surferlola Posted August 8, 2016 Report Share Posted August 8, 2016 On 8/6/2016 at 21:55, Alek5 said: Da ne bih otvarao novu temu, nadovezcu se naravno na sopstvenu temu, u kojoj sam nagovesti da cu nakon nekog vremena zapoceti upgrade nad DAC-om Teac UD501. Naravno, prva nadogradnje nakon mog istrazivanja je pocela sa promenom op-amp-ova NA5532 koji su zamenjeni sa Burson-om V5. zdravo zanima me da li se prilikom zamene opampa menjaju jos neki elementi? povod za moje pitanje je tekst vezan za modifikaciju pojacala musical fidelity a1, npr, a pretpostavljam da pitanje moze biti korisno i za druge uredjaje. (I decided to use the venerable NE5532 for the preamp. You can try different op-amps in this circuit, but if you do, I'd recommend that you increase the value of R3 and R4 to reduce the loading on the op-amp, as many of the popular alternatives generate more distortion into loads less than about 2kΩ. You could simply increase them by a factor of 10 (to 6k8 and 2k2), but I'd recommend 3k and 1K. Good quality but affordable alternatives to the NE5532 include the OPA2604 and the OPA2134. I have tried the latter (with 3K and 1K gain setting resistors), and it worked fine... If trying anything more exotic, do take care with layout and decoupling, as parasitc oscillations are a very real possibility with some of the high-speed options.) takodje, zanima me cena bursona v5? ja imam ugradjena podnozja u svom cdp-u, da li je dovoljno samo ubosti bursone (2 kom) ili treba jos neka nadgradnja? inace imao sam NE5532, sada 49720 ali nisam zadovoljan kako rade. Quote Link to comment Share on other sites More sharing options...
patason Posted August 9, 2016 Report Share Posted August 9, 2016 Na sajtu burson pod retailers ima naseg Aleka a sajt tog naseg distributera je www.kupujem prodajem.com! Smejurija,to govori o ozbiljnosti tj ocajnosti bursona,distributer nije samo ko nije pitao. A sto se tice upgrejda condova i ostalog u dac-u (ne pitajte sta je radjeno) mogu da preporucim firmu Grada Audio sa istog sajta (kup.prodajem),mozda se dobije i kolegijalni i distributerski popust. Quote Link to comment Share on other sites More sharing options...
Spachek Posted August 9, 2016 Report Share Posted August 9, 2016 @patason bas zna da ga zadinga Quote Link to comment Share on other sites More sharing options...
Alek5 Posted August 9, 2016 Report Share Posted August 9, 2016 Da ne dodje do zabune, clan surferlola je dobio detaljno obavestenje u PP. Ne zelim rekramirati Burson V5, tako sto cu ja pisati o njemu, nego tako sto ce kupci pricati o njemu. Vreme ce pokazati. @patason pokusava kao i mnogi, da na svaki nacin nadje resenje za ponizavanje, a ne nacin za pomoc. Kao prvo: Mi smo veoma smesno trziste za Burson. Meni su iz Bursona postavili neke uslo da bih bio distributer, ali propao bih kao i mnogi u Srbiji, da ih ne pominjem sada, kupovna moc je veoma mala. Na moju Molbu oni su pristali da prodajem op-amp-ove na sajtu Kupojem prodajem, jel tako sam smanjio troskove sajta itd. Nisam ja to uradio zbog sebe, nego zbog svih nas, da svako ko zeli kupiti Burson op-amp-ove, dobije po ceni kao na sajtu. Ako ja platim reklamu, transport, carinu, pa po kojoj ceni da prodajem taj Burson. Ukljucite malo mozak, nemojte samo kritikovati. Ja Nigde jos nisam napravio marketing za Burson. Da li se neko zapitao zasto? Zato sto sam unapred prodao