze biti problem pojacavac ako radi normalno na svim jacinama sem na nuli. pre ce biti da HU na nuli izbaci jednosmerni napon i izbaci protektor na pojacavacu. Ako je to u pitanju dovoljno ce biti staviti jedan sprezni kond izmedju Hu i pojacavaca. Ako ni to ne pomogne onda prolazi neka visoka frekvencija. Osciloskop i unimer mogu da ustanove problem za par sekundi. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 25, 2016 Report Share Posted November 25, 2016 Сви они већ имају кондезатор према излазним чинчевима. Quote Link to comment Share on other sites More sharing options...
nikola.m Posted November 25, 2016 Author Report Share Posted November 25, 2016 6 sati ranije, impuls said: Ne moze biti problem pojacavac ako radi normalno na svim jacinama sem na nuli. pre ce biti da HU na nuli izbaci jednosmerni napon i izbaci protektor na pojacavacu. Ako je to u pitanju dovoljno ce biti staviti jedan sprezni kond izmedju Hu i pojacavaca. Ako ni to ne pomogne onda prolazi neka visoka frekvencija. Osciloskop i unimer mogu da ustanove problem za par sekundi. Unimer imam, kako sa njim da proverim? Quote Link to comment Share on other sites More sharing options...
impuls Posted November 25, 2016 Report Share Posted November 25, 2016 Prvi test je da iskljucite interkonekt kabel skroz iz pojacala. Ako sa iskljucenim kablom pojacalo ulazi u zastitu, neispravno je pojacalo. Ako ne ulazi u zastitu proverite jednosmerni napon na chinch kablu koji dolazi od HU kad je utisano na nulu. ako ima jednosmernog napona onda je to problem. Ako nema jednosmernog napona prebacite unimer na naizmenicno i izmerite da li ima nekog oscilovanja a to ce se pokazati tako sto ce meriti neki naizmenicni napon Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 25, 2016 Report Share Posted November 25, 2016 21 sati ranije, nikola.m said: Hvala na odgovoru, probacu da nabavim drugo da probam 'си набавио други? Quote Link to comment Share on other sites More sharing options...
nikola.m Posted November 25, 2016 Author Report Share Posted November 25, 2016 Probao sam sa drugim i normalno radi, tkd onda je sigurno pojacalo otislo. E sad vredi to popravlajti ili da kupim drugo? A probacu i da izmerim ono pa cu videt Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 25, 2016 Report Share Posted November 25, 2016 1 minut ranije, nikola.m said: Probao sam sa drugim i normalno radi, onda je sigurno pojacalo otislo. 'сам лепо напис'о. 2 minuta ranije, nikola.m said: E sad vredi to popravlajti ili da kupim drugo? Који је појачавач у питању? Quote Link to comment Share on other sites More sharing options...
nikola.m Posted November 25, 2016 Author Report Share Posted November 25, 2016 Ground zero gzta 2000t Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 25, 2016 Report Share Posted November 25, 2016 30 minuta ranije, nikola.m said: E sad vredi to popravlajti ili da kupim drugo? Вреди поправљати али у твом случају, хм............? Провери ово што је уоквирено. Quote Link to comment Share on other sites More sharing options...
nikola.m Posted November 25, 2016 Author Report Share Posted November 25, 2016 E hvala ti lepo, provericu pa javim Quote Link to comment Share on other sites More sharing options...
