Filipescu Posted December 7, 2018 Report Share Posted December 7, 2018 Stize sledece nedelje... Quote Link to comment Share on other sites More sharing options...
Delija Posted December 7, 2018 Report Share Posted December 7, 2018 Ocekivao sam da kompletiras Benchmark. Quote Link to comment Share on other sites More sharing options...
Filipescu Posted December 7, 2018 Report Share Posted December 7, 2018 Bio je i on na nišanu, ali prvi izbor mi je bio ps audio direct stream mrežni plejer. To bi bilo end-game rešenje, ali se komad koji sam namerio prodao, pa sam gledao alternativu... DAC 3L HGC neće lik da mi salje iz Holandije, a ovaj komad mi je bio na trećem mestu... Kako sam ga našao na nekoj akciji, bio je no-brainer. U principu tačno ono sto sam tražio. Pravi vrhunski balansirani pre-amp da tera AH-B2, uz to ima sjajan DAC i ako poželim neke bolje sluške, imam i odlično pojačalo za njih... Šta (normalnom) čoveku više treba. Quote Link to comment Share on other sites More sharing options...
anubisgrau Posted December 7, 2018 Report Share Posted December 7, 2018 jel taj benchmark samo DAC ili je kompleksnija sprava Quote Link to comment Share on other sites More sharing options...
Filipescu Posted December 7, 2018 Report Share Posted December 7, 2018 Taj dac 3L hgc im je najbolji model dac-a i ima funkciju preampa. Benchmark snagas koji sam uzeo je prakticno razvijen zbog tog dac-a, tako da je to match made in heaven. Ali, i dalje sam misljenja da koliko god dac bio dobar, dedicated preamp je bolji. Otud i ova kupovina... Jednom ce i taj hgc sigurno uleteti na probu, pa kom obojci, kom opanci... Quote Link to comment Share on other sites More sharing options...
anubisgrau Posted December 8, 2018 Report Share Posted December 8, 2018 koliko je kostao u holandiji? Quote Link to comment Share on other sites More sharing options...
Filipescu Posted December 8, 2018 Report Share Posted December 8, 2018 Polovan je komad u pitanju, star godinu dana i trazi covek 1750. Inace se tu i tamo nalazi za 2000 plus... Quote Link to comment Share on other sites More sharing options...
anubisgrau Posted December 8, 2018 Report Share Posted December 8, 2018 1 sat ranije, Filipescu said: Polovan je komad u pitanju, star godinu dana i trazi covek 1750. Inace se tu i tamo nalazi za 2000 plus... video sam oglas. šteta što je u roterdamu, u ponedeljak idem u hag pa sam ti mogao doneti. mislim rado bi ovo probao, zapravo je ovo sa analognim preampom fini feature ako je DAC strava. sa druge strane poslednja naprava ovog tipa je bio audiolab M-DAC koji mi se iskreno nije naročito dopao iako je bio baziran na sličnom sabre čipu i pratio ga je sličan hype. svejedno voleo bih da probam, uvek imam neizdrž kada se pojave slične sprave. benchmarkov DAC1 mi se nije dopao, forenzika ali hladno. Quote Link to comment Share on other sites More sharing options...
Filipescu Posted December 8, 2018 Report Share Posted December 8, 2018 Hvala na ponudi! Naleteće već neki drugi put, makar na probu... Pa slicno sam cuo i za ovaj 3L, neki kazu da je ostar, ali to nikad ne mogu da procenim ukoliko ne znam šta je ostatak sistema. Poenta je da snagaš ima izvesnu dušu i moguće je da su zato dobar match, a neki treći opet kažu da je tu samo snagaš vrh... Ovaj ps što sam uzeo je baziran isto na tom sabre chipu, stim da ps navodno ima neku specijalnu foru fpga programiranja... Videću još... Quote Link to comment Share on other sites More sharing options...
jager Posted January 17, 2019 Report Share Posted January 17, 2019 Rca rodijum ... Quote Link to comment Share on other sites More sharing options...