kolicinu koju ni ja sam nisam ocekivao, mnogi audiofili su srecni sto Burson mogu kupiti po ceni kao na sajtu, a da pritom ne plate troskove slanja, carine i ostalih Gluposti. Nemojte se sekirati, necu se obogatiti od Bursona. Ja sam vec bogat covek, nema potrebe o tome brinuti. Za sve prave ljubitelje dobrog zvuka, javno govorim da ce dobiti Burson besplatno na probu, ali ljudi kao sto je "patason" me sputavaju u takvoj vrsti marketinga, dobijes op-amp, pa platis ako ti se svidi, ako ne vratis. To je moj cilj, da se od vas cuje da Burson V5 radi fantasticno! Sta vama znaci da to ja objavim, za vecinu vas ce biti samo povod za vredjanje i omalozavanje. Ja sam clan i drugih foruma u inostranstvu, nigde nema ovoliko mrznje i zlobe kao kod nas, to je strasno, mi smo definitivno zatrovana nacija, meni je stvarno zao zbog nas, ali ja kao jedan ili nas 20%, ne mozemo promeniti Srbiju. Zamolio bih javno sve, da ne daju uvredljive komentare i da ne pristupaju temi mimo pitanja koje je u ovoj temi. Ako ostvarimo zdravu kumunikaciju, lepo cemo se druziti i docicemo do dobrih rezultata u nasim sistemima. Grada Audio je dobar majstor, ali svoje znanj cuva za sebe i radi uredjaje po svom principo. Ja moj DAC radim po mom principu i zelim to sam uraditi. Pre kupovine Bursona, promenio sam silu hvaljenih op-amp-ova iz serije LME, Muses 02, AD, sve je to zvucalo veoma lose, mislio sam da su kutije u pitanju.. i nisam razmisljao kao neki: kako cu uvrediti nekog na forumu, nego posaljem mail Bursonu, oni prihvate da mi vrate novec u slucaju da se meni to ne svidi, fenomenalna saradnja, zdrava komunikacija i doprinelo je veliki rezultat u mom sistemu. Nisam ja kriv "patason" sto sam sposobniji od tebe, nije problem u meni prijatelju, problem je u tebi, kao i u mnogima sto samo prozivaju ovde na forumu i vredjaju, umesto da svi komuniciramo na zdravoj frekvenciji, druzenja, zamene op-amp-ova.. besplatna proba sa moje strane u svakom sistemu.. to se zove audiofilsko druzenje i ljubav prema muzici. Zato sam ja ovde gde jesem i imam to sto imam.. Za 20 dana ce stici treca porudzbina Bursona, svako ce dobiti na probu ako zeli. Zbog raznih komentara, nepoznati meni clanovi, platice 70% cene vrednosti proizvoda, u slucaju da se op-amp ne svidi, vracam novac. Svako ko dobije Burson V5, moze ga slikati i dati svoje misljenje o njemu. To je vase pravo za svaki proizvod. Ali nemojte davati smesne komentare, niko nije vrdan toga. Lepa rec velika vrata otvara. Nije tesko biti fin, ostalo je nas veoma malo koji vole muziku i stalno zele nesto novo, nedajmo da se i ovo malo rasturi. Mnogi koji su od mene kupili Burson V5 ne zele pricati o forumu a ne citati i pisati u njemu, bas zbog komentara nekih doticnih osoba, meni je zao sto je vecina audiofila napustila forum zbog osoba koji nisu vredni ni pomena. Svima zelim veoma lep uspeh u nadogradnji svojih sistema. Uzivajte u muzici. Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted August 9, 2016 Report Share Posted August 9, 2016 1 sat ranije, Alek5 said: Za 20 dana ce stici treca porudzbina Bursona, svako ce dobiti na probu ako zeli. Evo ja se javljam za "bezec" unapred, pare nemam al' dobru volju da probam imam, i da posle napisem utiske. Posle probe vracam, majke mi , osim u slucaju da me stvarno obori s nogu onda zajmim novce... Quote Link to comment Share on other sites More sharing options...
