beatgoeson Posted June 16, 2016 Report Share Posted June 16, 2016 Da ponesem mernu opremu? Quote Link to comment Share on other sites More sharing options...
Chieftec Posted June 16, 2016 Report Share Posted June 16, 2016 Šta fali merenjima, ovaj deo foruma je o tehnici. Neka promena tako može da se potkrepi dokazima, tj merenjem, ma koliko to imalo ili nemalo značaja na zvuk. A 'promenio sam konektor, umesto 2% srebra ima 2,5% i sada je bass drastičbo bolji' su ok teme? Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted June 16, 2016 Report Share Posted June 16, 2016 37 minuta ranije, beatgoeson said: Da ponesem mernu opremu? Obavezno, ali prvo slusanje pa gledanje. Quote Link to comment Share on other sites More sharing options...
thezox Posted June 17, 2016 Report Share Posted June 17, 2016 Ovo je Jim. Jim koristi tri sub-a. Budi kao Jim. Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted June 17, 2016 Report Share Posted June 17, 2016 Buahahahaha... Quote Link to comment Share on other sites More sharing options...
lalelala Posted June 17, 2016 Report Share Posted June 17, 2016 Jim je ljudina , oduvao bi ga i PC zvučnik Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted June 17, 2016 Report Share Posted June 17, 2016 19 sati ranije, Chieftec said: Šta fali merenjima, ovaj deo foruma je o tehnici. Neka promena tako može da se potkrepi dokazima, tj merenjem, ma koliko to imalo ili nemalo značaja na zvuk. A 'promenio sam konektor, umesto 2% srebra ima 2,5% i sada je bass drastičbo bolji' su ok teme? Sa vise srebrnine ce se visoki poboljsat' no basovina! Quote Link to comment Share on other sites More sharing options...
sondek Posted June 17, 2016 Report Share Posted June 17, 2016 'beš temu bez trolovanja? Šteta da ima neka koja je nije 90% u oftopicu? Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted June 17, 2016 Report Share Posted June 17, 2016 A sto se ti javljas? Mi smo i dalje "u temi" sa kritickim stavom. Sme li se? Odi ti u svoju Ban(an)ovinu, tamo ionako samo ti kadrujes i vodis glavnu rijec. Ovim zavrsavam trolovanje teme iniciran prethodnim postom onoga gospara. Quote Link to comment Share on other sites More sharing options...
Savoo70 Posted June 17, 2016 Report Share Posted June 17, 2016 Vidim da se javljaju samo korisnici sa vrlo skupim subovima i oni koji umeju da ih sami naprave . Pa jos pluste saveti za dva i vise komada. Znaci li to da u ovom delu relatrivno jeftinih resenja nema? Gledao sam malo cene i za SVS i za Rel. Ima i skromnijih resenja. To ne valja? Quote Link to comment Share on other sites More sharing options...
Delija Posted June 17, 2016 Report Share Posted June 17, 2016 Sto se tice SVS - rade posao i jeftiniji samo tako, ali uz odredjena ogranicenja. Recimo, uz BR varijante bas i ne idu mali zvucnici iliti sme da im se prepusti samo najnizi deo spektra. Opet, jeftinije kompresione varijante koje mogu da sviraju i visi deo spektra nemaju dovoljno "vatre" za bas glasno slusanje i/ili bas velike prostorije. Sve ima svoje Quote Link to comment Share on other sites More sharing options...
dj.nik Posted June 17, 2016 Report Share Posted June 17, 2016 29 minuta ranije, Savoo70 said: Vidim da se javljaju samo korisnici sa vrlo skupim subovima i oni koji umeju da ih sami naprave . Pa jos pluste saveti za dva i vise komada. Znaci li to da u ovom delu relatrivno jeftinih resenja nema? Gledao sam malo cene i za SVS i za Rel. Ima i skromnijih resenja. To ne valja? Pardoniram, ja navedoh proizvodjaca ciji sub-ovi kostaju od 215 do max. nekih 600 engleskih moneta. I to skupo? Za aktivni subwoofer, sa pojacalom? SumLJam da se nesto ozboljno za novce od ~ Lstg 250 moze napraviti u samogradnji. A ja ne bezim od iste, niti imamam dve leve ruke. Zarad istine, alat drzim u levoj, al' jos uvek pouzdano Quote Link to comment Share on other sites More sharing options...
