prophet Posted April 17, 2018 Report Share Posted April 17, 2018 Slazem se, to bi svaki audiofil pocetnik trebao da ima. Ili bar da cuje... dok ne cuje stvarno dobar zvucnik... ne daj Boze pogonjen cevnom amplifikacijom i gramofonom kao izvorom. Quote Link to comment Share on other sites More sharing options...
džonibigud Posted May 3, 2018 Report Share Posted May 3, 2018 Novina u Kii Audio ponudi Quote Link to comment Share on other sites More sharing options...
Father Posted May 3, 2018 Report Share Posted May 3, 2018 Maznuli mi dizajn! Quote Link to comment Share on other sites More sharing options...
džonibigud Posted May 3, 2018 Report Share Posted May 3, 2018 "...It's an extension for the Kii THREE that can be added at any time turning the stand mount speaker into a veritable floor stander. Adding 16 drivers and another 4000 WATTs to the current Kii THREE will give you a hint on what to expect." Quote Link to comment Share on other sites More sharing options...
Golum Posted May 3, 2018 Report Share Posted May 3, 2018 53 minuta ranije, džonibigud said: "...It's an extension for the Kii THREE that can be added at any time turning the stand mount speaker into a veritable floor stander. Adding 16 drivers and another 4000 WATTs to the current Kii THREE will give you a hint on what to expect." ...fireworks all over the place Quote Link to comment Share on other sites More sharing options...
Father Posted May 3, 2018 Report Share Posted May 3, 2018 Uz svo dužno poštovanje za brand, ali marketing im targetira naložene klince napumpanih mišića sa menadžerskim platama. Ista munja sa hiljadama Wati je bila ludilo sa plastikaner kasetofonima početkom devedesetih. Čudi malo taj "sirova snga" pristup ako su tematski hi fi zamišljene komponente. Suptilnost mi se čini malo zapostavljena. Quote Link to comment Share on other sites More sharing options...
zflazar Posted May 3, 2018 Report Share Posted May 3, 2018 da prostite, zasrali su šarmantni koncept "muzike za poneti". kao da je '80-tih uz novoizmišljeni walkman počeo da se nudi docking station u vidu pojačala i zvučnika od pola kubnih metara i 100kg žive vage. kii3 ima sasvim dovoljno basa takav kakav je, ovaj bas-toranj mu dođe samo za qrčenje i peglanje očnog i slušnog živca. Quote Link to comment Share on other sites More sharing options...
Golum Posted May 3, 2018 Report Share Posted May 3, 2018 Opljuvaste, a culi niste, jerbo cuo niko nije osim .ing ekipe Kii-a... Quote Link to comment Share on other sites More sharing options...
zflazar Posted May 3, 2018 Report Share Posted May 3, 2018 čuo sam i video sam Kii bez bas-tornja. i mislim da se toranj ne može strpati u putnu torbu. Eto. Quote Link to comment Share on other sites More sharing options...
lalelala Posted May 3, 2018 Report Share Posted May 3, 2018 1 sat ranije, zflazar said: čuo sam i video sam Kii bez bas-tornja. i mislim da se toranj ne može strpati u putnu torbu. Eto. U pravu si ... jos nisu izmislili kanister od 20 litara koji stane u dzep ! Quote Link to comment Share on other sites More sharing options...
prophet Posted May 3, 2018 Report Share Posted May 3, 2018 4 sati ranije, zflazar said: da prostite, zasrali su šarmantni koncept "muzike za poneti". kao da je '80-tih uz novoizmišljeni walkman počeo da se nudi docking station u vidu pojačala i zvučnika od pola kubnih metara i 100kg žive vage. kii3 ima sasvim dovoljno basa takav kakav je, ovaj bas-toranj mu dođe samo za qrčenje i peglanje očnog i slušnog živca. Lazo složio bih se u vezi basa. Ipak, treba imati u vidu da postoje i slušaonice veće zapremine, pa pretpostavljam da je to neka ideja. A nisam stekao utisak da su originalni koncept zamislili kao muziku za poneti. Poprilično to ozbiljno svira. Quote Link to comment Share on other sites More sharing options...
damic Posted May 3, 2018 Report Share Posted May 3, 2018 Na Gearslutz forumu, ako je neko pratio temu o Kii, bilo je komentara da im treba sub. Quote Link to comment Share on other sites More sharing options...
prophet Posted May 3, 2018 Report Share Posted May 3, 2018 35 minuta ranije, damic said: Na Gearslutz forumu, ako je neko pratio temu o Kii, bilo je komentara da im treba sub. Pa nije ovo klasično subwoofer rešenje za dodatak ekstenzije naniže, nje itekako već ima. Ovo je više u pravcu većih radijacionih površina i adekvatno tome većem pomeraju vazduha kao i rasterećenijem radu. Quote Link to comment Share on other sites More sharing options...