Alek5 Posted August 9, 2016 Report Share Posted August 9, 2016 7 minuta ranije, zveroguster said: Evo ja se javljam za "bezec" unapred, pare nemam al' dobru volju da probam imam, i da posle napisem utiske. Posle probe vracam, majke mi , osim u slucaju da me stvarno obori s nogu onda zajmim novce... Baciću te na trosak, nemoj to da radis.. u PP za koji model ste zainteresovani.. Singl V5 ili Dual V5, kolko op-amp-a.. i da vidimo da li smem da se oslonim na to majke mi.. Vec imam jednog sto govori, evo majke mi sacekaj jos 2 dana da nadjem novac.. Ja stvarno hocu svima da dam na probu, ali na "majke mi" nisu hteli ni meni iz Bursona da daju.. Kaze: plati, ne svidja ti se, ja vratim novac.. Dogovoricemo se u PP.. Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted August 9, 2016 Report Share Posted August 9, 2016 A ondak nista, mea culpa, ja razumeo da svako ko zeli moze da proba. Quote Link to comment Share on other sites More sharing options...
vladastevic Posted August 9, 2016 Report Share Posted August 9, 2016 Moglo bi da se organizuje neko grupno testiranje bursona na vise uredjaja?! Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted August 9, 2016 Report Share Posted August 9, 2016 4 sati ranije, patason said: Na sajtu burson pod retailers ima naseg Aleka a sajt tog naseg distributera je www.kupujem prodajem.com! Smejurija,to govori o ozbiljnosti tj ocajnosti bursona,distributer nije samo ko nije pitao. Lično mislim da je dobro što još jednu firmu imamo na srpskom tržištu. A što se tiče oglasa, mnogi distirbuteri su počeli upravo tako, nekima je to još uvek kanal prodaje, a da ne govorimo o trećima koji prodaju iz gepeka. A i ne vidim potrebu da u Srbiji postoji distributer za Burson kad je dovoljan jedan agent ili maloprodaja. Quote Link to comment Share on other sites More sharing options...
Alek5 Posted August 9, 2016 Report Share Posted August 9, 2016 20 minuta ranije, Willi Studer said: Lično mislim da je dobro što još jednu firmu imamo na srpskom tržištu. A što se tiče oglasa, mnogi distirbuteri su počeli upravo tako, nekima je to još uvek kanal prodaje, a da ne govorimo o trećima koji prodaju iz gepeka. A i ne vidim potrebu da u Srbiji postoji distributer za Burson kad je dovoljan jedan agent ili maloprodaja. Hvala puno na razumevanju i podrsci.. Mislim da ce svi imati korist od ovoga. Dobice proizvode po konacnim cenama kao na sajtu. Quote Link to comment Share on other sites More sharing options...