Technicssss Posted June 17, 2016 Report Share Posted June 17, 2016 Zdravo dobri ljudi Vidim da se raspricaste pa imam par (nadam se pametnih) pitanja: #1 - Da li se pri merenju frekventnog opsega dobija isti rezultat bez obzira na glasnocu? Dakle da li jedan sistem u npr najnizem opsegu imati iste rupe ili peak-ove na 20%, 30% ili 50% snage? #2 - Da li je zbog dopune najnizeg frekventnog opsega potrebno dodavati subwoofer vecim zvucnicima koji u praksi bez problema mogu da se spuste do 25Hz? #3 - Pitanje je slicno kao ono koje je neko postavio za B&W 801D Vs. 805N + sub, dakle da li je neko probao da uporedi bookshelf model neke serije + subwoofer sa vecim podnim modelom te iste serije? #4 - Da li ima nekih "pravila" sto se tice dimenzija kabineta i drajvera kada je u pitanju kombinacija zvucnika i sub-a? Da li za bookshelf modele sa mid / bass drajverima precnika npr 130 mm treba sub sa drajverom do npr 200 mm ili mogu i oni sa 250 / 300 mm? Da li ce veca snaga i dimenzije drajvera biti prepreka za uskladjivanje sa manjim zvucnicima? #5 - Koliki procenat srebra mora imati kabl mikrofona da bi lepo pokupio visoke frekvencije pri merenjima? p.s. Na peto pitanje ne morate odgovarati, cisto mala sala, nadam se da se nece shvatiti ozbiljno Dosla su vremena da cak i to moram da napomenem... Quote Link to comment Share on other sites More sharing options...
trotter Posted June 17, 2016 Report Share Posted June 17, 2016 #2 Ne dodaje se subwoofer zbog dopune niskih frekvencija nego zbog kvaliteta istih, moje je misljenje na osnovu pracenja ove teme i malo iscitavanja sa drugih strana. Nije svejedno ni koji subwoofer, verovatno 90% sub-ova na trzistu moze da brunda vrlo nisko i da drma namestaj ali to nije cilj. Nema ni puno muzike sa toliko niskim frekvencijama (25Hz) ali recimo da nisi mislio na tu odredjenu cifru. Drugo, postoji vrlo malo zvucnika koji mogu da odsviraju stvarno 25Hz, ma sta pisalo na specifikaciji nazad. Trece, koliko sam shvatio, uklapanje subwoofera (jedan ili vise) u sistem nije laganica i vrlo zavisi od konkretne prostorije gde je sistem, tako da smatram da je bilo kakvo razmisljanje o tome nepotrebno u smislu dobijanja kvalitetnog rezultata osim u slucaju ozbiljnog planiranja (merenja) i ulaganja jer prosto ubaciti sub u postojeci sistem bez konkretnih akcija u analizi postojece situacije u frekventnim pokazateljima na poziciji slusanja mislim da nema puno smisla? Quote Link to comment Share on other sites More sharing options...
pinokio Posted June 17, 2016 Report Share Posted June 17, 2016 Ima li iko ovde SVS PB 2000? ako da, kakva su vam iskustva? Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted June 17, 2016 Report Share Posted June 17, 2016 #1 Sam softver ima neka ograničenja glasnoće, radi tačnijih rezultata. Inače, pikovi i rupe ostaju isti (ili veoma slični) pri promeni glasnoće. Neke razlike su, eventualno, u distorziji koja je manja na nižem nivou. #4 Nema veze koliki je sub (ili više njih), bitno je da se dobro udenu u sistem. Procena veličine i broja je više pitanje veličine prostorije i glasnoće emitovanja. Quote Link to comment Share on other sites More sharing options...
Delija Posted June 17, 2016 Report Share Posted June 17, 2016 3 sati ranije, Technicssss said: #2 - Da li je zbog dopune najnizeg frekventnog opsega potrebno dodavati subwoofer vecim zvucnicima koji u praksi bez problema mogu da se spuste do 25Hz? Koji to zvucnik svira 25Hz uz roll-off od max -3dB, a da nije full aktiva? Quote Link to comment Share on other sites More sharing options...