RADE Posted May 4, 2018 Report Share Posted May 4, 2018 13 sati ranije, Father said: Uz svo dužno poštovanje za brand, ali marketing im targetira naložene klince napumpanih mišića sa menadžerskim platama. Ista munja sa hiljadama Wati je bila ludilo sa plastikaner kasetofonima početkom devedesetih. Čudi malo taj "sirova snga" pristup ako su tematski hi fi zamišljene komponente. Suptilnost mi se čini malo zapostavljena. sirova snaga je potrebna radi dinamike koja se na postavljenim snimcima na par mesta itekako dobro čuje . Nema dinamike ako pojačalo ima 50-100 w . Drugi pristup za dobijanje dinamike je korišćenje visokoefikasnih zvučnika .......u ovom slučaju mislim na kontraste između tihog i glasnog Quote Link to comment Share on other sites More sharing options...
Father Posted May 4, 2018 Report Share Posted May 4, 2018 Sve prihvatam. Verujem da su do 4000w došli množenjem 16 pojačala od 250w po svakom driveru. Sporna mi je "klinačka ložačka" marketinška ideja pristupa klijentu u ovoj rečenici: "Adding 16 drivers and another 4000 WATTs to the current Kii THREE will give you a hint on what to expect." Iz mog ugla marketinški opasno, zatim evidentno infantilno i na kraju proizvela je kod mene sliku nabudženog plastikanera sa buvljaka na kome piše 4000W. Isticanje snage ispred suptilnosti je po meni jako pogrešno. Ako će mo iskreno, klavir ili harfa prvenstveno poseduju eleganciju i suptilnost, zatim raskoš i lepotu, a na kraju dinamiku i snagu koja iznenađuje i budi iz te bajke u koju te uvedu svojim tonovima. Možda je to vidim sve pogrešno, jer su se i vremena promenila, ali u HiFi-ju ili HiEndu nikada snaga nije bila imperativ, baš naprotiv. Zar nije bilo ono: Vidi šta prava 3 wata mogu da ti dočaraju .... Kao što rekoh uz svo dužno poštovanje komentarisao sam propagandni koncept, a ne zvučnik kao takav, koji da dodam nisam čuo. Ljudi su stekli i preneli odličan utisak o njima i u to nemam razloga da sumnjam. Quote Link to comment Share on other sites More sharing options...
damic Posted May 4, 2018 Report Share Posted May 4, 2018 8 sati ranije, prophet said: Pa nije ovo klasično subwoofer rešenje za dodatak ekstenzije naniže, nje itekako već ima Ekstenzije ima ali neovoljno spl-a. Quote Link to comment Share on other sites More sharing options...
Zexx Posted May 4, 2018 Report Share Posted May 4, 2018 6 minuta ranije, damic said: Ekstenzije ima ali neovoljno spl-a. Ne treba svima 100+ decibela SPL, ali eto, za one kojima treba, izašli ljudi u susret. Quote Link to comment Share on other sites More sharing options...
SUROKVL Posted May 4, 2018 Report Share Posted May 4, 2018 36 minuta ranije, Father said: Sve prihvatam. Verujem da su do 4000w došli množenjem 16 pojačala od 250w po svakom driveru. Sporna mi je "klinačka ložačka" marketinška ideja pristupa klijentu u ovoj rečenici: "Adding 16 drivers and another 4000 WATTs to the current Kii THREE will give you a hint on what to expect." Iz mog ugla marketinški opasno, zatim evidentno infantilno i na kraju proizvela je kod mene sliku nabudženog plastikanera sa buvljaka na kome piše 4000W. Isticanje snage ispred suptilnosti je po meni jako pogrešno. Ako će mo iskreno, klavir ili harfa prvenstveno poseduju eleganciju i suptilnost, zatim raskoš i lepotu, a na kraju dinamiku i snagu koja iznenađuje i budi iz te bajke u koju te uvedu svojim tonovima. Možda je to vidim sve pogrešno, jer su se i vremena promenila, ali u HiFi-ju ili HiEndu nikada snaga nije bila imperativ, baš naprotiv. Zar nije bilo ono: Vidi šta prava 3 wata mogu da ti dočaraju .... Kao što rekoh uz svo dužno poštovanje komentarisao sam propagandni koncept, a ne zvučnik kao takav, koji da dodam nisam čuo. Ljudi su stekli i preneli odličan utisak o njima i u to nemam razloga da sumnjam. Sobzirom da ti, (kao u ostalom ni ja) nisi kupac, zabole ih Q šta misliš, oni se ciljnoj grupi kupaca obraćaju jezikom koji je toj grupi razumljiv. Kii sam po sebi ima i ekstenziju i SPL više nego dovoljne u adekvatnoj prostoriji, a za SPL-ovce i veće prostorije i one koji su se prenemagali da im je bas veštački i nabudžen, eto solucije i radosti ! Quote Link to comment Share on other sites More sharing options...