patason Posted August 10, 2016 Report Share Posted August 10, 2016 3 sati ranije, Alek5 said: Da ne dodje do zabune, clan surferlola je dobio detaljno obavestenje u PP. Ne zelim rekramirati Burson V5, tako sto cu ja pisati o njemu, nego tako sto ce kupci pricati o njemu. Vreme ce pokazati. @patason pokusava kao i mnogi, da na svaki nacin nadje resenje za ponizavanje, a ne nacin za pomoc. Kao prvo: Mi smo veoma smesno trziste za Burson. Meni su iz Bursona postavili neke uslo da bih bio distributer, ali propao bih kao i mnogi u Srbiji, da ih ne pominjem sada, kupovna moc je veoma mala. Na moju Molbu oni su pristali da prodajem op-amp-ove na sajtu Kupojem prodajem, jel tako sam smanjio troskove sajta itd. Nisam ja to uradio zbog sebe, nego zbog svih nas, da svako ko zeli kupiti Burson op-amp-ove, dobije po ceni kao na sajtu. Ako ja platim reklamu, transport, carinu, pa po kojoj ceni da prodajem taj Burson. Ukljucite malo mozak, nemojte samo kritikovati. Ja Nigde jos nisam napravio marketing za Burson. Da li se neko zapitao zasto? Zato sto sam unapred prodao kolicinu koju ni ja sam nisam ocekivao, mnogi audiofili su srecni sto Burson mogu kupiti po ceni kao na sajtu, a da pritom ne plate troskove slanja, carine i ostalih Gluposti. Nemojte se sekirati, necu se obogatiti od Bursona. Ja sam vec bogat covek, nema potrebe o tome brinuti. Za sve prave ljubitelje dobrog zvuka, javno govorim da ce dobiti Burson besplatno na probu, ali ljudi kao sto je "patason" me sputavaju u takvoj vrsti marketinga, dobijes op-amp, pa platis ako ti se svidi, ako ne vratis. To je moj cilj, da se od vas cuje da Burson V5 radi fantasticno! Sta vama znaci da to ja objavim, za vecinu vas ce biti samo povod za vredjanje i omalozavanje. Ja sam clan i drugih foruma u inostranstvu, nigde nema ovoliko mrznje i zlobe kao kod nas, to je strasno, mi smo definitivno zatrovana nacija, meni je stvarno zao zbog nas, ali ja kao jedan ili nas 20%, ne mozemo promeniti Srbiju. Zamolio bih javno sve, da ne daju uvredljive komentare i da ne pristupaju temi mimo pitanja koje je u ovoj temi. Ako ostvarimo zdravu kumunikaciju, lepo cemo se druziti i docicemo do dobrih rezultata u nasim sistemima. Grada Audio je dobar majstor, ali svoje znanj cuva za sebe i radi uredjaje po svom principo. Ja moj DAC radim po mom principu i zelim to sam uraditi. Pre kupovine Bursona, promenio sam silu hvaljenih op-amp-ova iz serije LME, Muses 02, AD, sve je to zvucalo veoma lose, mislio sam da su kutije u pitanju.. i nisam razmisljao kao neki: kako cu uvrediti nekog na forumu, nego posaljem mail Bursonu, oni prihvate da mi vrate novec u slucaju da se meni to ne svidi, fenomenalna saradnja, zdrava komunikacija i doprinelo je veliki rezultat u mom sistemu. Nisam ja kriv "patason" sto sam sposobniji od tebe, nije problem u meni prijatelju, problem je u tebi, kao i u mnogima sto samo prozivaju ovde na forumu i vredjaju, umesto da svi komuniciramo na zdravoj frekvenciji, druzenja, zamene op-amp-ova.. besplatna proba sa moje strane u svakom sistemu.. to se zove audiofilsko druzenje i ljubav prema muzici. Zato sam ja ovde gde jesem i imam to sto imam.. Za 20 dana ce stici treca porudzbina Bursona, svako ce dobiti na probu ako zeli. Zbog raznih komentara, nepoznati meni clanovi, platice 70% cene vrednosti proizvoda, u slucaju da se op-amp ne svidi, vracam novac. Svako ko dobije Burson V5, moze ga slikati i dati svoje misljenje o njemu. To je vase pravo za svaki proizvod. Ali nemojte davati smesne komentare, niko nije vrdan toga. Lepa rec velika vrata otvara. Nije tesko biti fin, ostalo je nas veoma malo koji vole muziku i stalno zele nesto novo, nedajmo da se i ovo malo rasturi. Mnogi koji su od mene kupili Burson V5 ne zele pricati o forumu a ne citati i pisati u njemu, bas zbog komentara nekih doticnih osoba, meni je zao sto je vecina audiofila napustila forum zbog osoba koji nisu vredni ni pomena. Svima zelim veoma lep uspeh