slavko Posted April 26, 2016 Report Share Posted April 26, 2016 Kupujem napajanje za gramofon Pro-ject : input AC 220V output AC 16V/500mA ponude na tel: 064 110 66 40 Link to comment Share on other sites More sharing options...
slavko Posted April 27, 2016 Author Report Share Posted April 27, 2016 Ako neko zna,kako da nabavim i gde trafo ili neku zamenu ,ne mora da bude original,neka mi javi u poruci. Hvala unapred. Link to comment Share on other sites More sharing options...
aaa zmaju! Posted April 29, 2016 Report Share Posted April 29, 2016 Mozda moze ovo da posluzi, dok se ne snadjes za bolje samo se resiti ispravljaca. http://www.kupujemprodajem.com/AC-Adapter-ispravljac-za-HP-220V-32-16V-32300602-oglas.htm?filter_id=71156061 Link to comment Share on other sites More sharing options...
Zexx Posted April 29, 2016 Report Share Posted April 29, 2016 2 sati ranije, aaa zmaju! said: Mozda moze ovo da posluzi, dok se ne snadjes za bolje samo se resiti ispravljaca. http://www.kupujemprodajem.com/AC-Adapter-ispravljac-za-HP-220V-32-16V-32300602-oglas.htm?filter_id=71156061 Čoveku treba AC na izlazu, ne DC. Link to comment Share on other sites More sharing options...
zek Posted April 29, 2016 Report Share Posted April 29, 2016 Ne bih rekao da mu treba AC već DC napon prema oznakama sa pločice. Samo nisam siguran da mu ne trebaju oba navedena napona, odnosno +32V i +16V - trebalo bi pogledati u Service manual kako je to povezano - da ne izađe neki beli dim. Link to comment Share on other sites More sharing options...
aaa zmaju! Posted April 29, 2016 Report Share Posted April 29, 2016 Ma neee, nije to originalni adapter, nego od nekog hp sa kp, vid`o sam da treba AC nego reko mozda moze trafuljak, brez ispravljaca, iz toga od hp sa kp Link to comment Share on other sites More sharing options...
slavko Posted May 1, 2016 Author Report Share Posted May 1, 2016 ULAZNI NAPON JE 220V..IZLAZNI JE 16V..ALI AC,ZNACI NIJE DC..500mA..ISTI TIP ISPRAVLJACA KORISTI SE I ZA PRO-JECT PHONO BOX MKII. NARUCIO SAM OD TRAFOMATIKA,DA MI NAMOTAJU TRAFO SA ISTIM SPECIFIKACIJAMA,SAMO STO CE BITI MALO JACI,UMESTO 8W,BICE 10W..NADAM SE DA TO STO JE JACI,NECE DA IMATI POSLEDICA PO RAD MOTORA. Link to comment Share on other sites More sharing options...
zek Posted May 1, 2016 Report Share Posted May 1, 2016 Neće, bitno je da nije slabiji (W) i da je odgovarajući napon (V). Napomena: Da li su uračunali i pad napona na izlazu trafoa kada se optereti gramofonom, da ti ne bude manji napon kada priključiš gramofon u odnosu na izlazni napon trafoa bez opterećenja. Link to comment Share on other sites More sharing options...
slavko Posted May 2, 2016 Author Report Share Posted May 2, 2016 E to ne bih znao da kazem,da li su uracunali,pad napona na izlazu,nazvacu ih sutra,jer nisu radili zbog praznika..ovo je fotka motora,sa podacima. Link to comment Share on other sites More sharing options...
slavko Posted May 10, 2016 Author Report Share Posted May 10, 2016 On 1.5.2016. at 1:19, zek said: Neće, bitno je da nije slabiji (W) i da je odgovarajući napon (V). Napomena: Da li su uračunali i pad napona na izlazu trafoa kada se optereti gramofonom, da ti ne bude manji napon kada priključiš gramofon u odnosu na izlazni napon trafoa bez opterećenja. Problem resen,nabavljen trafo,montiran u kuciste i radi savrseno,verujem mnogo bolje od originalnog,koji se fabricki isporucije.. Link to comment Share on other sites More sharing options...
