dragec Posted May 5, 2016 Report Share Posted May 5, 2016 Engleski audiofilski cd plejer u besprekornom stanju 10/10. Čita sve diskove u sekundi, originale, rezane itd. Ima nabavljiv laser. Uređaj je kao nov, nije otvaran, popravljan i slično, sve je u fabričkom stanju. Zvučno perfektan, ovo je viša klasa cd plejera i drastično popravlja zvuk u svim sistemima. Daljinski nije original, dajem univerzalni koji ima sve funkcije a može da posluži i bilo koji od Marantz cd plejera jer je isti kod. Pošto sam prešao na slušanje muzike preko DAC-a uređaj mi je višak, to jest suviše je skup da bih ga koristio samo kao transport, tako da je moguća zamena za jeftiniji cd plejer. Moguća proba. Kontakt: 069/75-73-74 Link to comment Share on other sites More sharing options...
dragec Posted May 5, 2016 Author Report Share Posted May 5, 2016 Cena: 350 EUR (nije fiksno) Link to comment Share on other sites More sharing options...
dragec Posted May 12, 2016 Author Report Share Posted May 12, 2016 Up! Evo i malo tehničkih specifikacija i kratak review ovog fenomenalnog cd plejera: Description : The Myryad MC-100 is built with stylish heavy face plates and well-designed ergonomics. Aesthetically, it appeals to those who prefer clean and functional equipments. It contains just the necessary operational functions, and a handy comfortable remote with the same front functions in addition to programming, display settings, and a bunch of number keys. The Myryad MC-100 is rather heavy due to the solid metal case and a sturdy chassis. The structure of the Myryad MC-100 is not complex but magnificent. The electronic circuits reside on two PCBs, with a wide distance between the power supply and audio circuits. The smaller electronic circuit with power supply smoothing capacitors and fuses, is installed beside a transformer. It is a conspicuous low EMI-generating toroidal transformer with secondary taps that feed the PCB. The bigger PCB with analog and digital circuits is installed on the right hand side. The power supply cables leading to audio PCB go through a very wide ferrite tube - filtering the high frequency debris. Much attention was paid to the reduction of electromagnetic interference in the player. The mains voltage is not connected directly to the transformer but passes through two small inductors connected in series. The front panel with display and control circuits is also separated from the rest of the player. There is a metal sheet screen about 2 cm behind the visible front plate, shielding other circuitries from possible detrimental noise. The system remote provides control of the basic functions, with numeric buttons that can select either CD tracks or FM presets. The Myryad MC-100 is not cluttered with buttons or knobs, portraying an understated elegance that inspires confidence. The Myryad MC-100's sound combines good rhythmic drive with very clean, articulate sound. It comes with a warmth that minimizes listening fatigue. The sound is powerful, refined and detailed. The Myryad MC-100 is a very reliable and clean sounding CD player that is built to last - an excellent player for audiophiles.Specifications : Digital Analogue Converter..................1bit Pulse Length Modulation (PLM) Frequency Response..........................20Hz - 20kHz ±0.3dB THD(1kHz).........................................0.003% @ 1kHz Signal Noise Ratio..............................104dB Dynamic Range..................................96dB Output Impedance..............................250 ohms Power Output.....................................2Vrms (when 0dB) Digital Output.....................................Coax 75 Omega, to SPDIF std external Front Panel Color...............................Titanium Tanzania color or black (6mm thick aluminum sheet) Dimensions(w x d x h)........................44 x 28.5 x 9.5 cm Weight..............................................5kg Link to comment Share on other sites More sharing options...
dragec Posted May 25, 2016 Author Report Share Posted May 25, 2016 Up! Cena pada na 300 EUR. Kontam da su mnogi audiofili prešli na digitaliju ali ovaj cd plejer ima zvuk takav da mnogo skuplji dakovi jednostavno ne mogu da mu priđu, neko ko ima dobru kolekciju originalnih cd-ova mogao bi da uzme ovaj plejer u razmatranje pogotovo po ovoj ceni Link to comment Share on other sites More sharing options...
dragec Posted April 7, 2017 Author Report Share Posted April 7, 2017 Up! Cd plejer još uvek u ponudi, kupio sam DAC pa mi je višak. Može zamena za skuplje uređaje, pojačalo ili zvučnici mi trebaju. Link to comment Share on other sites More sharing options...
Willi Studer Posted April 7, 2017 Report Share Posted April 7, 2017 U tekstu oglasa "mint" prepravljen u "besprekorno". Mint stanje je novo, nekorišćeno, u kutiji, eventualno raspakovano radi pregleda. Link to comment Share on other sites More sharing options...
dragec Posted May 28, 2017 Author Report Share Posted May 28, 2017 Prodato, može lock. Hvala. Link to comment Share on other sites More sharing options...