u nadogradnji svojih sistema. Uzivajte u muzici. odakle poceti posle ove epopeje....."alek5" (jos jednu stvar sam naucio od ovog bogatog i sposobnijeg od mene coveka,kako se obraca nekome po forumskom nadimku) sta je tebi uvredljivo u mom pisanju da je jadna firma ciji je takav zastupnik za bilo koje trziste.Aj sto nema firmu,poslovni prostor....al da dozvoli da se zastupnik registruje i vrsi prodaju,marketing preko sajta za kup-prodaju i hi fi foruma.Da to rade i drugi ne cini taj cin legitimnim i manje mizernim.To je tako bar za ugrubo ovih 20% Srbije u kojih ti sebe ubrajas,ali veruj mi laskas sebi. Zasto se ti pajtas sa moderatorom to je jasno,ko god ti ide na ruku taj je fin,kulturan,uspesan i bogat,ali zasto moderator ovde javno podrzava tebe koji, opet javno,ovde pises da si ti opste srpsko dobro koje treba ceniti jer nam svima velikim zalaganjem i zrtvom omogucujes da nesto kupimo bez placanja "carine,postarine,pdv-a i ostalih gluposti"!!!!!!?????Siguran sam da si se ti tim svojim "sposobnostima" obogatio(o tome vec pises ko zna koji put),znam da nisi jedini ali zadrzi to za sebe ili idi u poresku upravu pa im to nabij na nos,ne ovde. Meni je ovo jasno da se desava ali moderacija i vlasnik prema ovom pitanju MORAJU zauzeti stav kao prema pirateriji,nije na nama da to resavamo i sudimo ali ovde nema javne price o tome!Sledece na forumu ce biti tema "kako ukrasti i ubiti a da vas ne uhvate."-gde ce moderacija da uzme javno ucesca sa recima podrske i odobravanja. "alek5" da li ti ovo radis zarad neke koristi ili ti imponuje da si distributer bursona ili si ti stvarno jedna dobra dusa koja svoje odusevljenje opampovima zeli da podeli sa svetom bez ikakve koristi za sebe i po cenu krsenja zakon? Ako je ovo trece ja ti se iskreno izvinjavam i kupicu jedan par bilo kojih bursona bez probe (i nemam gde da probam meni sve diskretno)-mozda ce mi imponovati da ih posedujem makar i u vitrini-za fiskalni i garanciju cemo nesto da smuljamo,pomoci ce dobri ljudi.(nema dozivotne garancije na "majke mi" jel tako) Quote Link to comment Share on other sites More sharing options...
dragan333 Posted August 10, 2016 Report Share Posted August 10, 2016 9 sati ranije, patason said: Meni je ovo jasno da se desava ali moderacija i vlasnik prema ovom pitanju MORAJU zauzeti stav kao prema pirateriji,nije na nama da to resavamo i sudimo ali ovde nema javne price o tome!Sledece na forumu ce biti tema "kako ukrasti i ubiti a da vas ne uhvate."-gde ce moderacija da uzme javno ucesca sa recima podrske i odobravanja. "alek5" da li ti ovo radis zarad neke koristi ili ti imponuje da si distributer bursona ili si ti stvarno jedna dobra dusa koja svoje odusevljenje opampovima zeli da podeli sa svetom bez ikakve koristi za sebe i po cenu krsenja zakon? Ako je ovo trece ja ti se iskreno izvinjavam i kupicu jedan par bilo kojih bursona bez probe (i nemam gde da probam meni sve diskretno)-mozda ce mi imponovati da ih posedujem makar i u vitrini-za fiskalni i garanciju cemo nesto da smuljamo,pomoci ce dobri ljudi.(nema dozivotne garancije na "majke mi" jel tako) Bravo care gde si da te vodim na pivo? Hihihihihi postenjacine,dobre duse,lazni prijatelji itd...u ovoj neprofitnoj organizaciji nicu jedan do drugoga nicu iz dana u dan... Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted August 10, 2016 Report Share Posted August 10, 2016 11 sati ranije, patason said: Meni je ovo jasno da se desava ali moderacija i vlasnik prema ovom pitanju MORAJU zauzeti stav kao prema pirateriji,nije na nama da to resavamo i sudimo ali ovde nema javne price o tome!Sledece na forumu ce biti tema "kako ukrasti i ubiti a da vas ne uhvate."-gde ce moderacija da uzme javno ucesca sa recima podrske i odobravanja. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted August 10, 2016 Report Share Posted August 10, 2016 Pravda za Burson Quote Link to comment Share on other sites More sharing options...