pecass Posted June 17, 2016 Report Share Posted June 17, 2016 4 sati ranije, Technicssss said: Zdravo dobri ljudi Vidim da se raspricaste pa imam par (nadam se pametnih) pitanja: #1 - Da li se pri merenju frekventnog opsega dobija isti rezultat bez obzira na glasnocu? Dakle da li jedan sistem u npr najnizem opsegu imati iste rupe ili peak-ove na 20%, 30% ili 50% snage? #2 - Da li je zbog dopune najnizeg frekventnog opsega potrebno dodavati subwoofer vecim zvucnicima koji u praksi bez problema mogu da se spuste do 25Hz? #3 - Pitanje je slicno kao ono koje je neko postavio za B&W 801D Vs. 805N + sub, dakle da li je neko probao da uporedi bookshelf model neke serije + subwoofer sa vecim podnim modelom te iste serije? #4 - Da li ima nekih "pravila" sto se tice dimenzija kabineta i drajvera kada je u pitanju kombinacija zvucnika i sub-a? Da li za bookshelf modele sa mid / bass drajverima precnika npr 130 mm treba sub sa drajverom do npr 200 mm ili mogu i oni sa 250 / 300 mm? Da li ce veca snaga i dimenzije drajvera biti prepreka za uskladjivanje sa manjim zvucnicima? #5 - Koliki procenat srebra mora imati kabl mikrofona da bi lepo pokupio visoke frekvencije pri merenjima? p.s. Na peto pitanje ne morate odgovarati, cisto mala sala, nadam se da se nece shvatiti ozbiljno Dosla su vremena da cak i to moram da napomenem... Da dodam ±6 - Koji mikrofon se koristi u merenju omni Behringer sa 5$ kapislom ili maaaalko skuplji Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted June 17, 2016 Report Share Posted June 17, 2016 2 sati ranije, pecass said: ±6 - Koji mikrofon se koristi u merenju omni Behringer sa 5$ kapislom ili maaaalko skuplji Kao i svugde... kad vidiš da postoji neka stvar koja može da posluži i ista stvar ali maaaalko skuplja, dođe ti da kupiš ovu drugu, ali razum pobedi. Ponekad. Služi svrsi i ovaj Behringer, pogotovo ne bi trebalo da bude većih odstupanja u srednjem i nižem opsegu. Quote Link to comment Share on other sites More sharing options...
damic Posted June 18, 2016 Report Share Posted June 18, 2016 Malo edukacije nije na odmet: https://www.harman.com/sites/default/files/white-paper/12/11/2015 - 06%3A25/files/LoudspeakersandRoomsPt3.pdf https://www.harman.com/sites/default/files/white-paper/12/11/2015 - 06%3A12/files/multsubs.pdf Quote Link to comment Share on other sites More sharing options...
dj.nik Posted June 18, 2016 Report Share Posted June 18, 2016 I jos malo edukacije: http://www.linkwitzlab.com/rooms.htm Quote Link to comment Share on other sites More sharing options...
prophet Posted June 18, 2016 Report Share Posted June 18, 2016 16 sati ranije, Delija said: Koji to zvucnik svira 25Hz uz roll-off od max -3dB, a da nije full aktiva? Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted June 18, 2016 Report Share Posted June 18, 2016 16 sati ranije, Delija said: Koji to zvucnik svira 25Hz uz roll-off od max -3dB, a da nije full aktiva? i da nije DIY. @Prophet Aj' stavi dijagram bez smoothinga? Nije iz pakosti -. verujem da si ga dobro upeglao. Radoznalost je u pitanju. Quote Link to comment Share on other sites More sharing options...
prophet Posted June 18, 2016 Report Share Posted June 18, 2016 Nažalost otišlo stradavanjem HDD-a, između ostalog i komparativna merenja pasiva vs audissey koja smo radili kad si bio kod mene. Ti bi trebalo da možeš da pronađeš ona merenja koja audisey uploaduje u svoju bazu. Ovu sliku sam linkovao iz teme o mom sistemu, ne predstavlja konačnu verziju u kojoj je ispravljena anomalija na 880Hz kako fazna tako i spl kao i taj blagi porast. Koliko me sećanje služi konačnu verziju su čuli samo @pecass i @Sonichammer. Šta je postignuto? To da je opseg od 50Hz do preko 20kHz praktično na nuli i radi ono čemu teže svi korisnici full range ili panela ali ne upevaju u tome - da sve radi kao jedan drajver, gde čak i ekscesi van tog opsega ne prelaze 45 deg (podsetiću da je fabrički standard + - 45 deg i +- 3 db). Ovde je smoothing 1/3 što se smatra rezolucijom ljudskog uha. I da, sve je pasivno, radi kao dipole i natprosečno efikasno (radi sa lampašem od 7w) sa efektom zvučnog zida, a pritom effortless. Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted June 18, 2016 Report Share Posted June 18, 2016 Koliko se sećam, nisam nosio svoj laptop, ti si instalirao softver kod sebe. Tako da je i ta baza bila kod tebe. Quote Link to comment Share on other sites More sharing options...