Father Posted January 17, 2019 Report Share Posted January 17, 2019 Oppo-u za rođendan. Mala plastična operacija. FURUTECH FI-06 high end grade IEC chassis mount socket Gold or Rhodium plated α (Alpha) Conductors milled from solid Pure Copper • Nylon/fiberglass body • Accommodates wire diameters up to 3.5mm (set-screw) • Dimensions: 50.5 (W) x 23.9mm (D) x 33.5mm (H) ±0.1mm • Rated: 15A/250V Quote Link to comment Share on other sites More sharing options...
miletrosak1959 Posted January 17, 2019 Report Share Posted January 17, 2019 Zastitne kapice za RCA uticnice Quote Link to comment Share on other sites More sharing options...
džonibigud Posted January 17, 2019 Report Share Posted January 17, 2019 Quote Link to comment Share on other sites More sharing options...
laky Posted January 17, 2019 Report Share Posted January 17, 2019 12 minuta ranije, miletrosak1959 said: Zastitne kapice za RCA uticnice korisna stvar gde ste kupili. Quote Link to comment Share on other sites More sharing options...
miletrosak1959 Posted January 17, 2019 Report Share Posted January 17, 2019 19 minuta ranije, laky said: korisna stvar gde ste kupili. N.Sad,preko K.P. Quote Link to comment Share on other sites More sharing options...
Filipescu Posted January 17, 2019 Report Share Posted January 17, 2019 45 minuta ranije, Father said: Oppo-u za rođendan. Mala plastična operacija. FURUTECH FI-06 high end grade IEC chassis mount socket Gold or Rhodium plated α (Alpha) Conductors milled from solid Pure Copper • Nylon/fiberglass body • Accommodates wire diameters up to 3.5mm (set-screw) • Dimensions: 50.5 (W) x 23.9mm (D) x 33.5mm (H) ±0.1mm • Rated: 15A/250V Igraš se? 32 minuta ranije, džonibigud said: Qutest Čestitam! Quote Link to comment Share on other sites More sharing options...
Vlajo Posted January 17, 2019 Report Share Posted January 17, 2019 40 minuta ranije, džonibigud said: Opaaaa Sa srećom kupovina !!! Obavezno neko tvoje mišljenje o dacu, ako može, kad stigneš Quote Link to comment Share on other sites More sharing options...
džonibigud Posted January 17, 2019 Report Share Posted January 17, 2019 Hvala! Quote Link to comment Share on other sites More sharing options...
Father Posted January 17, 2019 Report Share Posted January 17, 2019 28 minuta ranije, Filipescu said: Igraš se? Iznenadio me jedan moj dragi prijatelj. Kaže našao povoljno za 11 dolara pa me se setio i poklonio. I sada mi nema mrdanja mora da se otvara. Quote Link to comment Share on other sites More sharing options...
JTGTS Posted January 17, 2019 Report Share Posted January 17, 2019 http://www.mkabl.rs/detalj?id=384 http://www.mkabl.rs/detalj?id=246 M2 young i palmer https://www.stereophile.com/tubepreamps/769/index.html Moj je SE ali neznam u cemu je razlika. Sve u svemu lepo je krenula 2019 godina ko zna kako ce se zavrsiti vec imam neke ideje Quote Link to comment Share on other sites More sharing options...
ab Posted January 17, 2019 Report Share Posted January 17, 2019 2 sati ranije, Father said: Iznenadio me jedan moj dragi prijatelj. Kaže našao povoljno za 11 dolara pa me se setio i poklonio. I sada mi nema mrdanja mora da se otvara. A gde? Welcome to the club Quote Link to comment Share on other sites More sharing options...
Father Posted January 17, 2019 Report Share Posted January 17, 2019 4 minuta ranije, ab said: A gde? Welcome to the club Pa sa neta, nisam pitao poručio jedan sebi, jedan meni i iznenadio me. Parvi drug za primer. Reče da je bilo u jednom trenutku na opasnom popustu i on kupio. Quote Link to comment Share on other sites More sharing options...
ab Posted January 17, 2019 Report Share Posted January 17, 2019 1 sat ranije, Father said: Pa sa neta, nisam pitao poručio jedan sebi, jedan meni i iznenadio me. Parvi drug za primer. Reče da je bilo u jednom trenutku na opasnom popustu i on kupio. Ne viđa se takav popust tako često - koliko je to 50-60%? Quote Link to comment Share on other sites More sharing options...
Father Posted January 17, 2019 Report Share Posted January 17, 2019 Ja sam video neku cenu oko 30-40 ojra valjda. Quote Link to comment Share on other sites More sharing options...
Father Posted January 17, 2019 Report Share Posted January 17, 2019 Nešto sam pobrkao cene. Evo kod francuza. https://www.audiophonics.fr/en/iec-inlets/furutech-fi-06-g-iec-inlet-gold-plated-pure-copper-p-10256.html Quote Link to comment Share on other sites More sharing options...