dragan333 Posted August 10, 2016 Report Share Posted August 10, 2016 11 minuta ranije, Vlajo said: Pravda za Burson U nasoj divnoj zemlji prijatelju moj je pravda davno nestala! Quote Link to comment Share on other sites More sharing options...
perodeformero Posted August 10, 2016 Report Share Posted August 10, 2016 Kome smeta jak Burson, i to baš sada, i kome to odgovara? Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted August 10, 2016 Report Share Posted August 10, 2016 Krletki! Buahahahahaahahah... Quote Link to comment Share on other sites More sharing options...
dragan333 Posted August 10, 2016 Report Share Posted August 10, 2016 Meni ne al jaka je firma cim ne moze da otvori malu poslovnicu od bar 10m2 imaju predstavnika mislim da bi to bilo sasvim ok! Zar ne? Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted August 10, 2016 Report Share Posted August 10, 2016 Ma nema potrebe za lokalom, to neminovno donosi troskove koji se odrazavaju na konacan proizvod. Ovo je idealna varijanta gde dobijas proizvod po ceni sa sajta, ni dinar vise. Ali Srbinu to ne odgovara, nesto tu nije kako valja, neko se tu bogati, neko hoce da nas zahebe, itd. Pritom ni malo ne branim doticnog distributera, nemam nista sa njim, cak mogu da kazem da je prilicno konfuzan i nedorecen u svojim komentarima sto za biznis svakako nije dobro, ali boze moj... Quote Link to comment Share on other sites More sharing options...
dragan333 Posted August 10, 2016 Report Share Posted August 10, 2016 4 minuta ranije, zveroguster said: Ma nema potrebe za lokalom, to neminovno donosi troskove koji se odrazavaju na konacan proizvod. Ovo je idealna varijanta gde dobijas proizvod po ceni sa sajta, ni dinar vise. Ali Srbinu to ne odgovara, nesto tu nije kako valja, neko se tu bogati, neko hoce da nas zahebe, itd. Pritom ni malo ne branim doticnog distributera, nemam nista sa njim, cak mogu da kazem da je prilicno konfuzan i nedorecen u svojim komentarima sto za biznis svakako nije dobro, ali boze moj... Ima istine! A cene hoce li biti kao sa zvanicnog sajta? Ako je tako svi mozemo direkt od njih kome sta treba poruciti! Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted August 10, 2016 Report Share Posted August 10, 2016 Cena kod Aleka za Burson opamp je cena koja stoji na sajtu (bez carina, slanja iz inostranstva i sl.) toliko treba da se plati njemu. E sad, troskovi slanja po Srbiji su na teretu kupca, ako cemo u sitna crevca. Quote Link to comment Share on other sites More sharing options...