Father Posted May 4, 2018 Report Share Posted May 4, 2018 Upravo tako, da te ne citiram. @SUROKVL Stari sofisticirani formirani audiofil nije njihova ciljna grupa. Naravno treba dodati i ono praznih džepova! Quote Link to comment Share on other sites More sharing options...
damic Posted May 4, 2018 Report Share Posted May 4, 2018 1 sat ranije, Father said: Zar nije bilo ono: Vidi šta prava 3 wata mogu da ti dočaraju .... Bilo nekad... Ovde mora velika snaga, Hoffman's Iron Law: http://techtalk.parts-express.com/forum/tech-talk-forum/13916-hoffman-s-iron-law https://trueaudio.com/st_trade.htm http://www.salksound.com/wp/?p=56 Quote Link to comment Share on other sites More sharing options...
SUROKVL Posted May 4, 2018 Report Share Posted May 4, 2018 23 minuta ranije, Father said: Upravo tako, da te ne citiram. @SUROKVL Stari sofisticirani formirani audiofil nije njihova ciljna grupa. Naravno treba dodati i ono praznih džepova! Ovo podvučeno je ključno, a ne audiofilski razlozi Quote Link to comment Share on other sites More sharing options...
damic Posted May 4, 2018 Report Share Posted May 4, 2018 Kad smo vec na ovoj temi, interesantan je spisak zvucnih jedinica sa cenama: LF Driver - Peerless SBS-160F35AL01-04 - $22https://www.digikey.com/product-deta...ource=octoparthttps://www.tymphany.com/wp-content/...F35AL01-04.pdfMF Driver - Peerless FSL-0512R01-08 - $20https://www.digikey.com/product-deta...ource=octoparthttps://www.tymphany.com/wp-content/...0512R01-08.pdfHF Driver - Seas 27TBCD/GB-DXT - $74https://www.madisoundspeakerstore.co...h1499-tweeter/ https://www.gearslutz.com/board/high-end/1048540-kii-three-have-you-heard-them-46.html Quote Link to comment Share on other sites More sharing options...
Father Posted May 4, 2018 Report Share Posted May 4, 2018 Kako je sva ta elektronika upakovana unutra je pravo čudo. Tu mislim na uopšte mesto da se to sve smesti unutar male kutije sa 6 drivera, a onda antivibraciona rešenja da ta elektronika zvučno ne rezonira ili u sebi stvara nus pojave koje elektronika ima kada je izložena vibraciji. Jaki magneti u neposrednoj blizini .... Setite se samo silnih rešenja za ispod nogica uređaja koji stoje na policama, a daleko od direktnog udarnog talasa ... Mnogo je ovde konstrukcijskih rešenja bilo potrebno, da se izvede ovakav koncept. Quote Link to comment Share on other sites More sharing options...
RADE Posted May 4, 2018 Report Share Posted May 4, 2018 2 sati ranije, damic said: Kad smo vec na ovoj temi, interesantan je spisak zvucnih jedinica sa cenama: LF Driver - Peerless SBS-160F35AL01-04 - $22https://www.digikey.com/product-deta...ource=octoparthttps://www.tymphany.com/wp-content/...F35AL01-04.pdfMF Driver - Peerless FSL-0512R01-08 - $20https://www.digikey.com/product-deta...ource=octoparthttps://www.tymphany.com/wp-content/...0512R01-08.pdfHF Driver - Seas 27TBCD/GB-DXT - $74https://www.madisoundspeakerstore.co...h1499-tweeter/ https://www.gearslutz.com/board/high-end/1048540-kii-three-have-you-heard-them-46.html nema veze cena nego kako zvučnik radi . Može da košta i 1000 evra komad ako ne radi kako treba . Pre neki dan sam ostavio primer malog pionira koji uz odgovarajuće pozicioniranje i odgovarajuću elektroniku radi bolje od 150 x skupljih zvučnika . A to kako pojedini zvučnici rade , e pa za to treba imati uši Quote Link to comment Share on other sites More sharing options...
RADE Posted May 4, 2018 Report Share Posted May 4, 2018 1 sat ranije, Father said: Kako je sva ta elektronika upakovana unutra je pravo čudo. Tu mislim na uopšte mesto da se to sve smesti unutar male kutije sa 6 drivera, a onda antivibraciona rešenja da ta elektronika zvučno ne rezonira ili u sebi stvara nus pojave koje elektronika ima kada je izložena vibraciji. Jaki magneti u neposrednoj blizini .... Setite se samo silnih rešenja za ispod nogica uređaja koji stoje na policama, a daleko od direktnog udarnog talasa ... Mnogo je ovde konstrukcijskih rešenja bilo potrebno, da se izvede ovakav koncept. recimo izlazni stepen za car audio sub vofer od 8 kw / 8000 w / koji vija dva suba od 46 cm se nalazi zavrnut za kutiju od šperploče debljine 15 mm i bez problema radi Quote Link to comment Share on other sites More sharing options...