Alek5 Posted August 10, 2016 Report Share Posted August 10, 2016 @patason ponovo pises po svojim nagadjanjima. Lepo pise, da kupci Bursona u Srbiji nece paltiti porez i carinu, a ne da porez i carina nisu placeni.. Sad ces izmisljati jos puno toga, jer verovatno nemas preceg posla. Ni u jednoj tvojoj temi nisam pisao sa takvim pristupom, niti sam od bilo kog clana zasluzio ovakvo obracanje. Ako ne mogu pomoci u nekoj temi, onda i ne pristupam temi, tako bih molio i tebe da postupas, a samim tim i sve ostale. Nema potrebe za bilo kakvim provokacijama. ko zeli kupiti Bursone, dobice, ko ne zeli nega zaobidje temu ili oglas i svi smo srecni. Hvala puno na razumevanju. @Vlajo Vama je poznat Clan dragan333, koji se lazno pretstavljao nekoliko puta. Mnogi clanovi su me kontaktirali zbog njega, ali nisam hteo to javno komentaristati, moram biti iskren, iz sazaljenja prema Draganu. Momak je u invalidskim kolicima i svoje vreme trenutno upraznjava pisanjem na forumu, jel mu na zalost njegovu, to jedini vid gubljenja vremena, i na zalost povukao negativnu starnu nekih clanova, pa ce pokusavati svako omalozavanje ako je moguce, ne bi li se zanimao. @dragan333 Molio bih te javno da ne kometrasises postove mimo teme, nije lepo, sve vise ima postova mimo teme i svi se brinu o tudjem zivotu, a ne pronalaze resenje da poboljsaju svoj. Molio bih te javno, posto nisi imao hrabrosti javiti se na telefon, nego si me zamolio da ti se obratim putem SMS-a, kao sto sam ti i rekao u SMS-u, bio sam ti burazer kad ti se niko nije javljao na telefon, pa sam ti pomagao iz dobre namere u sklapanju tvog sistema i nisam zasluzio takvo javno obracanje. Ako imamo nesto nerazjanjeno, imas moj broj telefona i uvek me mozes pozvati. Svako dobro ti zelim, brz oporavak i da sto pre nadjes neku bolju zanimaciju u zivotu, a da forum zaobidjes ako nemas nista pametno napisati u bilo kojoj temi. Jos jednom bih sve zamolio da postuju naslov teme, da komentari i pitanja budu u okviru naslova ili teme. Zahvaljujem se svima na razumevanju. Quote Link to comment Share on other sites More sharing options...
dragan333 Posted August 10, 2016 Report Share Posted August 10, 2016 5 minuta ranije, Alek5 said: @patason ponovo pises po svojim nagadjanjima. Lepo pise, da kupci Bursona u Srbiji nece paltiti porez i carinu, a ne da porez i carina nisu placeni.. Sad ces izmisljati jos puno toga, jer verovatno nemas preceg posla. Ni u jednoj tvojoj temi nisam pisao sa takvim pristupom, niti sam od bilo kog clana zasluzio ovakvo obracanje. Ako ne mogu pomoci u nekoj temi, onda i ne pristupam temi, tako bih molio i tebe da postupas, a samim tim i sve ostale. Nema potrebe za bilo kakvim provokacijama. ko zeli kupiti Bursone, dobice, ko ne zeli nega zaobidje temu ili oglas i svi smo srecni. Hvala puno na razumevanju. @Vlajo Vama je poznat Clan dragan333, koji se lazno pretstavljao nekoliko puta. Mnogi clanovi su me kontaktirali zbog njega, ali nisam hteo to javno komentaristati, moram biti iskren, iz sazaljenja prema Draganu. Momak je u invalidskim kolicima i svoje vreme trenutno upraznjava pisanjem na forumu, jel mu na zalost njegovu, to jedini vid gubljenja vremena, i na zalost povukao negativnu starnu nekih clanova, pa ce pokusavati svako omalozavanje ako je moguce, ne bi li se zanimao. @dragan333 Molio bih te javno da ne kometrasises postove mimo teme, nije lepo, sve vise ima postova mimo teme i svi se brinu o tudjem zivotu, a ne pronalaze resenje da poboljsaju svoj. Molio bih te javno, posto nisi imao hrabrosti javiti se na telefon, nego si me zamolio da ti se obratim putem SMS-a, kao sto sam ti i rekao u SMS-u, bio sam ti burazer kad ti se niko nije javljao na telefon, pa sam ti pomagao iz dobre namere u sklapanju tvog sistema i nisam zasluzio takvo javno obracanje. Ako imamo nesto nerazjanjeno, imas moj broj telefona i uvek me mozes pozvati. Svako dobro ti zelim, brz oporavak i da sto pre nadjes neku bolju zanimaciju u zivotu, a da forum zaobidjes ako nemas nista pametno napisati u bilo kojoj temi. Jos jednom bih sve zamolio da postuju naslov teme, da komentari i pitanja budu u okviru naslova ili teme. Zahvaljujem se svima na razumevanju. Ako sam se ja lazno predstavljao bog nek mi svedok bude. Audioquest tip6 200e kod aleka uz to naplacuje savetovanje vezano za hifi satro prijatelj...Molio me da mu porucim iz holandije kimber pk10 1,8m i pk14 1,5m od kojih nisam dinar uzeo se ciganisao za troskove slanja od 45e uz to cim su mu stigli poslao mi je cene konekcija onda me je optuzio da sam mu skinuo konekcije sa pk10 a meni ne rade prsti kod distributera kaze ima 40%popust (sto onda porucujes iz inostranstva) kablovi su izasli 400e kao novi! Mani se tih satro fora sazaljenja i laznog prijateljstva jer prvo nisi COVEK a sazaljenje mi nicije ne treba pogotovo nekoga poput tebe! Koliko imas profila na kp? Moj savet ne poslujte sa ovim necovekom i pokvarenjakok! Lepo mi je nekoliko ljudi savetovalo da ne poslujem sa njim...pocetnik uvek placa neiskustvo! Treba da te bude sramota! Banujte me jer sam iskren i cistog obraza za razliku od doticnog postenjacine! I molim te clanove kojima sam se lazno predstavljao i koji su te kontaktirali u vezi mene nek se jave!!! Stidi se Quote Link to comment Share on other sites More sharing options...
dragan333 Posted August 10, 2016 Report Share Posted August 10, 2016 2 sati ranije, Vlajo said: Pravda za Burson Po cemu sam ja vama poznat? Quote Link to comment Share on other sites More sharing options...
Alek5 Posted August 10, 2016 Report Share Posted August 10, 2016 9 minuta ranije, dragan333 said: Ako sam se ja lazno predstavljao bog nek mi svedok bude. Audioquest tip6 200e kod aleka uz to naplacuje savetovanje vezano za hifi satro prijatelj...Molio me da mu porucim iz holandije kimber pk10 1,8m i pk14 1,5m od kojih nisam dinar uzeo se ciganisao za troskove slanja od 45e uz to cim su mu stigli poslao mi je cene konekcija onda me je optuzio da sam mu skinuo konekcije sa pk10 a meni ne rade prsti kod distributera kaze ima 40%popust (sto onda porucujes iz inostranstva) kablovi su izasli 400e kao novi! Mani se tih satro fora sazaljenja i laznog prijateljstva jer prvo nisi COVEK a sazaljenje mi nicije ne treba pogotovo nekoga poput tebe! Koliko imas profila na kp? Moj savet ne poslujte sa ovim necovekom i pokvarenjakok! Lepo mi je nekoliko ljudi savetovalo da ne poslujem sa njim...pocetnik uvek placa neiskustvo! Treba da te bude sramota! Banujte me jer sam iskren i cistog obraza za razliku od doticnog postenjacine! I molim te clanove kojima sam se lazno predstavljao i koji su te kontaktirali u vezi mene nek se jave!!! Stidi se Smesan je tvoj komentar Dragane.. necu komentarisisati nista iz sazaljenja prema tebi.. Nega ti Bog da, da sto pre prohodas i da se manes foruma. Zelim ti sve najbolje u zivotu. Svaki momentar na ovo je suvisan. Quote Link to comment Share on other sites More sharing options...
